Hi WayneWWW:
Thanks for you replay!
log file:
boot.txt (87.2 KB)
When I execute sudo ifconfig eth0 up
on the terminal
boot logs:
[ 0.000000] ====Booting Linux on physical CPU 0x0000000000 [0x410fd421]-----4.0 carry board-------!!!
[ 0.000000] Linux version 5.10.65-tegra (aover@jd) (aarch64-buildroot-linux-gnu-gcc.br_real (Buildroot 2020.08) 9.3.0, GNU ld (GNU Binutils) 2.33.1) #42 SMP PREEMPT Sat Aug 13 16:24:08 CST 2022
[ 0.000000] OF: fdt: memory scan node memory@80000000, reg size 16,
[ 0.000000] OF: fdt: - 80000000 , c0000000
[ 0.000000] Machine model: NVIDIA Orin Jetson-Small Developer Kit
[ 0.000000] efi: EFI v2.70 by EDK II
[ 0.000000] efi: RTPROP=0x8548b1118 SMBIOS=0xbabc0000 SMBIOS 3.0=0x853310000 MEMATTR=0x852f4b018 ESRT=0x853269f18 RNG=0x85435ff18 MEMRESERVE=0x852f4cf18
[ 0.000000] efi: seeding entropy pool
[ 0.000000] esrt: Reserving ESRT space from 0x0000000853269f18 to 0x0000000853269f50.
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000086b800000, size 256 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] OF: reserved mem: initialized node fsi-carveout, compatible id nvidia,fsi-carveout
[ 0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal [mem 0x0000000100000000-0x000000087fffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x0000000087ffffff]
[ 0.000000] node 0: [mem 0x0000000088000000-0x00000000b9ccffff]
[ 0.000000] node 0: [mem 0x00000000ba800000-0x00000000ba9affff]
[ 0.000000] node 0: [mem 0x00000000babb0000-0x00000000babcffff]
[ 0.000000] node 0: [mem 0x00000000babd0000-0x00000000babfffff]
[ 0.000000] node 0: [mem 0x00000000c2000000-0x00000000c3ffffff]
[ 0.000000] node 0: [mem 0x0000000100000000-0x000000084fffffff]
[ 0.000000] node 0: [mem 0x0000000850000000-0x0000000851faffff]
[ 0.000000] node 0: [mem 0x0000000851fb0000-0x0000000852d00fff]
[ 0.000000] node 0: [mem 0x0000000852d01000-0x0000000852e62fff]
[ 0.000000] node 0: [mem 0x0000000852e63000-0x0000000852f1ffff]
[ 0.000000] node 0: [mem 0x0000000852f20000-0x0000000852f3ffff]
[ 0.000000] node 0: [mem 0x0000000852f40000-0x000000085317ffff]
[ 0.000000] node 0: [mem 0x0000000853180000-0x000000085319ffff]
[ 0.000000] node 0: [mem 0x00000008531a0000-0x000000085326ffff]
[ 0.000000] node 0: [mem 0x0000000853270000-0x000000085327ffff]
[ 0.000000] node 0: [mem 0x0000000853280000-0x000000085330ffff]
[ 0.000000] node 0: [mem 0x0000000853310000-0x000000085331ffff]
[ 0.000000] node 0: [mem 0x0000000853320000-0x0000000853cfffff]
[ 0.000000] node 0: [mem 0x0000000853d00000-0x0000000853f2ffff]
[ 0.000000] node 0: [mem 0x0000000853f30000-0x0000000853feffff]
[ 0.000000] node 0: [mem 0x0000000853ff0000-0x000000085412ffff]
[ 0.000000] node 0: [mem 0x0000000854130000-0x000000085418ffff]
[ 0.000000] node 0: [mem 0x0000000854190000-0x000000085424ffff]
[ 0.000000] node 0: [mem 0x0000000854250000-0x000000085425ffff]
[ 0.000000] node 0: [mem 0x0000000854260000-0x00000008542fffff]
[ 0.000000] node 0: [mem 0x0000000854300000-0x000000085434ffff]
[ 0.000000] node 0: [mem 0x0000000854350000-0x000000085435ffff]
[ 0.000000] node 0: [mem 0x0000000854360000-0x00000008543affff]
[ 0.000000] node 0: [mem 0x00000008543b0000-0x000000085464ffff]
[ 0.000000] node 0: [mem 0x0000000854650000-0x000000085469ffff]
[ 0.000000] node 0: [mem 0x00000008546a0000-0x000000085473ffff]
[ 0.000000] node 0: [mem 0x0000000854740000-0x000000085485ffff]
[ 0.000000] node 0: [mem 0x0000000854860000-0x00000008548affff]
[ 0.000000] node 0: [mem 0x00000008548b0000-0x000000085493ffff]
[ 0.000000] node 0: [mem 0x0000000854940000-0x000000085498ffff]
[ 0.000000] node 0: [mem 0x0000000854990000-0x00000008549affff]
[ 0.000000] node 0: [mem 0x00000008549b0000-0x0000000854a4ffff]
[ 0.000000] node 0: [mem 0x0000000854a50000-0x0000000854aaffff]
[ 0.000000] node 0: [mem 0x0000000854ab0000-0x0000000854b9ffff]
[ 0.000000] node 0: [mem 0x0000000854ba0000-0x000000085537ffff]
[ 0.000000] node 0: [mem 0x0000000855380000-0x000000085555ffff]
[ 0.000000] node 0: [mem 0x0000000855560000-0x000000087b8bffff]
[ 0.000000] node 0: [mem 0x000000087b8c0000-0x000000087b90ffff]
[ 0.000000] node 0: [mem 0x000000087b910000-0x000000087fffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x000000087fffffff]
[ 0.000000] On node 0 totalpages: 8109776
[ 0.000000] DMA zone: 3836 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 245456 pages, LIFO batch:63
[ 0.000000] Normal zone: 122880 pages used for memmap
[ 0.000000] Normal zone: 7864320 pages, LIFO batch:63
[ 0.000000] On node 0, zone DMA: 304 pages in unavailable ranges
[ 0.000000] On node 0, zone DMA: 80 pages in unavailable ranges
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 31 pages/cpu s90008 r8192 d28776 u126976
[ 0.000000] pcpu-alloc: s90008 r8192 d28776 u126976 alloc=31*4096
[ 0.000000] pcpu-alloc: [0] 00 [0] 01 [0] 02 [0] 03 [0] 04 [0] 05 [0] 06 [0] 07
[ 0.000000] pcpu-alloc: [0] 08 [0] 09 [0] 10 [0] 11
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: Virtualization Host Extensions
[ 0.000000] CPU features: kernel page table isolation disabled by kernel configuration
[ 0.000000] CPU features: detected: Spectre-v4
[ 0.000000] alternatives: patching kernel code
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 7983060
[ 0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 mminit_loglevel=4 console=ttyTCU0,115200 console=tty0 firmware_class.path=/etc/firmware fbcon=map:0 net.ifnames=0 nv-auto-config
[ 0.000000] Dentry cache hash table entries: 4194304 (order: 13, 33554432 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: mapped [mem 0x00000000a9cd0000-0x00000000b9cd0000] (256MB)
[ 0.000000] Memory: 31083492K/32439104K available (18432K kernel code, 3196K rwdata, 7048K rodata, 3904K init, 1071K bss, 1093468K reserved, 262144K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=12, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=12.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=12
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 960 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] GICv3: Distributor has no Range Selector support
[ 0.000000] GICv3: 16 PPIs implemented
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x000000000f440000
[ 0.000000] GICv2m: DT overriding V2M MSI_TYPER (base:608, num:70)
[ 0.000000] GICv2m: range[mem 0x0f410000-0x0f41ffff], SPI[608:677]
[ 0.000000] random: get_random_bytes called from start_kernel+0x378/0x4f4 with crng_init=0
[ 0.000000] arch_timer: cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000002] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.000567] Console: colour dummy device 80x25
[ 0.000783] printk: console [tty0] enabled
[ 0.000819] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[ 0.000831] pid_max: default: 32768 minimum: 301
[ 0.000878] LSM: Security Framework initializing
[ 0.000942] Mount-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.000989] Mountpoint-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.002608] rcu: Hierarchical SRCU implementation.
[ 0.002705] dyndbg: Ignore empty _ddebug table in a CONFIG_DYNAMIC_DEBUG_CORE build
[ 0.003094] DTS File Name: /media/aover/a086076b-427c-483c-be61-4f3fdd0074c7/home/jd/nvdia/nvdia_source_50/kernel/kernel-5.10/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t23x/concord/kernel-dts/tegra234-p3701-0000-p3737-0000.dts
[ 0.003103] DTB Build time: Aug 13 2022 17:20:22
[ 0.004159] Tegra Revision: A01 SKU: 0xd0 CPU Process: 0 SoC Process: 0
[ 0.004274] Remapping and enabling EFI services.
[ 0.005430] smp: Bringing up secondary CPUs ...
[ 0.005819] Detected PIPT I-cache on CPU1
[ 0.005853] GICv3: CPU1: found redistributor 100 region 0:0x000000000f460000
[ 0.005887] CPU1: Booted secondary processor 0x0000000100 [0x410fd421]
[ 0.006239] Detected PIPT I-cache on CPU2
[ 0.006249] GICv3: CPU2: found redistributor 200 region 0:0x000000000f480000
[ 0.006263] CPU2: Booted secondary processor 0x0000000200 [0x410fd421]
[ 0.006578] Detected PIPT I-cache on CPU3
[ 0.006586] GICv3: CPU3: found redistributor 300 region 0:0x000000000f4a0000
[ 0.006601] CPU3: Booted secondary processor 0x0000000300 [0x410fd421]
[ 0.008932] Detected PIPT I-cache on CPU4
[ 0.008955] GICv3: CPU4: found redistributor 10000 region 0:0x000000000f4c0000
[ 0.008981] CPU4: Booted secondary processor 0x0000010000 [0x410fd421]
[ 0.009351] Detected PIPT I-cache on CPU5
[ 0.009362] GICv3: CPU5: found redistributor 10100 region 0:0x000000000f4e0000
[ 0.009375] CPU5: Booted secondary processor 0x0000010100 [0x410fd421]
[ 0.009711] Detected PIPT I-cache on CPU6
[ 0.009722] GICv3: CPU6: found redistributor 10200 region 0:0x000000000f500000
[ 0.009737] CPU6: Booted secondary processor 0x0000010200 [0x410fd421]
[ 0.010088] Detected PIPT I-cache on CPU7
[ 0.010098] GICv3: CPU7: found redistributor 10300 region 0:0x000000000f520000
[ 0.010110] CPU7: Booted secondary processor 0x0000010300 [0x410fd421]
[ 0.012446] Detected PIPT I-cache on CPU8
[ 0.012469] GICv3: CPU8: found redistributor 20000 region 0:0x000000000f540000
[ 0.012495] CPU8: Booted secondary processor 0x0000020000 [0x410fd421]
[ 0.012864] Detected PIPT I-cache on CPU9
[ 0.012874] GICv3: CPU9: found redistributor 20100 region 0:0x000000000f560000
[ 0.012889] CPU9: Booted secondary processor 0x0000020100 [0x410fd421]
[ 0.013233] Detected PIPT I-cache on CPU10
[ 0.013244] GICv3: CPU10: found redistributor 20200 region 0:0x000000000f580000
[ 0.013259] CPU10: Booted secondary processor 0x0000020200 [0x410fd421]
[ 0.013597] Detected PIPT I-cache on CPU11
[ 0.013608] GICv3: CPU11: found redistributor 20300 region 0:0x000000000f5a0000
[ 0.013621] CPU11: Booted secondary processor 0x0000020300 [0x410fd421]
[ 0.013673] smp: Brought up 1 node, 12 CPUs
[ 0.013741] SMP: Total of 12 processors activated.
[ 0.013746] CPU features: detected: Privileged Access Never
[ 0.013749] CPU features: detected: LSE atomic instructions
[ 0.013751] CPU features: detected: User Access Override
[ 0.013754] CPU features: detected: 32-bit EL0 Support
[ 0.013757] CPU features: detected: Common not Private translations
[ 0.013760] CPU features: detected: RAS Extension Support
[ 0.013762] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[ 0.013766] CPU features: detected: CRC32 instructions
[ 0.013768] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[ 0.047374] CPU: All CPU(s) started at EL2
[ 0.049623] devtmpfs: initialized
[ 0.059078] Registered cp15_barrier emulation handler
[ 0.059095] Registered setend emulation handler
[ 0.059101] KASLR enabled
[ 0.059234] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.059247] futex hash table entries: 4096 (order: 6, 262144 bytes, linear)
[ 0.060786] pinctrl core: initialized pinctrl subsystem
[ 0.061224] SMBIOS 3.0.0 present.
