Main pipeline creation code:
Drop frame rate is set to 3
# Standard GStreamer initialization
GObject.threads_init()
Gst.init(None)
# Create gstreamer elements
pipeline = create_pipeline()
# Create nvstreammux instance to form batches from one or more sources.
streammux = create_streammux()
pipeline.add(streammux)
streamdemux = create_streamdemux()
for source_num in len(sources):
source = sources[source_num]
source_bin = create_source_bin(source_num, source, drop_frame_rate)
if not source_bin:
sys.stderr.write("Unable to create source bin \n")
pipeline.add(source_bin)
padname = "sink_%u" % source_num
sinkpad = streammux.get_request_pad(padname)
if not sinkpad:
sys.stderr.write(f"Unable to create sink pad bin for source {source_num} \n")
srcpad = source_bin.get_static_pad("src")
if not srcpad:
sys.stderr.write("Unable to create src pad bin \n")
srcpad.link(sinkpad)
pgie = create_pgie()
# create tracker
if config.use_nvtracker:
tracker = create_tracker([source_num for source_num in len(sources)])
# Use convertor to convert from NV12 to RGBA as required by nvosd
nvvidconv = create_nvvidconv([source_num for source_num in len(sources)])
# Create OSD to draw on the converted RGBA buffer.
nvosd = create_nvosd([source_num for source_num in len(sources)])
# nvvidconv_postosd = create_nvvidconv()
RTSP Out Code Start
# Create a caps filter
caps = create_capsfilter([source_num for source_num in len(sources)])
# Make the encoder
encoder = create_encoder([source_num for source_num in len(sources)])
# Make the payload-encode video into RTP packets
rtppay = create_rtppay([source_num for source_num in len(sources)])
# Make the UDP sink
udpsink_start_port = 5400
udpsink_port_list = [port for port in range(udpsink_start_port, udpsink_start_port+len([source_num for source_num in len(sources)]))]
sink = create_udpsink([source_num for source_num in len(sources)], udpsink_port_list)
RTSP Out Code End
streammux = add_streammux_props(streammux, frame_width, frame_height) # setting properties of streammux
pgie.set_property('config-file-path', primary_model_config_file) # setting properties of pgie
pipeline.add(pgie)
pipeline.add(streamdemux)
dum_var = [pipeline.add(v) for v in tracker.values()]
dum_var = [pipeline.add(v) for v in nvvidconv.values()]
dum_var = [pipeline.add(v) for v in nvosd.values()]
dum_var = [pipeline.add(v) for v in caps.values()]
dum_var = [pipeline.add(v) for v in encoder.values()]
dum_var = [pipeline.add(v) for v in rtppay.values()]
dum_var = [pipeline.add(v) for v in sink.values()]
# Link the elements together:
# uridecodebin -> streammux -> nvinfer ->
# nvtracker -> nvvidconv -> nvosd -> nvvidconv_postosd ->
# caps -> encoder -> rtppay -> udpsink
streammux.link(pgie)
pgie.link(streamdemux)
srcpad1 = streamdemux.get_request_pad(f"src_{source_num}")
if not srcpad1:
sys.stderr.write(" Unable to get the src pad of streamdemux \n")
continue
sinkpad1 = tracker[f"tracker_{source_num}"].get_static_pad("sink")
if not sinkpad1:
sys.stderr.write(" Unable to get sink pad of tracker \n")
else:
sinkpad1 = nvvidconv[f"nvvidconv_{source_num}"].get_static_pad("sink")
if not sinkpad1:
sys.stderr.write(" Unable to get sink pad of nvvidconv \n")
srcpad1.link(sinkpad1)
tracker[f"tracker_{source_num}"].link(nvvidconv[f"nvvidconv_{source_num}"])
nvvidconv[f"nvvidconv_{source_num}"].link(nvosd[f"nvosd_{source_num}"])
nvosd[f"nvosd_{source_num}"].link(caps[f"caps_{source_num}"])
caps[f"caps_{source_num}"].link(encoder[f"encoder_{source_num}"])
encoder[f"encoder_{source_num}"].link(rtppay[f"rtppay_{source_num}"])
rtppay[f"rtppay_{source_num}"].link(sink[f"sink_{source_num}"])
# create an event loop and feed gstreamer bus mesages to it
bus = pipeline.get_bus()
bus.add_signal_watch()
bus.connect("message", bus_call, loop)
# Start streaming
rtsp_port_num = 8554
server = GstRtspServer.RTSPServer.new()
server.props.service = "%d" % rtsp_port_num
server.attach(None)
factory_dict = dict()
for i in range(len(sources)):
udpsink_port = udpsink_port_list[i]
factory = GstRtspServer.RTSPMediaFactory.new()
factory.set_launch(
