ORN AGX OS jetson Install failure
I have an ORIN AGX that I installed a different versoin of Linux on and now I want to put it back to the OS and all other stuff that NVIDIA ships on it. And I’m failing in that regard.
So I downlaoded the following:
f25931d1b15cc10d11b60395bd33ec1a Tegra_Linux_Sample-Root-Filesystem_R35.4.1_aarch64.tbz2
78ab6da96c1da2da5f855c59bbcae791 Jetson_Linux_R35.4.1_aarch64.tbz2
I first untar the Tegra*.tbz2. Then I untar the Jetson*.tbz2 into the Linux_for_Tegra/rootfs directory. Then I kick off the install as instructed: sudo ./flash.sh jetson-agx-orin-devkit internal
The install starts, but finishes with the following:
[ 0.7192 ] Rebooting to recovery mode
[ 0.7198 ] tegrarcm_v2 --chip 0x23 0 --ismb2
[ 0.7229 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 0.7234 ] MB2 Applet version 01.00.0000
[ 0.7257 ] Booting to recovery mode
[ 0.7262 ] tegrarcm_v2 --chip 0x23 0 --reboot recovery
[ 0.7268 ] MB2 Applet version 01.00.0000
Parsing board information failed.
SoI started wirking with cursor to figure out how to fix. Cursor says ot bypass the reading of the EEPROM during the install, as follows:
$ sudo SKIP_EEPROM_CHECK=1 BOARDID=3701 BOARDSKU=0005 FAB=500 ./flash.sh jetson-agx-orin-devkit internal
Which yields a bootable OS, but no graphices at all. I need a serial connction to see what going on. Cursor wanted to see the entire console output from the bootup. gave it to him, or her.
Cursor tells me t olook for a line that states with “Reserved memory”, which should say 512Mib. I get the following in my console output:
[ 0.000000] Reserved memory: created CMA memory pool at 0x0000001018c00000, size 256 MiB
Cursor believes tha tthe EEPROOM is corruppted and wants me to made a slight modificatin to the EEPROM. I’m reluctant to do that. So I’m posting here.
What do you think? Should O modify the EEPROM as cursor suggests?
Jim
Please try to put the device in recovery mode.
And reflash the device.
OK, so then lets start form ground zero. When I put the ORIN AGX into ercovery mode, here’s what I see in respose to that:
D3640 [lumos]: /u2/balson > lsusb | grep NVI
Bus 001 Device 027: ID 0955:7023 NVIDIA Corp. APX
Bus 001 Device 026: ID 0955:7045 NVIDIA Corp. Tegra On-Platform Operator
I’ve downloaded the following tar files:
D3640 [lumos]: /ct/lumos/nvidia/jetson-releases/Jetson-35.4.1 > md5sum *.tbz2
I untar the Jetson_linux first, thne I untar the sample root filesystem into the rootfs directory under Linux_for_Tegra/rootfs.
Then I flash my ORIN AGX as follows:
And it churns along for maybe 10 seconds, maybe lewss. Here’s the full output that I get:
D3640 [lumos]: /ct/lumos/nvidia/jetson-releases/Jetson-35.4.1/tmp/Linux_for_Tegra > sudo ./flash.sh jetson-agx-orin-devkit internal
[sudo] password for balson:
L4T BSP Information:
R35 , REVISION: 4.1
User release: 0.0
Target Board Information:
Name: jetson-agx-orin-devkit, Board Family: t186ref, SoC: Tegra 234,
OpMode: production, Boot Authentication: NS,
Disk encryption: disabled ,
copying emc_fuse_dev_params(/ct/lumos/nvidia/jetson-releases/Jetson-35.4.1/tmp/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-br-bct-diag-boot.dts)… done.
copying device_config(/ct/lumos/nvidia/jetson-releases/Jetson-35.4.1/tmp/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-device-p3701-0000.dts)… done.
copying misc_config(/ct/lumos/nvidia/jetson-releases/Jetson-35.4.1/tmp/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-misc-p3701-0000.dts)… done.
