Hi,carolyuu!
Thanks to your instant reply.
I can now perform a re-flash, but I want to preserve this problematic environment. This issue emerged suddenly after multiple high-temperature power cycling tests, and I am eager to understand its cause.
Here is the uart log information:
g▒▒
[0000.063] I> MB1 (version: 1.4.0.1-t234-54845784-08e631ca)
[0000.068] I> t234-A01-1-Silicon (0x12347) Prod
[0000.073] I> Boot-mode : Coldboot
[0000.076] I> Entry timestamp: 0x00000000
[0000.080] I> last_boot_error: 0x0
[0000.083] I> BR-BCT: preprod_dev_sign: 0
[0000.086] I> rst_source: 0x0, rst_level: 0x0
[0000.091] I> Task: SE error check
[0000.094] I> Task: Bootchain select WAR set
[0000.098] I> Task: Enable SLCG
[0000.101] I> Task: CRC check
[0000.103] I> Task: Initialize MB2 params
[0000.108] I> MB2-params @ 0x40060000
[0000.111] I> Task: Crypto init
[0000.114] I> Task: Perform MB1 KAT tests
[0000.118] I> Task: NVRNG health check
[0000.121] I> NVRNG: Health check success
[0000.125] I> Task: MSS Bandwidth limiter settings for iGPU clients
[0000.131] I> Task: Enabling and initialization of Bandwidth limiter
[0000.137] I> No request to configure MBWT settings for any PC!
[0000.143] I> Task: Secure debug controls
[0000.147] I> Task: strap war set
[0000.150] I> Task: Initialize SOC Therm
[0000.154] I> Task: Program NV master stream id
[0000.158] I> Task: Verify boot mode
[0000.164] I> Task: Alias fuses
[0000.167] W> FUSE_ALIAS: Fuse alias on production fused part is not supported.
[0000.174] I> Task: Print SKU type
[0000.177] I> FUSE_OPT_CCPLEX_CLUSTER_DISABLE = 0x00000000
[0000.182] I> FUSE_OPT_GPC_DISABLE = 0x00000000
[0000.186] I> FUSE_OPT_TPC_DISABLE = 0x00000000
[0000.191] I> FUSE_OPT_DLA_DISABLE = 0x00000000
[0000.195] I> FUSE_OPT_PVA_DISABLE = 0x00000000
[0000.199] I> FUSE_OPT_NVENC_DISABLE = 0x00000000
[0000.204] I> FUSE_OPT_NVDEC_DISABLE = 0x00000000
[0000.208] I> FUSE_OPT_FSI_DISABLE = 0x00000000
[0000.212] I> FUSE_OPT_EMC_DISABLE = 0x00000000
[0000.217] I> FUSE_BOOTROM_PATCH_VERSION = 0x7
[0000.221] I> FUSE_PSCROM_PATCH_VERSION = 0x7
[0000.225] I> FUSE_OPT_ADC_CAL_FUSE_REV = 0x2
[0000.229] I> FUSE_SKU_INFO_0 = 0x90
[0000.232] I> FUSE_OPT_SAMPLE_TYPE_0 = 0x3 PS
[0000.237] I> FUSE_PACKAGE_INFO_0 = 0x2
[0000.240] I> SKU: Prod
[0000.242] I> Task: Boost clocks
[0000.245] I> Initializing PLLC2 for AXI_CBB.
[0000.250] I> AXI_CBB : src = 35, divisor = 0
[0000.254] I> Task: Voltage monitor
[0000.257] I> VMON: Vmon re-calibration and fine tuning done
[0000.262] I> Task: UPHY init
[0000.267] I> HSIO UPHY init done
[0000.270] W> Skipping GBE UPHY config
[0000.274] I> Task: Boot device init
[0000.277] I> Boot_device: QSPI_FLASH instance: 0
[0000.282] I> Qspi clock source : pllc_out0
[0000.286] I> QSPI Flash: Macronix 64MB
[0000.290] I> QSPI-0l initialized successfully
[0000.294] I> Task: TSC init
[0000.297] I> Task: Load membct
[0000.299] I> RAM_CODE 0x4000441
[0000.303] I> Loading MEMBCT
[0000.305] I> Slot: 0
[0000.307] I> Binary[1] block-3840 (partition size: 0x40000)
[0000.313] I> Binary name: MEM-BCT-1
[0000.316] I> Size of crypto header is 8192
[0000.320] I> Size of crypto header is 8192
[0000.324] I> strt_pg_num(3840) num_of_pgs(16) read_buf(0x40050000)
[0000.330] I> BCH of MEM-BCT-1 read from storage
[0000.334] I> BCH address is : 0x40050000
[0000.338] I> MEM-BCT-1 header integrity check is success
[0000.344] I> Binary magic in BCH component 1 is MEM1
[0000.348] I> component binary type is 1
[0000.352] I> strt_pg_num(3971) num_of_pgs(115) read_buf(0x40040000)
[0000.359] I> MEM-BCT-1 binary is read from storage
[0000.364] I> MEM-BCT-1 binary integrity check is success
[0000.369] I> Binary MEM-BCT-1 loaded successfully at 0x40040000 (0xe580)
[0000.375] I> RAM_CODE 0x4000441
[0000.381] I> RAM_CODE 0x4000441
[0000.385] I> Task: Load Page retirement list
[0000.389] I> Slot: 0
[0000.391] I> Binary[4] block-125952 (partition size: 0x80000)
[0000.396] I> Binary name: DRAM bad page list (P)
[0000.401] I> Size of crypto header is 8192
[0000.405] I> Size of crypto header is 8192
[0000.409] I> strt_pg_num(125952) num_of_pgs(16) read_buf(0x40050000)
[0000.415] I> BCH of DRAM bad page list (P) read from storage
[0000.421] I> BCH address is : 0x40050000
[0000.424] I> component binary type is 4
[0000.428] I> DRAM bad page list (P) header integrity check is success
[0000.434] I> Binary magic in BCH component 0 is BINF
[0000.439] I> component binary type is 4
[0000.443] I> component binary type is 4
[0000.446] I> Size of crypto header is 8192
[0000.450] I> component binary type is 4
[0000.454] I> strt_pg_num(125968) num_of_pgs(8) read_buf(0x40040000)
[0000.460] I> DRAM bad page list (P) binary is read from storage
[0000.466] I> DRAM bad page list (P) binary integrity check is success
[0000.472] I> Binary DRAM bad page list (P) loaded successfully at 0x40040000 (0x1000)
[0000.483] I> Task: SDRAM params override
[0000.487] I> Task: Save mem-bct info
[0000.490] I> Task: Carveout allocate
[0000.493] I> RCM blob carveout will not be allocated
[0000.498] I> Update CCPLEX IST carveout from MB1-BCT
[0000.503] I> ECC region[0]: Start:0x80000000, End:0xe80000000
[0000.509] I> ECC region[1]: Start:0x0, End:0x0
[0000.513] I> ECC region[2]: Start:0x0, End:0x0
[0000.517] I> ECC region[3]: Start:0x0, End:0x0
[0000.521] I> ECC region[4]: Start:0x0, End:0x0
[0000.526] I> Non-ECC region[0]: Start:0x0, End:0x0
[0000.530] I> Non-ECC region[1]: Start:0x0, End:0x0
[0000.535] I> Non-ECC region[2]: Start:0x0, End:0x0
[0000.540] I> Non-ECC region[3]: Start:0x0, End:0x0
[0000.544] I> Non-ECC region[4]: Start:0x0, End:0x0
[0000.555] I> allocated(CO:44) base:0xe49800000 size:0x36800000 align: 0x100000