"( udpsrc name=pay0 port=%d buffer-size=524288 caps=\"application/x-rtp, media=video, clock-rate=90000, encoding-name=(string)%s, payload=96 \" )" % (
udpsink_port, codec))
factory.set_shared(True)
factory_dict[f"factory_{i}"] = factory
server.get_mount_points().add_factory("/ds-test", factory_dict[f"factory_{source_num}"])
osdsinkpad = dict()
osdsinkpad[f"osdsinkpad_{source_num}"] = nvosd[f"nvosd_{source_num}"].get_static_pad("sink")
if not osdsinkpad[f"osdsinkpad_{source_num}"]:
sys.stderr.write(" Unable to get sink pad of nvosd \n")
for osp, source in zip(osdsinkpad.values(), sources):
osp.add_probe(Gst.PadProbeType.BUFFER, osd_sink_pad_buffer_probe, 0, source)
# start play back and listen to events
print("Starting pipeline \n", pipeline)
pipeline.set_state(Gst.State.PLAYING)
loop.run()
Creating source:
def create_source_bin(index, uri, drop_frame_rate):
# Create a source GstBin to abstract this bin's content from the rest of the pipeline
bin_name = "source-bin-%02d" % index
nbin = Gst.Bin.new(bin_name)
if not nbin:
sys.stderr.write(" Unable to create source bin \n")
uri_decode_bin = Gst.ElementFactory.make("uridecodebin", "uri-decode-bin")
if not uri_decode_bin:
sys.stderr.write(" Unable to create uri decode bin \n")
uri_decode_bin.set_property("uri", uri)
uri_decode_bin.connect("pad-added", cb_newpad, nbin)
uri_decode_bin.connect("child-added", decodebin_child_added, nbin, drop_frame_rate)
Gst.Bin.add(nbin, uri_decode_bin)
bin_pad = nbin.add_pad(Gst.GhostPad.new_no_target("src", Gst.PadDirection.SRC))
if not bin_pad:
sys.stderr.write(" Failed to add ghost pad in source bin \n")
return None
return nbin
cb_newpad & decodebin_child_added:
def cb_newpad(decodebin, decoder_src_pad, data):
print("In cb_newpad\n")
caps = decoder_src_pad.get_current_caps()
gststruct = caps.get_structure(0)
gstname = gststruct.get_name()
source_bin = data
features = caps.get_features(0)
if (gstname.find("video") != -1):
if features.contains("memory:NVMM"):
bin_ghost_pad = source_bin.get_static_pad("src")
if not bin_ghost_pad.set_target(decoder_src_pad):
sys.stderr.write("Failed to link decoder src pad to source bin ghost pad\n")
else:
sys.stderr.write(" Error: Decodebin did not pick nvidia decoder plugin.\n")
def decodebin_child_added(child_proxy, Object, name, drop_frame_rate, user_data):
print("Decodebin child added:", name)
if(name.find("decodebin") != -1):
Object.connect("child-added", decodebin_child_added, user_data, drop_frame_rate)
if(name.find("nvv4l2decoder") != -1):
print("Seting bufapi_version\n")
Object.set_property("drop-frame-interval", drop_frame_rate)
OSD Probe function is similar to below code:
def osd_sink_pad_buffer_probe(pad,info,u_data):
frame_number=0
#Intiallizing object counter with 0.
obj_counter = {
PGIE_CLASS_ID_VEHICLE:0,
PGIE_CLASS_ID_PERSON:0,
PGIE_CLASS_ID_BICYCLE:0,
PGIE_CLASS_ID_ROADSIGN:0
num_rects=0
gst_buffer = info.get_buffer()
if not gst_buffer:
print("Unable to get GstBuffer ")
return
# Retrieve batch metadata from the gst_buffer
# Note that pyds.gst_buffer_get_nvds_batch_meta() expects the
# C address of gst_buffer as input, which is obtained with hash(gst_buffer)
batch_meta = pyds.gst_buffer_get_nvds_batch_meta(hash(gst_buffer))
l_frame = batch_meta.frame_meta_list
while l_frame is not None:
try:
# Note that l_frame.data needs a cast to pyds.NvDsFrameMeta
# The casting is done by pyds.NvDsFrameMeta.cast()
# The casting also keeps ownership of the underlying memory
# in the C code, so the Python garbage collector will leave
# it alone.
except StopIteration:
break
frame_number=frame_meta.frame_num
num_rects = frame_meta.num_obj_meta
l_obj=frame_meta.obj_meta_list
while l_obj is not None:
try:
# Casting l_obj.data to pyds.NvDsObjectMeta
obj_meta=pyds.NvDsObjectMeta.cast(l_obj.data)
break
obj_counter[obj_meta.class_id] += 1
try:
l_obj=l_obj.next
break
# Acquiring a display meta object. The memory ownership remains in
# the C code so downstream plugins can still access it. Otherwise
# the garbage collector will claim it when this probe function exits.
display_meta=pyds.nvds_acquire_display_meta_from_pool(batch_meta)
display_meta.num_labels = 1
py_nvosd_text_params = display_meta.text_params[0]
