Orin nx 烧录不成功
orin nx, jetpack6.2.1, ubuntu22.04,确定nvme OK
烧录:
root@wel-H510M-D2VX-SI:/home/wel/nvidia-6.2.1/Linux_for_Tegra# sudo ./nvsdkmanager_flash.sh --storage nvme0n1p1
17:36:20.773 - Debug: User passed parameters: nvme0n1p1
17:36:20.774 - Debug: Identifying target board…
*** Checking ONLINE mode … OK.
*** Checking target board connection … 1 connections found.
*** Reading ECID … FUSELEVEL=fuselevel_production hwchipid=0x23 bootauth=NS
*** Reading EEPROM … “/home/wel/nvidia-6.2.1/Linux_for_Tegra/bootloader/tegraflash.py” --chip 0x23 --applet “/home/wel/nvidia-6.2 .1/Linux_for_Tegra/bootloader/mb1_t234_prod.bin” --cfg readinfo_t234_min_prod.xml --dev_params tegra234-br-bct-diag-boot.dts --devi ce_config tegra234-mb1-bct-device-p3701-0000.dts --misc_config tegra234-mb1-bct-misc-p3701-0000.dts --bins “mb2_applet applet_t234. bin” --skipuid --cmd “dump eeprom cvm cvm.bin; reboot recovery”
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0169 ] tegrasign_v3.py --key None --getmode mode.txt
[ 0.0170 ] Assuming zero filled SBK key
[ 0.0166 ] Pre-processing config: tegra234-mb1-bct-device-p3701-0000.dts
[ 0.0208 ] Pre-processing config: tegra234-mb1-bct-misc-p3701-0000.dts
[ 0.0266 ] Parsing partition layout
[ 0.0269 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[ 0.0275 ] Kernel DTB used: None
[ 0.0275 ] WARNING: dce base dtb is not provided
[ 0.0275 ] Parsing partition layout
[ 0.0277 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[ 0.0280 ] Creating list of images to be signed
[ 0.0282 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --list images_list.xml zerosbk
[ 0.0283 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[ 0.0289 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[ 0.0291 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[ 0.0326 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[ 0.1069 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[ 0.1220 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[ 0.1221 ] adding BCH for mb2_t234_aligned.bin
[ 0.1241 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[ 0.1332 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[ 0.1333 ] adding BCH for mb2_t234_aligned.bin
  • Step 2: Boot the device with flash initrd image *
/home/wel/nvidia-6.2.1/Linux_for_Tegra/temp_initrdflash/bootloader0 /home/wel/nvidia-6.2.1/Linux_for_Tegra
./tegraflash.py --bl uefi_jetson_minimal_with_dtb_sigheader.bin.encrypt --bct br_bct_BR.bct --securedev --bldtb tegra234-p3768-000 0+p3767-0003-nv.dtb --applet rcm_2_encrypt.rcm --applet_softfuse rcm_1_encrypt.rcm --instance 1-2 --cmd “rcmboot” --cfg secureflas h.xml --chip 0x23 --mb1_bct mb1_bct_MB1_sigheader.bct.encrypt --mem_bct mem_rcm_sigheader.bct.encrypt --mb1_cold_boot_bct mb1_cold_ boot_bct_MB1_sigheader.bct.encrypt --mb1_bin mb1_t234_prod_aligned_sigheader.bin.encrypt --psc_bl1_bin psc_bl1_t234_prod_aligned_si gheader.bin.encrypt --mem_bct_cold_boot mem_coldboot_sigheader.bct.encrypt --bins “psc_fw pscfw_t234_prod_sigheader.bin.encrypt; m ts_mce mce_flash_o10_cr_prod_sigheader.bin.encrypt; tsec_fw tsec_t234_sigheader.bin.encrypt; mb2_applet applet_t234_sigheader.bin.e ncrypt; mb2_bootloader mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt; xusb_fw xusb_t234_prod_sigheader.bin.encrypt; pva _fw nvpva_020_sigheader.fw.encrypt; dce_fw display-t234-dce_sigheader.bin.encrypt; nvdec nvdec_t234_prod_sigheader.fw.encrypt; bpmp _fw bpmp_t234-TE950M-A1_prod_sigheader.bin.encrypt; bpmp_fw_dtb tegra234-bpmp-3767-0003-3509-a02_with_odm_sigheader.dtb.encrypt; rc e_fw camera-rtcpu-t234-rce_sigheader.img.encrypt; ape_fw adsp-fw_sigheader.bin.encrypt; spe_fw spe_t234_sigheader.bin.encrypt; tos tos-optee_t234_sigheader.img.encrypt; eks eks_t234_sigheader.img.encrypt; kernel boot0.img; kernel_dtb tegra234-p3768-0000+p3767-00 03-nv.dtb” --bct_backup
version 1.0.0
Entering RCM boot
[ 0.0195 ] mb1_t234_prod_aligned_sigheader.bin.encrypt filename is from --mb1_bin
[ 0.0195 ] psc_bl1_t234_prod_aligned_sigheader.bin.encrypt filename is from --psc_bl1_bin
[ 0.0195 ] rcm boot with presigned binaries
[ 0.0197 ] tegrarcm_v2 --instance 1-2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_p rod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1 _sigheader.bct.encrypt
[ 0.0199 ] BR_CID: 0x80012344705DE5032800000002FF00C0
