Orin NX -- unable to blow fuses
We’re running into problems trying to blow fuses on our Orin NX
  • Jetson R36.4
  • Tried with massfuse package
  • Tried with fskp package
We get similar errors with either method,
With massfuse package:
sudo ./nvmfuse.sh --showlogs
Start fusing device: 3-3, PID: 799515
Fuse burn complete (WITH FAILURES)
nvmfuse.log
*** Boot Rom communication
/home/paul/sauron/mfuse/mfuse_jetson-orin-nano-devkit/temp_3-3/tegrarcm_v2 --new_session --instance 3-3 --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
BR_CID: 0xREDACTED
Sending bct_br
Sending mb1
Sending psc_bl1
Sending bct_mb1
*** Boot Rom communication succeeded.
*** Sending membct and RCM blob
/home/paul/sauron/mfuse/mfuse_jetson-orin-nano-devkit/temp_3-3/tegrarcm_v2 --instance 3-3 --chip 0x23 0 --pollbl --download bct_mem mem_rcm_sigheader.bct.encrypt --download blob blob.bin
BL: version 1.4.0.2-t234-54845784-08a4de08 last_boot_error: 0
Sending bct_mem
Sending blob
ERROR: might be timeout in USB write.
*** Error: Sending membct and RCM blob failed.
and serial output:
[0081.987] I> Binary name: MEM-BCT-0        [1909/1909]
[0081.990] I> Size of crypto header is 8192
[0081.994] I> Size of crypto header is 8192
[0081.999] I> BCH of MEM-BCT-0 read from storage
[0082.003] I> BCH address is : 0x40050000
[0082.007] I> MEM-BCT-0 header integrity check is success
[0082.012] I> Binary magic in BCH component 0 is MEM0
[0082.017] I> component binary type is 0
[0082.023] I> MEM-BCT-0 binary is read from storage
[0082.028] I> MEM-BCT-0 binary integrity check is success
[0082.033] I> Binary MEM-BCT-0 loaded successfully at 0x40040000 (0xe580)
[0082.039] I> RAM_CODE 0x4000021
[0082.045] I> RAM_CODE 0x4000021
[0082.049] I> Task: Load Page retirement list
[0082.053] I> Task: SDRAM params override
[0082.057] I> Task: Save mem-bct info
[0082.060] I> Task: Carveout allocate
[0082.063] I> Update CCPLEX IST carveout from MB1-BCT
[0082.068] I> ECC region[0]: Start:0x0, End:0x0
[0082.073] I> ECC region[1]: Start:0x0, End:0x0
[0082.077] I> ECC region[2]: Start:0x0, End:0x0
[0082.081] I> ECC region[3]: Start:0x0, End:0x0
[0082.085] I> ECC region[4]: Start:0x0, End:0x0
[0082.090] I> Non-ECC region[0]: Start:0x80000000, End:0x480000000
[0082.096] I> Non-ECC region[1]: Start:0x0, End:0x0
[0082.100] I> Non-ECC region[2]: Start:0x0, End:0x0
[0082.105] I> Non-ECC region[3]: Start:0x0, End:0x0
[0082.110] I> Non-ECC region[4]: Start:0x0, End:0x0
[0082.120] I> allocated(CO:43) base:0xbe000000 size:0x4000000 align: 0x200000
[0082.127] I> allocated(CO:39) base:0x47de00000 size:0x2200000 align: 0x10000
[0082.134] I> allocated(CO:20) base:0x47a000000 size:0x2000000 align: 0x2000000
[0082.141] I> allocated(CO:24) base:0x478000000 size:0x2000000 align: 0x2000000        [1878/1909]
[0082.148] I> allocated(CO:28) base:0x476000000 size:0x2000000 align: 0x2000000
[0082.156] I> allocated(CO:22) base:0x47c000000 size:0x1000000 align: 0x1000000
[0082.163] I> allocated(CO:35) base:0x475000000 size:0x1000000 align: 0x100000
[0082.170] I> allocated(CO:02) base:0x47d000000 size:0x800000 align: 0x800000
[0082.177] I> allocated(CO:03) base:0x474800000 size:0x800000 align: 0x800000