[0000.562] I> allocated(CO:31) base:0xe40000000 size:0x8000000 align: 0x8000000
[0000.569] I> allocated(CO:43) base:0xe3c000000 size:0x4000000 align: 0x200000
[0000.576] I> allocated(CO:39) base:0xe39e00000 size:0x2200000 align: 0x10000
[0000.583] I> allocated(CO:20) base:0xe36000000 size:0x2000000 align: 0x2000000
[0000.590] I> allocated(CO:24) base:0xe34000000 size:0x2000000 align: 0x2000000
[0000.597] I> allocated(CO:28) base:0xe32000000 size:0x2000000 align: 0x2000000
[0000.605] I> allocated(CO:29) base:0xe30000000 size:0x2000000 align: 0x2000000
[0000.612] I> allocated(CO:22) base:0xe48000000 size:0x1000000 align: 0x1000000
[0000.619] I> allocated(CO:41) base:0xe38e00000 size:0x1000000 align: 0x100000
[0000.626] I> allocated(CO:35) base:0xe38000000 size:0xe00000 align: 0x10000
[0000.633] I> allocated(CO:02) base:0xe49000000 size:0x800000 align: 0x800000
[0000.640] I> allocated(CO:03) base:0xe2f800000 size:0x800000 align: 0x800000
[0000.647] I> allocated(CO:06) base:0xe2f000000 size:0x800000 align: 0x800000
[0000.654] I> allocated(CO:56) base:0xe2e800000 size:0x800000 align: 0x200000
[0000.660] I> allocated(CO:07) base:0xe2e400000 size:0x400000 align: 0x400000
[0000.667] I> allocated(CO:33) base:0xe2e000000 size:0x400000 align: 0x200000
[0000.674] I> allocated(CO:23) base:0xe2de00000 size:0x200000 align: 0x200000
[0000.681] I> allocated(CO:01) base:0xe2dd00000 size:0x100000 align: 0x100000
[0000.688] I> allocated(CO:05) base:0xe2dc00000 size:0x100000 align: 0x100000
[0000.695] I> allocated(CO:08) base:0xe2db00000 size:0x100000 align: 0x100000
[0000.702] I> allocated(CO:09) base:0xe2da00000 size:0x100000 align: 0x100000
[0000.709] I> allocated(CO:15) base:0xe2d900000 size:0x100000 align: 0x100000
[0000.716] I> allocated(CO:17) base:0xe2d800000 size:0x100000 align: 0x100000
[0000.723] I> allocated(CO:27) base:0xe2d700000 size:0x100000 align: 0x100000
[0000.730] I> allocated(CO:42) base:0xe2d600000 size:0x100000 align: 0x100000
[0000.737] I> allocated(CO:54) base:0xe2d580000 size:0x80000 align: 0x80000
[0000.744] I> allocated(CO:34) base:0xe2d570000 size:0x10000 align: 0x10000
[0000.750] I> allocated(CO:72) base:0xe2d370000 size:0x200000 align: 0x10000
[0000.757] I> allocated(CO:47) base:0xe2ce00000 size:0x400000 align: 0x200000
[0000.764] I> allocated(CO:48) base:0xe2d350000 size:0x20000 align: 0x10000
[0000.771] I> allocated(CO:69) base:0xe2d330000 size:0x20000 align: 0x10000
[0000.778] I> allocated(CO:49) base:0xe2d320000 size:0x10000 align: 0x10000
[0000.784] I> allocated(CO:50) base:0xe2d310000 size:0x10000 align: 0x10000
[0000.791] I> allocated(CO:52) base:0xe2d300000 size:0x10000 align: 0x10000
[0000.798] I> NSDRAM base: 0x80000000, end: 0xe2d370000, size: 0xdad370000
[0000.805] I> Task: Thermal check
[0000.808] I> max_chip_limit = 125
[0000.811] I> min_chip_limit = -43
[0000.814] I> max temp read = 28
[0000.817] I> min temp read = 27
[0000.820] I> Task: Update FSI SCR with thermal fuse data
[0000.825] I> Task: Enable WDT 5th expiry
[0000.829] I> Task: I2C register
[0000.832] I> Task: Set I2C bus freq
[0000.835] I> Task: Reset FSI
[0000.838] I> Task: Pinmux init
[0000.841] I> Task: Prod config init
[0000.845] I> Task: Pad voltage init
[0000.848] I> Task: Prod init
[0000.851] I> Task: Program rst req config reg
[0000.855] I> Task: Common rail init
[0000.858] I> DONE: Thermal config
[0000.862] W> DEVICE_PROD: module = 13, instance = 4 not found in device prod.
[0000.870] I> DONE: SOC rail config
[0000.874] W> PMIC_CONFIG: Rail: MEMIO rail config not found in MB1 BCT.
[0000.881] I> DONE: MEMIO rail config
[0000.884] I> DONE: GPU rail info
[0000.887] I> DONE: CV rail info
[0000.890] I> Task: Mem clock src
[0000.893] I> Task: Misc. board config
[0000.897] I> PMIC_CONFIG: Platform config not found in MB1 BCT.
[0000.903] I> Task: SDRAM init
[0000.906] I> MemoryType: 4 MemBctRevision: 1
[0000.913] I> MSS CAR: PLLM/HUB programming for MemoryType: 4 and MemBctRevision: 1
[0000.920] I> MSS CAR: Init PLLM
[0000.923] I> MSS CAR: Init PLLHUB
[0000.928] I> Encryption: MTS: en, TX: en, VPR: en, GSC: en
[0000.940] I> SDRAM initialized!
[0000.943] I> SDRAM Size in Total 0xe00000000
[0000.947] I> Task: Dram Ecc scrub
[0000.950] I> DRAM ECC Scrub Mode: full
[0002.671] I> SDRAM scrub successful
[0002.674] I> Task: DRAM alias check
[0002.691] I> Task: Program NSDRAM carveout
[0002.695] I> NSDRAM carveout encryption is enabled
[0002.700] I> Program NSDRAM carveout
[0002.703] I> Task: Register checker
[0002.707] I> Task: Enable clock-mon
[0002.721] I> FMON: Fmon re-programming done
[0002.725] I> Task: Mapper init
[0002.728] I> Task: SC7 Context Init
[0002.731] I> Task: CCPLEX IST init
[0002.735] I> Task: CPU WP0
[0002.737] I> Loading MCE
[0002.740] I> Slot: 0
[0002.742] I> Binary[8] block-20736 (partition size: 0x80000)
[0002.747] I> Binary name: MCE
[0002.750] I> Size of crypto header is 8192
[0002.754] I> Size of crypto header is 8192
[0002.758] I> strt_pg_num(20736) num_of_pgs(16) read_buf(0x4003e000)
[0002.764] I> BCH of MCE read from storage
[0002.768] I> BCH address is : 0x4003e000
[0002.772] I> MCE header integrity check is success
[0002.777] I> Binary magic in BCH component 0 is MTSM
[0002.781] I> component binary type is 8
[0002.785] I> Size of crypto header is 8192
[0002.789] I> strt_pg_num(20752) num_of_pgs(357) read_buf(0x40000000)
[0002.797] I> MCE binary is read from storage
[0002.802] I> MCE binary integrity check is success
[0002.806] I> Binary MCE loaded successfully at 0x40000000 (0x2c880)
[0002.813] I> Size of crypto header is 8192
[0002.824] I> Size of crypto header is 8192
[0002.828] I> Sending WP0 mailbox command to PSC
[0002.837] I> Task: XUSB Powergate
[0002.840] I> Skipping powergate XUSB.
