Same image on orinnano8g but some cannot achive super mode,using jtop command can find out that cpu max freq 1.5Ghz,gpu max freq 624MHz,but power mode already set to MAXN SUPER,execute sudo jetson_clocks did not work
Hi @MaxineZ,
Could you run the following commands on both a board where Super Mode works and one where it does not?
cat /etc/nv_tegra_release
cat /etc/nv_boot_control.conf
tr '\0' '\n' < /proc/device-tree/compatible
sudo nvbootctrl dump-slots-info
sudo nvpmodel -q --verbose
These will help us compare the Jetson Linux and bootloader versions, board configurations, and power mode settings to identify any differences between the boards.
Also, could you confirm how the boards were flashed and which flashing configuration was used? Super Mode requires the appropriate flashing configuration, so it would be good to verify that both boards were flashed correctly.
Regards,
Carlos Jiménez
Embedded SW Engineer at RidgeRun
Contact us: support@ridgerun.com
Developers wiki: https://developer.ridgerun.com/
Website: www.ridgerun.com