[0082.184] I> allocated(CO:06) base:0x474000000 size:0x800000 align: 0x800000
[0082.191] I> allocated(CO:56) base:0x473800000 size:0x800000 align: 0x200000
[0082.197] I> allocated(CO:07) base:0x47d800000 size:0x400000 align: 0x400000
[0082.204] I> allocated(CO:33) base:0x473400000 size:0x400000 align: 0x200000
[0082.211] I> allocated(CO:19) base:0x473180000 size:0x280000 align: 0x10000
[0082.218] I> allocated(CO:23) base:0x47dc00000 size:0x200000 align: 0x200000
[0082.225] I> allocated(CO:01) base:0x473000000 size:0x100000 align: 0x100000
[0082.232] I> allocated(CO:05) base:0x472f00000 size:0x100000 align: 0x100000
[0082.239] I> allocated(CO:08) base:0x472e00000 size:0x100000 align: 0x100000
[0082.246] I> allocated(CO:09) base:0x472d00000 size:0x100000 align: 0x100000
[0082.253] I> allocated(CO:12) base:0x472c00000 size:0x100000 align: 0x100000
[0082.260] I> allocated(CO:15) base:0x472b00000 size:0x100000 align: 0x100000
[0082.267] I> allocated(CO:17) base:0x472a00000 size:0x100000 align: 0x100000
[0082.274] I> allocated(CO:27) base:0x472900000 size:0x100000 align: 0x100000
[0082.281] I> allocated(CO:42) base:0x472800000 size:0x100000 align: 0x100000
[0082.288] I> allocated(CO:54) base:0x473100000 size:0x80000 align: 0x80000
[0082.294] I> allocated(CO:34) base:0x4727f0000 size:0x10000 align: 0x10000
[0082.301] I> allocated(CO:72) base:0x4725f0000 size:0x200000 align: 0x10000
[0082.308] I> allocated(CO:46) base:0x440000000 size:0x20000000 align: 0x20000000
[0082.315] I> allocated(CO:47) base:0x472000000 size:0x400000 align: 0x200000
[0082.322] I> allocated(CO:50) base:0x471e00000 size:0x200000 align: 0x100000
[0082.329] I> allocated(CO:48) base:0x4725d0000 size:0x20000 align: 0x10000
[0082.336] I> allocated(CO:69) base:0x4725b0000 size:0x20000 align: 0x10000
[0082.343] I> allocated(CO:49) base:0x4725a0000 size:0x10000 align: 0x10000
[0082.350] I> NSDRAM base: 0x80000000, end: 0x4725f0000, size: 0x3f25f0000
[0082.356] I> Task: Thermal check
[0082.359] I> Using min_chip_limit as min_tmon_limit
[0082.364] I> Using max_chip_limit as max_tmon_limit
[0082.369] I> BCT max_tmon_limit = 105
[0082.372] I> BCT min_tmon_limit = -28
[0082.376] I> BCT max_tmon_limit = 105
[0082.379] I> BCT min_tmon_limit = -28
[0082.383] I> SKU specific max_chip_limit = 105
[0082.387] I> SKU specific min_chip_limit = -28
[0082.391] I> BCT max_chip_limit = 105
[0082.395] I> BCT min_chip_limit = -28
[0082.398] I> enable_soctherm_polling = 0
[0082.402] I> max temp read = 37
[0082.405] I> min temp read = 36
[0082.408] I> Enabling thermtrip
[0082.411] I> Task: Update FSI SCR with thermal fuse data
[0082.416] I> Task: Enable WDT 5th expiry
[0082.420] I> Task: I2C register
[0082.423] I> Task: Set I2C bus freq
[0082.426] I> Task: Reset FSI
[0082.429] I> Task: Pinmux init
[0082.432] I> skipped mmio_addr = 0x9240008
[0082.436] I> skipped mmio_addr = 0x9240000        [1825/1909]
[0082.440] I> skipped mmio_addr = 0x9240010
[0082.444] I> skipped mmio_addr = 0x9240018
[0082.448] I> skipped mmio_addr = 0x9240020
[0082.452] I> skipped mmio_addr = 0x9240030
[0082.456] I> skipped mmio_addr = 0x9240028
[0082.460] I> skipped mmio_addr = 0x9240038
[0082.464] I> skipped mmio_addr = 0x9240040
[0082.468] I> skipped mmio_addr = 0x9240048