[ 0.061231] DMI: /, BIOS r34.1-975eef6 04/06/2022
[ 0.061467] NET: Registered protocol family 16
[ 0.062295] DMA: preallocated 4096 KiB GFP_KERNEL pool for atomic allocations
[ 0.062503] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.062700] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.062759] audit: initializing netlink subsys (disabled)
[ 0.062865] audit: type=2000 audit(0.060:1): state=initialized audit_enabled=0 res=1
[ 0.063476] printk: console [ramoops-1] enabled
[ 0.063483] pstore: Registered ramoops as persistent store backend
[ 0.063489] ramoops: using 0x200000@0xba9b0000, ecc: 0
[ 0.063641] thermal_sys: Registered thermal governor 'step_wise'
[ 0.063642] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.063648] thermal_sys: Registered thermal governor 'pid_thermal_gov'
[ 0.065005] cpuidle: using governor menu
[ 0.065148] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.065264] ASID allocator initialised with 65536 entries
[ 0.065404] Serial: AMBA PL011 UART driver
[ 0.066812] tegra234_mc_sid_probe(): tegra234 mc-sid probe successful
[ 0.066836] Tegra reboot handler registered.
[ 0.066911] DTS File Name: /media/aover/a086076b-427c-483c-be61-4f3fdd0074c7/home/jd/nvdia/nvdia_source_50/kernel/kernel-5.10/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t23x/concord/kernel-dts/tegra234-p3701-0000-p3737-0000.dts
[ 0.066922] DTB Build time: Aug 13 2022 17:20:22
[ 0.081093] mc: mapped MMIO address: 0x(____ptrval____) -> 0x2c10000
[ 0.081113] mc: mapped MMIO address: 0x(____ptrval____) -> 0x2c20000
[ 0.081122] mc: mapped MMIO address: 0x(____ptrval____) -> 0x2c30000
[ 0.081133] mc: mapped MMIO address: 0x(____ptrval____) -> 0x2c40000
[ 0.081144] mc: mapped MMIO address: 0x(____ptrval____) -> 0x2c50000
[ 0.081153] mc: mapped MMIO address: 0x(____ptrval____) -> 0x2b80000
[ 0.081161] mc: mapped MMIO address: 0x(____ptrval____) -> 0x2b90000
[ 0.081170] mc: mapped MMIO address: 0x(____ptrval____) -> 0x2ba0000
[ 0.081178] mc: mapped MMIO address: 0x(____ptrval____) -> 0x2bb0000
[ 0.081187] mc: mapped MMIO address: 0x(____ptrval____) -> 0x1700000
[ 0.081195] mc: mapped MMIO address: 0x(____ptrval____) -> 0x1710000
[ 0.081203] mc: mapped MMIO address: 0x(____ptrval____) -> 0x1720000
[ 0.081211] mc: mapped MMIO address: 0x(____ptrval____) -> 0x1730000
[ 0.081220] mc: mapped MMIO address: 0x(____ptrval____) -> 0x1740000
[ 0.081229] mc: mapped MMIO address: 0x(____ptrval____) -> 0x1750000
[ 0.081237] mc: mapped MMIO address: 0x(____ptrval____) -> 0x1760000
[ 0.081245] mc: mapped MMIO address: 0x(____ptrval____) -> 0x1770000
[ 0.081257] nv-tegra-mc 2c10000.mc: No mssnvlink node
[ 0.081279] mc-err: mcerr ops are set to t23x
[ 0.081597] tegra23x-cbb 13a00000.cbb-en: secure_irq = 21
[ 0.081659] tegra23x-cbb c600000.aon-en: secure_irq = 22
[ 0.081704] tegra23x-cbb de00000.dce-en: secure_irq = 23
[ 0.081741] tegra23x-cbb be00000.rce-en: secure_irq = 24
[ 0.081777] tegra23x-cbb b600000.sce-en: secure_irq = 25
[ 0.085496] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.085512] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.085517] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.085523] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.087079] ACPI: Interpreter disabled.
[ 0.088192] vdd-av1v1-hub: supplied by vdd-5v-sys
[ 0.088305] vbusA-cvb: supplied by vdd-5v-sys
[ 0.088394] vbusB-cvb: supplied by vdd-5v-sys
[ 0.088499] vdd-usbc1-vbus: supplied by vdd-5v-sys
[ 0.088593] vdd-usbc2-vbus: supplied by vdd-5v-sys
[ 0.088878] iommu: Default domain type: Translated
[ 0.088917] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.089083] SCSI subsystem initialized
[ 0.089145] usbcore: registered new interface driver usbfs
[ 0.089160] usbcore: registered new interface driver hub
[ 0.089177] usbcore: registered new device driver usb
[ 0.089344] mc: Linux media interface: v0.10
[ 0.089354] videodev: Linux video capture interface: v2.00
[ 0.089483] pps_core: LinuxPPS API ver. 1 registered
[ 0.089489] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.089498] PTP clock support registered
[ 0.089697] tegra_wdt_t18x 2190000.watchdog: Tegra WDT init timeout = 120 sec
[ 0.089738] tegra_wdt_t18x 2190000.watchdog: Registered successfully
[ 0.091029] Registered efivars operations
[ 0.091466] FPGA manager framework
[ 0.091647] Advanced Linux Sound Architecture Driver Initialized.
[ 0.091903] Bluetooth: Core ver 2.22
[ 0.091920] NET: Registered protocol family 31
[ 0.091927] Bluetooth: HCI device and connection manager initialized
[ 0.091937] Bluetooth: HCI socket layer initialized
[ 0.091945] Bluetooth: L2CAP socket layer initialized
[ 0.091956] Bluetooth: SCO socket layer initialized
[ 0.092489] camchar: rtcpu character device driver loaded
[ 0.092726] clocksource: Switched to clocksource arch_sys_counter
[ 0.243495] VFS: Disk quotas dquot_6.6.0
[ 0.243533] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.243656] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.243914] tegra-carveouts tegra-carveouts: fsi :dma coherent mem declare 0x00000000bf000000,16777216
[ 0.243929] tegra-carveouts tegra-carveouts: assigned reserved memory node fsi-carveout
[ 0.243937] pnp: PnP ACPI: disabled
[ 0.243946] tegra-carveouts tegra-carveouts: vpr :dma coherent mem declare 0x00000000d6000000,704643072
[ 0.243950] nvmap_page_pool_init: Total RAM pages: 7836409
[ 0.243961] nvmap_page_pool_init: nvmap page pool size: 979551 pages (3826 MB)
[ 0.244003] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.244107] misc nvmap: created heap vpr base 0x00000000d6000000 size (688128KiB)
[ 0.245655] la/ptsa driver initialized.
[ 0.245713] NET: Registered protocol family 2
[ 0.245916] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.247673] misc nvmap: created heap fsi base 0x00000000bf000000 size (16384KiB)
[ 0.248147] tcp_listen_portaddr_hash hash table entries: 16384 (order: 6, 262144 bytes, linear)
[ 0.248195] TCP established hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.248406] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[ 0.248868] TCP: Hash tables configured (established 262144 bind 65536)
[ 0.248941] UDP hash table entries: 16384 (order: 7, 524288 bytes, linear)
[ 0.248998] UDP-Lite hash table entries: 16384 (order: 7, 524288 bytes, linear)
[ 0.249123] NET: Registered protocol family 1
[ 0.249419] RPC: Registered named UNIX socket transport module.
[ 0.249431] RPC: Registered udp transport module.
[ 0.249436] RPC: Registered tcp transport module.
[ 0.249440] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.249451] PCI: CLS 0 bytes, default 64
[ 0.249554] Trying to unpack rootfs image as initramfs...
[ 0.358457] Freeing initrd memory: 8196K
[ 0.360250] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.360404] kvm [1]: IPA Size Limit: 48 bits
[ 0.360569] kvm [1]: VHE mode initialized successfully
[ 0.361230] workingset: timestamp_bits=46 max_order=23 bucket_order=0
[ 0.362619] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.362818] NFS: Registering the id_resolver key type
[ 0.362838] Key type id_resolver registered
[ 0.362844] Key type id_legacy registered
[ 0.362872] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.362882] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 0.362897] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.374183] NET: Registered protocol family 38
[ 0.374208] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 239)
[ 0.374266] io scheduler mq-deadline registered
[ 0.374272] io scheduler kyber registered
[ 0.377623] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 0.377649] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 0.377671] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 0.377691] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[ 0.378360] ----|---- [tegra_camera_platform.c]---> tegra_camera_probe!-----by aover--
[ 0.379695] tegra_dc_assign_hw_data: no matching compatible node
[ 0.379702] tegradccommon module_init failed
[ 0.379708] tegradc module_init failed
[ 0.379913] EINJ: ACPI disabled.
[ 0.381091] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 0.381102] tegra-pmc: ### PMC reset source: SYS_RESET_N
[ 0.381110] tegra-pmc: ### PMC reset level: L0
[ 0.381114] tegra-pmc: ### PMC reset status reg: 0x0
[ 0.382144] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.386323] random: fast init done
[ 0.387360] printk: console [ttyTCU0] enabled
[ 2.219611] arm-smmu 12000000.iommu: probing hardware configuration...
[ 2.225532] arm-smmu 12000000.iommu: SMMUv2 with:
[ 2.230274] arm-smmu 12000000.iommu: stage 1 translation
[ 2.235665] arm-smmu 12000000.iommu: stage 2 translation
[ 2.241177] arm-smmu 12000000.iommu: nested translation
[ 2.246340] arm-smmu 12000000.iommu: stream matching with 128 register groups
[ 2.253516] arm-smmu 12000000.iommu: 128 context banks (0 stage-2 only)
[ 2.261737] arm-smmu 12000000.iommu: Supported page sizes: 0x00001000
[ 2.266555] arm-smmu 12000000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
[ 2.273114] arm-smmu 12000000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
[ 2.280232] arm-smmu 10000000.iommu: probing hardware configuration...
[ 2.286152] arm-smmu 10000000.iommu: SMMUv2 with:
[ 2.290875] arm-smmu 10000000.iommu: stage 1 translation
[ 2.296388] arm-smmu 10000000.iommu: stage 2 translation
[ 2.301812] arm-smmu 10000000.iommu: nested translation
[ 2.307239] arm-smmu 10000000.iommu: stream matching with 128 register groups
[ 2.314415] arm-smmu 10000000.iommu: 128 context banks (0 stage-2 only)
[ 2.322696] arm-smmu 10000000.iommu: Supported page sizes: 0x00001000
[ 2.327627] arm-smmu 10000000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
[ 2.334187] arm-smmu 10000000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
[ 2.341117] arm-smmu 8000000.iommu: probing hardware configuration...
[ 2.347314] arm-smmu 8000000.iommu: SMMUv2 with:
[ 2.352040] arm-smmu 8000000.iommu: stage 1 translation
[ 2.357552] arm-smmu 8000000.iommu: stage 2 translation
[ 2.362976] arm-smmu 8000000.iommu: nested translation
[ 2.368138] arm-smmu 8000000.iommu: stream matching with 128 register groups
[ 2.375314] arm-smmu 8000000.iommu: 128 context banks (0 stage-2 only)
[ 2.383588] arm-smmu 8000000.iommu: Supported page sizes: 0x00001000
[ 2.388528] arm-smmu 8000000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
[ 2.395088] arm-smmu 8000000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
[ 2.402159] arm-smmu-suspend 12000000.smmu_suspend: arm_smmu_suspend probe successful
[ 2.411121] tegra_profiler: version: 1.146, samples/io: 49/28
[ 2.415272] tegra_profiler: auth: init
[ 2.420028] tegra23x-qspi 3270000.spi: Adding to iommu group 0
[ 2.425685] libphy: Fixed MDIO Bus: probed
[ 2.429042] tun: Universal TUN/TAP device driver, 1.6
[ 2.434589] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[ 2.441379] hns3: Copyright (c) 2017 Huawei Corporation.
