Hi NV,
we encounter a panic issue,
when device is suspending and kernel log show “DCE RM Suspend rmStatus:0x0”,
trigger interrupt continually, for example: move mouse continually,
system is very easy to panic, hit rate is about 20%,
thanks.
[ 746.502259] Unable to handle kernel NULL pointer dereference at virtual address 0000000000000070
[ 746.502265] Mem abort info:
[ 746.502265] ESR = 0x0000000096000004
[ 746.502267] EC = 0x25: DABT (current EL), IL = 32 bits
[ 746.502269] SET = 0, FnV = 0
[ 746.502269] EA = 0, S1PTW = 0
[ 746.502270] FSC = 0x04: level 0 translation fault
[ 746.502271] Data abort info:
[ 746.502272] ISV = 0, ISS = 0x00000004
[ 746.502273] CM = 0, WnR = 0
[ 746.502274] user pgtable: 4k pages, 48-bit VAs, pgdp=000000012a253000
[ 746.502276] [0000000000000070] pgd=0000000000000000, p4d=0000000000000000
[ 746.502281] Internal error: Oops: 0000000096000004 [#1] PREEMPT SMP
[ 746.502284] Modules linked in: nvidia_drm(OE) nvidia_modeset(OE) lzo_rle lzo_compress zram zsmalloc nvme_fabrics ramoops reed_solomon bridge stp llc usb_f_ncm usb_f_mass_storage usb_f_acm u_serial usb_f_rndis u_ether libcomposite snd_soc_tegra210_admaif(O) snd_soc_tegra_utils(O) snd_soc_tegra_pcm snd_soc_tegra186_asrc(O) snd_soc_tegra210_mixer(O) snd_soc_simple_card_utils snd_soc_tegra186_arad(O) snd_soc_tegra210_afc(O) snd_soc_tegra210_dmic(O) snd_soc_tegra210_i2s(O) snd_soc_tegra210_ope(O) snd_soc_tegra210_mvc(O) snd_soc_tegra186_dspk(O) snd_soc_tegra210_sfc(O) snd_soc_tegra210_amx(O) snd_soc_tegra210_adx(O) r8153_ecm cdc_ether usbnet tegra210_adma spidev snd_soc_tegra210_ahub(O) nvvrs_pseq_rtc(O) crct10dif_ce r8152 tegra234_oc_event(O) mttcan(O) nvpps(O) nvpmodel_clk_cap(O) can_dev thermal_trip_event(O) tegra_cactmon_mc_all(O) joydev snd_hda_codec_hdmi tegra234_aon(O) tegra_aconnect at24 snd_hda_tegra snd_hda_codec pwm_tegra_tachometer(O) r8168(O) snd_hda_core mc_hwpm(O) nvidia(OE)
[ 746.502347] spi_tegra114 nv_imx219(O) tegra_pcie_dma_test(O) tegra_pcie_edma(O) nvidia_vrs_pseq(O) tegra_dce(O) host1x_fence(O) tsecriscv(O) nvhost_vi5(O) nvhost_isp5(O) nvhost_nvcsi_t194(O) tegra_camera(O) v4l2_dv_timings nvhost_nvcsi(O) tegra_camera_platform(O) capture_ivc(O) tegra_camera_rtcpu(O) ivc_bus(O) hsp_mailbox_client(O) ivc_ext(O) v4l2_fwnode v4l2_async governor_userspace videobuf2_dma_contig videobuf2_memops tegra_drm(O) videobuf2_v4l2 videobuf2_common nvhost_pva(O) nvhost_nvdla(O) tegra_wmark(O) nvhost_capture(O) videodev cec mc drm_kms_helper nvhwpm(O) host1x_nvhost(O) nvidia_p2p(O) ina3221 nvgpu(O) governor_pod_scaling(O) host1x(O) mc_utils(O) nvmap(O) nvsciipc(O) rtk_btusb(O) fuse drm ip_tables x_tables ipv6 pwm_fan(E) pwm_tegra(E) tegra_bpmp_thermal(E) tegra_xudc(E) ucsi_ccg(E) typec_ucsi(E) typec(E) nvme(E) nvme_core(E)
[ 746.502407] CPU: 2 PID: 1499 Comm: Xorg Tainted: G OE 5.15.148-tegra #1
[ 746.502410] Hardware name: NVIDIA ASUS PE1100N/ORIN NX 8G/JONXS-IM-A 8G/Jetson, BIOS 36.4.0-gcid-37537400 09/13/2024
[ 746.502412] pstate: 60400009 (nZCv daif +PAN -UAO -TCO -DIT -SSBS BTYPE=–)
[ 746.502415] pc : nvCtxDmaBind+0x1c/0x230 [nvidia_modeset]
[ 746.502493] lr : nvRmAllocAndBindSurfaceDescriptor+0x70/0x130 [nvidia_modeset]
[ 746.502548] sp : ffff80000bdabb00
[ 746.502549] x29: ffff80000bdabd30 x28: ffff0000b8f25f08 x27: 0000000000000008
[ 746.502552] x26: ffff0000b8f25008 x25: ffff000097365028 x24: ffff000097365008
[ 746.502555] x23: ffff0000b8f25014 x22: ffff0000a7ada008 x21: ffff0000a7ada008
[ 746.502557] x20: 0000000000000000 x19: ffff0000a7ada008 x18: ffffceceb4a8ce20
[ 746.502559] x17: ffffceceb4a8ce30 x16: ffffcecef6151d80 x15: ffff00008b8ebb68
[ 746.502561] x14: 0000000000000068 x13: 00000000000000c0 x12: 0000000000000068
[ 746.502563] x11: ffff0001f12ef8b8 x10: ffff80000bdab840 x9 : 00000000ffffffe8
[ 746.502565] x8 : ffff80000bdab820 x7 : 0000000000000000 x6 : ffffceceb4b8d000
[ 746.502567] x5 : 0000000000000001 x4 : 0000000000000004 x3 : 0000000000000009
[ 746.502570] x2 : 0000000000000009 x1 : 0000000000000000 x0 : 00000000c1d00000
[ 746.502572] Call trace:
[ 746.502574] nvCtxDmaBind+0x1c/0x230 [nvidia_modeset]
[ 746.502628] nvidia_frontend_unlocked_ioctl+0x60/0x80 [nvidia]
[ 746.502726] __arm64_sys_ioctl+0xb4/0x100
[ 746.502733] invoke_syscall+0x5c/0x130
[ 746.502740] el0_svc_common.constprop.0+0x64/0x110
[ 746.502743] do_el0_svc+0x74/0xa0
[ 746.502745] el0_svc+0x28/0x80
[ 746.502752] el0t_64_sync_handler+0xa4/0x130
[ 746.502754] el0t_64_sync+0x1a4/0x1a8
[ 746.502758] Code: f9002bfe 2a0203e3 b9490000 52800084 (b9407025)
[ 746.502763] —[ end trace 2162662de7169525 ]—
[ 746.508088] PM: suspend exit
nv_modeset_panic_20241120.log (33.1 KB)
