I have an Orin NX in a older Xavier NX Carrier board by Nvidia. However I am unable to flash it as its not recognized by the SDK manager that its in recovery mode. How do I go about flashing the Orin? I have looked at the pinout compared to the Xavier NX and this carrier board should suffice? Do I have to get a Orin NX compatible carrier board?
Also does the SDK manager support flashing for the Orin NX? I dont see it at all in the hardware list.
Thanks, that helped.
Im still stuck on the following error when executing the flash command Error: missing readinfofile (/home/username/Jetson_Orin_Nx/Linux_for_Tegra/bootloader/readinfo_t234_min_dev.xml).
And your issue is not same as “not recognized in recovery mode”… Your board is already in recovery mode and can be recognized. Please file new topic for your issue.
I retried above steps again (Quick Start — Jetson Linux Developer Guide documentation)
And it worked on this try, my OS is Pop OS (Ubuntu 22). I used the following packages:
I was trying to do it in a docker container before and I think this might have caused issues.
