Orin NX 16GB (Seeed reComputer J4012 / J401 carrier) — JetPack 7.2 ISO capsule update fails: "Capsule staged 5 times but version not bumped, aborting
Hardware:
  • Seeed Studio reComputer J4012 (Jetson Orin NX 16GB module, J401 carrier board)
  • Currently on JetPack 5.1.2 (L4T R35.5.0), UEFI/QSPI firmware 35.05.00 — confirmed via nvbootctrl dump-slots-info, both A/B slots report status: normal
Goal: upgrade to JetPack 7.2 via the official Jetson ISO (jetsoninstaller-r39.2.0-2026-06-01-23-53-13-arm64.iso from developer.nvidia.com — checksum-verified after download and again after writing to USB, so the media itself isn’t in question).
Steps taken:
  1. Wrote the verified ISO to a USB 3.0 drive, booted from it. GRUB loaded fine, “Install Jetson ISO r39.2.0” as the default entry.
  2. First attempt: selected “Install on NVMe.” Kernel began booting but logged repeated PCIe controller probe failures before hanging completely (fully unresponsive — Caps Lock didn’t even toggle):
    tegra194-pcie 14160000.pcie: deferred probe timeout, ignoring dependency
    tegra194-pcie 14100000.pcie: iommu configuration for device failed with -ETIMEDOUT
    tegra194-pcie 14100000.pcie: error -ENODATA: failed to get write interconnect
    tegra194-pcie 14160000.pcie: probe of 14160000.pcie failed with error -61
    (repeated across several PCIe controller instances)
  3. Power-cycled and retried. This time caught a firmware-update prompt that must have appeared (and auto-skipped after 30s) on the first attempt:
    *** NVIDIA QSPI Firmware Update Required ***
    New FW version : 39.02.00
    Current version : 35.05.00
    WARNING: Skipping the firmware update may cause the subsequent ISO installation to fail.
  4. Pressed Y to accept. System then looped — “Capsule update prepared, resetting the system in 2 seconds” — repeatedly, version never advancing past 35.05.00. After 5 attempts it self-halted:
    RunPreIsoInstaller: Capsule staged 5 times but version not bumped, aborting to prevent boot loop
    L4TLauncher: Iso boot loop detected, halting
What I think is going on: this matches this thread almost word-for-word (Orin Nano devkit, same “staged 5 times” message) — corrupted A_VER/B_VER partitions on QSPI NOR flash causing UEFI’s FMP library to permanently reject capsules. Found the community VerFix.efi tool (kyberpunk/nvidia-jetson-corrupted-ver-partition-fix on GitHub) built for this, but haven’t run it — wanted to check here before touching firmware partitions with a third-party tool.
Questions:
  1. Is corrupted VER partitions the right diagnosis, or could the PCIe probe failures from the first boot be a separate/contributing issue — possibly related to this being a third-party carrier rather than NVIDIA’s reference devkit?
  2. Is VerFix.efi safe/recommended here, or is there an official repair path?
  3. Confirmed nothing has touched NVMe throughout any of this (checked via nvbootctrl before/after) — is that assumption safe, or could repeated capsule-staging attempts affect anything beyond the QSPI VER partitions?
Happy to provide additional logs if useful.
hello francois.dehaibe ,
ya, it looks duplicate with Topic 379289 and matches the known R39.2.0 installer capsule-update issue.
it’s not recommend modifying the VER partitions with a third-party tool at this stage.
please first update the device firmware to R36.4.4 using the supported JetPack 6.2.1 upgrade path, then retry the JetPack 7.2 installer.
let’s give it a try to upgrade the release version.
if the PCIe probe failures remain after the firmware update, please open a separate topic with the serial logs for details.
