please also test that echo “host” to /sys/class/usb_role/usb2-0-role-switch/role when flash got stuck.
And connect a USB device to your usb flash port. Want to know if your port can work in host mode when error happened.
Tested with p3509-a02+p3767-0000.conf and flashing was successful, but boot failed after ~20s.
Moved the usb config (xusb_padctl, tegra_xudc, tegra_xhci) from p3509-a02+p3767-0000.conf to tegra234-p3768-0000-a0.dtsi and flashing with jetson-orin-nano-devkit is now successful, also orin booted without crashing and displayport is working. The usb config is not what we need (3x usb2, 2x usb3), will try to change it and come back if it affects the flashing again. Thank you for the help!