[ 2.446906] e1000e: Intel(R) PRO/1000 Network Driver
[ 2.451701] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 2.457666] igb: Intel(R) Gigabit Ethernet Network Driver
[ 2.463076] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 2.468913] PPP generic driver version 2.4.2
[ 2.473261] PPP BSD Compression module registered
[ 2.477955] PPP Deflate Compression module registered
[ 2.483212] PPP MPPE Compression module registered
[ 2.488033] usbcore: registered new interface driver r8152
[ 2.493359] usbcore: registered new interface driver asix
[ 2.498788] usbcore: registered new interface driver ax88179_178a
[ 2.504912] usbcore: registered new interface driver cdc_ether
[ 2.510859] usbcore: registered new interface driver net1080
[ 2.516457] usbcore: registered new interface driver cdc_subset
[ 2.522493] usbcore: registered new interface driver zaurus
[ 2.528186] usbcore: registered new interface driver cdc_ncm
[ 2.533869] usbcore: registered new interface driver aqc111
[ 2.539385] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 2.545596] ohci-pci: OHCI PCI platform driver
[ 2.549888] ohci-platform: OHCI generic platform driver
[ 2.555200] tegra-xusb 3610000.xhci: Adding to iommu group 1
[ 2.561035] usbcore: registered new interface driver uas
[ 2.566169] usbcore: registered new interface driver usb-storage
[ 2.572127] tegra-xudc 3550000.xudc: Adding to iommu group 2
[ 2.577976] mousedev: PS/2 mouse device common for all mice
[ 2.583319] usbcore: registered new interface driver xpad
[ 2.590560] tegra_rtc c2a0000.rtc: registered as rtc1
[ 2.594081] tegra_rtc c2a0000.rtc: setting system clock to 1970-01-01T00:00:30 UTC (30)
[ 2.601864] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 2.608073] i2c /dev entries driver
[ 2.611654] tegra-i2c 3160000.i2c: Adding to iommu group 3
[ 2.617237] tegra-i2c c240000.i2c: Adding to iommu group 3
[ 2.622635] tegra-i2c 3180000.i2c: Adding to iommu group 3
[ 2.628053] tegra-i2c 3190000.i2c: Adding to iommu group 3
[ 2.633390] tegra-i2c 31b0000.i2c: Adding to iommu group 3
[ 2.638900] tegra-i2c 31c0000.i2c: Adding to iommu group 3
[ 2.644323] tegra-i2c c250000.i2c: Adding to iommu group 3
[ 2.649673] tegra-i2c 31e0000.i2c: Adding to iommu group 3
[ 2.656731] -----|------ CSI [channel.c]----[tegra_channel_init]----by aover ---
[ 2.662490] -----|-----VI [graph.c] ---vi get port info ----by aover---
[ 2.669246] -----|------ CSI [channel.c]----[tegra_channel_init]----by aover ---
[ 2.676662] -----|-----VI [graph.c] ---vi get port info ----by aover---
[ 2.683317] -----|------VI [graph.c]----graph init------by aover ----
[ 2.689878] tegra-camrtc-capture-vi tegra-capture-vi: ep of_device is not enabled endpoint.
[ 2.698276] tegra-camrtc-capture-vi tegra-capture-vi: ep of_device is not enabled endpoint.
[ 2.707399] device-mapper: uevent: version 1.0.3
[ 2.711475] device-mapper: ioctl: 4.43.0-ioctl (2020-10-01) initialised: dm-devel@redhat.com
[ 2.720894] sdhci: Secure Digital Host Controller Interface driver
[ 2.726366] sdhci: Copyright(c) Pierre Ossman
[ 2.730740] Synopsys Designware Multimedia Card Interface Driver
[ 2.736761] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.742746] sdhci-tegra 3460000.sdhci: Adding to iommu group 4
[ 2.742792] sdhci-tegra 3400000.sdhci: Adding to iommu group 5
[ 2.743320] pstore: ignoring unexpected backend 'efi'
[ 2.743585] SMCCC: SOC_ID: ID = jep106:036b:0023 Revision = 0x00000401
[ 2.748557] tegra-bpmp bpmp: firmware: 43f75b5aad2b8e1992e4-f0425a554b3
[ 4.370205] hid: raw HID events driver (C) Jiri Kosina
[ 4.370773] usbcore: registered new interface driver usbhid
[ 4.370960] usbhid: USB HID core driver
[ 4.371288] tegra-dce d800000.dce: Adding to iommu group 6
[ 4.372446] dce: dce_ipc_channel_init:314 Invalid Channel State [0x0] for ch_type [2]
[ 4.373509] tegra234-aon c000000.aon: Adding to iommu group 7
[ 4.373603] dce: dce_wait_boot_complete:100 dce is ready to receive bootstrap commands
[ 4.374609] c000000.aon:hsp: probed
[ 4.374879] tegra234-aon c000000.aon: init done
[ 4.375217] tegra23x-psc e860000.psc: Adding to iommu group 8
[ 4.375657] tegra23x-psc e860000.psc: ext_cfg base:(____ptrval____)
[ 4.375857] tegra23x-psc e860000.psc: init done
[ 4.376129] tegra186-cam-rtcpu bc00000.rtcpu: Adding to iommu group 9
[ 4.376895] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[ 4.378481] dce: dce_mailbox_set_full_interrupt:165 Intr bit set multiple times for MB : [0x5]
[ 4.378790] dce: dce_admin_ipc_handle_signal:119 Spurious signal on channel: [0]. Ignored...
[ 4.379037] dce: dce_admin_send_cmd_ver:424 version : [0x2] err : [0x0]
[ 4.381175] tegra-ivc-bus bc00000.rtcpu:ivc-bus: region 0: iova=0xbfec0000-0xbfee01ff size=131584
[ 4.384533] dce: dce_mailbox_set_full_interrupt:165 Intr bit set multiple times for MB : [0x1]
[ 4.393179] tegra-ivc-bus bc00000.rtcpu:ivc-bus:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 4.401897] dce: dce_admin_setup_clients_ipc:480 Channel Reset Complete for Type [1] ...
[ 4.401900] dce: dce_admin_ipc_handle_signal:119 Spurious signal on channel: [1]. Ignored...
[ 4.401912] dce: dce_admin_ipc_handle_signal:119 Spurious signal on channel: [1]. Ignored...
[ 4.413044] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@1: dbg: ver=0 grp=1 RX[1x448]=0x1900-0x1b40 TX[1x448]=0x1b40-0x1d80
[ 4.421051] dce: dce_admin_setup_clients_ipc:456 Get queue info failed for [2]
[ 4.421414] dce: dce_mailbox_set_full_interrupt:165 Intr bit set multiple times for MB : [0x2]
[ 4.430501] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1d80-0x3e00 TX[1x8192]=0x3e00-0x5e80
[ 4.438211] dce: dce_admin_setup_clients_ipc:480 Channel Reset Complete for Type [3] ...
[ 4.438212] dce: dce_admin_ipc_handle_signal:119 Spurious signal on channel: [3]. Ignored...
[ 4.438224] dce: dce_admin_ipc_handle_signal:119 Spurious signal on channel: [3]. Ignored...
[ 4.449532] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5e80-0xaf00 TX[64x320]=0xaf00-0xff80
[ 4.456601] dce: dce_worker:209 DCE_BOOT_DONE
[ 4.465368] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0xff80-0x18000 TX[512x64]=0x18000-0x20080
[ 4.485128] random: crng init done
[ 4.493089] tegra-ivc-bus bc00000.rtcpu:ivc-bus:diag@5: diag: ver=0 grp=1 RX[1x64]=0x20080-0x20140 TX[1x64]=0x20140-0x20200
[ 4.546613] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (114)
[ 4.552484] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
[ 4.562797] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=6 sha1=e4da4cf5a29dccddc6d8f65bbd5202381ca3db13
[ 4.573286] t19x_cache tegra-cache: probed
[ 4.575847] scf-pmu-drv scf-pmu: Registered T23x SCF Uncore PMU
[ 4.604378] nvpmodel: initialized successfully
[ 4.604809] tegra_hv: get_hvd: not initialized yet
[ 4.604948] user_ivc_mempool: hypervisor not present
[ 4.605868] usbcore: registered new interface driver snd-usb-audio
[ 4.606711] u32 classifier
[ 4.606786] input device check on
[ 4.608746] Actions configured
[ 4.612178] Initializing XFRM netlink socket
[ 4.616864] NET: Registered protocol family 10
[ 4.622038] Segment Routing with IPv6
[ 4.624526] NET: Registered protocol family 17
[ 4.628809] NET: Registered protocol family 15
[ 4.633295] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 4.646655] Bluetooth: RFCOMM socket layer initialized
[ 4.651295] Bluetooth: RFCOMM ver 1.11
[ 4.655212] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 4.661074] Bluetooth: HIDP socket layer initialized
[ 4.666769] 9pnet: Installing 9P2000 support
[ 4.670479] Key type dns_resolver registered
[ 4.675593] registered taskstats version 1
[ 4.679238] pstore: Using crash dump compression: deflate
[ 4.684512] tegra194-pcie 14100000.pcie: Adding to iommu group 10
[ 4.696048] tegra194-pcie 14100000.pcie: Using GICv2m MSI allocator
[ 4.697436] tegra194-pcie 14160000.pcie: Adding to iommu group 11
[ 4.708333] tegra194-pcie 14160000.pcie: Using GICv2m MSI allocator
[ 4.709747] tegra194-pcie 141a0000.pcie: Adding to iommu group 12
[ 4.720533] tegra194-pcie 141a0000.pcie: Using GICv2m MSI allocator
[ 4.722037] tegra194-pcie 141a0000.pcie: Failed to get slot regulators: -517
[ 4.741944] tegra-gpcdma 2600000.gpcdma: Adding to iommu group 3
[ 4.743427] tegra-gpcdma 2600000.gpcdma: GPC DMA driver register 31 channels
[ 4.743791] host1x 13e40000.host1x: Adding to iommu group 13
[ 5.758909] t23x_init_gating_regs: Timed out waiting for syncpt ram init!
[ 5.769332] host1x 13e40000.host1x: initialized
[ 5.769770] iommu_context_dev 13e40000.host1x:niso0_ctx0: Adding to iommu group 14
[ 5.770225] iommu_context_dev 13e40000.host1x:niso0_ctx0: initialized (streamid=53, iommu=smmu.0x0000000012000000)
[ 5.771818] iommu_context_dev 13e40000.host1x:niso0_ctx1: Adding to iommu group 15
[ 5.772242] iommu_context_dev 13e40000.host1x:niso0_ctx1: initialized (streamid=54, iommu=smmu.0x0000000012000000)
[ 5.773791] iommu_context_dev 13e40000.host1x:niso0_ctx2: Adding to iommu group 16
[ 5.774219] iommu_context_dev 13e40000.host1x:niso0_ctx2: initialized (streamid=55, iommu=smmu.0x0000000012000000)
[ 5.775745] iommu_context_dev 13e40000.host1x:niso0_ctx3: Adding to iommu group 17
[ 5.776168] iommu_context_dev 13e40000.host1x:niso0_ctx3: initialized (streamid=56, iommu=smmu.0x0000000012000000)
[ 5.777709] iommu_context_dev 13e40000.host1x:niso0_ctx4: Adding to iommu group 18
[ 5.778110] iommu_context_dev 13e40000.host1x:niso0_ctx4: initialized (streamid=57, iommu=smmu.0x0000000012000000)
[ 5.779637] iommu_context_dev 13e40000.host1x:niso0_ctx5: Adding to iommu group 19
[ 5.780035] iommu_context_dev 13e40000.host1x:niso0_ctx5: initialized (streamid=58, iommu=smmu.0x0000000012000000)
[ 5.791388] iommu_context_dev 13e40000.host1x:niso0_ctx6: Adding to iommu group 20
[ 5.797931] iommu_context_dev 13e40000.host1x:niso0_ctx6: initialized (streamid=59, iommu=smmu.0x0000000012000000)
[ 5.809420] iommu_context_dev 13e40000.host1x:niso0_ctx7: Adding to iommu group 21
[ 5.815995] iommu_context_dev 13e40000.host1x:niso0_ctx7: initialized (streamid=60, iommu=smmu.0x0000000012000000)
[ 5.827462] iommu_context_dev 13e40000.host1x:niso1_ctx0: Adding to iommu group 22
[ 5.834006] iommu_context_dev 13e40000.host1x:niso1_ctx0: initialized (streamid=53, iommu=smmu.0x0000000008000000)
[ 5.845464] iommu_context_dev 13e40000.host1x:niso1_ctx1: Adding to iommu group 23
[ 5.852027] iommu_context_dev 13e40000.host1x:niso1_ctx1: initialized (streamid=54, iommu=smmu.0x0000000008000000)
[ 5.863481] iommu_context_dev 13e40000.host1x:niso1_ctx2: Adding to iommu group 24
[ 5.870070] iommu_context_dev 13e40000.host1x:niso1_ctx2: initialized (streamid=55, iommu=smmu.0x0000000008000000)
[ 5.881542] iommu_context_dev 13e40000.host1x:niso1_ctx3: Adding to iommu group 25
[ 5.888064] iommu_context_dev 13e40000.host1x:niso1_ctx3: initialized (streamid=56, iommu=smmu.0x0000000008000000)
[ 5.899529] iommu_context_dev 13e40000.host1x:niso1_ctx4: Adding to iommu group 26
[ 5.906086] iommu_context_dev 13e40000.host1x:niso1_ctx4: initialized (streamid=57, iommu=smmu.0x0000000008000000)
[ 5.917560] iommu_context_dev 13e40000.host1x:niso1_ctx5: Adding to iommu group 27
[ 5.924129] iommu_context_dev 13e40000.host1x:niso1_ctx5: initialized (streamid=58, iommu=smmu.0x0000000008000000)
[ 5.935599] iommu_context_dev 13e40000.host1x:niso1_ctx6: Adding to iommu group 28
[ 5.942137] iommu_context_dev 13e40000.host1x:niso1_ctx6: initialized (streamid=59, iommu=smmu.0x0000000008000000)
[ 5.953633] iommu_context_dev 13e40000.host1x:niso1_ctx7: Adding to iommu group 29
[ 5.960168] iommu_context_dev 13e40000.host1x:niso1_ctx7: initialized (streamid=60, iommu=smmu.0x0000000008000000)
[ 5.971662] falcon 15340000.vic: Adding to iommu group 30
[ 5.983285] falcon 15340000.vic: initialized
[ 5.983629] falcon 15380000.nvjpg: Adding to iommu group 31
[ 5.990536] falcon 15380000.nvjpg: initialized
[ 5.990765] falcon 15540000.nvjpg1: Adding to iommu group 32
[ 6.000903] falcon 15540000.nvjpg1: initialized
[ 6.001140] falcon 154c0000.nvenc: Adding to iommu group 33
[ 6.013943] falcon 154c0000.nvenc: initialized
[ 6.014162] falcon 15a50000.ofa: Adding to iommu group 34
[ 6.021529] falcon 15a50000.ofa: initialized
[ 6.021762] nvdec 15480000.nvdec: Adding to iommu group 35
[ 6.038534] nvdec 15480000.nvdec: initialized
[ 6.038750] tsec 15500000.tsec: Adding to iommu group 36
[ 6.046874] tsec 15500000.tsec: initialized
[ 6.048876] gic 2a41000.agic-controller: GIC IRQ controller registered
[ 6.055022] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[ 6.061504] gpio-394 (camera-control-output-low): hogged as output/low
[ 6.061698] gpio-397 (camera-control-output-low): hogged as output/low
[ 6.066892] gpio-487 (camera-control-output-low): hogged as output/low
[ 6.073099] gpio-486 (camera-control-output-low): hogged as output/low
[ 6.080488] gpiochip0: registered GPIOs 348 to 511 on tegra234-gpio
[ 6.086555] gpiochip1: registered GPIOs 316 to 347 on tegra234-gpio-aon
[ 6.092645] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 6.098772] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 6.104386] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 6.109986] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[ 6.116966] ----|---- [tegra_camera_platform.c]---> tegra_camera_probe!-----by aover--
[ 6.123665] misc tegra_camera_ctrl: tegra_camera_isomgr_register tpg_max_iso = 3916800KBs
[ 6.131822] tegra194-isp5 14800000.isp: Adding to iommu group 37
[ 6.140146] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: context isolation disabled due to no IOMMU
[ 6.147057] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: initialized
[ 6.152985] -----|------CSI [csi.c]---[tegra_csi_media_controller_init]---by aover---
[ 6.160940] -----|----- CSI [csi.c]---[csi_parse_dt]-----by aover ---
[ 6.167333] -----|----- CSI [csi.c]--get_port_info----by aover---
[ 6.173467] -----|----- CSI [csi.c]--get_port_info----by aover---
[ 6.179598] -----[v4l2-async.c]->[v4l2_async_register_subdev]->[begin] reslut:[0]---AOVER!!
