Orin nx auto reboot servral times
When we use our custom board using orin nx module, it will reboot auto matically servral times in three days.
when this firstly come out, we find the kern log but there is no err but only temp alert like this and reboot
[2026-08-09 21:02:57]  [115756.061112] thermal cooling_device11: hot-surface-alert cooling state: 1 -> 0
[2026-08-09 21:02:58]  [115756.065342] thermal cooling_device11: hot-surface-alert cooling state: 0 -> 1
[2026-08-09 21:02:58]  [115757.089112] thermal cooling_device11: hot-surface-alert cooling state: 1 -> 0
[2026-08-09 21:02:59]  [115757.403499] thermal cooling_device11: hot-surface-alert cooling state: 0 -> 1
[2026-08-09 21:02:59]  [115758.429162] thermal cooling_device11: hot-surface-alert cooling state: 1 -> 0
[2026-08-09 21:42:38]
[2026-08-09 21:44:05]  [0000.064] I> MB1 (version: 1.4.0.4-t234-54845784-e89ea9bc)
[2026-08-09 21:44:05]  [0000.070] I> t234-A01-1-Silicon (0x12347) Prod
[2026-08-09 21:44:05]  [0000.074] I> Boot-mode : Coldboot
[2026-08-09 21:44:05]  [0000.077] I> Entry timestamp: 0x00000000
[2026-08-09 21:44:05]  [0000.081] I> last_boot_error: 0x0
To find out if the hardware power issues, we test it in a weekend running our program. And it auto matically reboot
here is the full log from uart
com COM4 (2026-08-07_151148) COM4 (Prolific PL2303GT USB Serial COM Port (COM4)).log (641.4 KB)
In this test, its first reboot with a kernel panic
[2026-08-08 02:25:25]  [47408.650978] Unable to handle kernel paging request at virtual address 006ec8ffaa968fa1
[2026-08-08 04:22:19]  [47408.650990] Mem abort info:
[2026-08-08 04:22:19]  [47408.650991]   ESR = 0x0000000096000004
[2026-08-08 04:22:19]  [47408.650993]   EC = 0x25: DABT (current EL), IL = 32 bits
[2026-08-08 04:22:19]  [47408.650995]   SET = 0, FnV = 0
[2026-08-08 04:22:19]  [47408.650997]   EA = 0, S1PTW = 0
[2026-08-08 04:22:19]  [47408.650998]   FSC = 0x04: level 0 translation fault
[2026-08-08 04:22:19]  [47408.650999] Data abort info:
[2026-08-08 04:22:19]  [47408.651000]   ISV = 0, ISS = 0x00000004
[2026-08-08 04:22:19]  [47408.651001]   CM = 0, WnR = 0
[2026-08-08 04:22:19]  [47408.651002] [006ec8ffaa968fa1] address between user and kernel address ranges
[2026-08-08 04:22:19]  [47408.651005] Internal error: Oops: 0000000096000004 [#1] PREEMPT SMP
[2026-08-08 04:22:19]  [47408.651008] Modules linked in: nvidia_drm(O) nvidia_modeset(O) lzo_rle lzo_compress zram zsmalloc nvme_fabrics ramoops reed_solomon bridge stp llc usb_f_ncm usb_f_mass_storage algif_hash algif_skcipher usb_f_acm u_serial af_alg bnep usb_f_rndis u_ether libcomposite snd_soc_tegra210_admaif(O) snd_soc_tegra186_asrc(O) snd_soc_tegra_pcm snd_soc_tegra210_ope(O) snd_soc_tegra186_arad(O) snd_soc_tegra210_adx(O) snd_soc_tegra210_dmic(O) snd_soc_tegra210_afc(O) snd_soc_tegra210_mixer(O) snd_soc_tegra210_sfc(O) snd_soc_tegra210_amx(O) snd_soc_tegra210_mvc(O) snd_soc_tegra186_dspk(O) snd_soc_tegra210_i2s(O) snd_soc_tegra210_ahub(O) tegra210_adma nvvrs_pseq_rtc(O) rtk_btusb(O) btusb btrtl ftdi_sio btintel usbserial btbcm snd_soc_tegra_machine_driver(O) snd_soc_tegra_utils(O) crct10dif_ce snd_soc_simple_card_utils tegra234_oc_event(O) nvpmodel_clk_cap(O) tegra_cactmon_mc_all(O) thermal_trip_event(O) rtl8822ce(O) fusb301(O) lt6911uxe(O) mttcan(O) nvpps(O) tegra234_aon(O) can_dev tegra_aconnect