[ 0.0266 ] Sending bct_br
[ 0.0323 ] Sending mb1
[ 0.0328 ] Sending psc_bl1
[ 0.0437 ] Sending bct_mb1
[ 0.0501 ] Generating blob for T23x
[ 0.0510 ] tegrahost_v2 --chip 0x23 0 --generateblob blob.xml blob.bin
[ 0.0512 ] The number of images in blob is 19
[ 0.0514 ] blobsize is 101929200
[ 0.0514 ] Added binary blob_uefi_jetson_minimal_with_dtb_sigheader.bin.encrypt of size 2048064
[ 0.0782 ] Added binary blob_pscfw_t234_prod_sigheader.bin.encrypt of size 310768
[ 0.0786 ] Added binary blob_mce_flash_o10_cr_prod_sigheader.bin.encrypt of size 187120
[ 0.0787 ] Added binary blob_tsec_t234_sigheader.bin.encrypt of size 176128
[ 0.0788 ] Added binary blob_applet_t234_sigheader.bin.encrypt of size 279808
[ 0.0789 ] Not supported type: mb2_applet
[ 0.0789 ] Added binary blob_mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt of size 440944
[ 0.0791 ] Added binary blob_xusb_t234_prod_sigheader.bin.encrypt of size 164864
[ 0.0792 ] Added binary blob_nvpva_020_sigheader.fw.encrypt of size 2164640
[ 0.0799 ] Added binary blob_display-t234-dce_sigheader.bin.encrypt of size 12072192
[ 0.0847 ] Added binary blob_nvdec_t234_prod_sigheader.fw.encrypt of size 294912
[ 0.0862 ] Added binary blob_bpmp_t234-TE950M-A1_prod_sigheader.bin.encrypt of size 1027008
[ 0.0866 ] Added binary blob_tegra234-bpmp-3767-0003-3509-a02_with_odm_sigheader.dtb.encrypt of size 204736
[ 0.0868 ] Added binary blob_camera-rtcpu-t234-rce_sigheader.img.encrypt of size 458096
[ 0.0870 ] Added binary blob_adsp-fw_sigheader.bin.encrypt of size 415008
[ 0.0871 ] Added binary blob_spe_t234_sigheader.bin.encrypt of size 270336
[ 0.0872 ] Added binary blob_tos-optee_t234_sigheader.img.encrypt of size 1887312
[ 0.0879 ] Added binary blob_eks_t234_sigheader.img.encrypt of size 9232
[ 0.0881 ] Added binary blob_boot0.img of size 79265792
[ 0.1187 ] Added binary blob_tegra234-p3768-0000+p3767-0003-nv.dtb of size 251136
[ 0.1643 ] tegrarcm_v2 --instance 1-2 --chip 0x23 0 --pollbl --download bct_mem mem_rcm_sigheader.bct.encrypt --download blob blo b.bin
[ 0.1645 ] BL: version 1.4.0.4-t234-54845784-e89ea9bc last_boot_error: 0
[ 0.3096 ] Sending bct_mem
[ 0.3153 ] Sending blob
[ 4.3145 ] RCM-boot started
  • Step 3: Start the flashing process *
Waiting for target to boot-up…
Timeout
Device failed to boot to the initrd flash kernel. Please retrive the serial log during flashing to debug further.
Cleaning up…
调试串口输出:
L4TLauncher: Attempting RCM Boot
EFI stub: Booting Linux Kernel…
EFI stub: Using DTB from configuration table
EFI stub: Loaded initrd from LINUX_EFI_INITRD_MEDIA_GUID device path
EFI stub: Exiting boot services…
▒▒debugfs initialized
▒▒I/TC: Reserved shared memory is disabled
I/TC: Dynamic shared memory is enabled
I/TC: Normal World virtualization support is disabled
I/TC: Asynchronous notifications are disabled
▒▒[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd421]
[ 0.000000] Linux version 5.15.148-tegra (root@wel-H510M-D2VX-SI) (aarch64-buildroot-linux-gnu-gcc.br_real (Buildroot 2022.08) 1 1.3.0, GNU ld (GNU Binutils) 2.38) #1 SMP PREEMPT Tue Jun 9 16:07:45 CST 2026 ()
[ 0.000000] Machine model: NVIDIA Jetson Orin NX Engineering Reference Developer Kit
[ 0.000000] efi: EFI v2.70 by EDK II
[ 0.000000] efi: TPMFinalLog=0x22ed70000 SMBIOS=0xffff0000 SMBIOS 3.0=0x23dca0000 MEMATTR=0x23a28b018 TPMEventLog=0x22ed8a018 RN G=0x22a0b0018 MEMRESERVE=0x22ed8bf18
[ 0.000000] random: crng init done
[ 0.000000] secureboot: Secure boot disabled
[ 0.000000] Reserved memory: created CMA memory pool at 0x0000000261000000, size 256 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] NUMA: No NUMA configuration found
[ 0.000000] NUMA: Faking a node at [mem 0x0000000080000000-0x0000000277ffffff]
[ 0.000000] NUMA: NODE_DATA [mem 0x271302800-0x271304fff]
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal [mem 0x0000000100000000-0x0000000277ffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x00000000bdffffff]
[ 0.000000] node 0: [mem 0x00000000c2000000-0x00000000fffdffff]
[ 0.000000] node 0: [mem 0x00000000fffe0000-0x00000000ffffffff]
[ 0.000000] node 0: [mem 0x0000000100000000-0x000000022ed0cfff]
[ 0.000000] node 0: [mem 0x000000022ed0d000-0x000000022ed7ffff]
[ 0.000000] node 0: [mem 0x000000022ed80000-0x000000023c26ffff]