[ 6.188064] -----[v4l2-async.c]->[v4l2_async_register_subdev]->[begin] 111111---AOVER!!
[ 6.196114] -----[v4l2-async.c]->[v4l2_async_register_subdev]->[begin] 222222---AOVER!!
[ 6.204077] -----[v4l2-async.c]->[v4l2_async_register_subdev]->[begin] 333333---AOVER!!
[ 6.212214] -----[v4l2-async.c]->[v4l2_async_register_subdev]->[begin] LOOP END---AOVER!!
[ 6.220527] -----[v4l2-async.c]->[v4l2_async_register_subdev]->[begin] out_unlock---AOVER!!
[ 6.229014] -----[v4l2-async.c]->[v4l2_async_register_subdev]->[begin] reslut:[0]---AOVER!!
[ 6.237678] -----[v4l2-async.c]->[v4l2_async_register_subdev]->[begin] 111111---AOVER!!
[ 6.245641] -----[v4l2-async.c]->[v4l2_async_register_subdev]->[begin] 222222---AOVER!!
[ 6.253777] -----[v4l2-async.c]->[v4l2_async_register_subdev]->[begin] 333333---AOVER!!
[ 6.261741] -----[v4l2-async.c]->[v4l2_async_register_subdev]->[begin] LOOP END---AOVER!!
[ 6.270141] -----[v4l2-async.c]->[v4l2_async_register_subdev]->[begin] out_unlock---AOVER!!
[ 6.278941] tegra194-vi5 13e40000.host1x:vi0@15c00000: Adding to iommu group 38
[ 6.286593] tegra194-vi5 13e40000.host1x:vi1@14c00000: Adding to iommu group 39
[ 6.293787] scare-pigeon 13e40000.host1x:vi0-thi@15f00000: context isolation disabled due to no IOMMU
[ 6.303097] scare-pigeon 13e40000.host1x:vi0-thi@15f00000: initialized
[ 6.309088] scare-pigeon 13e40000.host1x:vi0-thi@15f00000: grid-of-semaphores not supported
[ 6.317542] scare-pigeon 13e40000.host1x:vi1-thi@14f00000: context isolation disabled due to no IOMMU
[ 6.327282] scare-pigeon 13e40000.host1x:vi1-thi@14f00000: initialized
[ 6.333496] scare-pigeon 13e40000.host1x:vi1-thi@14f00000: grid-of-semaphores not supported
[ 6.341858] scare-pigeon 13e40000.host1x:isp-thi@14b00000: context isolation disabled due to no IOMMU
[ 6.351432] scare-pigeon 13e40000.host1x:isp-thi@14b00000: initialized
[ 6.357651] scare-pigeon 13e40000.host1x:isp-thi@14b00000: grid-of-semaphores not supported
[ 6.366141] pva 16000000.pva0: Adding to iommu group 40
[ 6.389791] pva 16000000.pva0: initialized
[ 6.394699] nvdla 15880000.nvdla0: Adding to iommu group 41
[ 6.404092] nvdla 15880000.nvdla0: initialized
[ 6.405778] nvdla 158c0000.nvdla1: Adding to iommu group 42
[ 6.414831] nvdla 158c0000.nvdla1: initialized
[ 6.416516] tegra-fuse-burn efuse-burn: shutdown limit check disabled
[ 6.416690] tegra-fuse-burn efuse-burn: Fuse burn driver initialized
[ 6.417045] serial-tegra 3100000.serial: Adding to iommu group 3
[ 6.418514] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 13, base_baud = 0) is a TEGRA_UART
[ 6.424150] serial-tegra 3130000.serial: Adding to iommu group 3
[ 6.429845] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 63, base_baud = 0) is a TEGRA_UART
[ 6.461939] tegra-xusb 3610000.xhci: Firmware timestamp: 2021-12-01 05:27:10 UTC, Version: 80.03 release
[ 6.462209] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 6.462375] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 1
[ 6.463360] tegra-xusb 3610000.xhci: hcc params 0x0180ff05 hci version 0x120 quirks 0x0000000000050810
[ 6.470281] tegra-xusb 3610000.xhci: irq 231, io mem 0x03610000
[ 6.476396] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 6.484516] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 6.491691] usb usb1: Product: xHCI Host Controller
[ 6.496675] usb usb1: Manufacturer: Linux 5.10.65-tegra xhci-hcd
[ 6.502714] usb usb1: SerialNumber: 3610000.xhci
[ 6.507825] hub 1-0:1.0: USB hub found
[ 6.511226] hub 1-0:1.0: 4 ports detected
[ 6.515403] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 6.520659] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 2
[ 6.528274] tegra-xusb 3610000.xhci: Host supports USB 3.1 Enhanced SuperSpeed
[ 6.535678] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[ 6.543849] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 6.551102] usb usb2: Product: xHCI Host Controller
[ 6.556088] usb usb2: Manufacturer: Linux 5.10.65-tegra xhci-hcd
[ 6.562040] usb usb2: SerialNumber: 3610000.xhci
[ 6.567362] hub 2-0:1.0: USB hub found
[ 6.570645] hub 2-0:1.0: 4 ports detected
[ 6.575638] bwmgr API not supported
[ 6.575642] tegra-xusb 3610000.xhci: can't register EMC bwmgr (-22)
[ 6.584785] tegra-xudc 3550000.xudc: failed to get usbphy-0: -517
[ 6.614963] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 2009000 KHz, changing to: 2035200 KHz
[ 6.617659] cpufreq: cpufreq_online: CPU4: Running at unlisted initial frequency: 2006000 KHz, changing to: 2035200 KHz
[ 6.620998] cpufreq: cpufreq_online: CPU8: Running at unlisted initial frequency: 2010000 KHz, changing to: 2035200 KHz
[ 6.627221] tegra194-pcie 14100000.pcie: Using GICv2m MSI allocator
[ 6.628680] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 6.630615] tegra194-pcie 14100000.pcie: host bridge /pcie@14100000 ranges:
[ 6.634597] mmc0: CQHCI version 5.10
[ 6.641234] tegra194-pcie 14100000.pcie: IO 0x0030100000..0x00301fffff -> 0x0030100000
[ 6.641238] tegra194-pcie 14100000.pcie: MEM 0x20a8000000..0x20afffffff -> 0x0040000000
[ 6.653245] irq: IRQ289: trimming hierarchy from :pmc@c360000
[ 6.653388] tegra194-pcie 14100000.pcie: MEM 0x2080000000..0x20a7ffffff -> 0x2080000000
[ 6.661908] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 289
[ 6.672853] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit
[ 6.772722] usb 1-3: new full-speed USB device number 2 using tegra-xusb
[ 6.772728] tegra194-pcie 14100000.pcie: Link up
[ 6.773973] tegra194-pcie 14100000.pcie: PCI host bridge to bus 0001:00
[ 6.774157] pci_bus 0001:00: root bus resource [bus 00-ff]
[ 6.774298] pci_bus 0001:00: root bus resource [io 0x0000-0xfffff] (bus address [0x30100000-0x301fffff])
[ 6.774547] pci_bus 0001:00: root bus resource [mem 0x20a8000000-0x20afffffff] (bus address [0x40000000-0x47ffffff])
[ 6.774828] pci_bus 0001:00: root bus resource [mem 0x2080000000-0x20a7ffffff pref]
[ 6.775066] pci 0001:00:00.0: [10de:229e] type 01 class 0x060400
[ 6.775333] pci 0001:00:00.0: PME# supported from D0 D3hot
[ 6.778103] mmc0: Command Queue Engine enabled
[ 6.778223] mmc0: periodic cache flush enabled
[ 6.778340] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[ 6.778639] pci 0001:01:00.0: [10ec:c822] type 00 class 0x028000
[ 6.778905] pci 0001:01:00.0: reg 0x10: [io 0x0000-0x00ff]
[ 6.778997] mmcblk0: mmc0:0001 G1M15M 59.3 GiB
[ 6.779867] pci 0001:01:00.0: reg 0x18: [mem 0x20a8000000-0x20a800ffff 64bit]
[ 6.784646] mmcblk0rpmb: mmc0:0001 G1M15M partition 3 4.00 MiB, chardev (510:0)
[ 6.792457] pci 0001:01:00.0: supports D1 D2
[ 6.803361] pci 0001:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 6.808327] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11
[ 6.813133] pci 0001:00:00.0: BAR 14: assigned [mem 0x20a8000000-0x20a80fffff]
[ 6.822877] pci 0001:00:00.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 6.829176] pci 0001:01:00.0: BAR 2: assigned [mem 0x20a8000000-0x20a800ffff 64bit]
[ 6.836943] pci 0001:01:00.0: BAR 0: assigned [io 0x1000-0x10ff]
[ 6.843195] pci 0001:00:00.0: PCI bridge to [bus 01-ff]
[ 6.848249] pci 0001:00:00.0: bridge window [io 0x1000-0x1fff]
[ 6.854377] pci 0001:00:00.0: bridge window [mem 0x20a8000000-0x20a80fffff]
[ 6.861559] pci 0001:00:00.0: Max Payload Size set to 128/ 256 (was 256), Max Read Rq 512
[ 6.870083] pci 0001:01:00.0: Max Payload Size set to 128/ 128 (was 128), Max Read Rq 512
[ 6.878725] pcieport 0001:00:00.0: Adding to iommu group 10
[ 6.884291] pcieport 0001:00:00.0: PME: Signaling with IRQ 50
[ 6.890146] pcieport 0001:00:00.0: AER: enabled with IRQ 50
[ 6.896297] tegra194-pcie 14160000.pcie: Using GICv2m MSI allocator
[ 6.902828] tegra194-pcie 14160000.pcie: host bridge /pcie@14160000 ranges:
[ 6.908544] tegra194-pcie 14160000.pcie: IO 0x0036100000..0x00361fffff -> 0x0036100000
[ 6.917205] tegra194-pcie 14160000.pcie: MEM 0x2428000000..0x242fffffff -> 0x0040000000
[ 6.925687] tegra194-pcie 14160000.pcie: MEM 0x2140000000..0x2427ffffff -> 0x2140000000
[ 6.933052] usb 1-3: New USB device found, idVendor=13d3, idProduct=3549, bcdDevice= 0.00
[ 6.942408] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 6.949576] usb 1-3: Product: Bluetooth Radio
[ 6.953863] usb 1-3: Manufacturer: Realtek
[ 6.958062] usb 1-3: SerialNumber: 00e04c000001
[ 7.057911] usb 2-3: new SuperSpeedPlus Gen 2 USB device number 2 using tegra-xusb
[ 7.096682] usb 2-3: New USB device found, idVendor=0bda, idProduct=0420, bcdDevice= 1.40
[ 7.096968] usb 2-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 7.097206] usb 2-3: Product: 4-Port USB 3.0 Hub
[ 7.097358] usb 2-3: Manufacturer: Generic
[ 7.107392] hub 2-3:1.0: USB hub found
[ 7.109298] hub 2-3:1.0: 4 ports detected
[ 7.212724] usb 1-4: new high-speed USB device number 3 using tegra-xusb
[ 7.381295] usb 1-4: New USB device found, idVendor=0bda, idProduct=5420, bcdDevice= 1.40
[ 7.381537] usb 1-4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 7.381742] usb 1-4: Product: 4-Port USB 2.0 Hub
[ 7.381879] usb 1-4: Manufacturer: Generic
[ 7.383272] hub 1-4:1.0: USB hub found
[ 7.384679] hub 1-4:1.0: 4 ports detected
[ 7.837417] usb 2-3.1: new SuperSpeed Gen 1 USB device number 3 using tegra-xusb
[ 7.960084] usb 2-3.1: New USB device found, idVendor=0951, idProduct=1666, bcdDevice= 1.00
[ 7.960321] usb 2-3.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 7.960523] usb 2-3.1: Product: DataTraveler 3.0
[ 7.960662] usb 2-3.1: Manufacturer: Kingston
[ 7.960795] usb 2-3.1: SerialNumber: 60A44C3FABFFBF11096C015D
[ 7.962760] usb-storage 2-3.1:1.0: USB Mass Storage device detected
[ 7.963963] scsi host0: usb-storage 2-3.1:1.0
[ 8.050167] tegra194-pcie 14160000.pcie: Phy link never came up
[ 8.050389] tegra194-pcie 14160000.pcie: PCI host bridge to bus 0004:00
[ 8.050574] pci_bus 0004:00: root bus resource [bus 00-ff]
[ 8.050733] pci_bus 0004:00: root bus resource [io 0x100000-0x1fffff] (bus address [0x36100000-0x361fffff])
