Orin nx of DP cannot be displayed
JP6.2 ORIN NX development board
Orin NX of DP cannot be displayed.
兼容性不是很好,很多显示器开机之后无法显示,必须热插拔一次才能显示。在jp5.X上无此问题
Are you talking about using Orin Nano devkit?
是的,是orin nano开发套件
Could you share the monitor ID you have tested that can reproduce the error?
Also, share us the /var/log/Xorg.0.log and dmesg when error happened.
log.tar.gz (1.8 MB)
整个log
Is there any log from other kind of monitors?
有的牌子显示器可以,但是很多牌子显示器不行,jp5.X没有此问题。客户要求我们去解决此问题,发现开发板也有此问题,没办法确保客户用什么显示器,不能老是挑牌子。我们测试过几款,不少都会出现此问题
Could you at least check if all the monitors that hit issue all run with 2560x1440 mode?
显示器分辨率1920*1080和2560x1440 都试过,两个开机都无法显示