[2026-08-08 04:22:19]  [47408.651067]  cfg80211 pwm_tegra_tachometer(O) r8168(O) tegra_pcie_dma_test(O) snd_hda_codec_hdmi tegra_pcie_edma(O) snd_hda_tegra snd_hda_codec nvidia(O) snd_hda_core spi_tegra114 mc_hwpm(O) host1x_fence(O) nvidia_vrs_pseq(O) nvhost_isp5(O) tegra_dce(O) nvhost_vi5(O) nvhost_nvcsi_t194(O) tsecriscv(O) pwm_bl tegra_camera(O) v4l2_dv_timings nvhost_nvcsi(O) tegra_camera_platform(O) capture_ivc(O) tegra_camera_rtcpu(O) governor_userspace ivc_bus(O) hsp_mailbox_client(O) ivc_ext(O) v4l2_fwnode v4l2_async tegra_drm(O) videobuf2_dma_contig nvhost_pva(O) nvhost_nvdla(O) tegra_wmark(O) videobuf2_memops videobuf2_v4l2 nvhwpm(O) videobuf2_common videodev cec nvhost_capture(O) drm_kms_helper host1x_nvhost(O) mc tpm_ftpm_tee nvidia_p2p(O) ina3221 nvgpu(O) governor_pod_scaling(O) host1x(O) mc_utils(O) nvmap(O) nvsciipc(O) drm fuse ip_tables x_tables ipv6 pwm_fan pwm_tegra tegra_bpmp_thermal tegra_xudc ucsi_ccg typec_ucsi typec nvme nvme_core phy_tegra194_p2u pcie_tegra194
[2026-08-08 04:22:19]  [47408.651137] CPU: 0 PID: 0 Comm: swapper/0 Tainted: G           O      5.15.148-tegra #1
[2026-08-08 04:22:19]  [47408.651140] Hardware name: NVIDIA NVIDIA Jetson Orin NX Engineering Reference Developer Kit Super/Jetson, BIOS 36.4.4-gcid-41062509 06/16/2025
[2026-08-08 04:22:19]  [47408.651142] pstate: 004000c9 (nzcv daIF +PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[2026-08-08 04:22:19]  [47408.651145] pc : percpu_ref_get_many+0xa4/0xd0
[2026-08-08 04:22:19]  [47408.651154] lr : percpu_ref_get_many+0x9c/0xd0
[2026-08-08 04:22:19]  [47408.651156] sp : ffff800008003c80
[2026-08-08 04:22:19]  [47408.651157] x29: ffff800008003c80 x28: ffff0003f020d4f8 x27: ffff0000820001e7
[2026-08-08 04:22:19]  [47408.651159] x26: ffff00008001a400 x25: fffffc0000000000 x24: 0001000000000000
[2026-08-08 04:22:19]  [47408.651161] x23: ffff00008288d600 x22: 0000000000000000 x21: ffff0000820001e7
[2026-08-08 04:22:19]  [47408.651163] x20: b46ec8ffaa968fa1 x19: 0000000000000001 x18: 0000000000000000
[2026-08-08 04:22:19]  [47408.651165] x17: ffff569a5b7df000 x16: ffff800008000000 x15: 0000ffff7fae0d18
[2026-08-08 04:22:19]  [47408.651167] x14: 0000000100b3b48a x13: 00000000005d513d x12: ffffa96995036000
[2026-08-08 04:22:19]  [47408.651169] x11: ffffa9699545c000 x10: 00000c5dae3d18ce x9 : 0000000000000000
[2026-08-08 04:22:19]  [47408.651171] x8 : ffff00026ab28228 x7 : 0000000000000000 x6 : ffff569a5b7df000
[2026-08-08 04:22:19]  [47408.651173] x5 : 0000000000000108 x4 : ffff000083270000 x3 : ffffa96994a1b008
[2026-08-08 04:22:19]  [47408.651175] x2 : ffffa96992bd1db8 x1 : ffffa96995042ec0 x0 : 0000000000000001