# Setting display text to be shown on screen
# Note that the pyds module allocates a buffer for the string, and the
# memory will not be claimed by the garbage collector.
# Reading the display_text field here will return the C address of the
# allocated string. Use pyds.get_string() to get the string content.
py_nvosd_text_params.display_text = "Frame Number={} Number of Objects={} Vehicle_count={} Person_count={}".format(frame_number, num_rects, obj_counter[PGIE_CLASS_ID_VEHICLE], obj_counter[PGIE_CLASS_ID_PERSON])
# Now set the offsets where the string should appear
py_nvosd_text_params.x_offset = 10
py_nvosd_text_params.y_offset = 12
# Font , font-color and font-size
py_nvosd_text_params.font_params.font_name = "Serif"
py_nvosd_text_params.font_params.font_size = 10
# set(red, green, blue, alpha); set to White
py_nvosd_text_params.font_params.font_color.set(1.0, 1.0, 1.0, 1.0)
# Text background color
py_nvosd_text_params.set_bg_clr = 1
# set(red, green, blue, alpha); set to Black
py_nvosd_text_params.text_bg_clr.set(0.0, 0.0, 0.0, 1.0)
# Using pyds.get_string() to get display_text as string
print(pyds.get_string(py_nvosd_text_params.display_text))
pyds.nvds_add_display_meta_to_frame(frame_meta, display_meta)
try:
l_frame=l_frame.next
break
return Gst.PadProbeReturn.OK
We tested with multiple number of sources (1 to 3), results are same.
below are the sources and corresponding output from our app.
Source specifications:
- Stream #0:0: Video: h264 (High), yuv420p(tv, progressive), 960x576, 15 fps, 25 tbr, 90k tbn, 30 tbc
below is the output for above mentioned stream, frame number, frame time and diff between prev frame time and current frametime
Frame nubmer |
Current Frame Time |
Time diff |
Frame nubmer 06 |
1659421246 |
0.0041 |
Frame nubmer 07 |
1659421246 |
0.0036 |
Frame nubmer 08 |
1659421246 |
0.0033 |
Frame nubmer 09 |
1659421246 |
0.0034 |
Frame number 10 |
1659421247 |
1.0872 |
Frame number 11 |
1659421247 |
0.0038 |
Frame number 12 |
1659421247 |
0.0032 |
Frame number 13 |
1659421247 |
0.0031 |
Frame number 14 |
1659421247 |
0.0029 |
Frame number 15 |
1659421248 |
0.9158 |
Frame number 16 |
1659421248 |
0.0037 |
Frame number 17 |
1659421248 |
0.0034 |
Frame number 18 |
1659421248 |
0.0032 |
Frame number 19 |
1659421248 |
0.0031 |
Frame number 20 |
1659421249 |
0.9926 |
Frame number 21 |
1659421249 |
0.0038 |
Frame number 22 |
1659421249 |
0.0033 |
Frame number 23 |
1659421249 |
0.0031 |
Frame number 24 |
1659421249 |
0.003 |
Frame number 25 |
1659421250 |
1.0456 |
Frame number 26 |
1659421250 |
0.0037 |
Frame number 27 |
1659421250 |
0.0033 |
Frame number 28 |
1659421250 |
0.0033 |
Frame number 29 |
1659421250 |
0.0031 |
Frame number 30 |
1659421251 |
0.9532 |
- Stream #0:0: Video: h264 (High), yuvj420p(pc, bt709, progressive), 1920x1080, 15 fps, 25 tbr, 90k tbn, 30 tbc
Frame nubmer |
Time diff |
Frame nubmer 06 |
1659423201 |
0.161 |
Frame nubmer 07 |
1659423201 |
0.2312 |
Frame nubmer 08 |
1659423201 |
0.2091 |
Frame nubmer 09 |
1659423202 |
0.1907 |
Frame number 10 |
1659423202 |
0.2018 |
Frame number 11 |
1659423202 |
0.178 |
Frame number 12 |
1659423202 |
0.2221 |
Frame number 13 |
1659423202 |
0.2015 |
Frame number 14 |
1659423203 |
0.1973 |
Frame number 15 |
1659423203 |
0.1993 |
Frame number 16 |
1659423203 |
0.1589 |
Frame number 17 |
1659423203 |
0.2415 |
Frame number 18 |
1659423203 |
0.2004 |
Frame number 19 |
1659423204 |
0.2078 |
Frame number 20 |
1659423204 |
0.1945 |
Frame number 21 |
1659423204 |
0.1359 |
Frame number 22 |
1659423204 |
0.2622 |
Frame number 23 |
1659423204 |
0.2009 |
Frame number 24 |
1659423205 |
0.1971 |
Frame number 25 |
1659423205 |
0.2031 |
Frame number 26 |
1659423205 |
0.1615 |
Frame number 27 |
1659423205 |
0.2452 |
Frame number 28 |
1659423205 |
0.1944 |
Frame number 29 |
1659423206 |
0.1978 |
Frame number 30 |
1659423206 |
0.1991 |
With the first stream there is huge time diff every 5 frames, which is not present when second stream is used
