Hi Nvidia,
I’m tried to porting NPCT75x on Orin NX .
I got /dev/tpm0 and TPM is work.
But low after into OS. have any suggestions?
OS: Ubuntu 20.04
Device tree and pinmux as below
spi@3210000{ /* SPI1 in 40 pin conn /
cs-gpios = <&tegra_main_gpio TEGRA234_MAIN_GPIO(Z, 6) GPIO_ACTIVE_LOW>;
num-cs = <1>;
status = “okay”;
spidev: tpm@0 { / chip select 0 /
compatible = “tcg,tpm_tis-spi”;
status = “okay”;
reg = <0x0>;
#address-cells = <1>;
#size-cells = <1>;
spi-max-frequency = <50000000>;
controller-data {
nvidia,enable-hw-based-cs;
nvidia,rx-clk-tap-delay = <0x10>;
nvidia,tx-clk-tap-delay = <0x0>;
spi@1 { / chip select 1 */
compatible = “tegra-spidev”;
reg = <0x1>;
controller-data {
pinmux@2430000 {
pinctrl-0 = <0x179>;
pinctrl-names = “default”;
compatible = “nvidia,tegra234-pinmux”;
reg = <0x0 0x2430000 0x0 0x19100 0x0 0xc300000 0x0 0x4000>;
#gpio-range-cells = <0x3>;
status = “okay”;
linux,phandle = <0xab>;
phandle = <0xab>;
header-40pin-pinmux {
phandle = <0x179>;
linux,phandle = <0x179>;
pin19 {
nvidia,lpdr = <TEGRA_PIN_DISABLE>;
nvidia,enable-input = <TEGRA_PIN_ENABLE>;
nvidia,tristate = <TEGRA_PIN_DISABLE>;
nvidia,pull = <TEGRA_PIN_PULL_DOWN>;
nvidia,pins = "spi1_mosi_pz5";
nvidia,function = "spi1";
pin21 {
nvidia,pins = "spi1_miso_pz4";
pin23 {
nvidia,pins = "spi1_sck_pz3";
pin24 {
nvidia,pull = <TEGRA_PIN_PULL_UP>;
nvidia,pins = "spi1_cs0_pz6";
pin26 {
nvidia,tristate = <TEGRA_PIN_ENABLE>;
nvidia,pins = "spi1_cs1_pz7";