[2026-08-08 04:22:19]  [47408.651177] Call trace:
[2026-08-08 04:22:19]  [47408.651179]  percpu_ref_get_many+0xa4/0xd0
[2026-08-08 04:22:19]  [47408.651181]  refill_obj_stock+0x70/0x190
[2026-08-08 04:22:19]  [47408.651183]  obj_cgroup_uncharge+0x34/0x50
[2026-08-08 04:22:19]  [47408.651186]  memcg_slab_free_hook+0x94/0x160
[2026-08-08 04:22:19]  [47408.651188]  kmem_cache_free+0x25c/0x310
[2026-08-08 04:22:19]  [47408.651190]  radix_tree_node_rcu_free+0x48/0x60
[2026-08-08 04:22:19]  [47408.651196]  rcu_core+0x294/0x970
[2026-08-08 04:22:19]  [47408.651199]  rcu_core_si+0x1c/0x30
[2026-08-08 04:22:19]  [47408.651201]  __do_softirq+0x130/0x3b0
[2026-08-08 04:22:19]  [47408.651203]  irq_exit+0xc8/0xf0
[2026-08-08 04:22:19]  [47408.651207]  handle_domain_irq+0x78/0xb0
[2026-08-08 04:22:19]  [47408.651209]  gic_handle_irq+0x68/0x150
[2026-08-08 04:22:19]  [47408.651213]  call_on_irq_stack+0x20/0x50
[2026-08-08 04:22:19]  [47408.651216]  do_interrupt_handler+0x70/0x80
[2026-08-08 04:22:19]  [47408.651218]  el1_interrupt+0x30/0x80
[2026-08-08 04:22:19]  [47408.651223]  el1h_64_irq_handler+0x18/0x30
[2026-08-08 04:22:19]  [47408.651225]  el1h_64_irq+0x7c/0x80
[2026-08-08 04:22:19]  [47408.651227]  cpuidle_enter_state+0xbc/0x3f0
[2026-08-08 04:22:19]  [47408.651230]  cpuidle_enter+0x44/0x60
[2026-08-08 04:22:19]  [47408.651232]  do_idle+0x220/0x2b0
[2026-08-08 04:22:19]  [47408.651235]  cpu_startup_entry+0x34/0x70
[2026-08-08 04:22:19]  [47408.651237]  rest_init+0xf0/0x100
[2026-08-08 04:22:19]  [47408.651240]  arch_call_rest_init+0x1c/0x28
[2026-08-08 04:22:19]  [47408.651243]  start_kernel+0x6d0/0x710
[2026-08-08 04:22:19]  [47408.651245]  __primary_switched+0xbc/0xc4
[2026-08-08 04:22:19]  [47408.651250] Code: f9400694 97fff2ca 72001c1f 54000060 (f833029f)
[2026-08-08 04:22:19]  [47408.651255] ---[ end trace f4e1ed88ad077c3b ]---
[2026-08-08 04:22:19]  [47409.660229] Kernel panic - not syncing:
[2026-08-08 04:22:19]  [47409.660231] Oops: Fatal exception in interrupt
[2026-08-08 04:22:19]  [47409.870901] tegra-hda 3510000.hda: azx_get_response timeout, switching to polling mode: last cmd=0x004f0900
[2026-08-08 04:24:03]  [0000.063] I> MB1 (version: 1.4.0.4-t234-54845784-e89ea9bc)
[2026-08-08 04:24:03]  [0000.069] I> t234-A01-1-Silicon (0x12347) Prod
[2026-08-08 04:24:03]  [0000.073] I> Boot-mode : Coldboot
[2026-08-08 04:24:03]  [0000.076] I> Entry timestamp: 0x00000000
[2026-08-08 04:24:03]  [0000.080] I> last_boot_error: 0x0
[2026-08-08 04:24:03]  [0000.083] I> BR-BCT: preprod_dev_sign: 0
[2026-08-08 04:24:03]  [0000.087] I> rst_source: 0x2, rst_level: 0x1
But the next two reboot, only gets temp alert like before and reboot
[2026-08-08 11:11:18]  [24534.081843] thermal cooling_device11: hot-surface-alert cooling state: 1 -> 0
[2026-08-08 11:13:18]  [24534.096312] thermal cooling_device11: hot-surface-alert cooling state: 0 -> 1
[2026-08-08 11:13:18]  [24556.605847] thermal cooling_device11: hot-surface-alert cooling state: 1 -> 0