[0082.472] I> skipped mmio_addr = 0x9241000
[0082.476] I> skipped mmio_addr = 0x9241008
[0082.480] I> skipped mmio_addr = 0x9241010
[0082.483] I> skipped mmio_addr = 0x9241018
[0082.487] I> skipped mmio_addr = 0x9241020
[0082.491] I> skipped mmio_addr = 0x9241028
[0082.495] I> skipped mmio_addr = 0x9241030
[0082.499] I> skipped mmio_addr = 0x9241038
[0082.503] I> skipped mmio_addr = 0x9241040
[0082.507] I> skipped mmio_addr = 0x9242000
[0082.511] I> skipped mmio_addr = 0x9242008
[0082.515] I> Task: Prod config init
[0082.518] I> Task: Pad voltage init
[0082.522] I> Task: Prod init
[0082.525] I> Task: Program rst req config reg
[0082.529] I> Task: Common rail init
[0082.532] I> DONE: Thermal config
[0082.536] W> DEVICE_PROD: module = 13, instance = 4 not found in device prod.
[0082.545] I> DONE: SOC rail config
[0082.548] W> PMIC_CONFIG: Rail: MEMIO rail config not found in MB1 BCT.
[0082.555] I> DONE: MEMIO rail config
[0082.559] W> PMIC_CONFIG: Rail: GPU rail info not found in MB1 BCT.
[0082.565] I> DONE: GPU rail info
[0082.569] W> PMIC_CONFIG: Rail: CV rail info not found in MB1 BCT.
[0082.575] I> DONE: CV rail info
[0082.578] I> Task: Mem clock src
[0082.581] I> Task: Misc. board config
[0082.585] I> PMIC_CONFIG: Platform config not found in MB1 BCT.
[0082.590] I> Task: SDRAM init
[0082.593] I> MemoryType: 4 MemBctRevision: 1
[0082.600] I> MSS CAR: PLLM/HUB programming for MemoryType: 4 and MemBctRevision: 1
[0082.607] I> MSS CAR: Init PLLM
[0082.610] I> MSS CAR: Init PLLHUB
[0082.615] I> Encryption:   MTS: en, TX: en, VPR: en, GSC: en
[0082.626] I> SDRAM initialized!
[0082.629] I> SDRAM Size in Total 0x400000000
[0082.634] I> Task: Dram Ecc scrub
[0082.637] I> Task: DRAM alias check
[0082.642] E> Alias_checker: Read/write mis-match
[0082.646] C> Task 0x32 failed (err: 0x1c)
[0082.650] E> Top caller module: NONE, error module: NONE, reason: 0x1c, aux_info: 0x00
[0082.658] C> Boot Info Table status dump :
0111111100111000111111111111111111111111111110111
and when burning with the fskp package:
sudo ./fskp_fuseburn.py --board-spec orinnx-board-spec.txt -P ./out -c 0x23 -B ../../../../sauron.conf
FSKP execution started 2025-01-09 10:29:07.954549
fskp_fuseburn.py script version 0.2
Parsing input arguments
Setting up default paths
Setup host environment
Found NVIDIA device ID 0x7423
Getting target details
BR_CID: 0xREDACTED
ECID: 0xREDACTED
WARNING!! Testing Fuses option is selected
do you want to continue testing the fuses (Yes/No) yes
Downloading FSKP blob to target
command sudo /home/paul/sauron/fusing/Linux_for_Tegra/l4t/tools/flashtools/flash/tegrarcm_v2 --chip 0x23 --pollbl --download bct_mem /home/paul/sauron/fusing/Linux_for_Tegra/l4t/tools/flashtools/fuseburn/out/bct_MEM_sigheader.bct --download blob /home/paul/sauron/fusing/Linux_for_Tegra/l4t/tools/flashtools/fuseburn/out/blob.bin failed, exit-code=3 error =
command /home/paul/sauron/fusing/Linux_for_Tegra/l4t/tools/flashtools/flash/tegrarcm_v2 --chip 0x23 --pollbl --download bct_mem /home/paul/sauron/fusing/Linux_for_Tegra/l4t/tools/flashtools/fuseburn/out/bct_MEM_sigheader.bct --download blob /home/paul/sauron/fusing/Linux_for_Tegra/l4t/tools/flashtools/fuseburn/out/blob.bin failed.