[ 8.051020] pci_bus 0004:00: root bus resource [mem 0x2428000000-0x242fffffff] (bus address [0x40000000-0x47ffffff])
[ 8.051315] pci_bus 0004:00: root bus resource [mem 0x2140000000-0x2427ffffff pref]
[ 8.051566] pci 0004:00:00.0: [10de:229c] type 01 class 0x060400
[ 8.051833] pci 0004:00:00.0: PME# supported from D0 D3hot
[ 8.057451] pci 0004:00:00.0: PCI bridge to [bus 01-ff]
[ 8.057602] pci 0004:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 8.058030] pcieport 0004:00:00.0: Adding to iommu group 11
[ 8.058331] pcieport 0004:00:00.0: PME: Signaling with IRQ 52
[ 8.058817] pcieport 0004:00:00.0: AER: enabled with IRQ 52
[ 8.059131] pci_bus 0004:01: busn_res: [bus 01-ff] is released
[ 8.059355] pci 0004:00:00.0: Removing from iommu group 11
[ 8.059509] pci_bus 0004:00: busn_res: [bus 00-ff] is released
[ 8.066036] tegra194-pcie 141a0000.pcie: Using GICv2m MSI allocator
[ 8.071045] tegra194-pcie 141a0000.pcie: Failed to get slot regulators: -517
[ 8.071112] vdd-3v3-pcie: supplied by vdd-3v3-sys
[ 8.075720] avdd-cam-2v8: supplied by vdd-3v3-sys
[ 8.080366] vdd-dp: supplied by vdd-3v3-sys
[ 8.084579] vdd-3v3-sd: supplied by vdd-3v3-sys
[ 8.088722] usb 1-4.4: new high-speed USB device number 4 using tegra-xusb
[ 8.089517] dsi-vdd-1v8-bl-en: supplied by vdd-1v8-sys
[ 8.103118] tegra194-isp5 14800000.isp: initialized
[ 8.109875] tegra194-vi5 13e40000.host1x:vi0@15c00000: initialized
[ 8.112552] (NULL device *): fops function table already registered
[ 8.119354] tegra194-vi5 13e40000.host1x:vi1@14c00000: initialized
[ 8.124900] tegra-xudc 3550000.xudc: failed to get usbphy-0: -517
[ 8.131226] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 8.135892] tegra194-pcie 141a0000.pcie: Using GICv2m MSI allocator
[ 8.149162] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 289
[ 8.199910] usb 1-4.4: New USB device found, idVendor=214b, idProduct=7250, bcdDevice= 1.00
[ 8.200126] usb 1-4.4: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 8.200310] usb 1-4.4: Product: USB2.0 HUB
[ 8.202183] hub 1-4.4:1.0: USB hub found
[ 8.202904] hub 1-4.4:1.0: 4 ports detected
[ 8.249755] tegra194-pcie 141a0000.pcie: host bridge /pcie@141a0000 ranges:
[ 8.249957] tegra194-pcie 141a0000.pcie: IO 0x003a100000..0x003a1fffff -> 0x003a100000
[ 8.250188] tegra194-pcie 141a0000.pcie: MEM 0x2b28000000..0x2b2fffffff -> 0x0040000000
[ 8.250415] tegra194-pcie 141a0000.pcie: MEM 0x2740000000..0x2b27ffffff -> 0x2740000000
[ 8.496854] usb 1-4.4.1: new full-speed USB device number 5 using tegra-xusb
[ 8.620774] usb 1-4.4.1: New USB device found, idVendor=3151, idProduct=3020, bcdDevice= 0.02
[ 8.621016] usb 1-4.4.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 8.621227] usb 1-4.4.1: Product: Wireless Device
[ 8.621362] usb 1-4.4.1: Manufacturer: YICHIP
[ 8.630209] input: YICHIP Wireless Device as /devices/platform/3610000.xhci/usb1/1-4/1-4.4/1-4.4.1/1-4.4.1:1.0/0003:3151:3020.0001/input/input0
[ 8.689312] hid-generic 0003:3151:3020.0001: input,hidraw0: USB HID v2.00 Keyboard [YICHIP Wireless Device] on usb-3610000.xhci-4.4.1/input0
[ 8.704355] input: YICHIP Wireless Device Mouse as /devices/platform/3610000.xhci/usb1/1-4/1-4.4/1-4.4.1/1-4.4.1:1.1/0003:3151:3020.0002/input/input1
[ 8.705390] input: YICHIP Wireless Device System Control as /devices/platform/3610000.xhci/usb1/1-4/1-4.4/1-4.4.1/1-4.4.1:1.1/0003:3151:3020.0002/input/input2
[ 8.765070] input: YICHIP Wireless Device Consumer Control as /devices/platform/3610000.xhci/usb1/1-4/1-4.4/1-4.4.1/1-4.4.1:1.1/0003:3151:3020.0002/input/input3
[ 8.765556] hid-generic 0003:3151:3020.0002: input,hiddev96,hidraw1: USB HID v2.00 Mouse [YICHIP Wireless Device] on usb-3610000.xhci-4.4.1/input1
[ 8.844852] usb 1-4.4.4: new full-speed USB device number 6 using tegra-xusb
[ 8.952427] usb 1-4.4.4: New USB device found, idVendor=25a7, idProduct=fa23, bcdDevice= 2.41
[ 8.952670] usb 1-4.4.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 8.952885] usb 1-4.4.4: Product: 2.4G Receiver
[ 8.953020] usb 1-4.4.4: Manufacturer: Compx
[ 8.958539] input: Compx 2.4G Receiver as /devices/platform/3610000.xhci/usb1/1-4/1-4.4/1-4.4.4/1-4.4.4:1.0/0003:25A7:FA23.0003/input/input5
[ 9.017304] hid-generic 0003:25A7:FA23.0003: input,hidraw2: USB HID v1.10 Keyboard [Compx 2.4G Receiver] on usb-3610000.xhci-4.4.4/input0
[ 9.021856] input: Compx 2.4G Receiver Mouse as /devices/platform/3610000.xhci/usb1/1-4/1-4.4/1-4.4.4/1-4.4.4:1.1/0003:25A7:FA23.0004/input/input6
[ 9.022676] input: Compx 2.4G Receiver as /devices/platform/3610000.xhci/usb1/1-4/1-4.4/1-4.4.4/1-4.4.4:1.1/0003:25A7:FA23.0004/input/input7
[ 9.023188] input: Compx 2.4G Receiver Consumer Control as /devices/platform/3610000.xhci/usb1/1-4/1-4.4/1-4.4.4/1-4.4.4:1.1/0003:25A7:FA23.0004/input/input8
[ 9.054467] scsi 0:0:0:0: Direct-Access Kingston DataTraveler 3.0 PMAP PQ: 0 ANSI: 6
[ 9.081258] input: Compx 2.4G Receiver System Control as /devices/platform/3610000.xhci/usb1/1-4/1-4.4/1-4.4.4/1-4.4.4:1.1/0003:25A7:FA23.0004/input/input9
[ 9.082763] hid-generic 0003:25A7:FA23.0004: input,hiddev97,hidraw3: USB HID v1.10 Mouse [Compx 2.4G Receiver] on usb-3610000.xhci-4.4.4/input1
[ 9.217145] mmc1: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit
[ 9.358042] tegra194-pcie 141a0000.pcie: Phy link never came up
[ 9.358260] tegra194-pcie 141a0000.pcie: PCI host bridge to bus 0005:00
[ 9.358442] pci_bus 0005:00: root bus resource [bus 00-ff]
[ 9.358598] pci_bus 0005:00: root bus resource [io 0x200000-0x2fffff] (bus address [0x3a100000-0x3a1fffff])
[ 9.358871] pci_bus 0005:00: root bus resource [mem 0x2b28000000-0x2b2fffffff] (bus address [0x40000000-0x47ffffff])
[ 9.359163] pci_bus 0005:00: root bus resource [mem 0x2740000000-0x2b27ffffff pref]
[ 9.359408] pci 0005:00:00.0: [10de:229a] type 01 class 0x060400
[ 9.359673] pci 0005:00:00.0: PME# supported from D0 D3hot
[ 9.365384] pci 0005:00:00.0: PCI bridge to [bus 01-ff]
[ 9.365538] pci 0005:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 9.365959] pcieport 0005:00:00.0: Adding to iommu group 12
[ 9.366250] pcieport 0005:00:00.0: PME: Signaling with IRQ 54
[ 9.366880] pcieport 0005:00:00.0: AER: enabled with IRQ 54
[ 9.367394] pci_bus 0005:01: busn_res: [bus 01-ff] is released
[ 9.367620] pci 0005:00:00.0: Removing from iommu group 12
[ 9.367764] pci_bus 0005:00: busn_res: [bus 00-ff] is released
[ 9.373674] tegra-xudc 3550000.xudc: failed to get usbphy-0: -517
[ 9.379271] tegra-xudc 3550000.xudc: failed to get usbphy-0: -517
[ 9.385540] nvethernet 2310000.ethernet: Adding to iommu group 43
[ 9.391443] nvethernet 2310000.ethernet: failed to read skip mac reset flag, default 0
[ 9.399479] nvethernet 2310000.ethernet: failed to read MDIO address
[ 9.405850] nvethernet 2310000.ethernet: Failed to read nvida,pause_frames, so setting to default support as disable
[ 9.416438] nvethernet 2310000.ethernet: setting to default DMA bit mask
[ 9.423090] nvethernet 2310000.ethernet: max-platform-mtu DT entry missing, setting default 1500
[ 9.674850] -----|-----[ether_enable_eqos_clks]------by aover--
[ 9.674856] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 5.10.65-tegra #42
[ 9.675206] Hardware name: /, BIOS r34.1-975eef6 04/06/2022
[ 9.675370] Call trace:
[ 9.675459] dump_backtrace+0x0/0x1a0
[ 9.675564] show_stack+0x2c/0x40
[ 9.675668] dump_stack+0xd8/0x138
[ 9.675768] ether_enable_clks+0x520/0x710
[ 9.675885] ether_configure_car+0x1ec/0x8e0
[ 9.676009] ether_probe+0x10fc/0x2300
[ 9.676120] platform_drv_probe+0x58/0xb0
[ 9.676232] really_probe+0xf4/0x3d0
[ 9.676332] driver_probe_device+0x5c/0xc0
[ 9.676451] device_driver_attach+0x74/0x80
[ 9.676566] __driver_attach+0x64/0xe0
[ 9.676669] bus_for_each_dev+0x80/0xd0
[ 9.676774] driver_attach+0x30/0x40
[ 9.676869] bus_add_driver+0x14c/0x1f0
[ 9.677383] driver_register+0x64/0x110
[ 9.677954] __platform_driver_register+0x60/0x70
[ 9.678648] nvethernet_driver_init+0x20/0x28
[ 9.679284] do_one_initcall+0x4c/0x2d0
[ 9.679865] kernel_init_freeable+0x250/0x2d0
[ 9.680509] kernel_init+0x18/0x11c
[ 9.683285] ret_from_fork+0x10/0x18
[ 9.687896] nvethernet 2310000.ethernet: Ethernet MAC address: 48:b0:2d:78:a6:0a
[ 9.694173] -->macsec_probe()
[ 9.694182] -->macsec_get_platform_res()
[ 9.694213] <--macsec_get_platform_res()
[ 9.694214] -->macsec_enable_car()
[ 9.694480] <--macsec_enable_car()
[ 9.694501] <--macsec_probe()
[ 9.694503] nvethernet 2310000.ethernet: Macsec not enabled
[ 9.699742] nvethernet 2310000.ethernet: Macsec: Reduced MTU: 1466 Max: 1500
[ 9.707780] nvethernet 2310000.ethernet: eth0 (HW ver: 53) created with 8 DMA channels
[ 9.714823] tegra-xudc 3550000.xudc: failed to get usbphy-0: -517
[ 9.721044] irq: IRQ291: trimming hierarchy from :pmc@c360000
[ 9.726462] irq: IRQ292: trimming hierarchy from :interrupt-controller@f400000-1
[ 9.733985] irq: IRQ293: trimming hierarchy from :pmc@c360000
[ 9.739683] input: gpio-keys as /devices/platform/gpio-keys/input/input11
[ 9.746620] tegra-xudc 3550000.xudc: failed to get usbphy-0: -517
[ 9.752749] tegra-se-nvhost 15810000.se: Adding to iommu group 44
[ 9.758999] tegra-se-nvhost 15810000.se: initialized
[ 9.769877] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 9.770228] tegra-xudc 3550000.xudc: failed to get usbphy-0: -517
[ 9.776022] tegra-se-nvhost 15820000.se: Adding to iommu group 45
[ 9.782328] tegra-se-nvhost 15820000.se: initialized
[ 9.788852] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 9.793326] tegra-xudc 3550000.xudc: failed to get usbphy-0: -517
[ 9.799499] tegra-se-nvhost 15840000.se: Adding to iommu group 46
[ 9.805852] tegra-se-nvhost 15840000.se: initialized
[ 9.814016] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 9.816996] tegra-xudc 3550000.xudc: failed to get usbphy-0: -517
[ 9.821142] tegra_actmon d230000.actmon: in actmon_register()...
