Orin nx 8GB的无法烧录镜像,基于Jetson Linux 35.3.1
Currently, several attempts to burn orin nx 8GB based on version 35.3.1 have failed. Based on version 35.2.1, the orin nx 16GB module can be burned and used normally on the same backplane.
According to the guidance files and other topics, it is not possible to burn them properly. Is there any configuration error now
Burning instructions:sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1
-c tools/kernel_flash/flash_l4t_external.xml -p “-c bootloader/t186ref/cfg/flash_t234_qspi.xml”
–showlogs --network usb0 jetson-orin-nano-devkit internal
or Reference others to modify dtb pointing files in p3509-a02+p3767-0000
:sudo ADDITIONAL_DTB_OVERLAY_OPT=“BootOrderNvme.dtbo” ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1
–showlogs --network usb0 p3509-a02+p3767-0000 internal
Neither command is possible, what is the problem?
Are you using Orin Nano devkit carrier board or with your custom carrier board?
You could try to dump some logs first…
Otherwise I cannot tell what problem you have here. For example, forget to plug a power cable or usb cable also leads to flash failure. Who knows.
jetson-orin-nano-devkit.txt (262.7 KB)
p3509-a02-p3767-0000.txt (253.9 KB)
These are two types of conf configurations for burning error process logs
We used a custom backplane and have previously used 16GB orin nx for normal burning on the same backplane.
Do you need to change the configuration of the backplane?
Do I need to change the relevant configuration of the backplane, such as DTS? But orin nx 16GB can be used normally on it
please dump the device side log too.
burnfail.txt (260.6 KB)
log.txt (89.9 KB)
This is a complete burning process log and serial port log
Jetson cannot launch nfs with your host machine.
Do you have other host machine to test?
Also, is it a custom carrier board of orin nano devkit?
I only have one Orin nx module with 8GB,This motherboard is customized and can be used normally on the same motherboard with 16GB. Can there be any modification methods for troubleshooting?
So your host can work fine with Orin NX 16GB module + same carrier board?
Yes. I used the motherboard that was previously compatible with Jetson Nano, but now I can get up. There may be some issues with the motherboard being compatible with 8GB.
Please try to get a orin nano devkit to test… we don’t guarantee jetson nano board with Orin.
Okay, I’ll ask the hardware department. Thank you for your support
