According to the instruction on nvidia
when I change the device tree in tegra234-ethernet-3737-0000.dtsi as below:
/* MGBE - A */
ethernet@6810000 {
status = "okay";
/* 1:10G, 0:5G */
nvidia,uphy-gbe-mode = <1>;
/* 0:XFI 10G, 1:XFI 5G, 2:USXGMII 10G, 3:USXGMII 5G */
nvidia,phy-iface-mode = <0>;
nvidia,max-platform-mtu = <16383>;
fixed-link{
speed = <10000>;
full-duplex;
Eth0 is still missing and fail to install:
d@d-desktop:~$ sudo dmesg | grep eth
[ 0.000000] psci: probing for conduit method from DT.
[ 4.515548] usbcore: registered new interface driver cdc_ether
[ 6.420110] optee: probing for conduit method.
[ 11.513642] nvethernet 6810000.ethernet: Adding to iommu group 51
[ 11.522794] nvethernet 6810000.ethernet: failed to read skip mac reset flag, default 0
[ 11.532459] nvethernet 6810000.ethernet: failed to read MDIO address
[ 11.540513] nvethernet 6810000.ethernet: Failed to read nvida,pause_frames, so setting to default support as disable
[ 11.552869] nvethernet 6810000.ethernet: setting to default DMA bit mask
[ 11.561284] nvethernet 6810000.ethernet: Failed to read DMA Tx ring size, using default [4096]
[ 11.571660] nvethernet 6810000.ethernet: Failed to read DMA Rx ring size, using default [4096]
[ 11.583818] nvethernet 6810000.ethernet: invalid resource
[ 11.590866] nvethernet 6810000.ethernet: failed to ioremap MAC base address
[ 11.599520] nvethernet 6810000.ethernet: failed to allocate platform resources
[ 11.608455] nvethernet: probe of 6810000.ethernet failed with error -22
[ 14.031473] using random self ethernet address
[ 14.031476] using random host ethernet address
In addition, when we update it to R35.3.1, we supposed to make the same change as we did in R35.1 as below:
In Linux/bootloader/tegra234-mb2-bct-common.dtsi
eeprom {
cvm_eeprom_i2c_instance = <0>;
cvm_eeprom_i2c_slave_address = <0xa0>;
cvm_eeprom_read_size = <0x100>;
cvb_eeprom_i2c_instance = <0x0>;
cvb_eeprom_i2c_slave_address = <0xac>;
cvb_eeprom_read_size = <0x100>;
Change to:
eeprom {
cvb_eeprom_read_size = <0x000>;
