Orin NX UEFI Secure Boot
I’m working on Orin NX 8GB + Xavier NX developer kit.
I want to enable UEFI Secureboot at Flashing Time.
I applied this patch.
I made keys, and used following command to flash. But it failed with busy spin error.
Linux_for_Tegra$ sudo ./flash.sh --uefi-keys uefi_keys/uefi_keys.conf p3509-a02+p3767-0000 nvme0n1p1
E> Error in command_complete 18000 int_status
E> Sending CMD_SD_SEND_IF_COND failed
E> Error opening sdcard-0
E> Failed to initialize device 6-0
C> Storage init failed
C> Task 0x0 failed (err: 0x39390706)
E> Top caller module: SDMMC, error module: SDMMC, reason: 0x06, aux_info: 0x07
I> Busy Spin
[logs]
uart.txt (16.6 KB)
host-pc.txt (73.8 KB)
[environment]
Board: Orin NX 8GB + Xavier NX developer kit
L4T: R35.3.1
host-pc: ubuntu 18.04.6
What command enables UEFI Secureboot at flush time for Orin NX?
please see-also Topic 248137, comment#51, thanks
Thank you for your reply.
I read your shared topic.but it is different from my usecase.
I only want to try UEFI secureboot, not disk encyption.
I think flash.sh is not support Orin NX.
So, I want to know the substitute command.
How can I enable UEFI Secureboot at flush time on Orin NX?
Hi, @JerryChang I stil need your help.
I want to clarify the following two questions.
Dose “flash.sh --uefi-keys” support OrinNX + XavierNX carrier board?
How can I enable UEFI Secureboot at flush time on Orin NX without disk encyption?
thanks.
hello S.Harumoto,
you’ll need to execute this script for flashing Orin NX, i.e. $OUT/Linux_for_Tegra/tools/kernel_flash/l4t_initrd_flash.sh
and… it’s -p options for sending commands to flash.sh when generating the image for internal storage.
anyways, let me check this internally for test results…
Hi, @JerryChang
Is there any new information from the results of the internal check?
thanks.
FYI, we are still working on it… to enable UEFI secureboot in flashing time by Orin NX/Orin Nano.
