I recently upgraded the system of the orin nx 8gb module to jetpack6.2. I want to change the i2c clock frequency, but I don’t know how to do it.
Does anybody know how to set this up?
In Jetpack 5.x, I can modify it with the following command. However, in Jetpack 6.2, I cannot modify it using this method.There is no bus_clk_rate file in the jetpack6.2 system
echo 100000 > /sys/class/i2c-adapter/i2c-7/bus_clk_rate
Modify the clock-frequency in device tree to try.
i2c@31e0000 {
iommus = <0x04 0x04>;
#address-cells = <0x01>;
dma-coherent;
clock-names = "div-clk\0parent";
assigned-clocks = <0x03 0x37>;
assigned-clock-parents = <0x03 0x66>;
resets = <0x03 0x23>;
interrupts = <0x00 0x21 0x04>;
clocks = <0x03 0x37 0x03 0x66>;
#size-cells = <0x00>;
clock-frequency = <0x186a0>;
dma-names = "rx\0tx";
compatible = "nvidia,tegra194-i2c";
status = "disabled";
reg = <0x00 0x31e0000 0x00 0x100>;
phandle = <0x227>;
dmas = <0xed 0x1f 0xed 0x1f>;
reset-names = "i2c";
