Orin SPI2 in jekpack 6.0, can not work
hi all
When testing SPI2 in jekpack 6.0, some issues occurred. Currently, I am using SPI2 to connect to MCP2518FD, but the following error is reported.
i use the customboard
[   49.127133] ------------[ cut here ]------------
[   49.127169] WARNING: CPU: 7 PID: 818 at drivers/spi/spi-tegra114.c:1460 tegra_spi_transfer_one_message+0xa3c/0xbc8 [spi_tegra114]
[   49.127246] Modules linked in: can_raw can nvidia_modeset(O) aic8800_fdrv(OE) cfg80211 lzo_rle lzo_compress zram zsmalloc aic_load_fw(OE) ramoops reed_solomon nv_cam(O) max96717 snd_soc_tegra210_admaif(O) snd_soc_tegra186_asrc(O) snd_soc_tegra210_mixer(O) snd_soc_tegra_pcm snd_soc_tegra210_afc(O) snd_soc_tegra186_arad(O) snd_soc_tegra210_ope(O) snd_soc_tegra210_dmic(O) snd_soc_tegra210_amx(O) snd_soc_tegra210_mvc(O) snd_soc_tegra186_dspk(O) snd_soc_tegra210_sfc(O) snd_soc_tegra210_adx(O) snd_soc_tegra210_i2s(O) snd_soc_tegra210_ahub(O) tegra210_adma mcp251xfd nvvrs_pseq_rtc(O) tegra_pcie_dma_test(O) tegra_pcie_edma(O) snd_hda_codec_hdmi mttcan(O) can_dev tegra_cactmon_mc_all(O) tegra234_aon(O) tegra_aconnect snd_hda_tegra max96724 snd_hda_codec snd_hda_core max_serdes_all at24 pwm_tegra_tachometer(O) nvethernet(O) spi_tegra114(E) mc_hwpm(O) nvpps(O) host1x_fence(O) crct10dif_ce snd_soc_tegra_machine_driver(O) snd_soc_tegra_utils(O) snd_soc_simple_card_utils rfkill
[   49.127437]  tegra23x_perf_uncore(O) tegra234_oc_event(O) nvpmodel_clk_cap(O) nvidia(O) tegra_mce(O) thermal_trip_event(O) i2c_nvvrs11(O) lm90 nvhost_vi5(O) nvhost_isp5(O) nvhost_nvcsi_t194(O) nvidia_vrs_pseq(O) tegra_dce(O) bridge stp llc usb_f_ncm usb_f_mass_storage tegra_camera(O) v4l2_dv_timings nvhost_nvcsi(O) tegra_camera_platform(O) capture_ivc(O) tegra_camera_rtcpu(O) ivc_bus(O) hsp_mailbox_client(O) ivc_ext(O) v4l2_fwnode usb_f_acm v4l2_async videobuf2_dma_contig u_serial governor_userspace videobuf2_memops usb_f_rndis videobuf2_v4l2 tegra_drm(O) u_ether videobuf2_common videodev tegra_wmark(O) libcomposite nvhost_pva(O) mc nvhost_nvdla(O) cec tegra_se(O) nvhwpm(O) nvhost_capture(O) drm_kms_helper tsecriscv(O) host1x_nvhost(O) crypto_engine nvidia_p2p(O) ina3221 nvgpu(O) governor_pod_scaling(O) host1x(O) mc_utils(O) nvmap(O) nvsciipc(O) drm fuse ip_tables x_tables ipv6 pwm_fan(E) pwm_tegra(E) tegra_bpmp_thermal(E) tegra_xudc(E) ucsi_ccg(E) typec_ucsi(E) typec(E) nvme(E)
[   49.127711]  nvme_core(E) phy_tegra194_p2u(E) pcie_tegra194(E)
[   49.127738] CPU: 7 PID: 818 Comm: spi2 Tainted: G           OE     5.15.136-tegra #1
[   49.127748] Hardware name: NVIDIA NVIDIA Jetson AGX Orin Developer Kit/Jetson, BIOS 36.3.0-gcid-36191598 05/06/2024
[   49.127753] pstate: 60400009 (nZCv daif +PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[   49.127764] pc : tegra_spi_transfer_one_message+0xa3c/0xbc8 [spi_tegra114]
[   49.127774] lr : tegra_spi_transfer_one_message+0x550/0xbc8 [spi_tegra114]
[   49.127780] sp : ffff80000e30bce0
