OTA Tool - System image missing
I have some problems while trying to use the ota tool.
nvidia@compass-Precision-3680:~/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS_OTA/Linux_for_Tegra$ sudo ROOTFS_AB=1 ./tools/ota_tools/version_upgrade/l4t_generate_ota_package.sh brla4n-orin-nx R35-4
Skip generating binaries for "nvme0n1p1"
The directory /home/nvidia/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS_OTA/Linux_for_Tegra/ota_base_dir_tmp/internal_device/images-R35-ToT is not found
nvidia@compass-Precision-3680:~/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS_OTA/Linux_for_Tegra$ sudo ./tools/ota_tools/version_upgrade/build_base_recovery_image.sh brla4n-orin-nx R35-4 /home/nvidia/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS_OTA/Linux_for_Tegra /home/nvidia/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS_OTA/Linux_for_Tegra/rootfs /home/nvidia/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS_OTA/Linux_for_Tegra
BOARDID=3767 FAB=000 BOARDSKU=0000 BOARDREV= FUSELEVEL=fuselevel_production /home/nvidia/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS_OTA/Linux_for_Tegra/flash.sh --no-flash -Z brla4n-orin-nx nvme0n1p1
SUCCESS: get dtbfile name "tegra234-brla4n-orin-nx.dtb"
Unpacking initrd ...
42010 blocks
Packing initrd ...
58248 blocks
/home/nvidia/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS_OTA/Linux_for_Tegra/bootloader/mkbootimg --kernel /home/nvidia/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS_OTA/Linux_for_Tegra/kernel/Image --ramdisk /tmp/R35x_recovery/R35x_initrd.img --output /tmp/R35x_recovery/recovery.img --cmdline "root=/dev/initrd rw rootwait console=ttyTCU0,115200n8 fbcon=map:0 net.ifnames=0 video=tegrafb no_console_suspend=1 earlycon=tegra_comb_uart,mmio32,0x0c168000 base_version=R35-4 target_board=brla4n-orin-nx "
Copy /tmp/R35x_recovery/recovery_sigheader.img.encrypt to /tmp/R35x_recovery/recovery.img.R35x
Copy /tmp/R35x_recovery/recovery_sigheader.dtb.encrypt to /tmp/R35x_recovery/recovery.dtb.R35x
Copy generated recovery image and dtb into /home/nvidia/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS_OTA/Linux_for_Tegra/bootloader/
Finished
n-orin-nx R35-4
What could be the problem here that the file cannot be found?
Please provide the complete commands for performing an OTA update.
What are your BASE_BSP and TARGET_BSP?
Have you followed the official guidance?
I would like to reflash a board flashed with the same version.
I have used the following environment variables:
export BASE_BSP=/home/nvidia/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS_BASE_BSP/Linux_for_Tegra
export TARGET_BSP=/home/nvidia/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra
For the custom board i adapted the ota_board_specs.conf and extended it:
brla4n_orin_nx_ota_emmc_r35_spec=(
'boardid=3767;fab=000;boardsku=0000;boardrev=;fuselevel_s=1;chiprev=;chipsku=00:00:00:D3;board=brla4n-orin-nx;rootdev=nvme0n1p1;bup_type=bl;signed_img_dir=images-R35-ToT'
BRLA4N_ORIN_NX_R35_4_ALIAS="brla4n_orin_nx_ota_emmc_r35_spec"
T23X_DEVICES=(
	'IGX_ORIN_DEVKIT'
	'JETSON_AGX_ORIN_DEVKIT'
	'JETSON_AGX_ORIN_DEVKIT_INDUSTRIAL'
	'JETSON_ORIN_NANO_DEVKIT'
	'BRLA4N_ORIN_NX'
I found the problem. The custom device was not supportet in the l4t_generate_ota_package.sh
SUPPORTED_EXTERNAL_DEVICES=(
	'jetson-xavier-nx-devkit-emmc:nvme0n1'
	'jetson-orin-nano-devkit:nvme0n1'
	'brla4n-orin-nx:nvme0n1'
It might be good to allow any custom device.