./tegraflash.py --chip 0x23 --applet “/ct/lumos/nvidia/jetson-releases/Jetson-35.4.1/tmp/Linux_for_Tegra/bootloader/mb1_t234_prod.bin” --skipuid --cfg readinfo_t234_min_prod.xml --dev_params tegra234-br-bct-diag-boot.dts --device_config tegra234-mb1-bct-device-p3701-0000.dts --misc_config tegra234-mb1-bct-misc-p3701-0000.dts --bins “mb2_applet applet_t234.bin” --cmd “dump eeprom cvm cvm.bin; dump custinfo custinfo_out.bin; reboot recovery”
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0200 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 0.0206 ] File rcm_state open failed
[ 0.0207 ] ERROR: failed to read rcm_state
[ 0.0207 ]
[ 0.0227 ] tegrasign_v3.py --key None --getmode mode.txt
[ 0.0229 ] Assuming zero filled SBK key
[ 0.0209 ] Pre-processing config: tegra234-mb1-bct-device-p3701-0000.dts
[ 0.0303 ] Pre-processing config: tegra234-mb1-bct-misc-p3701-0000.dts
[ 0.0365 ] Parsing partition layout
[ 0.0379 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[ 0.0404 ] Kernel DTB used: None
[ 0.0404 ] WARNING: dce base dtb is not provided
[ 0.0404 ] Parsing partition layout
[ 0.0410 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[ 0.0417 ] Creating list of images to be signed
[ 0.0432 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --list images_list.xml zerosbk
[ 0.0438 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[ 0.0492 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[ 0.0501 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[ 0.0536 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[ 0.0542 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[ 0.0590 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[ 0.0591 ] adding BCH for mb2_t234_aligned.bin
[ 0.0622 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[ 0.0710 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[ 0.0711 ] adding BCH for mb2_t234_aligned.bin
[ 0.0816 ] Filling MB1 storage info
[ 0.0816 ] Parsing dev params for multi chains
[ 0.0854 ] Generating br-bct
[ 0.0872 ] Updating dev and MSS params in BR BCT
[ 0.0872 ] tegrabct_v2 --dev_param tegra234-br-bct-diag-boot_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[ 0.0904 ] Updating bl info
[ 0.0909 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo readinfo_t234_min_prod.xml.bin
[ 0.0914 ] WARNING: boot chain is not completed. set to 0
[ 0.0919 ] Generating signatures
[ 0.0940 ] tegrasign_v3.py --key None --list images_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.0941 ] Assuming zero filled SBK key
[ 0.1399 ] Warning: pub_key.key is not found
[ 0.1388 ] Parsing dev params for multi chains
[ 0.1389 ] Generating br-bct
[ 0.1411 ] Updating dev and MSS params in BR BCT
[ 0.1413 ] tegrabct_v2 --dev_param tegra234-br-bct-diag-boot_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[ 0.1438 ] Updating bl info
[ 0.1456 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
[ 0.1470 ] WARNING: boot chain is not completed. set to 0
[ 0.1486 ] Get Signed section of bct
[ 0.1501 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --listbct bct_list.xml
[ 0.1516 ] Signing BCT
[ 0.1537 ] tegrasign_v3.py --key None --list bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.1540 ] Assuming zero filled SBK key
[ 0.1581 ] Sha saved in br_bct_BR.sha
[ 0.1585 ] Warning: pub_key.key is not found
[ 0.1565 ] Updating BCT with signature
[ 0.1574 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesig bct_list_signed.xml
[ 0.1583 ] Offset :4608 Len :3584
[ 0.1588 ] Generating SHA2 Hash
[ 0.1609 ] tegrasign_v3.py --key None --list bct_list.xml --sha sha512
[ 0.1611 ] Assuming zero filled SBK key
[ 0.1640 ] Sha saved in br_bct_BR.sha
[ 0.1622 ] Updating BCT with SHA2 Hash
[ 0.1631 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesha bct_list_signed.xml
[ 0.1639 ] Offset :4608 Len :3584
[ 0.1641 ] Offset :68 Len :8124
[ 0.1643 ] Generating coldboot mb1-bct
[ 0.1651 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct.cfg --misc tegra234-mb1-bct-misc-p3701-0000_cpp.dtb --device tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[ 0.1658 ] MB1-BCT version: 0.10
[ 0.1660 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED1/ is not supported