[ 9.829173] tegra_actmon d230000.actmon: bwmgr_disable = 1
[ 9.836735] tegra_actmon d230000.actmon: initialization Completed for the device mc_all
[ 9.842281] tegra-xudc 3550000.xudc: failed to get usbphy-0: -517
[ 9.848424] hvc_sysfs: hypervisor is not present
[ 9.884311] ALSA device list:
[ 9.884398] No soundcards found.
[ 10.309665] sd 0:0:0:0: [sda] 30728832 512-byte logical blocks: (15.7 GB/14.7 GiB)
[ 10.309980] sd 0:0:0:0: [sda] Write Protect is off
[ 10.310126] sd 0:0:0:0: [sda] Mode Sense: 23 00 00 00
[ 10.310206] sd 0:0:0:0: [sda] No Caching mode page found
[ 10.310361] sd 0:0:0:0: [sda] Assuming drive cache: write through
[ 10.334223] sda: sda1 sda2
[ 10.338098] sd 0:0:0:0: [sda] Attached SCSI removable disk
[ 10.338449] tegra-xudc 3550000.xudc: failed to get usbphy-0: -517
[ 10.338874] Freeing unused kernel memory: 3904K
[ 10.348874] Run /init as init process
[ 10.348980] with arguments:
[ 10.348981] /init
[ 10.348982] nv-auto-config
[ 10.348984] with environment:
[ 10.348985] HOME=/
[ 10.348986] TERM=linux
[ 10.348987] mminit_loglevel=4
[ 10.359567] Root device found: mmcblk0p1
[ 10.360160] Found dev node: /dev/mmcblk0p1
[ 10.785141] EXT4-fs (mmcblk0p1): 5 orphan inodes deleted
[ 10.785324] EXT4-fs (mmcblk0p1): recovery complete
[ 10.790763] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 10.791911] Rootfs mounted over mmcblk0p1
[ 10.799921] Switching from initrd to actual rootfs
[ 10.889017] systemd[1]: System time before build time, advancing clock.
[ 10.914078] systemd[1]: systemd 245.4-4ubuntu3.15 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
[ 10.915158] systemd[1]: Detected architecture arm64.
[ 10.948144] systemd[1]: Set hostname to <ubuntu>.
[ 11.115296] systemd[1]: system-modprobe.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
[ 11.115672] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
[ 11.116569] systemd[1]: Created slice system-modprobe.slice.
[ 11.117039] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 11.117430] systemd[1]: Created slice User and Session Slice.
[ 11.117680] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 11.118125] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 11.118459] systemd[1]: Reached target User and Group Name Lookups.
[ 11.118674] systemd[1]: Reached target Slices.
[ 11.118837] systemd[1]: Reached target Swap.
[ 11.119167] systemd[1]: Listening on RPCbind Server Activation Socket.
[ 11.119462] systemd[1]: Listening on Syslog Socket.
[ 11.119716] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 11.119982] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 11.120865] systemd[1]: Listening on Journal Audit Socket.
[ 11.124923] systemd[1]: Listening on Journal Socket (/dev/log).
[ 11.130995] systemd[1]: Listening on Journal Socket.
[ 11.135991] systemd[1]: Listening on udev Control Socket.
[ 11.141429] systemd[1]: Listening on udev Kernel Socket.
[ 11.147752] systemd[1]: Mounting Huge Pages File System...
[ 11.153231] systemd[1]: Mounting POSIX Message Queue File System...
[ 11.159395] systemd[1]: Mounting RPC Pipe File System...
[ 11.164772] systemd[1]: Mounting Kernel Debug File System...
[ 11.170544] systemd[1]: Mounting Kernel Trace File System...
[ 11.176432] systemd[1]: Starting Journal Service...
[ 11.181362] systemd[1]: Starting Set the console keyboard layout...
[ 11.187481] systemd[1]: Starting Create list of static device nodes for the current kernel...
[ 11.195508] systemd[1]: Condition check resulted in Load Kernel Module drm being skipped.
[ 11.204426] systemd[1]: Started Nameserver information manager.
[ 11.209883] systemd[1]: Reached target Network (Pre).
[ 11.215523] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[ 11.223906] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[ 11.225469] systemd[1]: Starting Load Kernel Modules...
[ 11.238959] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 11.240797] tegra-xudc 3550000.xudc: failed to get usbphy-0: -517
[ 11.245030] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 11.252005] tegra-xudc 3550000.xudc: failed to get usbphy-0: -517
[ 11.263729] systemd[1]: Starting udev Coldplug all Devices...
[ 11.269793] systemd[1]: Started Journal Service.
[ 11.311352] systemd-journald[310]: Received client request to flush runtime journal.
[ 13.178668] nvidia: loading out-of-tree module taints kernel.
[ 13.184676] nv_platform 13800000.display: Adding to iommu group 47
[ 13.188572] platform 13800000.display:nvdisplay-niso: Adding to iommu group 48
[ 13.192826] tegra-xudc 3550000.xudc: failed to get usbphy-0: -517
[ 13.195828] NVRM: loading NVIDIA UNIX Kernel Module for aarch64 34.1.0 Release Build (buildbrain@mobile-u64-5280-d6000) Wed Apr 6 12:07:34 PDT 2022
[ 13.228732] spi-tegra114 3210000.spi: Adding to iommu group 3
[ 13.234060] spi-tegra114 3230000.spi: Adding to iommu group 3
[ 13.237426] tegra-xudc 3550000.xudc: failed to get usbphy-0: -517
[ 13.242011] irq: IRQ294: trimming hierarchy from :pmc@c360000
[ 13.242204] nct1008_nct72 4-004c: starting parse dt
[ 13.242378] nct1008_nct72 4-004c: !!!Found deprecated property!!!
[ 13.242555] nct1008_nct72 4-004c: success parsing dt
[ 13.242987] nct1008_nct72 4-004c: success in enabling tmp451 VDD rail
[ 13.251784] tegra-xudc 3550000.xudc: failed to get usbphy-0: -517
[ 13.254695] cpu-throttle-alert cooling device registered.
[ 13.257212] tegra-adma 2930000.adma: Tegra210 ADMA driver registered 16 channels
[ 13.260415] gpu-throttle-alert cooling device registered.
[ 13.261745] cv0-throttle-alert cooling device registered.
[ 13.262875] tegra-xudc 3550000.xudc: failed to get usbphy-0: -517
[ 13.263598] tegra-xudc 3550000.xudc: failed to get usbphy-0: -517
[ 13.264332] cv1-throttle-alert cooling device registered.
[ 13.265058] cv2-throttle-alert cooling device registered.
[ 13.265065] tegra-xudc 3550000.xudc: failed to get usbphy-0: -517
[ 13.265705] tegra-xudc 3550000.xudc: failed to get usbphy-0: -517
[ 13.266167] soc0-throttle-alert cooling device registered.
[ 13.269031] tegra-xudc 3550000.xudc: failed to get usbphy-0: -517
[ 13.269359] soc1-throttle-alert cooling device registered.
[ 13.269906] tegra-xudc 3550000.xudc: failed to get usbphy-0: -517
[ 13.273601] soc2-throttle-alert cooling device registered.
[ 13.280922] nct1008_nct72 4-004c: LOC shutdown limit 107
[ 13.283673] hot-surface-alert cooling device registered.
[ 13.284839] nct1008_nct72 4-004c: EXT shutdown limit 107
[ 13.286202] tegra-xudc 3550000.xudc: failed to get usbphy-0: -517
[ 13.286887] tegra-xudc 3550000.xudc: failed to get usbphy-0: -517
[ 13.290331] tegra-xudc 3550000.xudc: failed to get usbphy-0: -517
[ 13.294507] nvadsp 2993000.adsp: Adding to iommu group 49
[ 13.318030] nvadsp 2993000.adsp: in probe()...
