Hello, I have a OrinNX 16GB . I want to set root parititon, which is first partition as 80G,
I’ve set APPSIZE to 80G from:
→ Linux_for_Tegra/bootloader/generic/cfg/flash_t234_qspi_nvme.xml
→ Linux_for_Tegra/tool/kernel_flash/flash_l4t_nvme.xml
→ Linux_for_Tegra/tool/kernel_flash/flash_l4t_t234_nvme.xml
Flashing commands I’ve tried:
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 \
-S 80GiB \
-c tools/kernel_flash/flash_l4t_t234_nvme.xml \
-p “-c bootloader/generic/cfg/flash_t234_qspi.xml” \
–showlogs --network usb0 jetson-orin-nano-devkit-super internal
-c tools/kernel_flash/flash_l4t_t234_nvme.xml -p “-c bootloader/generic/cfg/flash_t234_qspi.xml” \
But I get errors while flashing:
[ 3.7058 ] tegrahost_v2 --chip 0x23 0 --align mem_rcm_1_aligned.bct[ 3.7064 ] tegrahost_v2 --chip 0x23 0 --magicid MEM1 --ratchet_blob ratchet_blob.bin --appendsigheader mem_rcm_1_aligned.bct zerosbk[ 3.7067 ] adding BCH for mem_rcm_1_aligned.bct[ 3.7098 ] tegrasign_v3.py --key None --list mem_rcm_1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512[ 3.7100 ] Assuming zero filled SBK key[ 3.7117 ] Warning: pub_key.key is not found[ 3.7119 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mem_rcm_1_aligned_sigheader.bct.encrypt mem_rcm_1_aligned_sigheader.bct.hash zerosbk[ 3.7133 ] Disabled BPMP dtb trim, using default dtb[ 3.7133 ] [ 3.7143 ] tegrahost_v2 --chip 0x23 0 --align mem_rcm_2_aligned.bct[ 3.7156 ] tegrahost_v2 --chip 0x23 0 --magicid MEM2 --ratchet_blob ratchet_blob.bin --appendsigheader mem_rcm_2_aligned.bct zerosbk[ 3.7162 ] adding BCH for mem_rcm_2_aligned.bct[ 3.7201 ] tegrasign_v3.py --key None --list mem_rcm_2_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512[ 3.7204 ] Assuming zero filled SBK key[ 3.7227 ] Warning: pub_key.key is not found[ 3.7229 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mem_rcm_2_aligned_sigheader.bct.encrypt mem_rcm_2_aligned_sigheader.bct.hash zerosbk[ 3.7251 ] Disabled BPMP dtb trim, using default dtb[ 3.7251 ] [ 3.7267 ] tegrahost_v2 --chip 0x23 0 --align mem_rcm_3_aligned.bct[ 3.7284 ] tegrahost_v2 --chip 0x23 0 --magicid MEM3 --ratchet_blob ratchet_blob.bin --appendsigheader mem_rcm_3_aligned.bct zerosbk[ 3.7292 ] adding BCH for mem_rcm_3_aligned.bct[ 3.7336 ] tegrasign_v3.py --key None --list mem_rcm_3_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512[ 3.7338 ] Assuming zero filled SBK key[ 3.7362 ] Warning: pub_key.key is not found[ 3.7365 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mem_rcm_3_aligned_sigheader.bct.encrypt mem_rcm_3_aligned_sigheader.bct.hash zerosbk[ 3.7384 ] Copying signatures[ 3.7392 ] tegrahost_v2 --chip 0x23 0 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml[ 3.7411 ] tegraparser_v2 --generategpt --pt flash.xml.bin[ 3.7419 ] End sector for APP, expected at: 119537630, actual: 0Error: Return value 4Command tegraparser_v2 --generategpt --pt flash.xml.bincp: cannot stat ‘signed/*’: No such file or directorycp: cannot stat ‘signed/flash.xml.tmp’: No such file or directoryUsing bpmp-dtb concatenated with odmdata in blob for t23x./tegraflash.py --bl uefi_jetson_minimal_with_dtb_sigheader.bin.encrypt --bct br_bct_BR.bct --bldtb tegra234-p3768-0000+p3767-0000-nv-super.dtb --applet rcm_2_encrypt.rcm --applet_softfuse rcm_1_encrypt.rcm --cmd “secureflash;reboot” --cfg secureflash.xml --chip 0x23 --mb1_bct mb1_bct_MB1_sigheader.bct.encrypt --mem_bct mem_rcm_sigheader.bct.encrypt --mb1_cold_boot_bct mb1_cold_boot_bct_MB1_sigheader.bct.encrypt --mb1_bin mb1_t234_prod_aligned_sigheader.bin.encrypt --psc_bl1_bin psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --mem_bct_cold_boot mem_coldboot_sigheader.bct.encrypt --bins “psc_fw pscfw_t234_prod_sigheader.bin.encrypt; mts_mce mce_flash_o10_cr_prod_sigheader.bin.encrypt; tsec_fw tsec_t234_sigheader.bin.encrypt; mb2_applet applet_t234_sigheader.bin.encrypt; mb2_bootloader mb2_t234_with_mb2_bct_MB2_sigheader.bin.encrypt; xusb_fw xusb_t234_prod_sigheader.bin.encrypt; pva_fw nvpva_020_sigheader.fw.encrypt; dce_fw display-t234-dce_sigheader.bin.encrypt; nvdec nvdec_t234_prod_sigheader.fw.encrypt; bpmp_fw bpmp_t234-TE980M-A1_prod_sigheader.bin.encrypt; bpmp_fw_dtb tegra234-bpmp-3767-0000-3768-super_with_odm_sigheader.dtb.encrypt; rce_fw camera-rtcpu-t234-rce_sigheader.img.encrypt; ape_fw adsp-fw_sigheader.bin.encrypt; spe_fw spe_t234_sigheader.bin.encrypt; tos tos-optee_t234_sigheader.img.encrypt; eks eks_t234_sigheader.img.encrypt” saving flash command in flashcmd.txt
*** no-flash flag enabled. Exiting now… ***
User can run above saved command in factory environment without providing pkc and sbk keys to flash a device
Before these APPSIZE changes, I was able to flash successfully but root partition has full size of the NVME. (In my case root was: 950G, NVME size: 1TB)
How can I solve this issue?
