OSError: Unable to open file (truncated file: eof = 760832, sblock->base_addr = 0,
TensorRT Version7.2.1.6
Quadro RTX 5000 dual GPU
Driver Version: 455.23.05
CUDA Version: 11.1
Ubuntu 18.04
python 3.6
Yolo_v4
nvidia/tao/tao-toolkit-tf:
docker_registry: nvcr.io
docker_tag: v3.21.08-py3
After running inference on images using
Running inference for detection on n images
!tlt yolo_v4 inference -i $DATA_DOWNLOAD_DIR/test_samples \
                       -o $USER_EXPERIMENT_DIR/yolo_infer_images \
                       -e $SPECS_DIR/yolo_v4_retrain_resnet18_kitti.txt \
                       -m $USER_EXPERIMENT_DIR/experiment_dir_retrain/weights/yolov4_resnet18_epoch_080.tlt \
                       -l $USER_EXPERIMENT_DIR/yolo_infer_labels \
                       -k $KEY
I get this error
/home/vaaan/.local/lib/python3.7/site-packages/tlt/init.py:20: DeprecationWarning:
The nvidia-tlt package will be deprecated soon. Going forward please migrate to using the nvidia-tao package.
warnings.warn(message, DeprecationWarning)
~/.tao_mounts.json wasn’t found. Falling back to obtain mount points and docker configs from ~/.tlt_mounts.json.
Please note that this will be deprecated going forward.
2021-11-08 11:29:35,370 [INFO] root: Registry: [‘nvcr.io’]
2021-11-08 11:29:35,531 [WARNING] tlt.components.docker_handler.docker_handler:
Docker will run the commands as root. If you would like to retain your
local host permissions, please add the “user”:“UID:GID” in the
DockerOptions portion of the “/home/vaaan/.tlt_mounts.json” file. You can obtain your
users UID and GID by using the “id -u” and “id -g” commands on the
terminal.
Using TensorFlow backend.
WARNING:tensorflow:Deprecation warnings have been disabled. Set TF_ENABLE_DEPRECATION_WARNINGS=1 to re-enable them.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:95: The name tf.reset_default_graph is deprecated. Please use tf.compat.v1.reset_default_graph instead.
2021-11-08 05:59:41,071 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:95: The name tf.reset_default_graph is deprecated. Please use tf.compat.v1.reset_default_graph instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:98: The name tf.placeholder_with_default is deprecated. Please use tf.compat.v1.placeholder_with_default instead.
2021-11-08 05:59:41,071 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:98: The name tf.placeholder_with_default is deprecated. Please use tf.compat.v1.placeholder_with_default instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:102: The name tf.get_default_graph is deprecated. Please use tf.compat.v1.get_default_graph instead.
2021-11-08 05:59:41,074 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:102: The name tf.get_default_graph is deprecated. Please use tf.compat.v1.get_default_graph instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:517: The name tf.placeholder is deprecated. Please use tf.compat.v1.placeholder instead.
2021-11-08 05:59:41,142 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:517: The name tf.placeholder is deprecated. Please use tf.compat.v1.placeholder instead.
File “/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/yolo_v4/scripts/inference.py”, line 180, in
File “/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/common/utils.py”, line 494, in return_func
File “/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/common/utils.py”, line 482, in return_func
File “/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/yolo_v4/scripts/inference.py”, line 176, in main
File “/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/yolo_v4/scripts/inference.py”, line 136, in inference
File “/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/yolo_v4/utils/model_io.py”, line 61, in load_model
File “/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/yolo_v4/utils/model_io.py”, line 49, in load_model
File “/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/yolo_v4/utils/model_io.py”, line 27, in get_model_with_input
File “/usr/local/lib/python3.6/dist-packages/keras/engine/saving.py”, line 417, in load_model
f = h5dict(filepath, ‘r’)
File “/usr/local/lib/python3.6/dist-packages/keras/utils/io_utils.py”, line 186, in init
self.data = h5py.File(path, mode=mode)
File “/usr/local/lib/python3.6/dist-packages/h5py/_hl/files.py”, line 312, in init
fid = make_fid(name, mode, userblock_size, fapl, swmr=swmr)
File “/usr/local/lib/python3.6/dist-packages/h5py/_hl/files.py”, line 142, in make_fid
fid = h5f.open(name, flags, fapl=fapl)
File “h5py/_objects.pyx”, line 54, in h5py._objects.with_phil.wrapper
File “h5py/_objects.pyx”, line 55, in h5py._objects.with_phil.wrapper
File “h5py/h5f.pyx”, line 78, in h5py.h5f.open
OSError: Unable to open file (truncated file: eof = 760832, sblock->base_addr = 0, stored_eof = 242984848)
2021-11-08 11:29:42,038 [INFO] tlt.components.docker_handler.docker_handler: Stopping container.
Please check if $KEY is correct.
Yes the key is correct as i set it up at the start of the code
0. Set up env variables and map drives
and i can run training so the key is good to go
Make sure your $USER_EXPERIMENT_DIR/experiment_dir_retrain/weights/yolov4_resnet18_epoch_080.tlt is not broken.
$USER_EXPERIMENT_DIR/experiment_dir_retrain/weights/yolov4_resnet18_epoch_080.tlt was indeed broken the size of the file was in kbs ,i used yolov4_resnet18_epoch_070.tlt and it worked .
Thank you,
