Orin NX 8Gb update QSPI error
Hi
i trying to update my OrinNX to 7.2.1 from 6.2.1, but it is unable to update via SDKManager (giver error on “waiting on boot-up”)
i tried to make external nvme with 7.2.1 , but it boots without GPU and has many errors in dmesg log
i created a usb flash with 7.,2.1 installer, on boot it tries to update capsule but gets a boot loop (not updating and boots up again to capsule update attempt.)
it has capsule 36.4.3, and i unable to update it even when updating system from 6.2.1 to 6.2.3 (qspi v36.5.2)
The following NEW packages will be installed:
nvidia-l4t-jetson-orin-nano-qspi-updater
0 upgraded, 1 newly installed, 0 to remove and 10 not upgraded.
Need to get 0 B/8 933 kB of archives.
After this operation, 11,0 MB of additional disk space will be used.
debconf: delaying package configuration, since apt-utils is not installed
(Reading database … 206929 files and directories currently installed.)
Preparing to unpack …/nvidia-l4t-jetson-orin-nano-qspi-updater_36.5.2-20260716114719_arm64.deb …
3767–0001–1–jetson-orin-nano-devkit-super-
TNSPEC 3767-303-0001-F.1-1-0-jetson-orin-nano-devkit-super-
COMPATIBLE_SPEC 3767–0001–1–jetson-orin-nano-devkit-super-
TEGRA_BOOT_STORAGE nvme0n1
TEGRA_CHIPID 0x23
TEGRA_OTA_BOOT_DEVICE /dev/mtdblock0
TEGRA_OTA_GPT_DEVICE /dev/mtdblock0
Info: Write TegraPlatformCompatSpec with 3767–0001–1–jetson-orin-nano-devkit-super-.
Info: The esp is already mounted to /boot/efi.
ERROR. Board 3767–0001–1–jetson-orin-nano-devkit-super- is not supported. Only Orin Nano devkit is supported.
dpkg: error processing archive /var/cache/apt/archives/nvidia-l4t-jetson-orin-nano-qspi-updater_36.5.2-20260716114719_arm64.deb (–unpack):
new nvidia-l4t-jetson-orin-nano-qspi-updater package pre-installation script subprocess returned error exit status 1
Errors were encountered while processing:
sudo nvbootctrl dump-slots-info
Current version: 36.4.3
Capsule update status: 3
Current bootloader slot: A
Active bootloader slot: A
num_slots: 2
slot: 0, status: normal
slot: 1, status: normal
How to solve that ?
I have Waveshare T801 DevBoard
thnx in advance
Vlad, Kyiv, Ukraine
  1. Are you using NV devkit or custom board? or you don’t know what I mean here?
  2. Is this your first time using this host +sdkmaanger to flash your board?
Thnks.
  1. use waveshare/twowin devkit board. i understand what it mean
  2. 1st time using orinNX, but not 1st and not 2nd using jetsons.
solved. got vendor bsp and updated qspi to 39.2.0
but freshly installed 7.2.1 to standalone nvme boot and run w/o vendor bsp,
Seems vendor bsp was need to just update qspi/capsule to 39.2.x
but anyway SDKmanager or scripts is unable to update system/jetpack on board without vendor bsp and additions - stuck on well known “waiting to boot-up” error.
Your board is not a NV devkit. Sdkmanager failure on it is expected.