[0002.843] I> Task: MB1 fixed firewalls
[0002.850] W> Firewall readback mismatch
[0002.855] I> Task: Load bpmp-fw
[0002.858] I> Slot: 0
[0002.860] I> Binary[15] block-9984 (partition size: 0x180000)
[0002.865] I> Binary name: BPMP_FW
[0002.868] I> Size of crypto header is 8192
[0002.872] I> Size of crypto header is 8192
[0002.876] I> strt_pg_num(9984) num_of_pgs(16) read_buf(0x807fe000)
[0002.883] I> BCH of BPMP_FW read from storage
[0002.887] I> BCH address is : 0x807fe000
[0002.891] I> BPMP_FW header integrity check is success
[0002.896] I> Binary magic in BCH component 0 is BPMF
[0002.900] I> component binary type is 15
[0002.904] I> Size of crypto header is 8192
[0002.908] I> strt_pg_num(10000) num_of_pgs(2028) read_buf(0x80000000)
[0002.926] I> BPMP_FW binary is read from storage
[0002.932] I> BPMP_FW binary integrity check is success
[0002.937] I> Binary BPMP_FW loaded successfully at 0x80000000 (0xfd640)
[0002.944] I> Slot: 0
[0002.946] I> Binary[16] block-13056 (partition size: 0x300000)
[0002.951] I> Binary name: BPMP_FW_DTB
[0002.955] I> Size of crypto header is 8192
[0002.959] I> Size of crypto header is 8192
[0002.963] I> strt_pg_num(13056) num_of_pgs(16) read_buf(0x807fc000)
[0002.969] I> BCH of BPMP_FW_DTB read from storage
[0002.974] I> BCH address is : 0x807fc000
[0002.977] I> BPMP_FW_DTB header integrity check is success
[0002.983] I> Binary magic in BCH component 0 is BPMD
[0002.988] I> component binary type is 16
[0002.991] I> Size of crypto header is 8192
[0002.995] I> strt_pg_num(13072) num_of_pgs(280) read_buf(0x807d8ff0)
[0003.003] I> BPMP_FW_DTB binary is read from storage
[0003.008] I> BPMP_FW_DTB binary integrity check is success
[0003.013] I> Binary BPMP_FW_DTB loaded successfully at 0x807d8ff0 (0x22f00)
[0003.020] I> Task: BPMP fw ast config
[0003.024] I> Task: Load psc-fw
[0003.027] I> Slot: 0
[0003.029] I> Binary[17] block-19200 (partition size: 0xc0000)
[0003.034] I> Binary name: PSC_FW
[0003.037] I> Size of crypto header is 8192
[0003.041] I> Size of crypto header is 8192
[0003.045] I> strt_pg_num(19200) num_of_pgs(16) read_buf(0x80ffe000)
[0003.052] I> BCH of PSC_FW read from storage
[0003.056] I> BCH address is : 0x80ffe000
[0003.060] I> PSC_FW header integrity check is success
[0003.064] I> Binary magic in BCH component 0 is PFWP
[0003.069] I> component binary type is 17
[0003.073] I> Size of crypto header is 8192
[0003.077] I> strt_pg_num(19216) num_of_pgs(717) read_buf(0x80fa4600)
[0003.087] I> PSC_FW binary is read from storage
[0003.092] I> PSC_FW binary integrity check is success
[0003.097] I> Binary PSC_FW loaded successfully at 0x80fa4600 (0x59980)
[0003.104] I> Task: Load nvdec-fw
[0003.107] I> Slot: 0
[0003.109] I> Binary[7] block-6400 (partition size: 0x100000)
[0003.114] I> Binary name: NVDEC
[0003.117] I> Size of crypto header is 8192
[0003.121] I> Size of crypto header is 8192
[0003.125] I> strt_pg_num(6400) num_of_pgs(16) read_buf(0x800fe000)
[0003.131] I> BCH of NVDEC read from storage
[0003.135] I> BCH address is : 0x800fe000
[0003.139] I> NVDEC header integrity check is success
[0003.144] I> Binary magic in BCH component 0 is NDEC
[0003.149] I> component binary type is 7
[0003.152] I> Size of crypto header is 8192
[0003.156] I> strt_pg_num(6416) num_of_pgs(560) read_buf(0x80000000)
[0003.166] I> NVDEC binary is read from storage
[0003.170] I> NVDEC binary integrity check is success
[0003.175] I> Binary NVDEC loaded successfully at 0x80000000 (0x46000)
[0003.182] I> Size of crypto header is 8192
[0003.193] I> Task: Load tsec-fw
[0003.196] I> TSEC-FW load support not enabled
[0003.200] I> Task: GPIO interrupt map
[0003.204] I> Task: SC7 context save
[0003.207] I> Slot: 0
[0003.209] I> Binary[27] block-0 (partition size: 0x100000)
[0003.215] I> Binary name: BR_BCT
[0003.218] I> Size of crypto header is 8192
[0003.222] I> Size of crypto header is 8192
[0003.226] I> Size of crypto header is 8192
[0003.230] I> strt_pg_num(0) num_of_pgs(16) read_buf(0xa0000000)
[0003.235] I> BR_BCT binary is read from storage
[0003.240] I> BR_BCT binary integrity check is success
[0003.245] I> Binary BR_BCT loaded successfully at 0xa0000000 (0x2000)
[0003.251] I> Slot: 0
[0003.253] I> Binary[13] block-21760 (partition size: 0x30000)
[0003.259] I> Binary name: SC7-FW
[0003.262] I> Size of crypto header is 8192
[0003.266] I> Size of crypto header is 8192
[0003.270] I> Size of crypto header is 8192
[0003.274] I> Size of crypto header is 8192
[0003.278] I> strt_pg_num(21760) num_of_pgs(16) read_buf(0xa0002000)
[0003.284] I> BCH of SC7-FW read from storage
[0003.288] I> BCH address is : 0xa0002000
[0003.292] I> SC7-FW header integrity check is success
[0003.297] I> Binary magic in BCH component 0 is WB0B
[0003.301] I> component binary type is 13
[0003.305] I> Size of crypto header is 8192
[0003.309] I> strt_pg_num(21776) num_of_pgs(347) read_buf(0xa0004000)
[0003.317] I> SC7-FW binary is read from storage
[0003.322] I> SC7-FW binary integrity check is success
[0003.327] I> Binary SC7-FW loaded successfully at 0xa0004000 (0x2b440)
[0003.333] I> Slot: 0
[0003.335] I> Binary[22] block-22144 (partition size: 0x30000)
[0003.341] I> Binary name: PSC_RF
[0003.344] I> Size of crypto header is 8192
[0003.348] I> Size of crypto header is 8192
[0003.352] I> Size of crypto header is 8192
[0003.356] I> Size of crypto header is 8192
[0003.360] I> strt_pg_num(22144) num_of_pgs(16) read_buf(0xa002f440)
[0003.366] I> BCH of PSC_RF read from storage
[0003.370] I> BCH address is : 0xa002f440
[0003.374] I> PSC_RF header integrity check is success
[0003.379] I> Binary magic in BCH component 0 is PSCR
[0003.384] I> component binary type is 22
[0003.387] I> Size of crypto header is 8192
[0003.391] I> strt_pg_num(22160) num_of_pgs(224) read_buf(0xa0031440)
[0003.399] I> PSC_RF binary is read from storage
[0003.403] I> PSC_RF binary integrity check is success
[0003.408] I> Binary PSC_RF loaded successfully at 0xa0031440 (0x1be60)
[0003.418] I> Task: Save WP0 payload to SC7 ctx
[0003.422] I> Task: Load MB2rf binary to SC7 ctx
[0003.426] I> Slot: 0
[0003.428] I> Binary[14] block-22528 (partition size: 0x20000)
[0003.434] I> Binary name: MB2_RF
[0003.437] I> Size of crypto header is 8192
[0003.441] I> Size of crypto header is 8192
[0003.445] I> Size of crypto header is 8192
[0003.449] I> Size of crypto header is 8192
[0003.453] I> strt_pg_num(22528) num_of_pgs(16) read_buf(0xa00d6aa0)
[0003.459] I> BCH of MB2_RF read from storage
[0003.463] I> BCH address is : 0xa00d6aa0
[0003.467] I> MB2_RF header integrity check is success
[0003.472] I> Binary magic in BCH component 0 is MB2R
[0003.477] I> component binary type is 14
[0003.481] I> Size of crypto header is 8192
[0003.484] I> strt_pg_num(22544) num_of_pgs(224) read_buf(0xa00d8aa0)
[0003.492] I> MB2_RF binary is read from storage
[0003.497] I> MB2_RF binary integrity check is success
