Hi, we are using the Orin NX 16GB 25 W module. I am doing a thermal study of our module to make sure it doesn’t overheat. The data sheet (enclosed) say the LPDDR5 produces 1.8W of heat. There are 2 of these in the module. So does each produce 1.8W? Of do both produce 1.8W?
Related topics
Topic | Replies | Views | Activity | |
Orin NX LPDDR5 power | 0 | 3 | April 10, 2025 | |
Seeking Thermal Clarification | 4 | 58 | January 8, 2025 | |
Maximum temperatures for inductor components mounted on Orin NX16GB modules | 7 | 56 | August 14, 2024 | |
Orin nx thermal design resistance values | 1 | 315 | February 29, 2024 | |
How to test Orin NX maximum power consumption? | 3 | 2947 | February 13, 2023 | |
Thermal resistance of Orin NX | 7 | 1072 | August 30, 2023 | |
Jetson Orin NX LPDDR5 Dimensions | 2 | 545 | December 8, 2022 | |
Jetson Orin NX RAM (LPDDR5) Temperature Monitoring | 8 | 602 | May 7, 2024 | |
The power consumption of Orin nano is larger than that of Orin NX? | 2 | 447 | February 23, 2024 | |
Orin NX 16G super mode max power in different temperature | 3 | 153 | April 23, 2025 |