[   49.127784] x29: ffff80000e30bce0 x28: 0000000000000000 x27: 0000000000000000
[   49.127790] x26: ffff80000cd73790 x25: ffff80000cd737d0 x24: 0000000040608007
[   49.127796] x23: ffff000092aaa800 x22: ffff000092b38600 x21: ffff000092b38600
[   49.127801] x20: ffff80000cd73848 x19: 0000000000000000 x18: 0000000000000000
[   49.127807] x17: 000000040044ffff x16: 005000f5b5503510 x15: 0000000000000000
[   49.127812] x14: ffff0000801dae80 x13: ffff3382ec16d000 x12: 00000000b464d91d
[   49.127819] x11: 0000000000000000 x10: 836db2a032b2883c x9 : 5eb61e7a18dc955e
[   49.127825] x8 : ffff00008985bdd8 x7 : 0000000000000003 x6 : 00000000f0c9536a
[   49.127833] x5 : 00000000410fd420 x4 : 0000000000c0000e x3 : 0000000000000000
[   49.127840] x2 : 0000000000000000 x1 : 0000000000000000 x0 : 0000000000000000
[   49.127850] Call trace:
[   49.127857]  tegra_spi_transfer_one_message+0xa3c/0xbc8 [spi_tegra114]
[   49.127864]  __spi_pump_messages+0x384/0x7f0
[   49.127928]  spi_pump_messages+0x2c/0x40
[   49.127936]  kthread_worker_fn+0xb8/0x290
[   49.127962]  kthread+0x184/0x190
[   49.127972]  ret_from_fork+0x10/0x20
[   49.127993] ---[ end trace 6fef0303a9df98a0 ]---
[   50.133091] sched: RT throttling activated
[   50.496652] spi-tegra114 c260000.spi: spi transfer timeout, err 0
[   50.501674] tegra-gpcdma 2600000.dma-controller: DMA pause timed out
[   50.502052] spi_master spi2: failed to transfer one message from queue
[   60.903040] ------------[ cut here ]------------
[   60.903070] WARNING: CPU: 2 PID: 1830 at drivers/spi/spi-tegra114.c:1460 tegra_spi_transfer_one_message+0xa3c/0xbc8 [spi_tegra114]
[   60.903145] Modules linked in: can_raw can nvidia_modeset(O) aic8800_fdrv(OE) cfg80211 lzo_rle lzo_compress zram zsmalloc aic_load_fw(OE) ramoops reed_solomon nv_cam(O) max96717 snd_soc_tegra210_admaif(O) snd_soc_tegra186_asrc(O) snd_soc_tegra210_mixer(O) snd_soc_tegra_pcm snd_soc_tegra210_afc(O) snd_soc_tegra186_arad(O) snd_soc_tegra210_ope(O) snd_soc_tegra210_dmic(O) snd_soc_tegra210_amx(O) snd_soc_tegra210_mvc(O) snd_soc_tegra186_dspk(O) snd_soc_tegra210_sfc(O) snd_soc_tegra210_adx(O) snd_soc_tegra210_i2s(O) snd_soc_tegra210_ahub(O) tegra210_adma mcp251xfd nvvrs_pseq_rtc(O) tegra_pcie_dma_test(O) tegra_pcie_edma(O) snd_hda_codec_hdmi mttcan(O) can_dev tegra_cactmon_mc_all(O) tegra234_aon(O) tegra_aconnect snd_hda_tegra max96724 snd_hda_codec snd_hda_core max_serdes_all at24 pwm_tegra_tachometer(O) nvethernet(O) spi_tegra114(E) mc_hwpm(O) nvpps(O) host1x_fence(O) crct10dif_ce snd_soc_tegra_machine_driver(O) snd_soc_tegra_utils(O) snd_soc_simple_card_utils rfkill