BL: version 1.4.0.4-t234-54845784-e89ea9bc last_boot_error: 0
Sending bct_mem
Sending blob
FSKP execution failed
  File "/home/paul/sauron/fusing/Linux_for_Tegra/l4t/tools/flashtools/fuseburn/./fskp_fuseburn.py", line 136, in <module>
    main(sys.argv)
  File "/home/paul/sauron/fusing/Linux_for_Tegra/l4t/tools/flashtools/fuseburn/./fskp_fuseburn.py", line 130, in main
    raise e
  File "/home/paul/sauron/fusing/Linux_for_Tegra/l4t/tools/flashtools/fuseburn/./fskp_fuseburn.py", line 125, in main
    u.main(commandLineArgs)
  File "/home/paul/sauron/fusing/Linux_for_Tegra/l4t/tools/flashtools/fuseburn/./fskp_fuseburn.py", line 100, in main
    h.send_fskp_blob_to_target_t234()
  File "/home/paul/sauron/fusing/Linux_for_Tegra/l4t/tools/flashtools/fuseburn/fskp_helper.py", line 734, in send_fskp_blob_to_target_t234
    self.run_sudo_cmd(cmd)
  File "/home/paul/sauron/fusing/Linux_for_Tegra/l4t/tools/flashtools/fuseburn/fskp_helper.py", line 616, in run_sudo_cmd
    raise OSError("command " + cmd + " failed.\n" + output)
OSError: command /home/paul/sauron/fusing/Linux_for_Tegra/l4t/tools/flashtools/flash/tegrarcm_v2 --chip 0x23 --pollbl --download bct_mem /home/paul/sauron/fusing/Linux_for_Tegra/l4t/tools/flashtools/fuseburn/out/bct_MEM_sigheader.bct --download blob /home/paul/sauron/fusing/Linux_for_Tegra/l4t/tools/flashtools/fuseburn/out/blob.bin failed.
Sending bct_mem
Sending blob
and the debug output from this attempt:
[0007.623] I> MB1 (version: 1.4.0.4-t234-54845784-e89ea9bc)
[0007.628] I> t234-A01-0-Silicon (0x12347) Prod
[0007.632] I> Boot-mode : Coldboot
[0007.636] I> Entry timestamp: 0x00000000
[0007.639] I> last_boot_error: 0x0
[0007.643] I> BR-BCT: preprod_dev_sign: 0
[0007.646] I> rst_source: 0x0, rst_level: 0x0
[0007.650] I> Task: SE error check
[0007.654] I> Task: Bootchain select WAR set
[0007.658] I> Task: Enable SLCG
[0007.660] I> Task: CRC check
[0007.663] I> Task: Initialize MB2 params
[0007.668] I> MB2-params @ 0x40060000
[0007.671] I> Task: Crypto init
[0007.674] I> Task: Perform MB1 KAT tests
[0007.678] I> Task: NVRNG health check
[0007.681] I> NVRNG: Health check success
[0007.685] I> Task: MSS Bandwidth limiter settings for iGPU clients
[0007.691] I> Task: Enabling and initialization of Bandwidth limiter
[0007.697] I> No request to configure MBWT settings for any PC!
[0007.703] I> Task: Secure debug controls
[0007.707] I> Task: strap war set
[0007.710] I> Task: Initialize SOC Therm
[0007.714] I> Task: Program NV master stream id
[0007.718] I> Task: Verify boot mode
[0007.724] I> Task: Alias fuses
[0007.727] W> FUSE_ALIAS: Fuse alias on production fused part is not supported.
