We short-circuited the RECOVERY to the ground, and can enter the Flash mode when booting.
However, when the RECOVERY has been short connected to the ground, why can it enter the system normally and enter the system desktop?
Not quite sure about the question. When the board is in recovery mode, it is just ready for the board to get flashed. That is what recovery mode is doing.
It won’t boot unless you remove the short circuit.
The reality is that the short circuit is still in place, but the NX core board can still boot normally.
It will boot in the first time after its flash. If you reboot again, then it won’t boot anymore unless you remove the short pins.
I need to confirm this result again
