Type-C can’t identify it on orin nx dev
Type-C接到电脑没有办法识别到orin nx开发板
Do you mean Orin NX can enter recovery mode but cannot be listed through lsusb on host PC?
Is your host PC in Ubuntu 18.04 or 20.04?
Do you mean Orin NX can enter recovery mode but cannot be listed through lsusb on host PC? -->yes
My host PC 20.04
Software version: Jetson Linux 35.2.1
update any?
The steps are same as Xavier NX developer kit. Please short pin #10, #11 of J14, and plug in power jack. On host PC, you can execute lsusb and see the device in recovery mode:
Bus 003 Device 053: ID 0955:7423 NVIDIA Corp. APX
And Orin nx dev do work donnot recovery mode ,but Type-C can’t identify it
之前这个链接没有解答完全,orinnx开发板进入ubunut系统之后,typeC识别不到,有没有办法识别到或者变成host模式
https://forums.developer.nvidia.com/t/orin-nx-do-work-whether-usb-0-can-be-used-as-a-usb-host/238978
I’m closing this topic due to there is no update from you for a period, assuming this issue was resolved.
If still need the support, please open a new topic. Thanks
Is this still an issue to support? Any result can be shared? Thanks