[0007.735] I> Task: Print SKU type
[0007.738] I> FUSE_OPT_CCPLEX_CLUSTER_DISABLE = 0x000001c8
[0007.743] I> FUSE_OPT_GPC_DISABLE = 0x00000002
[0007.747] I> FUSE_OPT_TPC_DISABLE = 0x000000f0
[0007.751] I> FUSE_OPT_DLA_DISABLE = 0x00000002
[0007.756] I> FUSE_OPT_PVA_DISABLE = 0x00000000
[0007.760] I> FUSE_OPT_NVENC_DISABLE = 0x00000000
[0007.764] I> FUSE_OPT_NVDEC_DISABLE = 0x00000000
[0007.769] I> FUSE_OPT_FSI_DISABLE = 0x00000001
[0007.773] I> FUSE_OPT_EMC_DISABLE = 0x0000000c
[0007.777] I> FUSE_BOOTROM_PATCH_VERSION = 0x7
[0007.782] I> FUSE_PSCROM_PATCH_VERSION = 0x7
[0007.786] I> FUSE_OPT_ADC_CAL_FUSE_REV = 0x2
[0007.790] I> FUSE_SKU_INFO_0 = 0xd4
[0007.793] I> FUSE_OPT_SAMPLE_TYPE_0 = 0x3 PS
[0007.797] I> FUSE_PACKAGE_INFO_0 = 0x2
[0007.801] I> SKU: Prod
[0007.803] I> Task: Boost clocks
[0007.806] I> Initializing NAFLL for BPMP_CPU_NIC.
[0007.811] I> BPMP NAFLL: fll_lock = 1, dvco_min_reached = 0
[0007.817] I> BPMP NAFLL lock success.
[0007.820] I> BPMP_CPU_NIC : src = 42, divisor = 0        [77/1926]
[0007.825] I> Initializing PLLC2 for AXI_CBB.
[0007.829] I> AXI_CBB : src = 35, divisor = 0
[0007.833] I> Task: Voltage monitor
[0007.836] I> VMON: Vmon re-calibration and fine tuning done
[0007.842] I> Task: UPHY init
[0007.845] W> UPHY: UPHY lane info table is empty in MB1 BCT.
[0007.850] I> Task: Boot device init
[0007.853] I> Boot_device: RCM
[0007.856] I> USB configuration success
[0008.735] I> Task: TSC init
[0008.737] I> Task: Load membct
[0008.740] I> RAM_CODE 0x4000021
[0008.743] I> Loading MEMBCT
[0008.746] I> Slot: 0
[0008.748] I> Binary[0] block-0 (partition size: 0x40000)
[0008.753] I> Binary name: MEM-BCT-0
[0008.757] I> Size of crypto header is 8192
[0008.761] I> Size of crypto header is 8192
[0008.887] I> BCH of MEM-BCT-0 read from storage
[0008.892] I> BCH address is : 0x40050000
[0008.895] I> MEM-BCT-0 header integrity check is success
[0008.901] I> Binary magic in BCH component 0 is MEM0
[0008.905] I> component binary type is 0
[0008.912] I> MEM-BCT-0 binary is read from storage
[0008.916] I> MEM-BCT-0 binary integrity check is success
[0008.922] I> Binary MEM-BCT-0 loaded successfully at 0x40040000 (0xe580)
[0008.928] I> RAM_CODE 0x4000021
[0008.933] I> RAM_CODE 0x4000021
[0008.937] I> Task: Load Page retirement list
[0008.942] I> Task: SDRAM params override
[0008.945] I> Task: Save mem-bct info
[0008.949] I> Task: Carveout allocate
[0008.952] I> Update CCPLEX IST carveout from MB1-BCT
[0008.957] I> ECC region[0]: Start:0x0, End:0x0
[0008.961] I> ECC region[1]: Start:0x0, End:0x0
[0008.966] I> ECC region[2]: Start:0x0, End:0x0
[0008.970] I> ECC region[3]: Start:0x0, End:0x0
[0008.974] I> ECC region[4]: Start:0x0, End:0x0
[0008.978] I> Non-ECC region[0]: Start:0x80000000, End:0x480000000
[0008.984] I> Non-ECC region[1]: Start:0x0, End:0x0
[0008.989] I> Non-ECC region[2]: Start:0x0, End:0x0
[0008.994] I> Non-ECC region[3]: Start:0x0, End:0x0
[0008.998] I> Non-ECC region[4]: Start:0x0, End:0x0
[0009.009] I> allocated(CO:43) base:0xbe000000 size:0x4000000 align: 0x200000
