Orin NX Custom Pinmux Fails To Flash
I am trying to create a massflash blob for a new pinmux I created. I used v1.01 of the orin nx / orin nano series document to generate these files on the A03 page.
I have made the following changes to the pinmux in the files I use to flash Orin NX modules:
  • GPIO #3, Set req initial state to drive 1
  • GPIO #6, Set Pin Direction to Input, req initial state to N/A
  • GPIO #12 Set Pin Direction to Output, Req initial state to Drive 1
  • CAM1_PWDN Change Req initial state to Z
  • GPIO #9 Change Pin Direction to bidirectional
I generate the following files with the excel sheet after making the above changes:
  1. pinmux.dtsi
  2. gpio.dtsi
  3. padvoltage.dtsi
I then copy the padvoltage.dtsi and pinmux.dtsi files to the <l4t_top>/bootloader/t186ref/BCT/ directory and copy the gpio.dtsi file to the <l4t_top>/bootloader/ directory.
I changed the board.conf PINMUX_CONFIG and PMC_CONFIG to point to the pinmux and padvoltage files that were generate.
I use this command to generate massflash blob: sudo ./tools/kernel_flash/l4t_initrd_flash.sh --no-flash --massflash 6 -p "-c bootloader/t186ref/cfg/flash_t234_qspi.xml --no-systemimg" --network usb0 board_conf_name nvme0n1p1
I get the following error on my host PC:
[   3.2957 ] Pre-processing config: new_pinmux.dtsi
Error: Return value 1
Command cpp -nostdinc -x assembler-with-cpp -D IN_DTS_CONTEXT new_pinmux.dtsi new_pinmux_cpp.dts
Error: /home/labdesk/Desktop/Linux_for_Tegra/bootloader/signed/flash.idx is not found
Error: failed to relocate images to /home/labdesk/Desktop/Linux_for_Tegra/tools/kernel_flash/images
Cleaning up...
I tried manually running the cpp command in the <l4t_top>/bootloader/t186ref/BCT/ directory and I get the following error:
labdesk@labdesk01:~/Desktop/Linux_for_Tegra/bootloader/t186ref/BCT $ cpp -nostdinc -x assembler-with-cpp -D IN_DTS_CONTEXT new_pinmux.dtsi new_pinmux_cpp.dts
Orin-monarch_e5000-pinmux_June_6.dtsi:33:10: fatal error: pinctrl-tegra.h: No such file or directory
   33 | #include "pinctrl-tegra.h"
How can I resolve this error?
Ah I figured it out, I had renamed the gpio.dtsi file to a different name than what was used in the excel document, I had to change that name back to the original name that the excel document assigned to the file and now I am able to generate my massflash blob.
Glad to know issue resolved, thanks for your update.
