Hello, NVIDIA Team,
For my purpose I’m trying to flash the SSD with encryption.
Here are the steps I’m following:
- Generate images for QSPI:
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --showlogs -p \ "-c bootloader/t186ref/cfg/flash_t234_qspi.xml" \ --no-flash --network usb0 jetson-orin-nano-devkit internal
- Generate the key:
echo "f0e0d0c0b0a001020304050607080900" > ekb.key
- Generate images for external storage device:
sudo ROOTFS_ENC=1 ./tools/kernel_flash/l4t_initrd_flash.sh \ --showlogs --no-flash --external-device nvme0n1p1 -i ./ekb.key \ -c ./tools/kernel_flash/flash_l4t_t234_nvme_rootfs_enc.xml \ --external-only --append --network usb0 \ jetson-orin-nano-devkit external
- Flash images into the both storage devices:
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --showlogs \ --network usb0 --flash-only
This process works well.
As a result, I have the following:
My SSD is 256 GiB, and I would like to utilize its full capacity.
I tried running the command with the -S 128GiB
flag, but it had no effect on the result:
--external-only --append --network usb0 -S 128GiB\
I also attempted modifying the layout file by replacing APP_ENC_SIZE
with a specific byte size, but encountered a block number error. A similar error occurred when I changed ROOTFSSIZE
in Linux_for_Tegra/p3767.conf.common
Any suggestions or guidance on adjusting the default disk size would be greatly appreciated!