[ 0.1663 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED1/ is not supported
[ 0.1665 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED1/ is not supported
[ 0.1668 ] ERROR: /misc/tsc_controls/tsc_locking_config is not supported
[ 0.1670 ] ERROR: /misc/tsc_controls/tsc_locking_diff_configuration is not supported
[ 0.1672 ] ERROR: /misc/tsc_controls/tsc_locking_ref_frequency_configuration is not supported
[ 0.1674 ] ERROR: /misc/tsc_controls/tsc_locking_control is not supported
[ 0.1674 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_configuration is not supported
[ 0.1674 ] ERROR: /misc/tsc_controls/tsc_locking_fast_adjust_configuration is not supported
[ 0.1674 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_delta_control is not supported
[ 0.1674 ] ERROR: /misc/tsc_controls/tsc_capture_control_ptx is not supported
[ 0.1674 ] ERROR: /misc/tsc_controls/tsc_capture_config_ptx is not supported
[ 0.1674 ] ERROR: /misc/tsc_controls/tsc_stscrsr is not supported
[ 0.1674 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_num_control is not supported
[ 0.1674 ]
[ 0.1674 ] Parsing config file :tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[ 0.1674 ] Added Platform Config 9 data with size :- 100
[ 0.1674 ]
[ 0.1674 ] Updating mb1-bct with firmware information
[ 0.1679 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo readinfo_t234_min_prod.xml.bin
[ 0.1692 ] tegrahost_v2 --chip 0x23 0 --align mb1_cold_boot_bct_MB1_aligned.bct
[ 0.1701 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --appendsigheader mb1_cold_boot_bct_MB1_aligned.bct zerosbk
[ 0.1707 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
[ 0.1732 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.1733 ] Assuming zero filled SBK key
[ 0.1743 ] Warning: pub_key.key is not found
[ 0.1728 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_cold_boot_bct_MB1_aligned_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_aligned_sigheader.bct.hash zerosbk
[ 0.1736 ] Generating recovery mb1-bct
[ 0.1741 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct.cfg --misc tegra234-mb1-bct-misc-p3701-0000_cpp.dtb --device tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[ 0.1746 ] MB1-BCT version: 0.10
[ 0.1747 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED1/ is not supported
[ 0.1749 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED1/ is not supported
[ 0.1751 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED1/ is not supported
[ 0.1752 ] ERROR: /misc/tsc_controls/tsc_locking_config is not supported
[ 0.1754 ] ERROR: /misc/tsc_controls/tsc_locking_diff_configuration is not supported
[ 0.1755 ] ERROR: /misc/tsc_controls/tsc_locking_ref_frequency_configuration is not supported
[ 0.1757 ] ERROR: /misc/tsc_controls/tsc_locking_control is not supported
[ 0.1757 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_configuration is not supported
[ 0.1757 ] ERROR: /misc/tsc_controls/tsc_locking_fast_adjust_configuration is not supported
[ 0.1757 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_delta_control is not supported
[ 0.1757 ] ERROR: /misc/tsc_controls/tsc_capture_control_ptx is not supported
[ 0.1757 ] ERROR: /misc/tsc_controls/tsc_capture_config_ptx is not supported
[ 0.1757 ] ERROR: /misc/tsc_controls/tsc_stscrsr is not supported
[ 0.1758 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_num_control is not supported
[ 0.1758 ]
[ 0.1758 ] Parsing config file :tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[ 0.1758 ] Added Platform Config 9 data with size :- 100
[ 0.1758 ]
[ 0.1758 ] Updating mb1-bct with firmware information
[ 0.1763 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct_MB1.bct --recov --updatefwinfo readinfo_t234_min_prod.xml.bin
[ 0.1775 ] tegrahost_v2 --chip 0x23 0 --align mb1_bct_MB1_aligned.bct
[ 0.1786 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --appendsigheader mb1_bct_MB1_aligned.bct zerosbk
[ 0.1790 ] adding BCH for mb1_bct_MB1_aligned.bct
[ 0.1816 ] tegrasign_v3.py --key None --list mb1_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.1817 ] Assuming zero filled SBK key
[ 0.1826 ] Warning: pub_key.key is not found
[ 0.1811 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_bct_MB1_aligned_sigheader.bct.encrypt mb1_bct_MB1_aligned_sigheader.bct.hash zerosbk