[ 0.000000] node 0: [mem 0x000000023c270000-0x000000023e1affff]
[ 0.000000] node 0: [mem 0x000000023e1b0000-0x0000000271dfffff]
[ 0.000000] node 0: [mem 0x0000000271e00000-0x0000000271ffffff]
[ 0.000000] node 0: [mem 0x0000000272000000-0x000000027259ffff]
[ 0.000000] node 0: [mem 0x0000000272f00000-0x0000000272ffffff]
[ 0.000000] node 0: [mem 0x0000000276000000-0x0000000277ffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x0000000277ffffff]
[ 0.000000] On node 0, zone DMA: 16384 pages in unavailable ranges
[ 0.000000] On node 0, zone Normal: 2400 pages in unavailable ranges
[ 0.000000] On node 0, zone Normal: 12288 pages in unavailable ranges
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 28 pages/cpu s76376 r8192 d30120 u114688
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: detected: Address authentication (architected algorithm)
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: Virtualization Host Extensions
[ 0.000000] CPU features: detected: Hardware dirty bit management
[ 0.000000] CPU features: detected: Spectre-v4
[ 0.000000] CPU features: detected: Spectre-BHB
[ 0.000000] CPU features: kernel page table isolation forced ON by KASLR
[ 0.000000] CPUmod /lresib/modetecteules/5.15.14Keregr paa/utabtes/drisoion (Krs/)
/ethernet 0alt000ek/68/0] r81ernko ves: patching kernel code
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 2001056
[ 0.000000] Policy zone: Normal
[ 0.000000] Kernel command line: root=/dev/initrd rw rootwait mminit_loglevel=4 console=ttyTCU0,115200 firmwble_re_cle_aassth=/e tc/f
ware fbcobleap:0 n reifne acce bl_prof_dataptr=2031616@0x271E10000 bl_prof_ro_ptr=65536@0xmod /lE00modules/5
.14 0.00a/kern0] Unkel/n kverel hy/mand lphy paramgraete"mm194u.ko oglevel=4 fbbe: ERRORp:0: c_prd ndatot ertr=2 ‘p031teg61694_p2u 271’: Exec formof_at error=65@0x271E00000", will be passed to ins /lib/pacules/5.15[ 0.008-tegr0] ernel/driverche hash tabtrole ller/d104pci857egr6 (a194.ko 11
, 8388probe: ERtes, lined nar)insert 0cie_tegra194Inode-c fhe at hasablore eies: 524288 (order: 10, 4194304 binss, mod /lib/earule s/5[ 0.00.140] egra/k auto-inierndrit: s/nck:offvmeeap/host/ ale-core.ko :off, heap free:off
[ modpro.00 ERROR0] : could nre TLB: minsappertvme’: m 0x00000000at err00-0x00000000ff
000] (64MB)
[ 0.00000insMemmodib/module499072.14K/88-tegr248a/kel/vaiverle hermal/tegra/teernel gra-bpmp-423rmal.ko ata
018modprobe:ata744 ERnit: c, 5oul bsd ns, 372032ins ‘tesea_bpmpd, 262_thal’: EK c foreservt error[ 0.000000] SLUB: HWalign=6ins4 , ib/moder=ule, M.15bje.14ctsegr CPUs=6, el/es=1
s/p 0pwm-te0] .koce event prostring ERROR: could not insrif 'pwm_tegra’sabled: E
[ 0rror000
0] rcu: Preemptible hierarcins /lib/al modules/5mentat.14egrionernel/.
0ver.000] rcuwmo: evwm- tr.kong is
modd.
be:[ ER000: c0] : d nRCUinsstrict ‘pfan’: ExeUs froormerrR_CPUS
6 to nr_cpu_ids=6.
[ 0ins000 /lib/modampoli.15var8-tegriana/kernaskdriCU enas/ugadd.
[ 0 'l000ompoTracing te’varian fot ormarroasks RCU ulenaot insd.
bled.
[ 0.000000] rcumod /lib/caluleated valu8-tf sa/kduler-driistvers/usb/elaec/s 1typko jiffie
s.
[ mod.00be: ERRORrcuould not ng geo 'typery Exec for rcu_fmatrorut_leaf=16, nr_cpu_ids=6
[ ins.00000 /lNR_IRQmodS: 64,s/5.15.14 64, pegrreaa/kcatel/ed dris/uirq0
typ 0.00typko 0] GICv3: GIC: modbe:Using split EOI/Deould not te mod ‘ucsi_ccg’:[ 0for.00000 er0] v3:ror 960 SPIs implemented
[ 0.00000mod0] modGICv3:s/5 0 .15end8-tegrs ia/kernemedrinted
ver[ sb/ 0gad0] /udGICc/tegrstrudcibu.kotor has no Rproangele ERROR: cort
d not [ ert ‘t000a_x0] Roo’: RQ c fdler: at errndle_irq
[ 0.000000] GICv3: 16 /lIs modules/5.15ed
8-tegr 0.00ern000netGICv6/v3:6.kU0: fo
und redistributor 0 region 0:0x000000000f440000
[ 0.000000] arch_timer: cp15 timer(s) runningprobe: ERMHz (physould not [ ins000 ‘iclo’: Execksourorm arerrsys_co
unter: mask: 0xffffffffffffmod /lff ib/_cyules/50xe.148-t710a/upda46,/dr maivenvpx_invpdle: 8ko 904
05314 ns
[ 0.000001] schinsclock: /lib/ts at modules/5solution 32n8-tegra/uevepdates/dr804ive651/et108net/nv
a/n 0vet.00her035/nvernConko e: colour dummy device 80x25
[ 0.000418] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=31250)
[ 0.000426] pid_max: default: 32768 minimum: 301
modbe:[ 0: coul050d not inux: ‘sititusb160x’: Ezinernel/dri 0s/u0485] sb/ec/typa: ec.becoming mindful.