[2026-08-08 11:13:40]  [24556.608750] thermal cooling_device11: hot-surface-alert cooling state: 0 -> 1
[2026-08-08 11:13:40]  [24715.325853] thermal cooling_device11: hot-surface-alert cooling state: 1 -> 0
[2026-08-08 11:16:19]  [24715.326800] thermal cooling_device11: hot-surface-alert cooling state: 0 -> 1
[2026-08-08 11:16:19]  [26100.797871] thermal cooling_device11: hot-surface-alert cooling state: 1 -> 0
[2026-08-08 11:39:25]  [26100.799373] thermal cooling_device11: hot-surface-alert cooling state: 0 -> 1
[2026-08-08 11:39:25]  [28582.973849] thermal cooling_device11: hot-surface-alert cooling state: 1 -> 0
[2026-08-08 12:20:47]  [28582.979860] thermal cooling_device11: hot-surface-alert cooling state: 0 -> 1
[2026-08-08 12:20:47]  WARNING @ [platform/drivers/mailbox/ivc_link_provider/mail_imo.c]: mail imo TX timeout
[2026-08-08 12:52:19]  failed to send thermal trip message to cpu!
[2026-08-08 12:52:19]  WARNING @ [platform/drivers/mailbox/ivc_link_provider/mail_imo.c]: mail imo TX timeout
[2026-08-08 12:52:36]  failed to send thermal trip message to cpu!
[2026-08-08 12:52:36]  WARNING @ [platform/drivers/mailbox/ivc_link_provider/mail_imo.c]: mail imo TX timeout
[2026-08-08 12:53:11]  failed to send thermal trip message to cpu!
[2026-08-08 12:53:18]  [0000.062] I> MB1 (version: 1.4.0.4-t234-54845784-e89ea9bc)
[2026-08-08 12:53:18]  [0000.068] I> t234-A01-1-Silicon (0x12347) Prod
[2026-08-08 12:53:18]  [0000.072] I> Boot-mode : Coldboot
[2026-08-08 12:53:18]  [0000.075] I> Entry timestamp: 0x00000000
[2026-08-08 12:53:18]  [0000.079] I> last_boot_error: 0x0
[2026-08-08 12:53:18]  [0000.082] I> BR-BCT: preprod_dev_sign: 0
[2026-08-08 12:53:18]  [0000.086] I> rst_source: 0x2, rst_level: 0x1
[2026-08-08 12:53:18]  [0000.090] I> Task: SE error check
[2026-08-08 12:53:18]  [0000.093] I> Task: Bootchain select WAR set
[2026-08-08 12:53:18]  [0000.097] I> Task: Enable SLCG
[2026-08-08 12:53:18]  [0000.100] I> Task: CRC check
[2026-08-08 12:53:18]  [0000.103] I> Task: Initialize MB2 params
What causes the panic and why it will auto reboot even there is no panic?
Thanks !
What kind of program are running?
This looks most like kernel memory corruption / use-after-free, surfacing in the memcg slab-free path — not a primary fault inside percpu_ref_get_many() itself.
Your trace dies in:
percpu_ref_get_many -> refill_obj_stock -> obj_cgroup_uncharge -> memcg_slab_free_hook -> kmem_cache_free -> radix_tree_node_rcu_free -> rcu_core
That exact signature has shown up in recent internal Tegra cases, including a JetPack 6.2 / 5.15.148-tegra Orin crash, where internal analysis concluded the invalid pointer strongly suggested corruption of the obj_cgroup / percpu_ref pointer rather than a bug in percpu_ref_get_many() itself.
BTW, could you have fan to avoid the thermal alert to clarify the root cause.
Hiy, shane
program contains voice and video recognition, it will use a lot memory.
I’ll try to avoid thermal alert
And this means through the uart debug message we can not get the root cause, right?
