Orin NX is failing to boot with the following error
ASSERT [FvbNorFlashStandaloneMm] /out/nvidia/optee.t234-uefi/StandaloneMmOptee_RELEASE/edk2-nvidia/Silicon/NVIDIA/Drivers/FvbNorFlashDxe/FvbNorFlashStandaloneMm.c(937): ((BOOLEAN)(0==1))
No changes were made, this failure occurred after a reboot and I have not been able to use it since.
Details-
Jetpack 6
L4T 36.3
Hi heartsystem,
Are you using the devkit or custom board for Orin NX?
heartsystem:
Jetpack 6
L4T 36.3
Could you verify with the latest Jetpack 6.1 (R36.4.0)?
We are using the devkit.
I will see if I can verify with Jetpack 6.1, but the work we are doing as of now is based on the following setup and we would prefer to keep it as is. Is this a known issue?
You can also refer to [Jetson Orin Nano] [OTA] [35.5.0][36.3] Failed to boot after OTA upgrade from 35.5.0 to 36.3 - #12 by KevinFFF to apply those 3 changes.
Since you are using the devkit, we would suggest you simply updating to the latest JP6.1 release.
Same thing is happening for me, it refusing to boot and I can’t install any Jetpack into it as my installation for flashing keeps failing at 99.5%.
Any recommendations would help
Hi usamamohiudin,
For the flash failed issue, please provide the full flash log.
You may create another topic to discuss your status in details.
system
Closed
November 6, 2024, 7:22am
9