fo 0t erro2] Mount-cache hash table entries: 16384 ( /lib/modules/5.15.1410 7ytes, a/ueartes/dr[ ivers/059platfo7] rm/ra/Mou/tegra-mce.ko t-cache hash table entries: 16384 (order: 5, 131072instesmodine /lar a21/[ mod.00ules/5.15rcu.14ieregra/updates/drSRCrs/U ispieme/spntaegrn.
.ko 0378
Tegra Revision: A01 SKU: 213 CPU Process: 0 SoC Process: 0
[ 0.004038] Remapping and enabling EFI services.
[ 0.004831] smp: Bringing up secondary CPUs …
[ 0.005302] Detected PIPT I-cache on CPU1
[ 0.005344] GICv3: CPU1: found redistributor 100 region 0:0x000000000f460000
[ 0.005366] CPU1: Booted secondary processor 0x0000000100 [0x410fd421]
[ 0.005790] Detected PIPT I-cache on CPU2
[ 0.005802] GICv3: CPU2: found redistributor 200 region 0:0x000000000f480000
[ 0.005816] CPU2: Booted secondary processor 0x0000000200 [0x410fd421]
[ 0.006215] Detected PIPT I-cache on CPU3
[ 0.006224] GICv3: CPU3: found redistributor 300 region 0:0x000000000f4a0000
[ 0.006238] CPU3: Booted secondary processor 0x0000000300 [0x410fd421]
[ 0.008697] Detected PIPT I-cache on CPU4
[ 0.008725] GICv3: CPU4: found redistributor 10200 region 0:0x000000000f500000
[ 0.008753] CPU4: Booted secondary processor 0x0000010200 [0x410fd421]
[ 0.009240] Detected PIPT I-cache on CPU5
[ 0.009253] GICv3: CPU5: found redistributor 10300 region 0:0x000000000f520000
[ 0.009268] CPU5: Booted secondary processor 0x0000010300 [0x410fd421]
[ 0.009327] smp: Brought up 1 node, 6 CPUs
[ 0.009331] SMP: Total of 6 processors activated.
[ 0.009335] CPU features: detected: 32-bit EL0 Support
[ 0.009336] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[ 0.009339] CPU features: detected: Common not Private translations
[ 0.009340] CPU features: detected: CRC32 instructions
[ 0.009340] CPU features: detected: Data cache clean to Point of Persistence
[ 0.009342] CPU features: detected: Generic authentication (architected algorithm)
[ 0.009343] CPU features: detected: RCpc load-acquire (LDAPR)
[ 0.009343] CPU features: detected: LSE atomic instructions
[ 0.009345] CPU features: detected: Privileged Access Never
[ 0.009346] CPU features: detected: RAS Extension Support
[ 0.009347] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[ 0.041053] CPU: All CPU(s) started at EL2
[ 0.042340] devtmpfs: initialized
[ 0.053786] KASLR enabled
[ 0.053876] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns
[ 0.053890] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[ 0.056009] pinctrl core: initialized pinctrl subsystem
[ 0.056518] SMBIOS 3.6.0 present.
[ 0.056527] DMI: NVIDIA NVIDIA Jetson Orin NX Engineering Reference Developer Kit/Jetson, BIOS 36.4.4-gcid-41062509 06/16/2025
[ 0.056823] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.057948] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[ 0.058019] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.058075] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.058124] audit: initializing netlink subsys (disabled)
[ 0.058200] audit: type=2000 audit(0.057:1): state=initialized audit_enabled=0 res=1
[ 0.059156] thermal_sys: Registered thermal governor ‘step_wise’
[ 0.059158] thermal_sys: Registered thermal governor ‘user_space’
[ 0.059159] thermal_sys: Registered thermal governor ‘power_allocator’
[ 0.061200] cpuidle: using governor menu
[ 0.061356] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.061420] ASID allocator initialised with 32768 entries
[ 0.062602] Serial: AMBA PL011 UART driver
[ 0.071101] tegra-mc 2c00000.memory-controller: unknown: write @0x0000000050060600: Security violation (TrustZone violation)
[ 0.071716] 31d0000.serial: ttyAMA0 at MMIO 0x31d0000 (irq = 117, base_baud = 0) is a SBSA
[ 0.080958] platform bpmp: Fixing up cyclic dependency with 2c60000.external-memory-controller
[ 0.088643] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.088648] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.088650] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.088652] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.089204] cryptd: max_cpu_qlen set to 1000
[ 0.090299] ACPI: Interpreter disabled.