[   60.903326]  tegra23x_perf_uncore(O) tegra234_oc_event(O) nvpmodel_clk_cap(O) nvidia(O) tegra_mce(O) thermal_trip_event(O) i2c_nvvrs11(O) lm90 nvhost_vi5(O) nvhost_isp5(O) nvhost_nvcsi_t194(O) nvidia_vrs_pseq(O) tegra_dce(O) bridge stp llc usb_f_ncm usb_f_mass_storage tegra_camera(O) v4l2_dv_timings nvhost_nvcsi(O) tegra_camera_platform(O) capture_ivc(O) tegra_camera_rtcpu(O) ivc_bus(O) hsp_mailbox_client(O) ivc_ext(O) v4l2_fwnode usb_f_acm v4l2_async videobuf2_dma_contig u_serial governor_userspace videobuf2_memops usb_f_rndis videobuf2_v4l2 tegra_drm(O) u_ether videobuf2_common videodev tegra_wmark(O) libcomposite nvhost_pva(O) mc nvhost_nvdla(O) cec tegra_se(O) nvhwpm(O) nvhost_capture(O) drm_kms_helper tsecriscv(O) host1x_nvhost(O) crypto_engine nvidia_p2p(O) ina3221 nvgpu(O) governor_pod_scaling(O) host1x(O) mc_utils(O) nvmap(O) nvsciipc(O) drm fuse ip_tables x_tables ipv6 pwm_fan(E) pwm_tegra(E) tegra_bpmp_thermal(E) tegra_xudc(E) ucsi_ccg(E) typec_ucsi(E) typec(E) nvme(E)
[   60.903628]  nvme_core(E) phy_tegra194_p2u(E) pcie_tegra194(E)
[   60.903655] CPU: 2 PID: 1830 Comm: ifconfig Tainted: G        W  OE     5.15.136-tegra #1
[   60.903670] Hardware name: NVIDIA NVIDIA Jetson AGX Orin Developer Kit/Jetson, BIOS 36.3.0-gcid-36191598 05/06/2024
[   60.903679] pstate: 60400009 (nZCv daif +PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[   60.903691] pc : tegra_spi_transfer_one_message+0xa3c/0xbc8 [spi_tegra114]
[   60.903699] lr : tegra_spi_transfer_one_message+0x550/0xbc8 [spi_tegra114]
[   60.903706] sp : ffff80000cd73450
[   60.903710] x29: ffff80000cd73450 x28: 00000000000000fc x27: ffff0000a1800940
[   60.903718] x26: ffff80000cd73680 x25: ffff80000cd736c0 x24: 0000000040408007
[   60.903725] x23: ffff000092aaa800 x22: ffff000092b38600 x21: ffff000092b38600
[   60.903733] x20: ffff80000cd736e8 x19: 0000000000000000 x18: 0000000000000000
[   60.903741] x17: 000000040044ffff x16: 005000f5b5503510 x15: 0000000000000000
[   60.903748] x14: ffff0000801dbe00 x13: ffff3382ec0dc000 x12: 00000000b464d91d
[   60.903755] x11: 0000000000000000 x10: dc48ca45fee5ae0a x9 : a2d9b3d1aae4fdd7
[   60.903765] x8 : ffff000089498f58 x7 : 0000000000000003 x6 : 0000000106b88f6a
[   60.903771] x5 : 00000000410fd420 x4 : 0000000000c0000e x3 : 0000000000000000
[   60.903778] x2 : 0000000000000000 x1 : 0000000000000000 x0 : 0000000000000000
[   60.903790] Call trace:
[   60.903799]  tegra_spi_transfer_one_message+0xa3c/0xbc8 [spi_tegra114]
[   60.903806]  __spi_pump_messages+0x384/0x7f0
[   60.903871]  __spi_sync+0x2d0/0x310
[   60.903878]  spi_sync+0x3c/0x60
[   60.903884]  mcp251xfd_regmap_crc_read+0x144/0x2c0 [mcp251xfd]
[   60.903902]  _regmap_raw_read+0xec/0x2e0
[   60.903925]  regmap_raw_read+0x1a0/0x290
[   60.903930]  regmap_bulk_read+0x1b8/0x260
[   60.903936]  mcp251xfd_dump+0xdc/0x31c [mcp251xfd]
[   60.903943]  mcp251xfd_chip_start+0x3c/0x7e0 [mcp251xfd]
[   60.903951]  mcp251xfd_open+0x2a0/0x390 [mcp251xfd]
[   60.903957]  __dev_open+0xf4/0x1e0
[   60.903987]  __dev_change_flags+0x19c/0x220
[   60.903993]  dev_change_flags+0x44/0x90
[   60.903999]  devinet_ioctl+0x548/0x700
[   60.904019]  inet_ioctl+0x1a4/0x1d0
[   60.904023]  sock_do_ioctl+0x58/0x110
[   60.904042]  sock_ioctl+0x2e0/0x4d0
[   60.904049]  __arm64_sys_ioctl+0xb4/0x100
