I’m building a product on a Jetson Orin NX that needs 3 independent displays through a single DP MST hub:
- a 12" touchscreen (robot UI, main screen)
- two 1920x1080 advertising screens, each showing different content
Only 2 of the 3 displays can be active at a time. I’d like to confirm whether this is a hard hardware limit, or whether there’s a supported way to get 3.
Setup
- Board: Jetson Orin NX Engineering Reference Developer Kit
- Jetson Linux R39.2.1 (JetPack 7.2.1), kernel
6.8.12-1021-tegra - Display driver: NVIDIA open kernel module r595.78, Xorg with GNOME (X11)
- MST hub: 4-in-1 DP to 3x HDMI (generic, from Alibaba: product link)
- Monitors:
- DP-0.1: Waveshare 12" 1024x600 with USB touch
- DP-0.2: Kingston W21.5 1920x1080
- DP-0.3: XMI 1920x1080
What happens
All 3 monitors are detected through the hub, and their EDIDs are read correctly:
DP-0.1 connected
DP-0.2 connected primary 1920x1080+0+0
DP-0.3 connected
Any 2 of them work fine as an extended desktop. Enabling the third fails:
$ xrandr --output DP-0.1 --auto --output DP-0.2 --auto --right-of DP-0.1 --output DP-0.3 --auto --right-of DP-0.2
xrandr: cannot find crtc for output DP-0.3
What I’ve tested
- Low resolution on all 3 (1024x600 + 640x480 + 640x480): same
cannot find crtcerror. So it doesn’t look like a DP bandwidth limit. - Mirroring the 3rd display (
--same-as) onto an active output: same error. xrandr --listproviders:crtcs: 2 outputs: 5- Kernel DRM (
DRM_IOCTL_MODE_GETRESOURCESon/dev/dri/card2, nv_platform):crtcs=2 connectors=3 encoders=4 - Device tree
display@13800000(tegra234-display): onlynvdisplay_p0_clkandnvdisplay_p1_clkhead clocks. - nvidia_modeset / nvidia_drm module parameters: none relate to the head count.
I’ve also read this thread, where it was stated that MST supports “up to 2 monitors at most”.
Questions
- Is the 2-head limit on Orin NX a hard hardware limit of the T234 display controller, or a software/driver limit that could be lifted in a future release?
- Is there any supported configuration (device tree, DCB, driver option, xorg.conf MetaModes, etc.) that allows a 3rd independent display on Orin NX, through MST or otherwise?
- If not, what is NVIDIA’s recommended approach for 3 independent displays on Orin NX? For example, is a DisplayLink/EVDI USB display supported on R39.2.1, or is there another validated solution?
- Can one head drive a wide mode (for example 3840x1080) over a single MST stream, for use with an external video wall splitter?