[ 0.091283] VDD_1V8_AO: supplied by VDD_5V0_SYS
[ 0.091381] VDD_3V3_AO: supplied by VDD_5V0_SYS
[ 0.091543] VDD_AV10_HUB: supplied by VDD_5V0_SYS
[ 0.091897] iommu: Default domain type: Translated
[ 0.091900] iommu: DMA domain TLB invalidation policy: strict mode
[ 0.092093] SCSI subsystem initialized
[ 0.092248] vgaarb: loaded
[ 0.092345] usbcore: registered new interface driver usbfs
[ 0.092360] usbcore: registered new interface driver hub
[ 0.092373] usbcore: registered new device driver usb
[ 0.092765] pps_core: LinuxPPS API ver. 1 registered
[ 0.092768] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 0.092777] PTP clock support registered
[ 0.092841] EDAC MC: Ver: 3.0.0
[ 0.093481] Registered efivars operations
[ 0.093924] FPGA manager framework
[ 0.093986] Advanced Linux Sound Architecture Driver Initialized.
[ 0.094266] Bluetooth: Core ver 2.22
[ 0.094281] NET: Registered PF_BLUETOOTH protocol family
[ 0.094284] Bluetooth: HCI device and connection manager initialized
[ 0.094287] Bluetooth: HCI socket layer initialized
[ 0.094290] Bluetooth: L2CAP socket layer initialized
[ 0.094297] Bluetooth: SCO socket layer initialized
[ 0.094528] clocksource: Switched to clocksource arch_sys_counter
[ 0.118103] VFS: Disk quotas dquot_6.6.0
[ 0.118140] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.118252] pnp: PnP ACPI: disabled
[ 0.120449] NET: Registered PF_INET protocol family
[ 0.120598] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.122064] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)
[ 0.122104] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.122111] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.122190] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[ 0.122801] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.122883] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
[ 0.122907] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear)
[ 0.123000] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.123192] RPC: Registered named UNIX socket transport module.
[ 0.123195] RPC: Registered udp transport module.
[ 0.123196] RPC: Registered tcp transport module.
[ 0.123196] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.123565] PCI: CLS 0 bytes, default 64
[ 0.123684] Unpacking initramfs…
[ 0.131088] hw perfevents: enabled with armv8_cortex_a78 PMU driver, 7 counters available
[ 0.132981] Initialise system trusted keyrings
[ 0.133001] Key type blacklist registered
[ 0.133062] workingset: timestamp_bits=42 max_order=21 bucket_order=0
[ 0.135461] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.135730] NFS: Registering the id_resolver key type
[ 0.135741] Key type id_resolver registered
[ 0.135744] Key type id_legacy registered
[ 0.135780] nfs4filelayout_init: NFSv4 File Layout Driver Registering…
[ 0.135788] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering…
[ 0.135800] ntfs: driver 2.1.32 [Flags: R/O].
[ 0.135956] 9p: Installing v9fs 9p2000 file system support
[ 0.136271] integrity: Platform Keyring initialized
[ 0.150935] Key type asymmetric registered
[ 0.150942] Asymmetric key parser ‘x509’ registered
[ 0.150983] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[ 0.150987] io scheduler mq-deadline registered
[ 0.150989] io scheduler kyber registered
[ 0.161801] EINJ: ACPI disabled.
[ 0.174502] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.176350] SuperH (H)SCI(F) driver initialized
[ 0.176742] msm_serial: driver initialized
[ 0.177474] printk: console [ttyTCU0] enabled
[ 0.178527] arm-smmu 8000000.iommu: probing hardware configuration…
[ 0.178533] arm-smmu 8000000.iommu: SMMUv2 with:
[ 0.178538] arm-smmu 8000000.iommu: stage 1 translation
[ 0.178539] arm-smmu 8000000.iommu: stage 2 translation
[ 0.178540] arm-smmu 8000000.iommu: nested translation
[ 0.178546] arm-smmu 8000000.iommu: stream matching with 128 register groups
[ 0.178550] arm-smmu 8000000.iommu: 128 context banks (0 stage-2 only)
[ 0.178575] arm-smmu 8000000.iommu: Supported page sizes: 0x61311000
[ 0.178579] arm-smmu 8000000.iommu: Stage-1: 48-bit VA → 48-bit IPA
[ 0.178581] arm-smmu 8000000.iommu: Stage-2: 48-bit IPA → 48-bit PA
[ 0.179665] arm-smmu 10000000.iommu: probing hardware configuration…
[ 0.179669] arm-smmu 10000000.iommu: SMMUv2 with:
[ 0.179674] arm-smmu 10000000.iommu: stage 1 translation
[ 0.179676] arm-smmu 10000000.iommu: stage 2 translation
[ 0.179678] arm-smmu 10000000.iommu: nested translation
[ 0.179681] arm-smmu 10000000.iommu: stream matching with 128 register groups
[ 0.179684] arm-smmu 10000000.iommu: 128 context banks (0 stage-2 only)
[ 0.179690] arm-smmu 10000000.iommu: Supported page sizes: 0x61311000
[ 0.179692] arm-smmu 10000000.iommu: Stage-1: 48-bit VA → 48-bit IPA
[ 0.179693] arm-smmu 10000000.iommu: Stage-2: 48-bit IPA → 48-bit PA
[ 0.180119] arm-smmu 12000000.iommu: probing hardware configuration…
[ 0.180123] arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.180125] arm-smmu 12000000.iommu: stage 1 translation
[ 0.180127] arm-smmu 12000000.iommu: stage 2 translation
[ 0.180128] arm-smmu 12000000.iommu: nested translation
[ 0.180133] arm-smmu 12000000.iommu: stream matching with 128 register groups
[ 0.180135] arm-smmu 12000000.iommu: 128 context banks (0 stage-2 only)
[ 0.180139] arm-smmu 12000000.iommu: Supported page sizes: 0x61311000
[ 0.180141] arm-smmu 12000000.iommu: Stage-1: 48-bit VA → 48-bit IPA
[ 0.180142] arm-smmu 12000000.iommu: Stage-2: 48-bit IPA → 48-bit PA
[ 0.187702] loop: module loaded
[ 0.188509] megasas: 07.717.02.00-rc1
[ 0.192754] tun: Universal TUN/TAP device driver, 1.6
[ 0.193386] thunder_xcv, ver 1.0
[ 0.193422] thunder_bgx, ver 1.0
[ 0.193447] nicpf, ver 1.0
[ 0.194346] hclge is initializing
[ 0.194381] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[ 0.194387] hns3: Copyright (c) 2017 Huawei Corporation.
