测试现象】机器高温70℃贮存1h后,机器机器无法进入系统,卡在开机界面或者命令行处。
【发生概率】测试2pcs机器,1pcs出现该故障。用的是38.4.0 用了typeC转dp线 出现了 插拔显示器端DP接口,存在白屏卡顿
please check uart log instead of only checking the display.
BPMP.txt (40.3 KB)
com COM35 (2026-09-29_193940) COM35 (USB Serial Port (COM35)).log (305.4 KB)
UTC0.txt (16.2 KB)
TZ0.txt (25.9 KB)
RCE.txt (1.7 KB)
RAW.txt (324.2 KB)
PSCFW.txt (950 Bytes)
DCE.txt (1.6 KB)
CCPLEX0.txt (230.9 KB)
这个log 我们用的是JP 7.2 39.2.0,也复现了同样的问题
06 [2026-09-29 19:40:31.692] [ 30.154266] [TS:51008125289] [kworke][0x1cc1856][11:38:53.925930] wlan: [131:E:OSIF] osif_twt_enable_complete_cb: obsolete request^M[ 30.533484] [TS:51387343208] EtherCAT WARNING 0: 125 datagrams TIMED OUT!^M
2607 [2026-09-29 19:40:32.059] [ 31.537017] [TS:52390875694] EtherCAT WARNING 0: 125 datagrams TIMED OUT!^M
2608 [2026-09-29 19:40:33.065] [ 31.955209] [TS:52809068083] obc_max96712 9-0029: num_lanes property not found^M
2609 [2026-09-29 19:40:33.480] [ 31.955212] [TS:52809070666] obc_max96712 9-0029: port_a_clk property not found^M[ 31.955213] [TS:52809071731] obc_max96712 9-0029: mipi_rate not found, use default 1.5G^M
2610 [2026-09-29 19:40:33.484] [ 31.955214] [TS:52809073305] obc_max96712 9-0029: link_mask not found^M
2611 [2026-09-29 19:40:33.499] [ 32.540576] [TS:53394435287] EtherCAT WARNING 0: 125 datagrams TIMED OUT!^M
2612 [2026-09-29 19:40:34.060] [ 32.797496] [TS:53651355017] debugfs: Directory ‘max96712_0’ with parent ‘/’ already present!^M
2613 [2026-09-29 19:40:34.325] [ 33.135142] [TS:53989000956] obc_max96712 9-0029: max96712_check_link_lock failed 0^M
2614 [2026-09-29 19:40:34.665] [ 33.151992] [TS:54005851211] g300 9-0066: supply vcc not found, using dummy regulator^M
2615 [2026-09-29 19:40:34.668] [ 33.152083] [TS:54005941859] g300 9-0066: pps-gpios not found -2^M
2616 [2026-09-29 19:40:34.669] [ 33.152087] [TS:54005945702] g300 9-0066: camera num 0 no found serialer dev^M
2617 [2026-09-29 19:40:34.684] [ 33.152101] [TS:54005960211] tegra-nvcsi 8181200000.host1x:nvcsi@8188000000: Failed to create device link (0x180) with 9-0066^M
2618 [2026-09-29 19:40:34.699] [ 33.152189] [TS:54006047767] g300 9-0067: supply vcc not found, using dummy regulator^M
2619 [2026-09-29 19:40:34.716] [ 33.152226] [TS:54006085258] g300 9-0067: pps-gpios not found -2^M
2620 [2026-09-29 19:40:34.717] [ 33.152228] [TS:54006087109] g300 9-0067: camera num 0 no found serialer dev^M
2621 [2026-09-29 19:40:34.718] [ 33.152232] [TS:54006090443] tegra-nvcsi 8181200000.host1x:nvcsi@8188000000: Failed to create device link (0x180) with 9-0067^M
2622 [2026-09-29 19:40:34.733] ^M^M
2623 [2026-09-29 19:41:17.115] tegra-ubuntu login:
Your log shows that it has prompt to ask your login. Are you sure the log matches to your photo?
我们用39.2.0在常温下 进行的复测,直接用的两头都是DP的线 连接的显示器。显示 登录界面输入密码后,卡在白屏 2-3min后进入到桌面。log对应的最新 拍摄的视频 如下
想釐清一下, 所以這個問題跟高溫有關連嗎?
当时测试的人员测的有一些误导。现在的问题是 常温状态下 测试 为什么 显示 登录界面输入密码后,卡在白屏 2-3min后进入到桌面 ?
請問你的uart 在等待的那2-3分鐘有顯示任何log嗎
有发现 是 什么问题么
There is no useful info from those log.
Is your issue able to reproduce on NV devkit with jp7.2.1?
yes !
Which display head are you using on Jetson devkit?
DP display
May try other cable?
这个与cable没有关系,我们有多台,不通显示器和线束都可以复现
问一下 jp7.3.0 什么时候发布?
We tried this test on AGX Thor devkit on jp7.2.1 but could not see anything similar to the video you shared.