[0003.502] I> Binary MB2_RF loaded successfully at 0xa00d8aa0 (0x1bfc0)
[0003.508] I> Task: Save fuse alias data to SC7 ctx
[0003.513] I> Task: Save PMIC data to SC7 ctx
[0003.517] I> Task: Save Pinmux data to SC7 ctx
[0003.521] I> Task: Save Pad Voltage data to SC7 ctx
[0003.526] I> Task: Save controller prod data to SC7 ctx
[0003.531] I> Task: Save prod cfg data to SC7 ctx
[0003.535] I> Task: Save I2C bus freq data to SC7 ctx
[0003.540] I> Task: Save SOCTherm data to SC7 ctx
[0003.544] I> Task: Save FMON data to SC7 ctx
[0003.549] I> Task: Save VMON data to SC7 ctx
[0003.553] I> Task: Save TZDRAM data to SC7 ctx
[0003.557] I> Task: Save GPIO int data to SC7 ctx
[0003.561] I> Task: Save clock data to SC7 ctx
[0003.566] I> Task: Save debug data to SC7 ctx
[0003.570] I> Task: Save MBWT data to SC7 ctx
[0003.578] I> SC7 context save done
[0003.581] I> Task: Load MB2/Applet/FSKP
[0003.585] I> Loading MB2
[0003.587] I> Slot: 0
[0003.589] I> Binary[6] block-8448 (partition size: 0x80000)
[0003.595] I> Binary name: MB2
[0003.597] I> Size of crypto header is 8192
[0003.601] I> Size of crypto header is 8192
[0003.605] I> strt_pg_num(8448) num_of_pgs(16) read_buf(0x8007e000)
[0003.611] I> BCH of MB2 read from storage
[0003.615] I> BCH address is : 0x8007e000
[0003.619] I> MB2 header integrity check is success
[0003.624] I> Binary magic in BCH component 0 is MB2B
[0003.629] I> component binary type is 6
[0003.632] I> Size of crypto header is 8192
[0003.636] I> strt_pg_num(8464) num_of_pgs(838) read_buf(0x80000000)
[0003.647] I> MB2 binary is read from storage
[0003.652] I> MB2 binary integrity check is success
[0003.657] I> Binary MB2 loaded successfully at 0x80000000 (0x68b10)
[0003.663] I> Task: Map CCPLEX SHARED carveout
[0003.667] I> Task: Prepare MB2 params
[0003.671] I> Task: Dram ecc test
[0003.674] I> Task: Misc NV security settings
[0003.678] I> NVDEC sticky bits programming done
[0003.683] I> Successfully powergated NVDEC
[0003.686] I> Task: Disable/Reload WDT
[0003.690] I> Task: Program misc carveouts
[0003.694] I> Program IPC carveouts
[0003.697] I> Task: Disable SCPM/POD reset
[0003.701] I> SLCG Global override status := 0x0
[0003.706] I> MB1: MSS reconfig completed
I> MB2 (version: 0.0.0.0-t234-54845784-934581f8)
I> Emulation:
I> Entry timestamp: 0x0038f608
I> Regular heap: [base:0x40040000, size:0x10000]
I> DMA heap: [base:0xe2e800000, size:0x800000]
I> Task: ARI update carveout TZDRAM (0x50002050)
I> Task: Check MC errors (0x5000204c)
I> Task: Enable hot-plug capability (0x500290f8)
I> Task: TZDRAM heap init (0x5001a0fc)
I> Task: PSC mailbox init (0x50018864)
I> Task: Crypto init (0x50006874)
I> Task: Enable GP-SE clock (0x500021b4)
I> Task: Measured Boot init (0x5001c04c)
I> Task: fTPM silicon identity init (0x5001c1f8)
I> fTPM is not enabled.
I> Task: OEM SC7 context save init (0x5001b598)
I> Task: I2C register (0x50002010)
I> Task: Map CCPLEX_INTERWORLD_SHMEM carveout (0x50001ff8)
I> Task: Program CBB PCIE AMAP regions (0x5001bcf8)
I> Task: Boot device init (0x50001f40)
I> Task: Partition Manager Init (0x50001f20)
I> Active chain: 0
I> Found 58 partitions in QSPI_FLASH (instance 0)
I> Active chain: 0
W> Cannot find any partition table for 00000003
> PARTITION_MANAGER: Failed to publish partition.
I> Active chain: 0
I> Found 15 partitions in SDMMC_USER (instance 3)
I> Task: Load and authenticate registered FWs (0x5001f064)
I> Task: Load AUXP FWs (0x50028c7c)
I> Successfully register SPE FW load task with MB2 loader
I> Skipping SCE FW load
I> Successfully register RCE FW load task with MB2 loader
I> Successfully register DCE FW load task with MB2 loader
I> Unpowergating APE
I> Unpowergate done
I> Successfully register APE FW load task with MB2 loader
I> Successfully register FSI FW load task with MB2 loader
I> Successfully register XUSB FW load task with MB2 loader
I> Active chain: 0
I> Partition name: A_spe-fw
I> Size of partition: 589824
I> Binary@ device:3/0 block-55040 (partition size: 0x90000), name: A_spe-fw
I> Active chain: 0
I> Partition name: A_rce-fw
I> Size of partition: 1048576
I> Binary@ device:3/0 block-56192 (partition size: 0x100000), name: A_rce-fw
I> spe: Authentication Finalize Done
I> Binary spe loaded successfully at 0xe2db00000
I> Active chain: 0
I> Partition name: A_dce-fw
I> Size of partition: 2097152
I> Binary@ device:3/0 block-38656 (partition size: 0x200000), name: A_dce-fw
I> rce: Authentication Finalize Done
I> Binary rce loaded successfully at 0xe2d800000
I> Successfully register RCE FW context save task with MB2 loader
I> dce : oem authentication of header done
I> dce : meta-blob integrity check is success.
I> dce : will be decompressed at 0xe36000000
I> version 1 Bin 1 BCheckSum 0 content_size 0 Content ChkSum 1 reserved_00 0
I> Reserved10 0 BlockMaxSize 5 Reserved11 0
I> dce : decompressed to 9528912 bytes
I> dce: plain binary integrity check is success
I> Active chain: 0
I> Partition name: A_adsp-fw
I> Binary@ device:3/0 block-58240 (partition size: 0x200000), name: A_adsp-fw
I> dce: Authentication Finalize Done
I> Binary dce loaded successfully at 0xe36000000
I> Active chain: 0
I> Partition name: A_fsi-fw
I> Size of partition: 6291456
I> Binary@ device:3/0 block-42752 (partition size: 0x600000), name: A_fsi-fw
I> FSI load addr: 0xe30000000
I> ape: Authentication Finalize Done
I> Binary ape loaded successfully at 0xe2e400000
I> Successfully register APE FW context save task with MB2 loader
I> Active chain: 0
I> Partition name: A_xusb-fw
I> Size of partition: 262144
I> Binary@ device:3/0 block-9472 (partition size: 0x40000), name: A_xusb-fw
I> fsi: Authentication Finalize Done
I> Binary fsi loaded successfully at 0xe30000000
I> Successfully register FSI FW context save task with MB2 loader
I> Configuring FSI PLL
W> PLLFSI init is not supported
I> FSI_CHSM_ATCM DMA xfer done
I> FSI_CHSM_BTCM DMA xfer done
I> FSI_CPU0_ATCM DMA xfer done
I> FSI_CPU0_BTCM DMA xfer done
I> FSI_CPU0_CTCM DMA xfer done
I> FSI_CPU1_ATCM DMA xfer done
I> FSI_CPU1_BTCM DMA xfer done
I> FSI_CPU1_CTCM DMA xfer done
I> FSI_CPU2_ATCM DMA xfer done
I> FSI_CPU2_BTCM DMA xfer done
I> FSI_CPU2_CTCM DMA xfer done
I> FSI_CPU3_ATCM DMA xfer done
I> FSI_CPU3_BTCM DMA xfer done
I> FSI_CPU3_CTCM DMA xfer done
I> FSI_SRAM DMA xfer done
I> xusb: Authentication Finalize Done
I> Binary xusb loaded successfully at 0xe2dc00000
I> Successfully register XUSB FW context save task with MB2 loader
I> Task: Carveout setup (0x500217e4)
I> Program remaining OEM carveouts
I> Task: Enable FSITHERM (0x50018738)
I> Task: Enable FSI VMON (0x50018234)
I> FSI VMON: FSI Vmon re-calibration and fine tuning done
I> Task: Validate FSI Therm readings (0x50018318)
I> FSITHERM max temp = 28
I> FSITHERM min temp = 28
I> Task: Restore XUSB sec (0x50001ef4)
I> Task: Enable FSI SE clock (0x50018cc0)
I> Enable FSI-SE clock and 10ms delay...