[0009.016] I> allocated(CO:39) base:0x47de00000 size:0x2200000 align: 0x10000
[0009.023] I> allocated(CO:20) base:0x47a000000 size:0x2000000 align: 0x2000000
[0009.030] I> allocated(CO:24) base:0x478000000 size:0x2000000 align: 0x2000000
[0009.037] I> allocated(CO:28) base:0x476000000 size:0x2000000 align: 0x2000000
[0009.044] I> allocated(CO:22) base:0x47c000000 size:0x1000000 align: 0x1000000
[0009.051] I> allocated(CO:35) base:0x475000000 size:0x1000000 align: 0x100000
[0009.058] I> allocated(CO:02) base:0x47d000000 size:0x800000 align: 0x800000
[0009.065] I> allocated(CO:03) base:0x474800000 size:0x800000 align: 0x800000
[0009.072] I> allocated(CO:06) base:0x474000000 size:0x800000 align: 0x800000
[0009.079] I> allocated(CO:56) base:0x473800000 size:0x800000 align: 0x200000
[0009.086] I> allocated(CO:07) base:0x47d800000 size:0x400000 align: 0x400000
[0009.093] I> allocated(CO:33) base:0x473400000 size:0x400000 align: 0x200000
[0009.100] I> allocated(CO:19) base:0x473180000 size:0x280000 align: 0x10000
[0009.107] I> allocated(CO:23) base:0x47dc00000 size:0x200000 align: 0x200000
[0009.114] I> allocated(CO:01) base:0x473000000 size:0x100000 align: 0x100000
[0009.121] I> allocated(CO:05) base:0x472f00000 size:0x100000 align: 0x100000
[0009.128] I> allocated(CO:08) base:0x472e00000 size:0x100000 align: 0x100000
[0009.135] I> allocated(CO:09) base:0x472d00000 size:0x100000 align: 0x100000
[0009.142] I> allocated(CO:12) base:0x472c00000 size:0x100000 align: 0x100000
[0009.149] I> allocated(CO:15) base:0x472b00000 size:0x100000 align: 0x100000
[0009.156] I> allocated(CO:17) base:0x472a00000 size:0x100000 align: 0x100000
[0009.162] I> allocated(CO:27) base:0x472900000 size:0x100000 align: 0x100000
[0009.169] I> allocated(CO:42) base:0x472800000 size:0x100000 align: 0x100000
[0009.176] I> allocated(CO:54) base:0x473100000 size:0x80000 align: 0x80000
[0009.183] I> allocated(CO:34) base:0x4727f0000 size:0x10000 align: 0x10000
[0009.190] I> allocated(CO:72) base:0x4725f0000 size:0x200000 align: 0x10000
[0009.197] I> allocated(CO:46) base:0x440000000 size:0x20000000 align: 0x20000000
[0009.204] I> allocated(CO:47) base:0x472000000 size:0x400000 align: 0x200000
[0009.211] I> allocated(CO:50) base:0x471e00000 size:0x200000 align: 0x100000
[0009.218] I> allocated(CO:48) base:0x4725d0000 size:0x20000 align: 0x10000
[0009.225] I> allocated(CO:69) base:0x4725b0000 size:0x20000 align: 0x10000
[0009.231] I> allocated(CO:49) base:0x4725a0000 size:0x10000 align: 0x10000
[0009.238] I> NSDRAM base: 0x80000000, end: 0x4725f0000, size: 0x3f25f0000
[0009.245] I> Task: Thermal check
[0009.248] I> Using min_chip_limit as min_tmon_limit
[0009.253] I> Using max_chip_limit as max_tmon_limit
[0009.257] I> BCT max_tmon_limit = 105
[0009.261] I> BCT min_tmon_limit = -28
[0009.264] I> BCT max_tmon_limit = 105
[0009.268] I> BCT min_tmon_limit = -28
[0009.271] I> SKU specific max_chip_limit = 105
[0009.276] I> SKU specific min_chip_limit = -28
