HI,
I have tried OTA from 32.3.1 to 32.6.1. If I set the BASE_BSP to the TARGET_BSP, and do the step as " Updating Jetson Linux with Image-Based Over-the-Air Update" said, the OTA update successfully. But if I set the BASE_BSP to right value, The OTA failed.The attatched file is the log of the failed ota.
ota-to-4.6.1-failed.txt (39.0 KB)
hello tianyi2,
could you please share your steps in details to reproduce the failure.
here’s the kernel panic error, this means your rootfs might be corrupted.
[ 4.601419] Failed to execute /init (error -2)
[ 4.601562] Kernel panic - not syncing: No working init found. Try passing init= option to kernel. See Linux Documentation/init.txt for guidance.
I found the reason.
In build_base_recovery_image.sh, there is a cmd “_librariesdir=$(find “${_rootfs_dir}/lib” -name libc.so.6 | tail -1 | awk -F/ ‘{ print $(NF-1) }’)”, and it first finds the dir arm-linux-gnueabihf, not the dir aarch64-linux-gnu.
