Hello nvidia teams
I have two Orin NX modules: FAB 301 and FAB 300.
Board ID(3767) version(300) sku(0001) revision(M.3)
Board ID(3767) version(301) sku(0000) revision(G.1)
I can successfully flash JP5.1.1 on the FAB 300 module , but I encounter an error message when flashing the FAB 301 module.
* Step 2: Boot the device with flash initrd image *
/home/po/nvidia_pure/Linux_for_Tegra/temp_initrdflash/bootloader0 /home/po/nvidia_pure/Linux_for_Tegra
./tegraflash.py --bl uefi_jetson_with_dtb_sigheader.bin.encrypt --bct br_bct_BR.bct --securedev --bldtb nru50+_ONX_16gb.dtb --applet rcm_2_encrypt.rcm --applet_softfuse rcm_1_encrypt.rcm --cmd "rcmboot" --cfg secureflash.xml --chip 0x23 --mb1_bct mb1_bct_MB1_sigheader.bct.encrypt --mem_bct mem_rcm_sigheader.bct.encrypt --mb1_cold_boot_bct mb1_cold_boot_bct_MB1_sigheader.bct.encrypt --mb1_bin mb1_t234_prod_aligned_sigheader.bin.encrypt --psc_bl1_bin psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --mem_bct_cold_boot mem_coldboot_sigheader.bct.encrypt --bins "psc_fw pscfw_t234_prod_sigheader.bin.encrypt; mts_mce mce_flash_o10_cr_prod_sigheader.bin.encrypt; mb2_applet applet_t234_sigheader.bin.encrypt; mb2_bootloader mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt; xusb_fw xusb_t234_prod_sigheader.bin.encrypt; dce_fw display-t234-dce_sigheader.bin.encrypt; nvdec nvdec_t234_prod_sigheader.fw.encrypt; bpmp_fw bpmp_t234-TE990M-A1_prod_sigheader.bin.encrypt; bpmp_fw_dtb tegra234-bpmp-3767-0000-a02-3509-a02_with_odm_sigheader.dtb.encrypt; sce_fw camera-rtcpu-sce_sigheader.img.encrypt; rce_fw camera-rtcpu-t234-rce_sigheader.img.encrypt; ape_fw adsp-fw_sigheader.bin.encrypt; spe_fw spe_t234_sigheader.bin.encrypt; tos tos-optee_t234_sigheader.img.encrypt; eks eks_t234_sigheader.img.encrypt; kernel boot0.img; kernel_dtb nru50+_ONX_16gb.dtb" --secondary_gpt_backup --bct_backup --boot_chain A --instance 3-4
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
Entering RCM boot
[ 0.2971 ] mb1_t234_prod_aligned_sigheader.bin.encrypt filename is from --mb1_bin
[ 0.2972 ] psc_bl1_t234_prod_aligned_sigheader.bin.encrypt filename is from --psc_bl1_bin
[ 0.2972 ] rcm boot with presigned binaries
[ 0.3030 ] tegrarcm_v2 --instance 3-4 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[ 0.3091 ] BR_CID: 0x80012344705DF1A13000000009FF0040
[ 0.3524 ] Sending bct_br
[ 0.3920 ] Sending mb1
[ 0.3940 ] Sending psc_bl1
[ 0.4047 ] Sending bct_mb1
[ 0.4125 ] Generating blob for T23x
[ 0.4261 ] tegrahost_v2 --chip 0x23 0 --generateblob blob.xml blob.bin
[ 0.4323 ] The number of images in blob is 18
[ 0.4344 ] blobsize is 72787323
[ 0.4350 ] Added binary blob_uefi_jetson_with_dtb_sigheader.bin.encrypt of size 2920512
[ 0.6374 ] Added binary blob_pscfw_t234_prod_sigheader.bin.encrypt of size 375168
[ 0.6411 ] Added binary blob_mce_flash_o10_cr_prod_sigheader.bin.encrypt of size 190592
[ 0.6431 ] Added binary blob_applet_t234_sigheader.bin.encrypt of size 277312
[ 0.6448 ] Not supported type: mb2_applet
[ 0.6455 ] Added binary blob_mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt of size 437984
[ 0.6478 ] Added binary blob_xusb_t234_prod_sigheader.bin.encrypt of size 164864
[ 0.6496 ] Added binary blob_display-t234-dce_sigheader.bin.encrypt of size 9097216
[ 0.6774 ] Added binary blob_nvdec_t234_prod_sigheader.fw.encrypt of size 294912
[ 0.6849 ] Added binary blob_bpmp_t234-TE990M-A1_prod_sigheader.bin.encrypt of size 1048000
[ 0.6892 ] Added binary blob_tegra234-bpmp-3767-0000-a02-3509-a02_with_odm_sigheader.dtb.encrypt of size 138880
[ 0.6921 ] Added binary blob_camera-rtcpu-sce_sigheader.img.encrypt of size 166304
[ 0.6949 ] Added binary blob_camera-rtcpu-t234-rce_sigheader.img.encrypt of size 537952
[ 0.6973 ] Added binary blob_adsp-fw_sigheader.bin.encrypt of size 400960
[ 0.6990 ] Added binary blob_spe_t234_sigheader.bin.encrypt of size 270336
[ 0.7007 ] Added binary blob_tos-optee_t234_sigheader.img.encrypt of size 1064752
[ 0.7026 ] Added binary blob_eks_t234_sigheader.img.encrypt of size 9232
[ 0.7042 ] Added binary blob_boot0.img of size 55046144
[ 0.8857 ] Added binary blob_nru50+_ONX_16gb.dtb of size 345099
[ 1.2275 ] tegrarcm_v2 --instance 3-4 --chip 0x23 0 --pollbl --download bct_mem mem_rcm_sigheader.bct.encrypt --download blob blob.bin
[ 1.2337 ] BL: version 0.32.0.1-t234-54845784-1cb23efd last_boot_error: 0
[ 1.2761 ] Sending bct_mem
[ 1.3159 ] Sending blob
[ 1.5843 ] ERROR: might be timeout in USB write.
Error: Return value 3
Command tegrarcm_v2 --instance 3-4 --chip 0x23 0 --pollbl --download bct_mem mem_rcm_sigheader.bct.encrypt --download blob blob.bin
Cleaning up...
Please refer to the attachment for the full error log.
I would appreciate any advice you could provide. Thank you!
OrinNX_FAB301.txt (246.7 KB)