[0009.280] I> BCT max_chip_limit = 105
[0009.283] I> BCT min_chip_limit = -28
[0009.287] I> enable_soctherm_polling = 0
[0009.291] I> max temp read = 36
[0009.294] I> min temp read = 35
[0009.297] I> Enabling thermtrip
[0009.300] I> Task: Update FSI SCR with thermal fuse data
[0009.305] I> Task: Enable WDT 5th expiry
[0009.309] I> Task: I2C register
[0009.312] I> Task: Set I2C bus freq
[0009.315] I> Task: Reset FSI
[0009.318] I> Task: Pinmux init
[0009.321] I> skipped mmio_addr = 0x9240008
[0009.325] I> skipped mmio_addr = 0x9240000
[0009.329] I> skipped mmio_addr = 0x9240010
[0009.333] I> skipped mmio_addr = 0x9240018
[0009.337] I> skipped mmio_addr = 0x9240020
[0009.341] I> skipped mmio_addr = 0x9240030
[0009.345] I> skipped mmio_addr = 0x9240028
[0009.348] I> skipped mmio_addr = 0x9240038
[0009.352] I> skipped mmio_addr = 0x9240040
[0009.356] I> skipped mmio_addr = 0x9240048
[0009.360] I> skipped mmio_addr = 0x9241000
[0009.364] I> skipped mmio_addr = 0x9241008
[0009.368] I> skipped mmio_addr = 0x9241010
[0009.372] I> skipped mmio_addr = 0x9241018
[0009.376] I> skipped mmio_addr = 0x9241020
[0009.380] I> skipped mmio_addr = 0x9241028
[0009.384] I> skipped mmio_addr = 0x9241030
[0009.388] I> skipped mmio_addr = 0x9241038
[0009.392] I> skipped mmio_addr = 0x9241040
[0009.396] I> skipped mmio_addr = 0x9242000
[0009.400] I> skipped mmio_addr = 0x9242008
[0009.404] I> Task: Prod config init
[0009.407] I> Task: Pad voltage init
[0009.410] I> Task: Prod init
[0009.413] E> prod table is empty in MB1 BCT
[0009.417] I> Task: Program rst req config reg
[0009.421] I> Task: Common rail init
[0009.425] I> DONE: Thermal config
[0009.429] W> DEVICE_PROD: module = 13, instance = 4 not found in device prod.
[0009.437] I> DONE: SOC rail config
[0009.441] W> PMIC_CONFIG: Rail: MEMIO rail config not found in MB1 BCT.
[0009.448] I> DONE: MEMIO rail config
[0009.452] W> PMIC_CONFIG: Rail: GPU rail info not found in MB1 BCT.
[0009.458] I> DONE: GPU rail info
[0009.461] W> PMIC_CONFIG: Rail: CV rail info not found in MB1 BCT.
[0009.467] I> DONE: CV rail info
[0009.470] I> Task: Mem clock src
[0009.473] I> Task: Misc. board config
[0009.477] I> PMIC_CONFIG: Platform config not found in MB1 BCT.
[0009.483] I> Task: SDRAM init
[0009.486] I> MemoryType: 4 MemBctRevision: 1
[0009.492] I> MSS CAR: PLLM/HUB programming for MemoryType: 4 and MemBctRevision: 1
[0009.500] I> MSS CAR: Init PLLM
[0009.503] I> MSS CAR: Init PLLHUB
[0009.508] I> Encryption:   MTS: en, TX: en, VPR: en, GSC: en
[0009.519] I> SDRAM initialized!
[0009.522] I> SDRAM Size in Total 0x400000000
[0009.526] I> Task: Dram Ecc scrub
[0009.529] I> Task: DRAM alias check
[0009.534] E> Alias_checker: Read/write mis-match
[0009.538] C> Task 0x32 failed (err: 0x1c)
[0009.542] E> Top caller module: NONE, error module: NONE, reason: 0x1c, aux_info: 0x00
[0009.550] C> Boot Info Table status dump :
What can we do to get this working?
Please contact with your NVIDIA representative to get the support via another channel. Thanks
