OrinNX with USB3.0 not working
I am using Jetson OrinNX SOM with XavierNX Devkit with USB3.0 Camera. When I try to livetsream the camera, I cannot se camera feed.
I am using in headless environment. Below is the gstreamer pipeline and dmesg logs I shared, have a look once:
Receving:
gst-launch-1.0 udpsrc port=4000 ! application/x-rtp, media=video, clock-rate=90000, encoding-name=H264, payload=96 ! rtpjitterbuffer latency=100 ! rtph264depay ! avdec_h264 ! autovideoconvert ! autovideosink sync=false
Sending:
gst-launch-1.0 v4l2src device=/dev/video0 ! “video/x-raw, format=YUYV, height=1080, width=1920, format=YUY2, framerate=30/1” ! nvvidconv ! nvv4l2h265enc maxperf-enable=1 bitrate=1920000 control-rate=0 ! h265parse ! rtph265pay ! udpsink host=192.168.55.100 port=4000 sync=false
Setting pipeline to PAUSED …
Opening in BLOCKING MODE
Pipeline is live and does not need PREROLL …
Setting pipeline to PLAYING …
New clock: GstSystemClock
Redistribute latency…
NvMMLiteOpen : Block : BlockType = 8
===== NVMEDIA: NVENC =====
NvMMLiteBlockCreate : Block : BlockType = 8
USBCamera_dmesglogs.txt (66.5 KB)
Also I shared the formats:
v4l2-ctl --list-formats-ext
ioctl: VIDIOC_ENUM_FMT
Type: Video Capture
[0]: 'YUYV' (YUYV 4:2:2)
	Size: Discrete 1920x1080
		Interval: Discrete 0.017s (60.000 fps)
		Interval: Discrete 0.020s (50.000 fps)
		Interval: Discrete 0.033s (30.000 fps)
		Interval: Discrete 0.040s (25.000 fps)
Looks like you encode the frame data into H265 and try to decode it as H264. Please use H264 or H265 in both sender and receiver.
gst-launch-1.0 v4l2src device=/dev/video0 ! “video/x-raw, format=YUY2, width=1920, height=1080, framerate=30/1” ! nvvidconv ! nvv4l2h265enc maxperf-enable=1 bitrate=1920000 control-rate=0 ! h265parse ! rtph265pay ! udpsink host=192.168.55.100 port=4000 sync=false
Still unable to see video feed