[ 0.194435] e1000: Intel(R) PRO/1000 Network Driver
[ 0.194442] e1000: Copyright (c) 1999-2006 Intel Corporation.
[ 0.194477] e1000e: Intel(R) PRO/1000 Network Driver
[ 0.194480] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 0.194504] igb: Intel(R) Gigabit Ethernet Network Driver
[ 0.194510] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 0.194534] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[ 0.194542] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 0.194760] sky2: driver version 1.30
[ 0.195370] PPP generic driver version 2.4.2
[ 0.195478] PPP BSD Compression module registered
[ 0.195484] PPP Deflate Compression module registered
[ 0.195494] NET: Registered PF_PPPOX protocol family
[ 0.195589] usbcore: registered new interface driver asix
[ 0.195610] usbcore: registered new interface driver ax88179_178a
[ 0.195622] usbcore: registered new interface driver cdc_ether
[ 0.195643] usbcore: registered new interface driver net1080
[ 0.195654] usbcore: registered new interface driver cdc_subset
[ 0.195666] usbcore: registered new interface driver zaurus
[ 0.195738] VFIO - User Level meta-driver version: 0.3
[ 0.197322] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 0.197332] ehci-pci: EHCI PCI platform driver
[ 0.197357] ehci-platform: EHCI generic platform driver
[ 0.197440] ehci-orion: EHCI orion driver
[ 0.197514] ehci-exynos: EHCI Exynos driver
[ 0.197594] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 0.197618] ohci-pci: OHCI PCI platform driver
[ 0.197650] ohci-platform: OHCI generic platform driver
[ 0.197729] ohci-exynos: OHCI Exynos driver
[ 0.198152] usbcore: registered new interface driver usb-storage
[ 0.200294] i2c_dev: i2c /dev entries driver
[ 0.201702] pps pps0: new PPS source ktimer
[ 0.201711] pps pps0: ktimer PPS source registered
[ 0.201720] pps_ldisc: PPS line discipline registered
[ 0.203987] device-mapper: ioctl: 4.45.0-ioctl (2021-03-22) initialised: dm-devel@redhat.com
[ 0.205952] sdhci: Secure Digital Host Controller Interface driver
[ 0.205957] sdhci: Copyright(c) Pierre Ossman
[ 0.206454] Synopsys Designware Multimedia Card Interface Driver
[ 0.207108] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.208270] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.209138] SMCCC: SOC_ID: ID = jep106:036b:0234 Revision = 0x00000401
[ 0.209732] tegra-bpmp bpmp: Adding to iommu group 0
[ 0.211055] tegra-bpmp bpmp: firmware: e941463f35523d12ee54-da583751bbf
[ 0.703727] Freeing initrd memory: 35024K
[ 3.681596] clocksource: tsc: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 3.681626] clocksource: osc: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 49772407460 ns
[ 3.681629] clocksource: usec: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
[ 3.681941] hid: raw HID events driver (C) Jiri Kosina
[ 3.682199] usbcore: registered new interface driver usbhid
[ 3.682205] usbhid: USB HID core driver
[ 3.687301] optee: probing for conduit method.