[   60.904069]  invoke_syscall+0x5c/0x130
[   60.904089]  el0_svc_common.constprop.0+0x64/0x110
[   60.904096]  do_el0_svc+0x74/0xa0
[   60.904103]  el0_svc+0x28/0x80
[   60.904119]  el0t_64_sync_handler+0xa4/0x130
[   60.904123]  el0t_64_sync+0x1a4/0x1a8
[   60.904131] ---[ end trace 6fef0303a9df98a1 ]---
[   60.908223] tegra-gpcdma 2600000.dma-controller: DMA pause timed out
[   60.908389] spi-tegra114 c260000.spi: TxDma Xfer failed
[   61.004890] spi-tegra114 c260000.spi: spi transfer timeout, err 0
[   61.006153] spi_master spi2: failed to transfer one message from queue
[   71.142993] ------------[ cut here ]------------
[   71.143020] WARNING: CPU: 2 PID: 1830 at drivers/spi/spi-tegra114.c:1460 tegra_spi_transfer_one_message+0xa3c/0xbc8 [spi_tegra114]
[   71.143078] Modules linked in: can_raw can nvidia_modeset(O) aic8800_fdrv(OE) cfg80211 lzo_rle lzo_compress zram zsmalloc aic_load_fw(OE) ramoops reed_solomon nv_cam(O) max96717 snd_soc_tegra210_admaif(O) snd_soc_tegra186_asrc(O) snd_soc_tegra210_mixer(O) snd_soc_tegra_pcm snd_soc_tegra210_afc(O) snd_soc_tegra186_arad(O) snd_soc_tegra210_ope(O) snd_soc_tegra210_dmic(O) snd_soc_tegra210_amx(O) snd_soc_tegra210_mvc(O) snd_soc_tegra186_dspk(O) snd_soc_tegra210_sfc(O) snd_soc_tegra210_adx(O) snd_soc_tegra210_i2s(O) snd_soc_tegra210_ahub(O) tegra210_adma mcp251xfd nvvrs_pseq_rtc(O) tegra_pcie_dma_test(O) tegra_pcie_edma(O) snd_hda_codec_hdmi mttcan(O) can_dev tegra_cactmon_mc_all(O) tegra234_aon(O) tegra_aconnect
[   71.143178] spi-tegra114 c260000.spi: RxDma Xfer failed
[   71.143183]  snd_hda_tegra
[   71.143185]  max96724 snd_hda_codec
[   71.143190] spi-tegra114 c260000.spi: DmaXfer: ERROR bit set 0x400005
[   71.143193]  snd_hda_core
[   71.143196] spi-tegra114 c260000.spi: DmaXfer 0x40409827:0x00000100
[   71.143197]  max_serdes_all
[   71.143199]  at24 pwm_tegra_tachometer(O) nvethernet(O) spi_tegra114(E) mc_hwpm(O) nvpps(O) host1x_fence(O) crct10dif_ce snd_soc_tegra_machine_driver(O) snd_soc_tegra_utils(O) snd_soc_simple_card_utils rfkill tegra23x_perf_uncore(O) tegra234_oc_event(O) nvpmodel_clk_cap(O) nvidia(O) tegra_mce(O) thermal_trip_event(O) i2c_nvvrs11(O) lm90 nvhost_vi5(O) nvhost_isp5(O) nvhost_nvcsi_t194(O) nvidia_vrs_pseq(O) tegra_dce(O) bridge stp llc usb_f_ncm usb_f_mass_storage tegra_camera(O) v4l2_dv_timings nvhost_nvcsi(O) tegra_camera_platform(O) capture_ivc(O) tegra_camera_rtcpu(O) ivc_bus(O) hsp_mailbox_client(O) ivc_ext(O) v4l2_fwnode usb_f_acm v4l2_async videobuf2_dma_contig u_serial governor_userspace videobuf2_memops usb_f_rndis videobuf2_v4l2 tegra_drm(O) u_ether videobuf2_common videodev tegra_wmark(O) libcomposite nvhost_pva(O) mc nvhost_nvdla(O) cec tegra_se(O) nvhwpm(O) nvhost_capture(O) drm_kms_helper tsecriscv(O) host1x_nvhost(O) crypto_engine nvidia_p2p(O) ina3221 nvgpu(O)