[ 0.1819 ] Error: Skip generating mem_bct because sdram_config is not defined
[ 0.1820 ] Error: Skip generating mem_bct because sdram_config is not defined
[ 0.1820 ] Copying signatures
[ 0.1825 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
[ 0.1865 ] mb1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
[ 0.1867 ] psc_bl1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
[ 0.1867 ] Boot Rom communication
[ 0.1872 ] tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[ 0.1877 ] BR_CID: 0x80012344705DD3DF0800000013FD81C0
[ 0.1884 ] Sending bct_br
[ 0.1885 ] Sending mb1
[ 0.1889 ] Sending psc_bl1
[ 0.2004 ] Sending bct_mb1
[ 0.2067 ] Boot Rom communication completed
[ 0.2088 ] tegrahost_v2 --chip 0x23 0 --align applet_t234_aligned.bin
[ 0.2099 ] tegrahost_v2 --chip 0x23 0 --magicid MB2A --appendsigheader applet_t234_aligned.bin zerosbk
[ 0.2104 ] adding BCH for applet_t234_aligned.bin
[ 0.2188 ] tegrasign_v3.py --key None --list applet_t234_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.2189 ] Assuming zero filled SBK key
[ 0.2202 ] Warning: pub_key.key is not found
[ 0.2189 ] tegrahost_v2 --chip 0x23 0 --updatesigheader applet_t234_aligned_sigheader.bin.encrypt applet_t234_aligned_sigheader.bin.hash zerosbk
[ 0.2200 ] Sending mb2_applet…
[ 0.2206 ] tegrarcm_v2 --chip 0x23 0 --pollbl --download applet applet_t234_sigheader.bin.encrypt
[ 0.2211 ] BL: version 1.2.0.0-t234-54845784-562369e5 last_boot_error: 0
[ 0.4126 ] Sending applet
[ 0.5214 ] completed
[ 0.5245 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 0.5274 ] MB2 Applet version 01.00.0000
[ 0.7393 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 0.7398 ] MB2 Applet version 01.00.0000
[ 0.7425 ] Retrieving board information
[ 0.7431 ] tegrarcm_v2 --chip 0x23 0 --oem platformdetails chip chip_info.bin
[ 0.7437 ] MB2 Applet version 01.00.0000
[ 0.7457 ] Saved platform info in chip_info.bin
[ 0.7511 ] Chip minor revision: 1
[ 0.7512 ] Bootrom revision: 0x7
[ 0.7513 ] Ram code: 0x3
[ 0.7513 ] Chip sku: 0xd0
[ 0.7513 ] Chip Sample: prod
[ 0.7520 ] Retrieving EEPROM data
[ 0.7520 ] tegrarcm_v2 --oem platformdetails eeprom cvm /ct/lumos/nvidia/jetson-releases/Jetson-35.4.1/tmp/Linux_for_Tegra/bootloader/cvm.bin --chip 0x23 0
[ 0.7526 ] MB2 Applet version 01.00.0000
[ 0.7547 ] Saved platform info in /ct/lumos/nvidia/jetson-releases/Jetson-35.4.1/tmp/Linux_for_Tegra/bootloader/cvm.bin
[ 0.7906 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 0.7932 ] MB2 Applet version 01.00.0000
[ 0.7966 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 0.7971 ] MB2 Applet version 01.00.0000
[ 0.7993 ] Dumping customer Info
[ 0.7998 ] tegrarcm_v2 --chip 0x23 0 --oem dump bct tmp.bct
[ 0.8003 ] MB2 Applet version 01.00.0000
[ 0.8024 ] Saved bct in tmp.bct
[ 0.8102 ] tegrabct_v2 --brbct tmp.bct --chip 0x23 0 --custinfo /ct/lumos/nvidia/jetson-releases/Jetson-35.4.1/tmp/Linux_for_Tegra/bootloader/custinfo_out.bin
[ 0.8108 ] C[ 0.8110 ] ustomer data saved in /ct/lumos/nvidia/jetson-releases/Jetson-35.4.1/tmp/Linux_for_Tegra/bootloader/custinfo_out.bin successfully
[ 0.8110 ] Rebooting to recovery mode
[ 0.8116 ] tegrarcm_v2 --chip 0x23 0 --ismb2
[ 0.8148 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 0.8153 ] MB2 Applet version 01.00.0000
[ 0.8174 ] Booting to recovery mode
[ 0.8179 ] tegrarcm_v2 --chip 0x23 0 --reboot recovery
[ 0.8183 ] MB2 Applet version 01.00.0000
And feeding this info to cursor it says that the EEPROM needs to be adjusted, which I am reluctant to do until I hear that from NVIDIA.
And now here’s a little more history. This box come to us form NVIDIA with the standard OS and jetpack on it. But we are working with an offshore team to upgrde the OS to Linux 6.18.x. And we did have Lim=nus 6.18.x o nit. Now I want to go back tothe standard software as shipped by NVIDIA, and this is where I run into issues.
Any help appreciated
Jim
Please upload the serial console log also as a file for us to review.
Could you please provide any update for this topic?
Was never resolved. We now have 2 ORIN boxed that can only run a custom yicto build.
Please provide the serial console log, as the issue is hard to debug without it.