[ 3.687352] optee: revision 4.2 (d78bc5fa)
[ 3.746667] optee: dynamic shared memory is enabled
[ 3.746929] optee: initialized driver
[ 3.749609] usbcore: registered new interface driver snd-usb-audio
[ 3.751273] NET: Registered PF_PACKET protocol family
[ 3.752443] Bluetooth: RFCOMM TTY layer initialized
[ 3.752454] Bluetooth: RFCOMM socket layer initialized
[ 3.752476] Bluetooth: RFCOMM ver 1.11
[ 3.752747] 9pnet: Installing 9P2000 support
[ 3.752863] Key type dns_resolver registered
[ 3.753911] printk: console [ttyTCU0]: printing thread started
[ 3.753986] Loading compiled-in X.509 certificates
[ 3.757428] Loaded X.509 cert ‘Build time autogenerated kernel key: 398f265b2a58d683d9f7a791a9b8c0e79a14ec86’
[ 3.786695] gpio-433 (Wel_gpio12): hogged as output/high
[ 3.790456] gpio-328 (Wel_gpio03): hogged as output/high
[ 3.790483] gpio-329 (Wel_gpio04): hogged as output/high
[ 3.790500] gpio-330 (Wel_gpio05): hogged as output/high
[ 3.790532] gpio-341 (Wel_gpio10): hogged as output/high
[ 3.790553] gpio-331 (Wel_gpio06): hogged as input
[ 3.792792] tegra-gpcdma 2600000.dma-controller: Adding to iommu group 1
[ 3.795010] tegra-gpcdma 2600000.dma-controller: GPC DMA driver register 31 channels
[ 3.797263] serial-tegra 3100000.serial: RX in PIO mode
[ 3.797268] serial-tegra 3100000.serial: TX in PIO mode
[ 3.797402] 3100000.serial: ttyTHS1 at MMIO 0x3100000 (irq = 112, base_baud = 0) is a TEGRA_UART
[ 3.799402] serial-tegra 3110000.serial: RX in PIO mode
[ 3.799409] serial-tegra 3110000.serial: TX in PIO mode
[ 3.799514] 3110000.serial: ttyTHS2 at MMIO 0x3110000 (irq = 113, base_baud = 0) is a TEGRA_UART
[ 3.804932] tegra_rtc c2a0000.rtc: registered as rtc1
[ 3.804954] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 3.805636] tegra-i2c 3160000.i2c: Adding to iommu group 1
[ 3.813866] tegra-i2c 3180000.i2c: Adding to iommu group 1
[ 3.818499] tegra-i2c 31b0000.i2c: Adding to iommu group 1
[ 3.823803] tegra-i2c c240000.i2c: Adding to iommu group 1
[ 3.835195] rtc-pcf8563 1-0051: registered as rtc0
[ 3.836488] rtc-pcf8563 1-0051: setting system clock to 2026-06-09T09:41:04 UTC (1780998064)
[ 3.838382] i2c 1-0025: Fixing up cyclic dependency with 3520000.padctl
[ 3.839288] tegra-i2c c250000.i2c: Adding to iommu group 1
[ 3.868537] cpufreq: cpufreq_online: CPU4: Running at unlisted initial frequency: 1561000 KHz, changing to: 1510400 KHz
[ 3.872504] tegra-xusb 3610000.usb: Adding to iommu group 2
[ 3.888044] tegra-xusb 3610000.usb: Firmware timestamp: 2023-02-10 03:48:10 UTC
[ 3.888053] tegra-xusb 3610000.usb: xHCI Host Controller
[ 3.888070] tegra-xusb 3610000.usb: new USB bus registered, assigned bus number 1
[ 3.888830] tegra-xusb 3610000.usb: hcc params 0x0180ff05 hci version 0x120 quirks 0x0000000000010810
[ 3.888854] tegra-xusb 3610000.usb: irq 124, io mem 0x03610000
[ 3.888981] tegra-xusb 3610000.usb: xHCI Host Controller
[ 3.888985] tegra-xusb 3610000.usb: new USB bus registered, assigned bus number 2
[ 3.888989] tegra-xusb 3610000.usb: Host supports USB 3.1 Enhanced SuperSpeed
[ 3.889461] hub 1-0:1.0: USB hub found
[ 3.889476] hub 1-0:1.0: 4 ports detected
[ 3.889779] hub 2-0:1.0: USB hub found
[ 3.889791] hub 2-0:1.0: 4 ports detected
[ 3.891372] irq: IRQ228: trimming hierarchy from :bus@0:pmc@c360000
[ 3.891439] irq: IRQ229: trimming hierarchy from :bus@0:interrupt-controller@f400000-1
[ 3.891511] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[ 3.892276] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 3.893203] cfg80211: Loaded X.509 cert ‘sforshee: 00b28ddf47aef9cea7’
[ 3.893422] cfg80211: Loaded X.509 cert ‘wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600’
[ 3.893508] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 3.893513] platform regulatory.0: Falling back to sysfs fallback for: regulatory.db
[ 3.932780] ALSA device list:
[ 3.932784] No soundcards found.
[ 3.938594] Freeing unused kernel memory: 7744K
[ 3.938678] Run /init as init process
[ 3.958414] Root device found: initrd
[ 3.985948] r8168: loading out-of-tree module taints kernel.