I notice there are thermal warning in the log.
Could you add extra fan to make the board into lower temperature and see if it makes the issue not happened?
Hi, wayne
I’ll try to test
Hi @ 854053437,
In addition to the cooling test suggested earlier, could you please collect some additional information while reproducing the issue?
  1. Please run tegrastats while the voice/video recognition application is running and attach the output leading up to the reboot. This will help us monitor the system status before the reboot.
  2. Does the reboot still occur when the voice/video recognition application is not running?
  3. If possible, could you test the workloads separately and let us know whether the issue can be reproduced in each of the following cases?
    • Voice recognition only
    • Video recognition only
    • Voice and video recognition together
Please also keep the UART log running together with tegrastats during the test so that we can correlate the system status with the logs immediately before the reboot.
Regards,
Oscar Mendez
Embedded SW Engineer at RidgeRun
Contact us: support@ridgerun.com
Developers wiki: https://developer.ridgerun.com/
Website: www.ridgerun.com
Hi,Wayne
We add extra fan to keep the temperature low, and there is no thermal alert. But after a night running, system still auto reboot, here is the debug log
COM_20260817190700.log (212.6 KB)
[40108.149514] ACK 04 d4
[40108.151201] ACK 04 d4
[40432.430853] ACK 04 d4
[40432.432445] ACK 04 d4
[40635.997685] ACK 04 d4
[40635.997870] ACK 04 d4
[40635.999580] ACK 04 d4
[0000.067] I> MB1 (version: 1.4.0.4-t234-54845784-e89ea9bc)
[0000.072] I> t234-A01-1-Silicon (0x12347) Prod
[0000.076] I> Boot-mode : Coldboot
[0000.079] I> Entry timestamp: 0x00000000
[0000.083] I> last_boot_error: 0x0
[0000.086] I> BR-BCT: preprod_dev_sign: 0
[0000.090] I> rst_source: 0x2, rst_level: 0x1
[0000.094] I> Task: SE error check
[0000.097] I> Task: Bootchain select WAR set
[0000.101] I> Task: Enable SLCG
[0000.104] I> Task: CRC check
[0000.107] I> Task: Initialize MB2 params
[0000.111] I> MB2-params @ 0x40060000
[0000.115] I> Task: Crypto init
[0000.118] I> Task: Perform MB1 KAT tests
our app is running and it auto reboot
I find that before reboot, the ACK print is from
nvidia-oot\drivers\net\wireless\realtek\rtl8822ce\core\rtw_recv.c
	switch (type) {
	case WIFI_MGT_TYPE: /* mgnt */
		DBG_COUNTER(adapter->rx_logs.core_rx_pre_mgmt);
		retval = validate_recv_mgnt_frame(adapter, precv_frame);
		if (retval == _FAIL) {
			DBG_COUNTER(adapter->rx_logs.core_rx_pre_mgmt_err);
		retval = _FAIL; /* only data frame return _SUCCESS */
		break;
	case WIFI_CTRL_TYPE: /* ctrl */
		if (subtype == 0xd4)
			printk("ACK %02x %02x\n",type, subtype);
And here is other one get the reboot issuse
They disabled the wifi and get board stable, so is this wifi issuse?
You could try but as there is no obvious crash log from it, it is not possible to confirm if it is really related to wifi.
I‘ve disabled wifi and continue our test
Hi, Wayne
after we disabled wifi, the system do not get auto-reboot after two days running with our app.
So, if this is wifi caused issuse, I wonder is there any bug in this wifi driver in our Jetpack(6.1.2 r3644)?
Which wifi card is in use here?
our custom board is using RTL8822, same as devkit board.
Is there any method to easily trigger this issue?
From our test, we dont know how to trigger this issue, and our app does not use wifi function yet.
Is wifi ever connected to AP during the test?
That need to check with our app developer and I dont know the whole realization. All I know is before auto reboot there is alot ACK 04 d4 message from the wifi driver.
This does not have anything to do with reboot crash.
Hi, Wayne
We found that without disable wifi, when system auto reboot, the wifi is connected to AP. And in our other board wifi is not connected to anything.
You may need to reproduce your issue on NV devkit. Those symptoms are not enough to debug an issue.