[   71.143422]  governor_pod_scaling(O) host1x(O) mc_utils(O) nvmap(O) nvsciipc(O) drm fuse ip_tables x_tables ipv6 pwm_fan(E) pwm_tegra(E) tegra_bpmp_thermal(E) tegra_xudc(E) ucsi_ccg(E) typec_ucsi(E) typec(E) nvme(E) nvme_core(E) phy_tegra194_p2u(E) pcie_tegra194(E)
[   71.143493] CPU: 2 PID: 1830 Comm: ifconfig Tainted: G        W  OE     5.15.136-tegra #1
[   71.143502] Hardware name: NVIDIA NVIDIA Jetson AGX Orin Developer Kit/Jetson, BIOS 36.3.0-gcid-36191598 05/06/2024
[   71.143510] pstate: 60400009 (nZCv daif +PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[   71.143521] pc : tegra_spi_transfer_one_message+0xa3c/0xbc8 [spi_tegra114]
[   71.143527] lr : tegra_spi_transfer_one_message+0x550/0xbc8 [spi_tegra114]
[   71.143533] sp : ffff80000cd73450
[   71.143537] x29: ffff80000cd73450 x28: 00000000000000fc x27: ffff0000a1800940
[   71.143545] x26: ffff80000cd73680 x25: ffff80000cd736c0 x24: 0000000040408007
[   71.143551] x23: ffff000092aaa800 x22: ffff000092b38600 x21: ffff000092b38600
[   71.143558] x20: ffff80000cd736e8 x19: 0000000000000000 x18: 0000000000000000
[   71.143566] x17: 000000040044ffff x16: 005000f5b5503510 x15: 0000000000000000
[   71.143572] x14: ffff0000801dbe00 x13: ffff3382ec0dc000 x12: 00000000b464d91d
[   71.143578] x11: 0000000000000000 x10: dc48ca45fee5ae0a x9 : a2d9b3d1aae4fdd7
[   71.143583] x8 : ffff000089498f58 x7 : 0000000000000003 x6 : 0000000119cb5f6a
[   71.143590] x5 : 00000000410fd420 x4 : 0000000000c0000e x3 : 0000000000000000
[   71.143596] x2 : 0000000000000000 x1 : 0000000000000000 x0 : 0000000000000000
[   71.143605] Call trace:
[   71.143611]  tegra_spi_transfer_one_message+0xa3c/0xbc8 [spi_tegra114]
[   71.143620]  __spi_pump_messages+0x384/0x7f0
[   71.143662]  __spi_sync+0x2d0/0x310
[   71.143668]  spi_sync+0x3c/0x60
[   71.143676]  mcp251xfd_regmap_crc_read+0x144/0x2c0 [mcp251xfd]
[   71.143690]  _regmap_raw_read+0xec/0x2e0
[   71.143711]  regmap_raw_read+0x1a0/0x290
[   71.143716]  regmap_bulk_read+0x1b8/0x260
[   71.143721]  mcp251xfd_dump+0xdc/0x31c [mcp251xfd]
[   71.143728]  mcp251xfd_chip_start+0x3c/0x7e0 [mcp251xfd]
[   71.143734]  mcp251xfd_open+0x2a0/0x390 [mcp251xfd]
[   71.143739]  __dev_open+0xf4/0x1e0
[   71.143762]  __dev_change_flags+0x19c/0x220
[   71.143768]  dev_change_flags+0x44/0x90
[   71.143775]  devinet_ioctl+0x548/0x700
[   71.143792]  inet_ioctl+0x1a4/0x1d0
[   71.143796]  sock_do_ioctl+0x58/0x110
[   71.143809]  sock_ioctl+0x2e0/0x4d0
[   71.143813]  __arm64_sys_ioctl+0xb4/0x100
[   71.143825]  invoke_syscall+0x5c/0x130
[   71.143842]  el0_svc_common.constprop.0+0x64/0x110
[   71.143848]  do_el0_svc+0x74/0xa0
[   71.143853]  el0_svc+0x28/0x80
[   71.143867]  el0t_64_sync_handler+0xa4/0x130
[   71.143872]  el0t_64_sync+0x1a4/0x1a8
[   71.143878] ---[ end trace 6fef0303a9df98a2 ]---
[   71.244522] spi-tegra114 c260000.spi: spi transfer timeout, err 0
[   71.249537] tegra-gpcdma 2600000.dma-controller: DMA pause timed out
and i try to disable the dma , just use tegra_spi_start_cpu_based_transfer , ti can work up .
