客户自定义板子
orin nx 6.2 ,I225-IT donot work.
orin nx 5.1.1 ,I225-IT do work.
尝试从intel官网上下载驱动编译之后,能正常加载,但是无法工作。
请问一下,是什么原因导致的,谢谢
客户自定义板子
请问一下,是什么原因导致的,谢谢
Based on the provided context, it appears that you are experiencing issues with the Intel I225-IT Ethernet controller on the Jetson Orin NX platform. Specifically, you mentioned that the I225-IT does not work on the Orin NX 62, but it does work on the Orin NX 511.
Unfortunately, the provided context does not offer a clear explanation for this discrepancy. However, I can provide some general information about the Jetson Orin NX platform and the Intel I225-IT Ethernet controller that might be helpful.
The Jetson Orin NX is a series of NVIDIA modules that provide a powerful platform for AI computing and IoT applications. The Orin NX 62 and Orin NX 511 are likely different variants of the Jetson Orin NX module, with different specifications and features.
The Intel I225-IT is a Gigabit Ethernet controller that is commonly used on various platforms, including the Jetson Orin NX. It is possible that the I225-IT is not properly configured or supported on the Orin NX 62, which could explain why it does not work on that particular module.
To troubleshoot this issue, you may want to check the following:
It is also possible that the issue is specific to the Orin NX 62 and not related to the I225-IT itself. In this case, you may want to try using a different Ethernet controller or seeking further assistance from NVIDIA or Intel support.
In comparison, the Orin NX 511 seems to work with the I225-IT, which suggests that the issue might be specific to the Orin NX 62. However, without more information, it is difficult to determine the root cause of the problem.
If you have any further questions or would like to provide more information about your setup and configuration, I would be happy to try and assist you further.
hello 252830387,
please double check you’ve adapt the driver correctly. JP-5 and JP-6 they’re using different kernel version,
you may see-also developer guide, From Rel-35 Kernel 5.10 to Rel-36 Kernel 5.15.
