Orin nx flash log
你好,
我在烧录nx时 ,出现了下面打印:
tar: Read checkpoint 410000
tar: Read checkpoint 420000
tar: Read checkpoint 430000
tar: Read checkpoint 440000
tar: Read checkpoint 450000
tar: Read checkpoint 460000
tar: Read checkpoint 470000
tar: Read checkpoint 480000
tar: Read checkpoint 490000
tar: Read checkpoint 500000
tar: Read checkpoint 510000
tar: Read checkpoint 520000
tar: Read checkpoint 530000
tar: Read checkpoint 540000
tar: Read checkpoint 550000
tar: Read checkpoint 560000
writing item=20, 9:0:secondary_gpt, 117037841920, 16896, gpt_secondary_9_0.bin, 16896, fixed-<reserved>-0, 6e3ed5e87f770f7ed7030e391b236062ce687f2a
[ 426]: l4t_flash_from_kernel: Successfully flash the external device
[ 426]: l4t_flash_from_kernel: Flashing success
[ 426]: l4t_flash_from_kernel: The device size indicated in the partition layout xml is smaller than the actual size. This utility will try to fix the GPT.
Flash is successful
Reboot device
Cleaning up...
Log is saved to Linux_for_Tegra/initrdlog/flash_3-2_0_20250228-085751.log
The device size indicated in the partition layout xml is smaller than the actual size. This utility will try to fix the GPT. 这个是什么意思?有什么问题?
What is your external device? NVMe or USB?
Please format your external device to ext4 first below flashing.