but use tegra_spi_start_cpu_based_transfer only can send 1 message, and cannot recv any message.
i can also use the spi@3210000 and spi@3230000 is work well
my dts settings :
        spi@c260000{
			status = "okay";
			spi-max-frequency = <12000000>;
			spi_can4: spi_can4@0 {
				compatible = "microchip,mcp2518fd";
				status = "okay";
				reg = <0x0>;
				clocks = <&can_clock>;
				interrupts-extended = <&gpio_aon TEGRA234_AON_GPIO(AA, 7) IRQ_TYPE_LEVEL_LOW>;
				vdd-supply = <&vdd_5v0_sys>;
				xceiver-supply = <&vdd_5v0_sys>;
				controller-data {
					nvidia,enable-hw-based-cs;
					nvidia,cs-setup-clk-count = <0x1e>;
					nvidia,cs-hold-clk-count = <0x1e>;
					nvidia,rx-clk-tap-delay = <0x1f>;
					nvidia,tx-clk-tap-delay = <0x0>;
how can i fix it ? i think is a bug in spi-tegra114.c
If the device cannot be flashed/booted, please refer to the page to get uart log from the device:
Jetson/General debug - eLinux.org
And get logs of host PC and Jetson device for reference. If you are using custom board, you can compare uart log of developer kit and custom board to get more information.
Also please check FAQs:
Jetson AGX Orin FAQ
If possible, we would suggest follow quick start in developer guide to re-flash the system:
Quick Start — NVIDIA Jetson Linux Developer Guide 1 documentation
And see if the issue still persists on a clean-flashed system.
sorry it doesn’t seem to be of much help.
Hi duztfeng,
It seems you are using SPI2 from SPE.
Could you share the full device tree for further check?
ok
is my dts file
example.dts.txt (363.0 KB)
this issue is same as AGX Orin spi-tegra114 c260000.spi crashed when sending large amounts of data in JetPack 6.0 - #13 by bbear953308023
and i set the max dma buffer to 256 , the spi can up well
but . the mcp2518fd in this spi , cannot recv any message and just can only send 1 can package.
hello @KevinFFF
this issue has been block our project , did you have any suggestions?
If the issue is specific to sending packet size > 256 Bytes,
please modify the following line in your device tree to check if it could help.
		spi@c260000 {
			compatible = "nvidia,tegra210-spi";
			reg = <0x00 0xc260000 0x00 0x1000>;
			interrupts = <0x00 0x25 0x04>;
			#address-cells = <0x01>;
			#size-cells = <0x00>;
			clocks = <0x04 0x88>;
			clock-names = "spi";
			iommus = <0x05 0x04>;
			assigned-clocks = <0x04 0x88>;
			assigned-clock-parents = <0x04 0x66>;
			resets = <0x04 0x5c>;
			reset-names = "spi";
-			dmas = <0xe1 0x13 0xe1 0x13>;
+			dmas = <0xe1 0x10 0xe1 0x10>;
			dma-names = "rx\0tx";
			dma-coherent;
			status = "okay";
			spi-max-frequency = <0xb71b00>;
			nvidia,clock-always-on;
this change seems work
but, mcp2518fd still cannot send/receive CAN data packets
MCP2518FD is connected on SPI interface.
Please apply the patch from Jetson orin nano SPI Speed not changing - #9 by KevinFFF to check if it could help.
sorry this patch has no effect
Is there the data on SPI bus?
Could you also verify using MCP2518FD on SPI1?
We’ve verified it working on the devkit with JP6.2.
hi @KevinFFF i update my jetpack to 36.4, this issue still persists.
this bus has spi data , because the mcp2518fd can be set up, and set params
but can not send or recv can message.
our board has 3 mcp2518fd , there connected to spi1: spi@3210000 、 spi2 spi@c260000 、spi@3230000
only the spi2 spi@c260000 has this issue.
dmas = <0xe1 0x10 0xe1 0x10>; works well , fixed the dma 256byte issue. but the can message still cannot send and recv。
Do you mean that spi1 and spi3 work as expected for MCP251FD but you still hit the issue for spi@c260000?
