When my jetson orin nx module finished brushing the jetpack 6.2 system, I could switch MAXN mode, but my GPU frequency remained unchanged and was still 765MHz. And when using the jtop command to view information, jetpack missing is displayed.
Please share the dmesg first.
open your terminal on Jetson. Type “dmesg > log.txt” and attach that log.
I also upgraded jetpack to 6.2, with MAXN mode, but the GPU frequency did not increase, what is the reason
Please also share the content of /etc/nvpmodel/nvpmodel.conf
sorry, wrong path.
What is the result of
ll /etc/nvpmodel.conf
and share me the content of it.
The result
the config file
nvpmodel.conf.txt (8.1 KB)
1.txt (5.6 KB)
Hi @whjshishen your board is not Orin NX. Please file your own topic.
The config file is still the non super one. How did you flash the board?
Ok, in fact, I also have this problem with orin nx, and I found that it is normal to upgrade the public version to JETPACK 6.2, only these orin nano/NX modules are not able to work, I think jetpack 6.2 does not support these modules
Please use manual flash command. Looks like both of you didn’t flash the super mode config. Non super mode config is still in use.
https://docs.nvidia.com/jetson/archives/r36.4.3/DeveloperGuide/IN/QuickStart.html?highlight=super
->Jetson Orin Nano Developer Kit with Super Configuration (NVMe)
Ok, now I have tried, but I still have questions, why can’t the SDK be used? I am a loyal customer of NVIDIA, and I hope you can also use Orin Nano/NX module to test.