I> Task: Initialize SBSA UART CAR (0x50002118)
I> Task: Initialize CPUBL Params (0x50019cac)
I> CPUBL-params @ 0xe32000000
I> Task: Ratchet update (0x5002a194)
W> Skip ratchet update - OPTIN fuse not set
I> Task: Prepare eeprom data (0x50019a78)
I> Task: Revoke PKC fuse (0x50001d40)
I> PKC revoke fuse burn not requested
I> Task: FSI padctl context save (0x5001b874)
I> Task: Unpowergate APE (0x50019428)
W> mb2_unpowergate_ape: skip! APE is in unpowergated state
I> Task: OEM firewalls (0x50025cf0)
I> OEM firewalls configured
I> Task: Powergate APE (0x5001959c)
I> Powergating APE
I> Powergate done
I> Task: OEM firewall restore saved settings (0x50026144)
I> Task: Unhalt AUXPs (0x50028f00)
I> Unhalting SPE..
I> Enabling combined UART
▒▒▒▒spe: early_init
▒▒▒▒vic initialized
▒▒▒▒tsc initialized
▒▒▒▒aon lic initialized
▒▒▒▒spe: tag is 5243985d1b1eb3f06fac6d36bd7e74ac
▒▒▒▒spe: SafeRTOS v8.4
▒▒▒▒spe: init
▒▒▒▒scheduler initialized
▒▒▒▒aon hsp initialized
▒▒▒▒tag initialized
▒▒▒▒tcu initialized
▒▒▒▒bpmp ipc initialized
▒▒▒▒spe: late init
▒▒▒▒cpu_nic clock initialized
▒▒▒▒apb clock initialized
▒▒▒▒pm initialized
▒▒▒▒bpmp hsp initialized
▒▒▒▒top1 hsp initialized
▒▒▒▒ccplex ipc initialized
▒▒▒▒spe: start scheduler
I> Task: Trigger mailbox for PSC-BL1 exit (0x500188e4)
I> Sending opcode 0x4d420802 to psc
▒▒INFO: Entering psc_monitor_init!
INFO: GSC22 BOM:0xe48002000 SIZE:0x1000000 CLIENT_ACCESS1:00180000
INFO: PSCFW BUILD VERSION: 8a33b23-73b589c-8a15f76-rel-t234
INFO: mstatus:0xa00000808
INFO: Supervisor entry_point:c108c00
▒▒I> Received ACK from psc
I> Tas▒▒INFO: MONITOR: user task addr:0xe48022000, blob offset:0x00020000
INFO: MONITOR: populated user images:13
INFO: mret to Supervisor!
INFO: psc supervisor init.
INFO: psc_irq_init...
INFO: enter idle task.
hwwdt_init: WDT boot cfg 0x710010 sts 0x10
bpmp: socket 0
bpmp: base binary md5 is fcc6f4f897ab64a32c3de470c48f0036
bpmp: combined binary md5 is 7d1cdfee8f0665c27c257e26a9da03e5
bpmp: firmware tag is 7d1cdfee8f0665c27c25-fcc6f4f897a
Control register check for CBB_CENTRAL_CBB_FIREWALL_MCB_BLF failed, expected value: 80030000 != actual value: 00000000 address: 13a159d0
Write control check for CBB_CENTRAL_CBB_FIREWALL_MCB_BLF failed, expected value: 0f18000b != actual value: 00000000 address: 13a159c8
initialized vwdt
initialized mail_early
initialized fuse
initialized vfrel
initialized adc
fmon_populate_monitors: found 199 monitors
initialized fmon
initialized mc
initialized reset
initialized uphy_early
initialized emc_early
initialized pm
465 clocks registered
initialized clk_mach
initialized clk_cal_early
initialized clk_mach_early_config
initialized io_dpd
initialized soctherm
initialized regime
initialized i2c
vrmon_dt_init: vrmon node not found
vrmon_chk_boot_state: found 0 rail monitors
initialized vrmon
initialized regulator
▒▒k: Start secure NOR provision (0x5001bb10)
I> Task: Load FSI keyblob (0x50018d08)
I> Sending opcode OP_FSI_KEYBLOB to ▒▒initialized avfs_clk_platform
initialized powergate
▒▒psc-fw
I> Sending opcode 0x4653494b to psc
▒▒INFO: END TASK:FSIK
▒▒initialized dvs
▒▒I> Receiv▒▒initialized clk_mach_config
initialized suspend
initialized strap
initialized mce_dbell
▒▒ed ACK from psc
I> FSI KeyBlob DMA xfer done
I> Sending opcode OP_PSC_KEY_MANAGER to psc-fw
I> Sending opcode 0x4b45594d to psc
▒▒INFO: [PKCS11-KM] Operation INIT START
INFO: Uninitialized WUW_KEY, Manifest:8211
INFO: PSC_KM_APP_BUILD_VERSION: 74db7d0
INFO: [PKCS11-KM] Operation INIT Successful
INFO: END TASK:KEYM
I> Task: Unhalt AUXPs (0x50028f08)
I> SCE unhalt skipped
I> Unhalting RCE
I> RCE unhalt successful
I> DCE unhalt successful
I> APE unhalt skipped
I> ▒▒MODS: CHSM firmware version 1.1.0 (3524f6b)
Overtemp Threshold set to 0xec0
Undertemp Threshold set to 0x3aa0
▒▒[ 4.433556] Camera-FW on t234-rce-safe started
TCU early console enabled.
