Orin Som cannot boot on the Xavier carriboard developed by our company, but the same board Xavier SOM can work normally. After analysis, it is found that VIN_PWR_ON signal is abnormal on Orin SOM, only 450ms high level, and then it remains low level all the time. How can I solve this problem? Thanks!
YES, We have patched orin+ Xavier Carriboard Patch as suggested by SYNNEX FAE.But the problem remains
Hi, you should follow Orin Design Guide to check your custom carrier board design.