[ 13.319123] qspi_mtd spi6.0: MX25U51279G (65536 Kbytes)
[ 13.319650] tegra-xudc 3550000.xudc: failed to get usbphy-0: -517
[ 13.333522] qspi_mtd spi6.0: mtd .name = spi6.0, .size = 0x4000000 (64MiB) .erasesize = 0x00010000 (64KiB) .numeraseregions = 0
[ 13.345008] nvadsp 2993000.adsp: nvadsp_app_module_probe
[ 13.345591] tegra-xudc 3550000.xudc: failed to get usbphy-0: -517
[ 13.355990] nct1008_nct72 4-004c: initial LOC temp: 37000
[ 13.357484] tegra-hda 3510000.hda: Adding to iommu group 50
[ 13.358885] tegra-xudc 3550000.xudc: failed to get usbphy-0: -517
[ 13.361686] tegra-asoc: sound: Adding to iommu group 49
[ 13.363085] nct1008_nct72 4-004c: initial EXT temp: 42750
[ 13.371464] tegra-xudc 3550000.xudc: failed to get usbphy-0: -517
[ 13.375895] nct1008_nct72 4-004c: hi_b:-4, lo_b:0
[ 13.397828] nct1008_nct72 4-004c: nct1008_probe: initialized
[ 13.402932] tegra-xudc 3550000.xudc: failed to get usbphy-0: -517
[ 13.442462] 1 fixed-partitions partitions found on MTD device spi6.0
[ 13.442669] Creating 1 MTD partitions on "spi6.0":
[ 13.442806] 0x000000000000-0x000004000000 : "Whole_flash0"
[ 13.443937] tegra-xudc 3550000.xudc: failed to get usbphy-0: -517
[ 13.445193] tegra210-adsp aconnect@2a41000:adsp_audio: Adding to iommu group 49
[ 13.445475] tegra210_adsp_audio_probe: platform probe started
[ 13.445976] tegra210-adsp tegra210-adsp: Default param-type to BYTE for mp3-dec1
[ 13.450747] tegra210-adsp tegra210-adsp: Default param-type to BYTE for spkprot
[ 13.455106] tegra-xudc 3550000.xudc: failed to get usbphy-0: -517
[ 13.458644] tegra210-adsp tegra210-adsp: Default param-type to BYTE for src
[ 13.464458] input: NVIDIA Jetson AGX Orin HDA HDMI/DP,pcm=3 as /devices/platform/3510000.hda/sound/card0/input12
[ 13.470943] tegra210-adsp tegra210-adsp: Default param-type to BYTE for aac-dec1
[ 13.481901] tegra-xudc 3550000.xudc: failed to get usbphy-0: -517
[ 13.488394] tegra210-adsp tegra210-adsp: Default param-type to BYTE for aec
[ 13.490641] nvgpu: 17000000.ga10b nvgpu_nvhost_syncpt_init:135 [INFO] syncpt_unit_base 60000000 syncpt_unit_size 4000000 size 10000
[ 13.494515] input: NVIDIA Jetson AGX Orin HDA HDMI/DP,pcm=7 as /devices/platform/3510000.hda/sound/card0/input13
[ 13.501466] tegra210-adsp tegra210-adsp: Default param-type to BYTE for wire
[ 13.516021] input: NVIDIA Jetson AGX Orin HDA HDMI/DP,pcm=8 as /devices/platform/3510000.hda/sound/card0/input14
[ 13.525758] tegra210-adsp tegra210-adsp: adma channel page address dt entry not found
[ 13.528180] rtl88x2ce 0001:01:00.0: Adding to iommu group 10
[ 13.528473] rtl88x2ce 0001:01:00.0: enabling device (0000 -> 0003)
[ 13.535363] tegra-xudc 3550000.xudc: failed to get usbphy-0: -517
[ 13.535987] input: NVIDIA Jetson AGX Orin HDA HDMI/DP,pcm=9 as /devices/platform/3510000.hda/sound/card0/input15
[ 13.536107] usbcore: registered new interface driver btusb
[ 13.543550] tegra210-adsp tegra210-adsp: using adma channel page 0
[ 13.552043] tegra-xudc 3550000.xudc: failed to get usbphy-0: -517
[ 13.556858] nvadsp 2993000.adsp: ADSP OS firmware already loaded
[ 13.558465] rtk_btusb: Realtek Bluetooth USB driver ver 3.1
[ 13.558469] rtk_btcoex: rtk_btcoex_init: version: 1.2
[ 13.558471] rtk_btcoex: create workqueue
[ 13.562590] rtk_btcoex: alloc buffers 1792, 2432 for ev and l2
[ 13.564289] tegra-xudc 3550000.xudc: failed to get usbphy-0: -517
[ 13.572182] cryptd: max_cpu_qlen set to 1000
[ 13.573982] tegra-xudc 3550000.xudc: failed to get usbphy-0: -517
[ 13.576356] tegra-xudc 3550000.xudc: failed to get usbphy-0: -517
[ 13.578668] tegra-xudc 3550000.xudc: failed to get usbphy-0: -517
[ 13.579188] rtk_btusb: btusb_probe intf->cur_altsetting->desc.bInterfaceNumber 0
[ 13.580778] tegra-xudc 3550000.xudc: failed to get usbphy-0: -517
[ 13.583022] tegra-xudc 3550000.xudc: failed to get usbphy-0: -517
[ 13.585432] tegra-xudc 3550000.xudc: failed to get usbphy-0: -517
[ 13.590682] rtk_btusb: btusb_probe can_wakeup 1, may wakeup 0
[ 13.605740] tegra-xudc 3550000.xudc: failed to get usbphy-0: -517
[ 13.609246] rtk_btusb: patch_add
[ 13.632539] tegra-xudc 3550000.xudc: failed to get usbphy-0: -517
[ 13.638531] rtk_btusb: auto suspend is disabled
[ 13.638534] rtk_btusb: pid = 0x3549
[ 13.638536] rtk_btusb: patch_add: Reset gEVersion to 0xff
[ 13.638546] rtk_btusb: set_bit(HCI_QUIRK_RESET_ON_CLOSE, &hdev->quirks);
[ 13.638869] rtk_btusb: btusb_probe: done
[ 13.639473] rtk_btusb: btusb_open start
[ 13.639475] rtk_btusb: btusb_open hdev->promisc ==0
[ 13.639476] rtk_btusb: download_patch start
[ 13.639478] rtk_btusb: chip type value: 0x73
[ 13.639480] rtk_btusb: HCI reset.
[ 13.651662] rtk_btusb: read_ver_rsp->lmp_subver = 0x8822
[ 13.657485] usbcore: registered new interface driver rtk_btusb
[ 13.663478] rtk_btusb: read_ver_rsp->hci_rev = 0xc
[ 13.673969] rtk_btusb: patch_entry->lmp_sub = 0x8822
[ 13.673971] rtk_btusb: load_firmware start
[ 13.673972] rtk_btusb: lmp_version = 0x8822
[ 13.673973] rtk_btusb: config filename rtl8822cu_config
[ 13.675576] rtk_btusb: no bdaddr file /opt/bdaddr
[ 13.679063] rtk_btusb: 55 ab 23 87 00 00
[ 13.679072] rtk_btusb: Config file length 6, new length 6
[ 13.684430] rtk_btusb: fw name is rtl8822cu_fw
[ 13.685072] rtk_btusb: This is not 8723a, use new patch style!
[ 13.685078] rtk_btusb: rtk_get_eversion: gEVersion 255
[ 13.686659] rtk_btusb: eversion->status = 0x0, eversion->version = 0x3
[ 13.686663] rtk_btusb: load_firmware: New gEVersion 3
[ 13.686666] rtk_btusb: rtk_get_fw_project_id: opcode 0, len 1, data 13
[ 13.686668] rtk_btusb: lmp_version is 8822, project_id is 8822, match!
[ 13.686670] rtk_btusb: fw_version = 0x9a8cbc9
[ 13.686671] rtk_btusb: number_of_total_patch = 3
[ 13.686672] rtk_btusb: chipID 4
[ 13.686673] rtk_btusb: patch_length 0x8590
[ 13.686674] rtk_btusb: start_offset 0x00005d00
[ 13.686675] rtk_btusb: Svn version: 1940234490
[ 13.686676] rtk_btusb: Coexistence: BTCOEX_20210106-2020
[ 13.686677] rtk_btusb: buf_len = 0x8596
[ 13.686686] rtk_btusb: fw: exists, config file: exists
[ 13.686687] rtk_btusb: load_firmware done
[ 13.686699] rtk_btusb: download_data start
[ 13.790597] tegra-xudc 3550000.xudc: failed to get usbphy-0: -517
[ 13.858672] rtk_btusb: download_data done
[ 13.858677] rtk_btusb: HCI reset.
[ 13.869655] rtk_btusb: read_ver_rsp->lmp_subver = 0xcbc9
[ 13.869659] rtk_btusb: read_ver_rsp->hci_rev = 0x9a8
[ 13.869660] rtk_btusb: patch_entry->lmp_sub = 0x8822
[ 13.869665] rtk_btusb: Rtk patch end 0
[ 13.869668] rtk_btusb: btusb_open set HCI_RUNNING
[ 13.869684] rtk_btcoex: Open BTCOEX
[ 13.869686] rtk_btusb: btusb_open end
[ 13.871667] rtk_btcoex: BTCOEX hci_rev 0x09a8
[ 13.871669] rtk_btcoex: BTCOEX lmp_subver 0xcbc9
[ 13.891658] rtk_btusb: btusb_notify: hci0 evt 3
[ 13.904039] tegra210-adsp tegra210-adsp: Loaded app wire
[ 13.904045] tegra210-adsp tegra210-adsp: Loaded app apm
[ 13.904047] tegra210-adsp tegra210-adsp: Loaded app adma
[ 13.904048] tegra210-adsp tegra210-adsp: Loaded app adma_tx
[ 13.904050] nvadsp_set_adma_dump_reg: callback for adma reg dump is sent to 0000000098189ef6
[ 13.928392] tegra210-adsp tegra210-adsp: Tegra210 ADSP driver successfully registered
[ 13.929105] tegra-xudc 3550000.xudc: failed to get usbphy-0: -517
[ 14.159478] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 14.159494] Bluetooth: BNEP socket layer initialized
[ 14.429813] loop: module loaded
[ 14.520776] -----|-----[ether_enable_eqos_clks]------by aover--
[ 14.520785] CPU: 1 PID: 670 Comm: NetworkManager Tainted: G O 5.10.65-tegra #42
[ 14.520788] Hardware name: /, BIOS r34.1-975eef6 04/06/2022
[ 14.520791] Call trace:
[ 14.520801] dump_backtrace+0x0/0x1a0
[ 14.520805] show_stack+0x2c/0x40
[ 14.520813] dump_stack+0xd8/0x138
[ 14.520820] ether_enable_clks+0x520/0x710
[ 14.520822] ether_open+0x74/0xac0
[ 14.520827] __dev_open+0xe4/0x190
[ 14.520829] __dev_change_flags+0x168/0x1c0
[ 14.520832] dev_change_flags+0x3c/0x80
[ 14.520836] do_setlink+0x604/0xd50
[ 14.520839] __rtnl_newlink+0x3fc/0x790
[ 14.520841] rtnl_newlink+0x54/0x80
[ 14.520844] rtnetlink_rcv_msg+0x124/0x340
[ 14.520849] netlink_rcv_skb+0x5c/0x120
[ 14.520852] rtnetlink_rcv+0x28/0x40
[ 14.520855] netlink_unicast+0x1c0/0x280
[ 14.520858] netlink_sendmsg+0x1c4/0x3d0
[ 14.520861] ____sys_sendmsg+0x288/0x2c0
[ 14.520863] ___sys_sendmsg+0x8c/0xd0
[ 14.520865] __sys_sendmsg+0x78/0xd0
[ 14.520866] __arm64_sys_sendmsg+0x2c/0x40
[ 14.520869] el0_svc_common.constprop.0+0x7c/0x1c0
[ 14.520871] do_el0_svc+0x34/0xa0
[ 14.520874] el0_svc+0x1c/0x30
[ 14.520876] el0_sync_handler+0xa8/0xb0
[ 14.520877] el0_sync+0x16c/0x180
[ 14.524737] -----|-----[ether_open]-----by aover---
[ 14.524745] CPU: 1 PID: 670 Comm: NetworkManager Tainted: G O 5.10.65-tegra #42
[ 14.524750] Hardware name: /, BIOS r34.1-975eef6 04/06/2022
[ 14.524754] Call trace:
[ 14.524759] dump_backtrace+0x0/0x1a0
[ 14.524764] show_stack+0x2c/0x40
[ 14.524772] dump_stack+0xd8/0x138
[ 14.524778] ether_open+0x1b0/0xac0
[ 14.524783] __dev_open+0xe4/0x190
[ 14.524787] __dev_change_flags+0x168/0x1c0
[ 14.524791] dev_change_flags+0x3c/0x80
[ 14.524796] do_setlink+0x604/0xd50
[ 14.524799] __rtnl_newlink+0x3fc/0x790
[ 14.524803] rtnl_newlink+0x54/0x80
[ 14.524806] rtnetlink_rcv_msg+0x124/0x340
[ 14.524810] netlink_rcv_skb+0x5c/0x120
[ 14.524814] rtnetlink_rcv+0x28/0x40
[ 14.524815] netlink_unicast+0x1c0/0x280
[ 14.524818] netlink_sendmsg+0x1c4/0x3d0
[ 14.524820] ____sys_sendmsg+0x288/0x2c0
[ 14.524821] ___sys_sendmsg+0x8c/0xd0
[ 14.524823] __sys_sendmsg+0x78/0xd0
[ 14.524824] __arm64_sys_sendmsg+0x2c/0x40
[ 14.524827] el0_svc_common.constprop.0+0x7c/0x1c0
[ 14.524828] do_el0_svc+0x34/0xa0
[ 14.524831] el0_svc+0x1c/0x30
[ 14.524832] el0_sync_handler+0xa8/0xb0
[ 14.524833] el0_sync+0x16c/0x180
[ 14.532053] nvgpu: 17000000.ga10b tpc_pg_mask_store:1042 [INFO] no value change, same mask already set
[ 15.402079] zram: Added device: zram0
[ 15.402206] zram: Added device: zram1
[ 15.404082] zram: Added device: zram2
[ 15.404328] zram: Added device: zram3
[ 15.405107] zram: Added device: zram4
[ 15.405319] zram: Added device: zram5
[ 15.405507] zram: Added device: zram6
[ 15.405747] zram: Added device: zram7
[ 15.405947] zram: Added device: zram8
[ 15.406098] zram: Added device: zram9
[ 15.406196] zram: Added device: zram10
[ 15.406289] zram: Added device: zram11
[ 15.449765] zram0: detected capacity change from 0 to 1337929728
[ 15.516791] Adding 1306568k swap on /dev/zram0. Priority:5 extents:1 across:1306568k SS
[ 15.519582] zram1: detected capacity change from 0 to 1337929728
[ 15.568788] Adding 1306568k swap on /dev/zram1. Priority:5 extents:1 across:1306568k SS
[ 15.570879] zram2: detected capacity change from 0 to 1337929728
[ 15.624828] Adding 1306568k swap on /dev/zram2. Priority:5 extents:1 across:1306568k SS
[ 15.627600] zram3: detected capacity change from 0 to 1337929728
[ 15.677237] Adding 1306568k swap on /dev/zram3. Priority:5 extents:1 across:1306568k SS
[ 15.679479] zram4: detected capacity change from 0 to 1337929728
[ 15.716806] Adding 1306568k swap on /dev/zram4. Priority:5 extents:1 across:1306568k SS
[ 15.719097] zram5: detected capacity change from 0 to 1337929728
[ 15.777043] Adding 1306568k swap on /dev/zram5. Priority:5 extents:1 across:1306568k SS
[ 15.779427] zram6: detected capacity change from 0 to 1337929728
[ 15.828848] Adding 1306568k swap on /dev/zram6. Priority:5 extents:1 across:1306568k SS
[ 15.831143] zram7: detected capacity change from 0 to 1337929728
[ 15.880860] Adding 1306568k swap on /dev/zram7. Priority:5 extents:1 across:1306568k SS
[ 15.883459] zram8: detected capacity change from 0 to 1337929728
[ 15.940867] Adding 1306568k swap on /dev/zram8. Priority:5 extents:1 across:1306568k SS
[ 15.943245] zram9: detected capacity change from 0 to 1337929728
[ 15.992854] Adding 1306568k swap on /dev/zram9. Priority:5 extents:1 across:1306568k SS
[ 15.995131] zram10: detected capacity change from 0 to 1337929728
[ 16.040848] Adding 1306568k swap on /dev/zram10. Priority:5 extents:1 across:1306568k SS
[ 16.043225] zram11: detected capacity change from 0 to 1337929728
[ 16.097013] Adding 1306568k swap on /dev/zram11. Priority:5 extents:1 across:1306568k SS
[ 26.671324] nvidia-modeset: Loading NVIDIA UNIX Kernel Mode Setting Driver for aarch64 34.1.0 Release Build (buildbrain@mobile-u64-5280-d6000) Wed Apr 6 12:07:36 PDT 2022
[ 26.671376] NVRM gpumgrGetSomeGpu: Failed to retrieve pGpu - Too early call!.