▒▒initialized emc
initialized emc_mrq
initialized clk_cal
initialized uphy_dt
initialized uphy_mrq
HSIO UPHY reset has been de-asserted 0x0
initialized uphy
fmon_enable: FMON_GBE_UPHY_L7_CORE_TX: detected fault 0x1
fmon_enable: FMON_MGBE3_TX_PCS: detected fault 0x1
fmon_enable: FMON_MGBE3_MAC: detected fault 0x1
fmon_enable: FMON_GBE_UPHY_L4_CORE_TX: detected fault 0x1
fmon_enable: FMON_MGBE0_TX_PCS: detected fault 0x1
fmon_enable: FMON_MGBE0_MAC: detected fault 0x1
fmon_enable: FMON_GBE_UPHY_L5_CORE_TX: detected fault 0x1
fmon_enable: FMON_MGBE1_TX_PCS: detected fault 0x1
fmon_enable: FMON_MGBE1_MAC: detected fault 0x1
fmon_enable: FMON_GBE_UPHY_L6_CORE_TX: detected fault 0x1
fmon_enable: FMON_MGBE2_TX_PCS: detected fault 0x1
fmon_enable: FMON_MGBE2_MAC: detected fault 0x1
initialized pg_late
initialized pg_mrq_init
swdtimer_init: reg polling start w period 47 ms
initialized swdtimer
initialized hwwdt_late
initialized bwmgr
initialized thermal_host_trip
initialized thermal_mrq
initialized oc_mrq
initialized reset_mrq
initialized mail_mrq
initialized fmon_mrq
initialized clk_mrq
initialized avfs_mrq
initialized i2c_mrq
initialized tag_mrq
initialized bwmgr_mrq
initialized console_mrq
initialized clk_sync_fmon_post
verify_rate_range: FMON_PWM3: rate 872728 below min 18750000
fmon_update_config: FMON_PWM3: detected fault 0x80
initialized clk_cal_late
initialized noc_late
initialized cvc
initialized avfs_clk_mach_post
initialized avfs_clk_platform_post
initialized cvc_late
initialized rm
initialized console_late
handling unreferenced clks
enable can1_core
enable can1_host
enable can2_core
enable can2_host
enable pwm3
enable mss_encrypt
enable maud
enable pl▒▒[ 4.603505] Camer▒▒lg_ref
enable dsi_core
enable aza_2xbit
enable pllc4_muxed
enable sdmmc4_a▒▒a-FW on t234-rce-safe ready SHA1=55ecd57d (crt 12.955 ms, total boot 183.968 m▒▒Unhalted R52 cores
▒▒s)
▒▒ ▒▒xicif
enable xusb_ss
▒▒U▒▒enable xusb_fs
enable xusb_falcon
enable xusb_core▒▒s▒▒_mux
enable dsi_lp
enable sdmmc_legacy_tm
initialized clk_mach_post
initialized pg_post
initialized regulator_post
▒▒i▒▒initialized profile
initialized mrq
initialized patrol_scrubber
initialized cactmon
initialized extras_post
bpmp: init complete
▒▒n▒▒
▒▒g▒▒FSI▒▒ ▒▒ un▒▒D▒▒hal▒▒E▒▒t s▒▒F▒▒ucc▒▒A▒▒ess▒▒U▒▒ful▒▒L▒▒
▒▒T▒▒I> ▒▒(▒▒Tas▒▒C▒▒k: ▒▒O▒▒Loa▒▒M▒▒d C▒▒B▒▒PUB▒▒I▒▒L (▒▒N▒▒0x5▒▒E▒▒001▒▒D▒▒9dd▒▒_▒▒0)▒▒U▒▒
▒▒A▒▒I> ▒▒R▒▒Tas▒▒T▒▒k: ▒▒)▒▒Loa▒▒ ▒▒d T▒▒f▒▒OS ▒▒o▒▒(0x▒▒r▒▒500▒▒ ▒▒1a5▒▒l▒▒60)▒▒o▒▒
▒▒g▒▒I> ▒▒g▒▒Tas▒▒i▒▒k: ▒▒n▒▒Loa▒▒g▒▒d a▒▒
▒▒nd authen▒▒
▒▒tic▒▒F▒▒ate▒▒S▒▒ re▒▒I▒▒gis▒▒ ▒▒ter▒▒I▒▒ed ▒▒N▒▒FWs▒▒T▒▒ (0▒▒E▒▒x50▒▒R▒▒01f▒▒N▒▒064▒▒A▒▒)▒▒L▒▒
▒▒ ▒▒I> ▒▒F▒▒Act▒▒I▒▒ive▒▒R▒▒ ch▒▒M▒▒ain▒▒W▒▒: 0▒▒A▒▒
▒▒R▒▒I> ▒▒E▒▒Par▒▒ ▒▒tit▒▒v▒▒ion▒▒e▒▒ na▒▒r▒▒me:▒▒s▒▒ A_▒▒i▒▒cpu▒▒o▒▒-bo▒▒n▒▒otl▒▒:▒▒oad▒▒ ▒▒er▒▒1▒▒
▒▒.▒▒I> ▒▒0▒▒Siz▒▒.▒▒e o▒▒0▒▒f p▒▒
▒▒art▒▒
▒▒iti▒▒w▒▒on:▒▒e▒▒ 36▒▒l▒▒700▒▒c▒▒16▒▒o▒▒
▒▒m▒▒I> ▒▒e▒▒Bin▒▒ ▒▒ary▒▒t▒▒@ d▒▒o▒▒evi▒▒ ▒▒ce:▒▒l▒▒3/0▒▒k▒▒ bl▒▒/▒▒ock▒▒M▒▒-22▒▒P▒▒784▒▒
▒▒ (p▒▒
▒▒art▒▒b▒▒iti▒▒o▒▒on ▒▒o▒▒siz▒▒t▒▒e: ▒▒ ▒▒0x3▒▒a▒▒800▒▒r▒▒00)▒▒g▒▒, n▒▒s▒▒ame▒▒ ▒▒: A▒▒0▒▒_cp▒▒x▒▒u-b▒▒2▒▒oot▒▒4▒▒loa▒▒ ▒▒der▒▒0▒▒
▒▒x1▒▒I> ▒▒3▒▒cpu▒▒ ▒▒bl ▒▒0▒▒: o▒▒x▒▒em ▒▒0▒▒aut▒▒ ▒▒hen▒▒0▒▒tic▒▒x▒▒ati▒▒3▒▒on ▒▒0▒▒of ▒▒c▒▒hea▒▒7▒▒der▒▒0▒▒ do▒▒8▒▒ne▒▒3▒▒
▒▒9
▒▒I> ▒▒i▒▒cpu▒▒n▒▒bl ▒▒i▒▒: m▒▒t▒▒eta▒▒i▒▒-bl▒▒a▒▒ob ▒▒l▒▒int▒▒i▒▒egr▒▒z▒▒ity▒▒i▒▒ ch▒▒n▒▒eck▒▒g▒▒ is▒▒ ▒▒ su▒▒h▒▒cce▒▒e▒▒ss.▒▒a▒▒
▒▒p
calling constructors
initializing ▒▒I> ▒▒m▒▒cpu▒▒p▒▒bl ▒▒
▒▒: w▒▒i▒▒ill▒▒n▒▒ be▒▒i▒▒ de▒▒t▒▒com▒▒i▒▒pre▒▒a▒▒sse▒▒l▒▒d a▒▒i▒▒t 0▒▒z▒▒xe2▒▒i▒▒ce0▒▒n▒▒000▒▒g▒▒0▒▒ ▒▒
▒▒t▒▒I> ▒▒h▒▒ver▒▒r▒▒sio▒▒e▒▒n 1▒▒a▒▒ Bi▒▒d▒▒n 1▒▒s▒▒ BC▒▒
▒▒r▒▒Sum▒▒s▒▒ ▒▒hec▒▒i▒▒kSu▒▒n▒▒m 0▒▒i▒▒ co▒▒t▒▒nte▒▒i▒▒nt_▒▒a▒▒siz▒▒l▒▒DCE▒▒i▒▒e 0▒▒z▒▒: F▒▒i▒▒ Co▒▒n▒▒W B▒▒g▒▒nte▒▒ ▒▒oot▒▒t▒▒nt ▒▒i▒▒ Do▒▒m▒▒Chk▒▒e▒▒ne
▒▒ 1 ▒▒i▒▒res▒▒n▒▒erv▒▒i▒▒ed_▒▒t▒▒00 ▒▒i▒▒ 0▒▒a▒▒
▒▒l▒▒I> ▒▒i▒▒Res▒▒z▒▒erv▒▒i▒▒ed1▒▒n▒▒0 0▒▒g▒▒ Bl▒▒ ▒▒ock▒▒p▒▒Max▒▒o▒▒Siz▒▒r▒▒e 5▒▒t▒▒ Re▒▒s▒▒ser▒▒
▒▒ved▒▒c▒▒11 ▒▒r▒▒0▒▒e▒▒
▒▒ating bootstrap completion thread
top of bootstrap2()
creating bootstrap completion thread for cpu 1
creating bootstrap completion thread for cpu 2
creating bootstrap completion thread for cpu 3
releasing 3 secondary cpus
initializing platform
INIT: cpu 1, calling hook 0x107dd (arm_generic_timer_init_secondary_cpu) at level 0x6ffff, flags 0x2
INIT: cpu 2, calling hook 0x107dd (arm_generic_timer_init_secondary_cpu) at level 0x6ffff, flags 0x2
INIT: cpu 3, calling hook 0x107dd (arm_generic_timer_init_secondary_cpu) at level 0x6ffff, flags 0x2
DRBC Initialization success
entering scheduler on cpu 1
entering scheduler on cpu 2
entering scheduler on cpu 3
Critical Error mask - 0x400
Non-Critical Error mask - 0x800
▒▒I> ▒▒DramECC Initialization success
NvHsm_Init : initializing SCE HSM Interrupts
NvHsm_Init : module initialized
▒▒bl ▒▒sc7 : LIC init - Done
sc7 : BPMP_HSP SM6 and SM7 init - Done
sc7 : FSI SC7 Init Done
initializing target
calling apps_init()
▒▒: d▒▒starting app fsi_mods_test
▒▒eco▒▒Info: fsi_tegra_mods_test: ^^^^^ FSI Tegra MODS test start... ^^^^^
Info: ccplex_to_fsi_mailbox_init: tegra_hsp_init success for HSP_CCPLEX_TO_FSI
▒▒mpr▒▒Info: ccplex_to_fsi_mailbox_init: tegra_hsp_set_sm_type success for HSP_CCPLEX_TO_FSI, SM_CCPLEX_FSI_INDEX, HSP_SM_TYPE_128
▒▒ess▒▒Info: ccplex_to_fsi_mailbox_init: tegra_hsp_sm_full_enable api returned success...!
