Yes, if it is a step that makes the kernel not compatible, then it should happen right after the next reboot.
If you could still boot into the error situation, maybe I could share some steps and we can check what is wrong on your side. But need sometime before I shared out what to check.
No, the log says to press enter to enter the bash console, but this does not work.
However, we were able to determine why it no longer boots. Somehow the initrd image file was changed. We have decompiled a working initrd and one that is affected by the problem. We noticed that many files are missing. For example in the lib/modules folder:
waep@waep-p360:~/Documents/l4t_initrd_decomp/failing/lib/modules/5.15.148-tegra$ ls -l
total 4
drwxrwxr-x 3 waep waep 4096 Mär 19 10:27 kernel
waep@waep-p360:~/Documents/l4t_initrd_decomp/failing/lib/modules/5.15.148-tegra$ cd kernel/
waep@waep-p360:~/Documents/l4t_initrd_decomp/failing/lib/modules/5.15.148-tegra/kernel$ ls -l
total 4
drwxrwxr-x 3 waep waep 4096 Mär 19 10:27 drivers
waep@waep-p360:~/Documents/l4t_initrd_decomp/failing/lib/modules/5.15.148-tegra/kernel$ cd drivers/
waep@waep-p360:~/Documents/l4t_initrd_decomp/failing/lib/modules/5.15.148-tegra/kernel/drivers$ ls -l
total 4
drwxrwxr-x 3 waep waep 4096 Mär 19 10:27 net
waep@waep-p360:~/Documents/l4t_initrd_decomp/failing/lib/modules/5.15.148-tegra/kernel/drivers$ cd net/
waep@waep-p360:~/Documents/l4t_initrd_decomp/failing/lib/modules/5.15.148-tegra/kernel/drivers/net$ ls -l
total 4
drwxrwxr-x 3 waep waep 4096 Mär 19 10:27 ethernet
waep@waep-p360:~/Documents/l4t_initrd_decomp/failing/lib/modules/5.15.148-tegra/kernel/drivers/net$ cd ethernet/
waep@waep-p360:~/Documents/l4t_initrd_decomp/failing/lib/modules/5.15.148-tegra/kernel/drivers/net/ethernet$ ls -l
total 4
drwxrwxr-x 4 waep waep 4096 Mär 19 10:27 realtek
waep@waep-p360:~/Documents/l4t_initrd_decomp/failing/lib/modules/5.15.148-tegra/kernel/drivers/net/ethernet$ cd realtek/
waep@waep-p360:~/Documents/l4t_initrd_decomp/failing/lib/modules/5.15.148-tegra/kernel/drivers/net/ethernet/realtek$ ls -l
total 8
drwxrwxr-x 2 waep waep 4096 Mär 19 10:27 r8126
drwxrwxr-x 2 waep waep 4096 Mär 19 10:27 r8168
As you can see, there is almost nothing in the lib/modules folder of the decompiled failing initrd image, so there is no PCI driver either. However, we do not know when the change of the initrd happens.
If we are trapped in this boat problem, this is how we get out of it:
power up jetson and go to UEFI Settings
in UEFI Settings we are going to DeviceManager->NVIDIA Configuration->L4T Configuration and changing L4T Boot Mode to Kernel Partition
system boots up and we replace the initrd image that is not working with a working one.
then reboot and change the changed setting in the UEFI settings back to extlinux
reboot again and the system runs again as before the incident
What I don’t understand is how the new initrd gets into the QSPI. As I understand it, the initrd is loaded from the QSPI because the nvme cannot yet be accessed at this stage of the boot process. How does the initrd copied to the boot directory get to the QSPI? Sorry if that is a dumb question.
By boot disk do you mean the nvme disk in our case? But how is the initrd loaded from the nvme if the pcie driver can only be loaded after the initrd has been loaded and without pcie driver no access to the nvme can take place? Again, sorry if this is a stupid question.
