Orin nx, SDK:6.2.1, ubuntu22.04
系统烧录成功, 启动失败,启动日志如下:
1.txt (74.9 KB)
1.txt (74.9 KB)
Based on the provided context, it appears that you are inquiring about the Jetson Orin NX module, specifically with regards to the SDK621 and Ubuntu 22.04.
Here’s a comprehensive answer:
Hardware Requirements:
To get started with the Jetson Orin NX module, you will need:
Software Requirements:
Jetson Orin NX Series Product Design Guide:
The Jetson Orin NX Series Product Design Guide (DG-10931-001_v1.4) provides detailed information on the developer kit feature considerations, including the Button Power MCU (EFM8SB10F2G) and USB SuperSpeed Hub (Realtek RTS5420-GR).
Jetson Linux 36.4.3:
Jetson Linux 36.4.3 is a Product quality release that supports all Jetson AGX Orin, Jetson Orin NX, and Jetson Orin Nano Production Modules, as well as the Jetson AGX Orin Developer Kit and Jetson Orin Nano Developer Kit. It includes Linux Kernel 5.15, an Ubuntu 22.04-based root file system, a UEFI-based bootloader, and OP-TEE as Trusted Execution Environment.
Comparison with Other Modules:
The Jetson Orin NX module is similar to the Jetson Orin Nano module, but with some key differences. The Jetson Orin NX module has a higher power budget and extended clock-frequency steps compared to the Jetson Orin Nano module.
Development and Production Modules:
Development modules are sold only as components of a developer kit, while production modules are compatible with the listed carrier boards and are mainly intended for production use. Both development and production modules are sold separately.
In summary, to work with the Jetson Orin NX module, you will need to ensure you have the necessary hardware and software requirements, including JetPack 6.2/Jetson Linux 36.4.3 and Jetson Platform services 2.0. You can refer to the Jetson Orin NX Series Product Design Guide and Jetson Linux Developer Guide for detailed documentation.
Your system is stuck in recovery boot.
L4TLauncher: Attempting Recovery Boot
Please follow this page to make it go back to normal boot and dump log again.