Info: fsi_to_ccplex_mailbox_init: tegra_hsp_init success for HSP_FSI_TO_CCPLEX
▒▒ed ▒▒Info: fsi_to_ccplex_mailbox_init: tegra_hsp_set_sm_type success for HSP_FSI_TO_CCPLEX, SM_CCPLEX_FSI_INDEX, HSP_SM_TYPE_128
▒▒to ▒▒Info: fsi_ccplex_mailbox_empty_callback: Disable the shared mailbox empty interrupt is Success...!
▒▒334▒▒Info: fsi_to_ccplex_mailbox_init: tegra_hsp_sm_empty_enable api returned success...!
▒▒656▒▒starting app shell
▒▒0 b▒▒Info: chsm_hsp_init: tegra_hsp_init success for FSI_HSP_TX
entering main console loop
Info: chsm_hsp_init: tegra_hsp_set_sm_type success for FSI_HSP_TX, SM_INDEX 0, and HSP_SM_TYPE_128
] Info: chsm_hsp_init: tegra_hsp_init success for FSI_HSP_RX
starting app sanity_test
Info: chsm_hsp_init: tegra_hsp_set_sm_type success for FSI_HSP_RX, type HSP_SM_TYPE_128
Run sanity tests using console command
Info: chsm_hsp_init: CORE_0_RECV_MB is empty...!
Info: chsm_hsp_init: chsm hsp initialized...!
▒▒ytes
I> cpubl: plain binary integrity check is success
I> Active chain: 0
I> Partition name: A_secure-os
I> Size of partition: 4194304
I> Binary@ device:3/0 block-29952 (partition size: 0x400000), name: A_secure-os
I> cpubl_params: nsdram: carveout: 1, encryption: 1
I> NSDRAM carveout base: 0x80000000, size: 0xdad370000
I> cpubl: Authentication Finalize Done
I> Binary cpubl loaded successfully at 0xe2ce00000
I> tos: Authentication Finalize Done
I> Binary tos loaded successfully at 0xe3fdc7000
I> Relocating OP-TEE dtb from: 0xe3fefec50 to 0xe3c000860, size: 0x2886
I> [0] START: 0x80000000, SIZE: 0xdad370000
I> [1] START: 0xe32000000, SIZE: 0x2000000
I> Setting NS memory ranges to OP-TEE dtb finished.
I> Active chain: 0
I> Partition name: A_eks
I> Binary@ device:3/0 block-38144 (partition size: 0x40000), name: A_eks
I> eks: Authentication Finalize Done
I> Binary eks loaded successfully at 0xe2e800400
I> EKB detected (length: 0x410) @ VA:0xe2e800400
I> Task: Prepare TOS params (0x5001a4d8)
I> Setting EKB blob info to OPTEE dtb finished.
I> Setting OPTEE arg3: 0xe3c000860
I> Task: OEM SC7 context save (0x5001b970)
I> OEM sc7 context saved
I> Task: Disable MSS perf stats (0x50028f94)
I> Task: Program display sticky bits (0x50028f10)
I> Task: Storage device deinit (0x500020bc)
I> Task: SMMU external bypass disable (0x50018848)
I> Task: SMMU init (0x50018764)
I> Task: Program GICv3 registers (0x50029034)
I> Task: Audit firewall settings (0x50025f44)
I> Task: Bootchain failure check (0x500025c8)
I> Current Boot-Chain Slot: 0
I> BR-BCT Boot-Chain is 0, and status is 1. Set UPDATE_BRBCT bit to 0
I> MB2 finished
▒▒NOTICE: BL31: v2.6(release):cec9a2bc3
NOTICE: BL31: Built : 20:19:41, Feb 19 2024
I/TC: Physical secure memory base 0xe3c040000 size 0x3fc0000
I/TC:
I/TC: Non-secure external DT found
I/TC: OP-TEE version: 3.22 (gcc version 9.3.0 (Buildroot 2020.08)) #2 Tue Feb 20 04:28:56 UTC 2024 aarch64
I/TC: WARNING: This OP-TEE configuration might be insecure!
I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html
I/TC: Primary CPU initializing
I/TC: Test OEM keys are being used. This is insecure for shipping products!
I/TC: Primary CPU switching to normal world boot
Jetson UEFI firmware (version 5.0-35550185 built on 2024-02-20T04:21:22+00:00)
▒▒I/TC: Reserved shared memory is disabled
I/TC: Dynamic shared memory is enabled
I/TC: Normal World virtualization support is disabled
I/TC: Asynchronous notifications are disabled
E/TC:?? 00
E/TC:?? 00 User mode data-abort at address 0x40 (translation fault)
E/TC:?? 00 esr 0x92000005 ttbr0 0x2000e3c1ba000 ttbr1 0x00000000 cidr 0x0
E/TC:?? 00 cpu #0 cpsr 0x60000000
E/TC:?? 00 x0 00000000405e0000 x1 0000000000000000
E/TC:?? 00 x2 0000000000000020 x3 00000000405f5c58
E/TC:?? 00 x4 00000000405f5c57 x5 00000000405d9410
E/TC:?? 00 x6 00000000000000fc x7 00000000000000fc
E/TC:?? 00 x8 00000000000000fc x9 0000000000000000
E/TC:?? 00 x10 0000a00000001000 x11 0000000000000040
E/TC:?? 00 x12 0000000000000000 x13 4200004000000000
E/TC:?? 00 x14 0000000000000000 x15 0000000000000000
E/TC:?? 00 x16 00000000400491f8 x17 00000000000000f8
E/TC:?? 00 x18 0000000000000000 x19 00000000405ef160
E/TC:?? 00 x20 00000000405f5c58 x21 00000000405e0000
E/TC:?? 00 x22 0000000000000020 x23 000000000000003f
E/TC:?? 00 x24 00000000405f5c57 x25 0000000000000000
E/TC:?? 00 x26 0000000000001000 x27 0000000000040000
E/TC:?? 00 x28 0000000040508000 x29 00000000405f5bb0
E/TC:?? 00 x30 0000000040500370 elr 00000000405d9494
E/TC:?? 00 sp_el0 00000000405f5bb0
E/TC:?? 00 region 0: va 0x0000000040000000 pa 0x0000000e3c042000 size 0x002000 flags ---R-X
E/TC:?? 00 region 1: va 0x0000000040002000 pa 0x0000000e3c190000 size 0x001000 flags ---RW-
E/TC:?? 00 region 2: va 0x0000000040004000 pa 0x0000000e3c240000 size 0x03f000 flags r-xR--
E/TC:?? 00 region 3: va 0x0000000040043000 pa 0x0000000e3c27f000 size 0x001000 flags rw----
E/TC:?? 00 region 4: va 0x0000000040044000 pa 0x0000000e3c280000 size 0x00b000 flags r-x---
E/TC:?? 00 region 5: va 0x000000004004f000 pa 0x0000000e3c28b000 size 0x001000 flags rw----
E/TC:?? 00 region 6: va 0x0000000040050000 pa 0x0000000e3c28c000 size 0x001000 flags r-x---
E/TC:?? 00 region 7: va 0x0000000040051000 pa 0x0000000e3c28d000 size 0x2b3000 flags r-xR--
E/TC:?? 00 region 8: va 0x0000000040304000 pa 0x0000000e3c540000 size 0x1fc000 flags rw-RW-
E/TC:?? 00 region 9: va 0x0000000040500000 pa 0x0000000e3c73c000 size 0x008000 flags r-x---
E/TC:?? 00 region 10: va 0x0000000040508000 pa 0x0000000e3c744000 size 0x001000 flags rw-RW-
E/TC:?? 00 region 11: va 0x0000000040509000 pa 0x0000000e3c745000 size 0x001000 flags r-x---
