Hi Nvidia,
We are testing the internal ethernet on Orin NX module. (GBE_MD0~3)
The ethernet is disconnected when the system overloading.
Orin NX 16GB/Orin Nano 8GB
Orin Nano Devkit carrier board
L4T 35.4.1
Test tool : BurnInTest Windows/ARM version
https://www.passmark.com/products/burnintest/download.php
Our test step:
- Connect the x86 RJ45 ethernet and Orin NX RJ45 ethernet.
- Set the static IP to both.
- Run burnintest tool client on Orin NX.
- Run burnintest tool host on x86 PC. The test tool will connect to OrinNX and start testing.
- Run cuda matrixMulCUBLAS GPU sample code on Orin NX. The gpu loading is up to 99%.
- After many minutes. The x86 burnintest tool will show that unable to connect to Orin NX.