[ 3.989064] Mount initrd as rootfs and enter recovery mode
[ 4.010280] phy_tegra194_p2u: disagrees about version of symbol module_layout
[ 4.030218] pcie_tegra194: disagrees about version of symbol module_layout
[ 4.049996] nvme_core: disagrees about version of symbol module_layout
[ 4.069097] tegra_bpmp_thermal: disagrees about version of symbol module_layout
[ 4.087073] pwm_tegra: disagrees about version of symbol module_layout
[ 4.103737] pwm_fan: disagrees about version of symbol module_layout
[ 4.121591] libcomposite: disagrees about version of symbol module_layout
[ 4.139200] typec: disagrees about version of symbol module_layout
[ 4.156090] typec: disagrees about version of symbol module_layout
[ 4.175088] tegra_xudc: disagrees about version of symbol module_layout
[ 4.198399] ipv6: disagrees about version of symbol module_layout
[ 4.211535] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[ 4.252948] typec: disagrees about version of symbol module_layout
[ 4.286512] tegra-qspi 3270000.spi: Adding to iommu group 3
[ 4.287079] tegra-qspi 3270000.spi: Prod config not found for QSPI: -19
[ 4.288241] spi-nor spi0.0: mx25u51279g (65536 Kbytes)
[ 4.343131] hub 1-2:1.0: USB hub found
[ 4.343598] hub 1-2:1.0: 4 ports detected
[ 4.455120] usb 2-1: new SuperSpeed USB device number 2 using tegra-xusb
[ 4.476764] hub 2-1:1.0: USB hub found
[ 4.477529] hub 2-1:1.0: 4 ports detected
[ 4.584530] usb 1-3: new high-speed USB device number 3 using tegra-xusb
[ 4.716044] hub 1-3:1.0: USB hub found
[ 4.716641] hub 1-3:1.0: 4 ports detected
[ 4.778722] usb 1-2.2: new high-speed USB device number 4 using tegra-xusb
[ 4.862778] hub 1-2.2:1.0: USB hub found
[ 4.863379] hub 1-2.2:1.0: 4 ports detected
[ 4.929481] usb 2-1.2: new SuperSpeed USB device number 3 using tegra-xusb
[ 4.952454] hub 2-1.2:1.0: USB hub found
[ 4.953792] hub 2-1.2:1.0: 4 ports detected
[ 5.679531] usb 1-3.1: new high-speed USB device number 6 using tegra-xusb
[ 5.841372] usb 2-1.4: new SuperSpeed USB device number 4 using tegra-xusb
[ 5.933777] usb 1-3.2: new full-speed USB device number 7 using tegra-xusb
[ 6.075344] input: C-Media Electronics Inc. USB Audio Device as /devices/platform/bus@0/3610000.usb/usb1/1-3/1-3.2/1-3.2:1.2/000 3:0D8C:0012.0001/input/input1
[ 6.127319] hid-generic 0003:0D8C:0012.0001: input,hidraw0: USB HID v1.00 Device [C-Media Electronics Inc. USB Audio Device] on usb-3610000.usb-3.2/input2
Connection timeout: device /dev/nvme0n1 is still not ready.
[ 66.528786] cfg80211: failed to load regulatory.db
No known UDC device found
[ 75.412610] ipv6: disagrees about version of symbol module_layout
bash: cannot set terminal process group (-1): Inappropriate ioctl for device
bash: no job control in this shell
bash-5.1# [ 75.429570] ipv6: disagrees about version of symbol module_layout
烧录步骤,哪里有问题
make -C kernel
sudo -E make install -C kernel
cp kernel/kernel-jammy-src/arch/arm64/boot/Image ../kernel/Image
make modules
sudo -E make modules_install
sudo ./tools/l4t_update_initrd.sh
make dtbs
cp kernel-devicetree/generic-dts/dtbs/* ../kernel/dtb/
— 🤖 This is an automated AI response. I’m here to help, but please verify important details! —
根据提供的文档和日志信息,问题出在于烧录步骤中没有正确更新initrd。烧录步骤中提到make -C kernelsudo -E make install -C kernelcp kernel/kernel-jammy-src/arch/arm64/boot/Image ../kernel/Imagemake modulessudo -E make modules_installsudo ./tools/l4t_update_initrd.shmake dtbscp kernel-devicetree/generic-dts/dtbs/* ../kernel/dtb/sudo ./nvsdkmanager_flash.sh --storage nvme0n1p1
但是,根据日志信息,烧录步骤中没有正确更新initrd。日志信息中提到Timeout Device failed to boot to the initrd flash kernel. Please retrive the serial log during flashing to debug further.,这表明烧录步骤中没有正确更新initrd。
解决方法是按照烧录步骤正确更新initrd。具体步骤如下:
  1. 运行sudo ./tools/l4t_update_initrd.sh命令更新initrd。
  2. 确保/Linux_for_Tegra/kernel/dtb目录下有正确的设备树文件。
  3. 确保/Linux_for_Tegra/kernel/Image文件是最新的内核镜像。
  4. 运行sudo ./nvsdkmanager_flash.sh --storage nvme0n1p1命令烧录设备。
注意:确保烧录步骤中所有命令都正确执行,并且没有任何错误信息。
— We support team will also look into your issue to have further suggestions soon. please stay tuned. —
From the serial log, this does not look like an NVMe hardware failure at this point. The stronger indication is that the initrd boot environment has a kernel/module mismatch.
There are several messages like these:
Then the log continues with:
This means the initrd kernel starts, but key modules cannot be loaded. As a result, both the NVMe device and USB device mode / flashing network may fail to come up, and the host side keeps waiting for the target until it times out.
Please first make sure the custom kernel flow uses a consistent set of files from the same Jetson Linux R36.4.4 / JetPack 6.2.1 source release: Image, in-tree modules, NVIDIA out-of-tree modules, DTBs, and initrd. Also make sure the commands below are run from <Linux_for_Tegra>/source.
I suggest doing a clean rebuild and reinstall first:
cd <Linux_for_Tegra>/source
export CROSS_COMPILE=<toolchain-path>/bin/aarch64-buildroot-linux-gnu-
export INSTALL_MOD_PATH=<Linux_for_Tegra>/rootfs/
export KERNEL_HEADERS=$PWD/kernel/kernel-jammy-src
make -C kernel
make modules
make dtbs
Then flash the NVMe again.
Recommendation:
If you want to confirm the hardware and NVMe path first, please try one flash with the original JetPack 6.2.1 BSP without replacing the kernel:
If the original BSP can flash successfully but the custom-kernel BSP fails, then the issue is in the consistency of the custom kernel, modules, and initrd.
Official documentation:
For a modified BSP, you can also refer to the “Bringing Up the Jetson Module for the initrd Flash Tool” section in the flashing guide. That flow separates the image generated from the modified BSP from the original BSP initrd flashing environment.
Hope this helps!