[ 26.671380] NVRM nvAssertFailedNoLog: Assertion failed: NV_FALSE @ gpu_mgr.c:295
[ 26.671387] CPU: 0 PID: 1262 Comm: modprobe Tainted: G O 5.10.65-tegra #42
[ 26.671388] Hardware name: /, BIOS r34.1-975eef6 04/06/2022
[ 26.671390] Call trace:
[ 26.671400] dump_backtrace+0x0/0x1a0
[ 26.671403] show_stack+0x2c/0x40
[ 26.671408] dump_stack+0xd8/0x138
[ 26.671438] os_dump_stack+0x14/0x1c [nvidia]
[ 26.671458] tlsEntryUnreference+0x198/0x1a0 [nvidia]
[ 26.671473] gpumgrGetSomeGpu+0x80/0x98 [nvidia]
[ 26.671488] threadPriorityRestore+0xa8/0x2f0 [nvidia]
[ 26.671504] rmclientConstruct_IMPL+0x160/0x258 [nvidia]
[ 26.671519] __nvoc_ctor_RmClient+0x5c/0x88 [nvidia]
[ 26.671534] __nvoc_objCreate_RmClient+0x7c/0x118 [nvidia]
[ 26.671549] resservClientFactory+0x28/0x90 [nvidia]
[ 26.671565] serverAllocClient+0x19c/0x318 [nvidia]
[ 26.671580] serverAllocResource+0x140/0x2e8 [nvidia]
[ 26.671595] rmapiAllocWithSecInfo+0x17c/0x2e8 [nvidia]
[ 26.671611] rmapiAllocWithSecInfoTls+0x74/0xa8 [nvidia]
[ 26.671626] rmapiInitDeprecatedContext+0x520/0x598 [nvidia]
[ 26.671668] nvkms_call_rm+0x5c/0x90 [nvidia_modeset]
[ 26.671700] nvRmApiAlloc+0x30/0x40 [nvidia_modeset]
[ 26.671703] do_one_initcall+0x4c/0x2d0
[ 26.671706] do_init_module+0x5c/0x210
[ 26.671708] load_module+0x2068/0x2680
[ 26.671709] __do_sys_finit_module+0xb4/0xf0
[ 26.671711] __arm64_sys_finit_module+0x28/0x40
[ 26.671714] el0_svc_common.constprop.0+0x7c/0x1c0
[ 26.671716] do_el0_svc+0x34/0xa0
[ 26.671719] el0_svc+0x1c/0x30
[ 26.671721] el0_sync_handler+0xa8/0xb0
[ 26.671722] el0_sync+0x16c/0x180
[ 26.671727] NVRM gpumgrGetSomeGpu: Failed to retrieve pGpu - Too early call!.
[ 26.671730] NVRM nvAssertFailedNoLog: Assertion failed: NV_FALSE @ gpu_mgr.c:295
[ 26.693425] fuse: init (API version 7.32)
[ 26.808742] [eqos_poll_for_swr][588][type:0x4][loga-0x0] poll_for_swr: timeout
[ 26.808997] net eth0: failed to poll MAC Software reset
[ 27.178107] start_addr=(0x20000), end_addr=(0x40000), buffer_size=(0x20000), smp_number_max=(16384)
[ 27.425112] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call result 0x56:
[ 27.425705] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call result 0x56:
[ 27.426361] NVRM rmapiAllocWithSecInfo: allocation failed; status: Given class-id not valid [NV_ERR_INVALID_CLASS] (0x00000022)
[ 27.426363] NVRM rmapiAllocWithSecInfo: client:0xc1d00001 parent:0xcaf00001 object:0x0 class:0x402c
[ 27.428127] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call result 0x56:
[ 27.440013] NVRM nvAssertFailed: Assertion failed: 0 @ g_mem_mgr_nvoc.h:1190
[ 27.440023] CPU: 3 PID: 1254 Comm: Xorg Tainted: G O 5.10.65-tegra #42
[ 27.440024] Hardware name: /, BIOS r34.1-975eef6 04/06/2022
[ 27.440026] Call trace:
[ 27.440036] dump_backtrace+0x0/0x1a0
[ 27.440038] show_stack+0x2c/0x40
[ 27.440044] dump_stack+0xd8/0x138
[ 27.440075] os_dump_stack+0x14/0x1c [nvidia]
[ 27.440094] tlsEntryUnreference+0x198/0x1a0 [nvidia]
[ 27.440109] ctxdmaConstruct_IMPL+0x36c/0x3b8 [nvidia]
[ 27.440124] __nvoc_ctor_ContextDma+0x74/0xa8 [nvidia]
[ 27.440139] __nvoc_objCreate_ContextDma+0x78/0x118 [nvidia]
[ 27.440153] __nvoc_objCreateDynamic+0x54/0x60 [nvidia]
[ 27.440168] resservResourceFactory+0x74/0x100 [nvidia]
[ 27.440182] indexRemove+0x290/0x518 [nvidia]
[ 27.440196] serverAllocResourceUnderLock+0x214/0x5f0 [nvidia]
[ 27.440210] serverAllocResource+0x244/0x2e8 [nvidia]
[ 27.440225] rmapiAllocWithSecInfo+0x17c/0x2e8 [nvidia]
[ 27.440239] rmapiAllocWithSecInfoTls+0x74/0xa8 [nvidia]
[ 27.440254] rmapiInitDeprecatedContext+0x520/0x598 [nvidia]
[ 27.440289] nvkms_call_rm+0x5c/0x90 [nvidia_modeset]
[ 27.440316] nvRmApiAlloc+0x30/0x40 [nvidia_modeset]
[ 27.440338] nvkms_ioctl_common+0x174/0x1a0 [nvidia_modeset]
[ 27.440354] nvidia_frontend_unlocked_ioctl+0x58/0x78 [nvidia]
[ 27.440359] __arm64_sys_ioctl+0xa8/0xf0
[ 27.440362] el0_svc_common.constprop.0+0x7c/0x1c0
[ 27.440364] do_el0_svc+0x34/0xa0
[ 27.440368] el0_svc+0x1c/0x30
[ 27.440369] el0_sync_handler+0xa8/0xb0
[ 27.440370] el0_sync+0x16c/0x180
[ 27.440450] NVRM nvAssertFailed: Assertion failed: 0 @ g_mem_mgr_nvoc.h:1190
[ 27.440510] NVRM nvAssertFailed: Assertion failed: 0 @ g_mem_mgr_nvoc.h:1190
[ 27.440568] NVRM nvAssertFailed: Assertion failed: 0 @ g_mem_mgr_nvoc.h:1190
[ 27.440623] NVRM nvAssertFailed: Assertion failed: 0 @ g_mem_mgr_nvoc.h:1190
[ 27.440681] NVRM nvAssertFailed: Assertion failed: 0 @ g_mem_mgr_nvoc.h:1190
[ 27.440757] NVRM nvAssertFailed: Assertion failed: 0 @ g_mem_mgr_nvoc.h:1190
[ 27.491312] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call result 0x56:
[ 27.492689] NVRM nvAssertFailed: Assertion failed: 0 @ g_mem_mgr_nvoc.h:1190
[ 27.607754] NVRM nvAssertFailed: Assertion failed: 0 @ g_mem_mgr_nvoc.h:1175
[ 27.608205] NVRM nvAssertFailed: Assertion failed: 0 @ g_mem_mgr_nvoc.h:1190
[ 27.787584] NVRM nvAssertFailed: Assertion failed: 0 @ g_mem_mgr_nvoc.h:1175
[ 30.730403] NVRM nvAssertFailed: Assertion failed: 0 @ g_mem_mgr_nvoc.h:1175
[ 30.731194] NVRM nvAssertFailed: Assertion failed: 0 @ g_mem_mgr_nvoc.h:1175
[ 39.901044] vdd-12v-sys: disabling
[ 39.901060] vdd-3v3-ftdi: disabling
[ 39.901069] vdd-3v3-pcie: disabling
[ 39.901074] avdd-cam-2v8: disabling
[ 39.901080] vdd-12v-pcie: disabling
[ 39.901085] dsi-vdd-1v8-bl-en: disabling
[ 55.239545] start_addr=(0x20000), end_addr=(0x40000), buffer_size=(0x20000), smp_number_max=(16384)
[ 88.232132] start_addr=(0x20000), end_addr=(0x40000), buffer_size=(0x20000), smp_number_max=(16384)
[ 131.264245] start_addr=(0x20000), end_addr=(0x40000), buffer_size=(0x20000), smp_number_max=(16384)
[ 184.236340] start_addr=(0x20000), end_addr=(0x40000), buffer_size=(0x20000), smp_number_max=(16384)
[ 210.837679] NVRM nvAssertFailed: Assertion failed: 0 @ g_mem_mgr_nvoc.h:1175
[ 210.997184] NVRM nvAssertFailed: Assertion failed: 0 @ g_mem_mgr_nvoc.h:1190
[ 210.997277] NVRM nvAssertFailed: Assertion failed: 0 @ g_mem_mgr_nvoc.h:1190
[ 210.997365] NVRM nvAssertFailed: Assertion failed: 0 @ g_mem_mgr_nvoc.h:1190
[ 210.997448] NVRM nvAssertFailed: Assertion failed: 0 @ g_mem_mgr_nvoc.h:1190
[ 210.997534] NVRM nvAssertFailed: Assertion failed: 0 @ g_mem_mgr_nvoc.h:1190
[ 210.997613] NVRM nvAssertFailed: Assertion failed: 0 @ g_mem_mgr_nvoc.h:1190
[ 210.997686] NVRM nvAssertFailed: Assertion failed: 0 @ g_mem_mgr_nvoc.h:1190
[ 211.065176] NVRM nvAssertFailed: Assertion failed: 0 @ g_mem_mgr_nvoc.h:1190
[ 211.065383] NVRM nvAssertFailed: Assertion failed: 0 @ g_mem_mgr_nvoc.h:1175
[ 211.065481] NVRM nvAssertFailed: Assertion failed: 0 @ g_mem_mgr_nvoc.h:1190
[ 211.065618] NVRM nvAssertFailed: Assertion failed: 0 @ g_mem_mgr_nvoc.h:1175
[ 211.143574] NVRM nvAssertFailed: Assertion failed: 0 @ g_mem_mgr_nvoc.h:1190
[ 211.867717] NVRM nvAssertFailed: Assertion failed: 0 @ g_mem_mgr_nvoc.h:1175
[ 211.867996] NVRM nvAssertFailed: Assertion failed: 0 @ g_mem_mgr_nvoc.h:1190
[ 212.075013] NVRM nvAssertFailed: Assertion failed: 0 @ g_mem_mgr_nvoc.h:1175
[ 215.504190] NVRM nvAssertFailed: Assertion failed: 0 @ g_mem_mgr_nvoc.h:1175
[ 215.505036] NVRM nvAssertFailed: Assertion failed: 0 @ g_mem_mgr_nvoc.h:1175