If so, please run the following command on your board.
$ sudo dtc -I fs -O dts -o extracted_proc.dts /proc/device-tree
And share extracted_proc.dts + dmesg for further check.
hi @KevinFFF
Do you mean that spi1 and spi3 work as expected for MCP251FD but you still hit the issue for spi@c260000 ?
→ yes
there is my dts file and dmesg log
dmesg.log (133.3 KB)
extracted_proc.dts.txt (441.0 KB)
What is spi-gpio in your device tree? Is that your custom driver?
Have you configured the pinmux for spi2 manually before using it?
Please also add the following line to check if it could help.
			spi_can4@0 {
				clocks = <0x116>;
				xceiver-supply = <0x117>;
				interrupts-extended = <0x118 0x07 0x08>;
				vdd-supply = <0x117>;
				status = "okay";
				reg = <0x00>;
				phandle = <0x2a4>;
				controller-data {
+					nvidia,enable-hw-based-cs;
					nvidia,tx-clk-tap-delay = <0x00>;
Do you run any command for spi2 so that it prints the following info?
[   64.027499] mcp251xfd spi3.0 can3: FIFO setup: TEF: 8*12 bytes = 96 bytes, TX: 8*72 bytes = 576 bytes
[   64.027513] mcp251xfd spi3.0 can3: FIFO setup: RX-0: 16*76 bytes = 1216 bytes
[   64.027516] mcp251xfd spi3.0 can3: FIFO setup: free: 160 bytes
hi @KevinFFF
–》 That’s another SPI, emulated by GPIO, which has nothing to do with the current issue.
–》 yes, there is my configure
                spi2_sck_pcc0 {
                    nvidia,pins = "spi2_sck_pcc0";
                    nvidia,function = "spi2";
                    nvidia,pull = <TEGRA_PIN_PULL_UP>;
                    nvidia,tristate = <TEGRA_PIN_DISABLE>;
                    nvidia,enable-input = <TEGRA_PIN_DISABLE>;
                    nvidia,io-high-voltage = <TEGRA_PIN_DISABLE>;
                    nvidia,lpdr = <TEGRA_PIN_DISABLE>;
                spi2_miso_pcc1 {
                    nvidia,pins = "spi2_miso_pcc1";
                    nvidia,tristate = <TEGRA_PIN_ENABLE>;
                    nvidia,enable-input = <TEGRA_PIN_ENABLE>;
                spi2_mosi_pcc2 {
                    nvidia,pins = "spi2_mosi_pcc2";
                spi2_cs0_pcc3 {
                    nvidia,pins = "spi2_cs0_pcc3";
nvidia,enable-hw-based-cs; → It has no effect on solving this problem
is config the spi3 can3.
sudo ip link set can3 type can bitrate 1000000 sample-point 0.75 dbitrate 5000000 dsample-point 0.75 berr-reporting on fd on restart-ms 100
sudo ifconfig can3 up
can3 dts is that
	aliases {
		can2 = &spi_can3;
		can3 = &spi_can4;
		can4 = &spi_can5;
		can5 = &spi_can6;
		can6 = &spi_can7;
		can7 = &spi_can8;
        spi@c260000{
			status = "okay";
			//nvidia,maximum-dma-buffer-size = <256>;
			dmas = <&gpcdma 16>, <&gpcdma 16>;
				status = "okay";
				reg = <0x0>;
				//interrupt-parent = <&gpio>;
				//interrupts = <TEGRA234_MAIN_GPIO(N, 1) IRQ_TYPE_LEVEL_LOW>;
				controller-data {
Please configure nvidia,pull as TEGRA_PIN_PULL_NONE instead.
You can refer to Jetson Sensor Processing Engine (SPE) Developer Guide: SPI application (app/spi-app.c and app/spi-slv-app.c) for details.
Have you verified SPI loopback test for spi2 before using mcp2518fd for CAN data?
hi @KevinFFF
I configure TEGRA_PIN_PULL_NONE instead.
and the spi2 loopback test is fail
The result is very strange. It seems that sending numbers or certain specific characters will result in inconsistencies.
Other SPI bus don’t have this problem.
how can i do for next ?
Could you get a scope to check SPI data from SPI2 when you connect with MCP2518FD?
I remember that the level is different from others since there’s no level shift to transform from 1.8V to 3.3V as others.
