My system is jetpack5.1.5. After I shut down all X servers, I want to use the following command to operate the screen.
sudo dd if=/dev/urandom of=/dev/fb0 bs=480 count=800
But it didn’t work. The screen didn’t respond. If I do the same operation in jetpack6.1, the screen will respond. Does jp5.1.5 not support framebuffer operation?
Because we will not use jetpack6.1 at present, I want to know whether the current system can operate fb0?
