Timestamp counter supported: Yes
CPU Profiling Environment Check
Root privilege: disabled
Linux Kernel Paranoid Level = 0
Linux Distribution = Ubuntu
Linux Kernel Version = 5.15.0-56-generic: OK
Linux perf_event_open syscall available: OK
Sampling trigger event available: OK
Intel(c) Last Branch Record support: Available
CPU Profiling Environment (process-tree): OK
CPU Profiling Environment (system-wide): OK
Set the depth for the backtraces collected for OS runtime libraries calls.
–osrt-backtrace-stack-size
integer
6144
Set the stack dump size, in bytes, to generate backtraces for OS runtime libraries calls.
–osrt-backtrace-threshold
nanoseconds
80000
Set the duration, in nanoseconds, that all OS runtime libraries calls must execute before backtraces are collected.
–osrt-threshold
< nanoseconds >
1000 ns
Set the duration, in nanoseconds, that Operating System Runtime (osrt) APIs must execute before they are traced. Values much less than 1000 may cause significant overhead and result in extremely large result files. Default is 1000 (1 microsecond). Note: Not available for IBM Power targets.
All of these are modifiers to the osrt option itself.
