Orin NX DRM HDR output failed when using the 08_video_dec_drm sample
I’m testing HDR output on the Orin NX DRM. I searched other posts that said the Orin NX’s HDR output is not working. Has this problem been resolved on your site?
https://forums.developer.nvidia.com/t/render-yuv422-10bit-to-10-bits-monitor-on-orin-nx/290177/3
https://forums.developer.nvidia.com/t/how-to-change-dp-data-format-from-rgb-to-yuv422/296928
This is what I did in my test environment.
root@yuan:~# cat /etc/nv_tegra_release
# R36 (release), REVISION: 4.0, GCID: 37537400, BOARD: generic, EABI: aarch64, DATE: Fri Sep 13 04:36:44 UTC 2024
# KERNEL_VARIANT: oot
TARGET_USERSPACE_LIB_DIR=nvidia
TARGET_USERSPACE_LIB_DIR_PATH=usr/lib/aarch64-linux-gnu/nvidia
root@yuan:~# sudo apt-cache show nvidia-jetpack
Package: nvidia-jetpack
Source: nvidia-jetpack (6.1)
Version: 6.1+b123
Architecture: arm64
Maintainer: NVIDIA Corporation
Installed-Size: 194
Depends: nvidia-jetpack-runtime (= 6.1+b123), nvidia-jetpack-dev (= 6.1+b123)
Homepage: http://developer.nvidia.com/jetson
Priority: standard
Section: metapackages
Filename: pool/main/n/nvidia-jetpack/nvidia-jetpack_6.1+b123_arm64.deb
SHA256: b6475a6108aeabc5b16af7c102162b7c46c36361239fef6293535d05ee2c2929
SHA1: f0984a6272c8f3a70ae14cb2ca6716b8c1a09543
MD5sum: a167745e1d88a8d7597454c8003fa9a4
Description: NVIDIA Jetpack Meta Package
Description-md5: ad1462289bdbc54909ae109d1d32c0a8
root@yuan:~# cat /proc/device-tree/model
NVIDIA Jetson Orin NX Engineering Reference Developer Kit
root@yuan:~# cd /usr/src/jetson_multimedia_api/samples/08_video_dec_drm/
root@yuan:~# sudo systemctl stop gdm
root@yuan:~# loginctl terminate-seat seat0
root@yuan:~# modprobe nvidia-drm modeset=1
root@yuan:/usr/src/jetson_multimedia_api/samples/08_video_dec_drm# ./video_dec_drm ./output.h265 H265 -fps 5 --disable-ui
Set governor to performance before enabling profiler
Using VT number 2
Opening in BLOCKING MODE
NvMMLiteOpen : Block : BlockType = 279
NvMMLiteBlockCreate : Block : BlockType = 279
Starting decoder capture loop thread
Input file read complete
Video Resolution: 1920x1080
Query and set capture successful
[ERROR] (NvDrmRenderer.cpp:805) <renderer0> Failed to create frame buffer
[ERROR] (NvDrmRenderer.cpp:895) <renderer0> Error in rendering frame
Currently HDR video playback is not enabled on Orin series.
Thanks for your reply.
Is there any plan to support HDR in the future?
Does DRM output currently support YUV 4:2:0 10-bit (P010) and YUV 4:2:2 10-bit (P210)?