E/TC:?? 00 region 12: va 0x000000004050a000 pa 0x0000000e3c746000 size 0x002000 flags rw-RW-
E/TC:?? 00 region 13: va 0x000000004050c000 pa 0x0000000e3c748000 size 0x005000 flags r-x---
E/TC:?? 00 region 14: va 0x0000000040511000 pa 0x0000000e3c74d000 size 0x001000 flags rw-RW-
E/TC:?? 00 region 15: va 0x0000000040512000 pa 0x0000000e3c74e000 size 0x001000 flags r-x---
E/TC:?? 00 region 16: va 0x0000000040513000 pa 0x0000000e3c74f000 size 0x0c3000 flags rw-RW-
E/TC:?? 00 region 17: va 0x00000000405d6000 pa 0x0000000e3c812000 size 0x00a000 flags r-x---
E/TC:?? 00 region 18: va 0x00000000405e0000 pa 0x0000000e3c81c000 size 0x001000 flags rw-RW-
E/TC:?? 00 region 19: va 0x00000000405e1000 pa 0x0000000e3c81d000 size 0x001000 flags r-x---
E/TC:?? 00 region 20: va 0x00000000405e2000 pa 0x0000000e3c81e000 size 0x002000 flags rw-RW-
E/TC:?? 00 region 21: va 0x00000000405e4000 pa 0x0000000e3c820000 size 0x006000 flags r-x---
E/TC:?? 00 region 22: va 0x00000000405ea000 pa 0x0000000e3c826000 size 0x001000 flags rw-RW-
E/TC:?? 00 region 23: va 0x00000000405eb000 pa 0x0000000e3c827000 size 0x001000 flags r-x---
E/TC:?? 00 region 24: va 0x00000000405ec000 pa 0x0000000e3c828000 size 0x01f000 flags rw-RW-
E/TC:?? 00 region 25: va 0x000000004060b000 pa 0x0000000e3c847000 size 0x015000 flags rw-RW-
E/TC:?? 00 region 26: va 0x0000000040620000 pa 0x000000000c198000 size 0x001000 flags rw----
E/TC:?? 00 region 27: va 0x0000000040621000 pa 0x0000000003270000 size 0x010000 flags rw----
E/TC:?? 00 region 28: va 0x0000000040631000 pa 0x000000000c390000 size 0x002000 flags rw----
▒▒ERROR: Exception reason=0 syndrome=0xbe000011
ERROR: **************************************
ERROR: RAS Uncorrectable Error in IOB, base=0xe010000:
ERROR: Status = 0xec000612
ERROR: SERR = Error response from slave: 0x12
ERROR: IERR = CBB Interface Error: 0x6
ERROR: Overflow (there may be more errors) - Uncorrectable
ERROR: MISC0 = 0xc4420040
ERROR: MISC1 = 0xd4c860000000000
ERROR: MISC2 = 0x0
ERROR: MISC3 = 0x0
ERROR: ADDR = 0x8000000003270000
ERROR: sdei_dispatch_event returned -1
Unhandled Exception in EL3.
x30 = 0x0000000050011384
x0 = 0x0000000000000000
x1 = 0x0000000000000000
x2 = 0x000000005000d1b8
x3 = 0x0000000000000047
x4 = 0x0000000000000000
x5 = 0x0000000000000043
x6 = 0x0000000000000001
x7 = 0x0000000000000000
x8 = 0x000000005000b7ec
x9 = 0x0000000000000000
x10 = 0x0000000003270000
x11 = 0x0000000000000003
x12 = 0x0000000e2cd28000
x13 = 0x00000000000113d8
x14 = 0x0000000e279800a8
x15 = 0x0000000e2cd28000
x16 = 0x0000000e26ae4cd4
x17 = 0x0000000001e80008
x18 = 0x0000000000000000
x19 = 0x0000000003270000
x20 = 0x000000000000001c
x21 = 0x0000000e27980000
x22 = 0x000000000000001d
x23 = 0x0000000e279800a8
x24 = 0x0000000003270000
x25 = 0x0000000000000001
x26 = 0x0000000000000001
x27 = 0x0000000000000000
x28 = 0x0000000000000001
x29 = 0x0000000e2d1fe520
scr_el3 = 0x000000000003073d
sctlr_el3 = 0x00000000b0cd183f
cptr_el3 = 0x0000000000000000
tcr_el3 = 0x0000000080823518
daif = 0x00000000000003c0
mair_el3 = 0x00000000004404ff
spsr_el3 = 0x00000000600003cd
elr_el3 = 0x0000000050011384
ttbr0_el3 = 0x0000000050026ac1
esr_el3 = 0x0000000002000000
far_el3 = 0x0000000000000000
spsr_el1 = 0x0000000000000000
elr_el1 = 0x0000000000000000
spsr_abt = 0x0000000000000000
spsr_und = 0x0000000000000000
spsr_irq = 0x0000000000000000
spsr_fiq = 0x0000000000000000
sctlr_el1 = 0x0000000030d00800
actlr_el1 = 0x0000000000000000
cpacr_el1 = 0x0000000000300000
csselr_el1 = 0x0000000000000000
sp_el1 = 0x0000000000000000
esr_el1 = 0x0000000000000000
ttbr0_el1 = 0x0000000000000000
ttbr1_el1 = 0x0000000000000000
mair_el1 = 0x0000000000000000
amair_el1 = 0x0000000000000000
tcr_el1 = 0x0000000000000000
tpidr_el1 = 0x0000000000000000
tpidr_el0 = 0x0000000080000000
tpidrro_el0 = 0x0000000000000000
par_el1 = 0x0000000000000800
mpidr_el1 = 0x0000000081000000
afsr0_el1 = 0x0000000000000000
afsr1_el1 = 0x0000000000000000
contextidr_el1 = 0x0000000000000000
vbar_el1 = 0x0000000000000000
cntp_ctl_el0 = 0x0000000000000005
cntp_cval_el0 = 0x000000001125f712
cntv_ctl_el0 = 0x0000000000000000
cntv_cval_el0 = 0x0000000000000000
cntkctl_el1 = 0x0000000000000000
sp_el0 = 0x0000000e26c6b2f0
isr_el1 = 0x0000000000000040
cpuectlr_el1 = 0xa000000b40543000
gicd_ispendr regs (Offsets 0x200 - 0x278)
Offset: value
0000000000000200: 0x0000000000000000
0000000000000204: 0x0000000000000000
0000000000000208: 0x0000000000000000
000000000000020c: 0x0000000000000000
0000000000000210: 0x0000000000000000
0000000000000214: 0x0000000000000000
0000000000000218: 0x0000000000010000
000000000000021c: 0x0000000000020000
0000000000000220: 0x0000000000000000
0000000000000224: 0x0000000000000000
0000000000000228: 0x0000000000000000
000000000000022c: 0x0000000000000000
0000000000000230: 0x0000000000000000
0000000000000234: 0x0000000000000000
0000000000000238: 0x0000000000000000
000000000000023c: 0x0000000000000000
0000000000000240: 0x0000000000000000
0000000000000244: 0x0000000000000000
0000000000000248: 0x0000000000000000
000000000000024c: 0x0000000000000000
0000000000000250: 0x0000000000000000
0000000000000254: 0x0000000000000000
0000000000000258: 0x0000000000000000
000000000000025c: 0x0000000000000000
0000000000000260: 0x0000000000000000
0000000000000264: 0x0000000000000000
0000000000000268: 0x0000000000000000
000000000000026c: 0x0000000000000000
0000000000000270: 0x0000000000000000
0000000000000274: 0x0000000000000000
0000000000000278: 0x0000000000000000
000000000000027c: 0x0000000000000000
