I need to update the AGX Orin from 34.1 to 35.0. Will it be possible with OTA update?
I followed the steps for the OTA in the link below: Software Packages and the Update Mechanism — Jetson Linux<br/>Developer Guide 34.1 documentation
After Updating the nvidia-l4t-apt-source.list from 34.1 to 35.0, I have issued the below commands and the output as follows
sudo apt update
Hit:1 https://repo.download.nvidia.com/jetson/common r35.0 InRelease
Hit:2 https://repo.download.nvidia.com/jetson/t234 r35.0 InRelease
Hit:3 http://ports.ubuntu.com/ubuntu-ports focal InRelease
Hit:4 http://ports.ubuntu.com/ubuntu-ports focal-updates InRelease
Hit:5 http://ports.ubuntu.com/ubuntu-ports focal-backports InRelease
Hit:6 http://ports.ubuntu.com/ubuntu-ports focal-security InRelease
Reading package lists... Done
Building dependency tree
Reading state information... Done
All packages are up to date.
sudo apt dist-upgrade
Reading package lists… Done
Reading state information… Done
Calculating upgrade… Done
The following packages were automatically installed and are no longer required:
apt-clone archdetect-deb bogl-bterm busybox-static cryptsetup-bin dctrl-tools dpkg-repack gdal-data gir1.2-timezonemap-1.0 gir1.2-xkl-1.0 grub-common libaec0 libarmadillo9 libarpack2 libavcodec-dev
libavformat-dev libavresample-dev libavresample4 libavutil-dev libcfitsio8 libcharls2 libdap25 libdapclient6v5 libdc1394-22-dev libdebian-installer4 libepsilon1 libevent-core-2.1-7
libevent-pthreads-2.1-7 libexif-dev libfreexl1 libfwupdplugin1 libfyba0 libgdal26 libgdcm-dev libgdcm3.0 libgeos-3.8.0 libgeos-c1v5 libgeotiff5 libgl2ps1.4 libgphoto2-dev libhdf4-0-alt libhdf5-103
libhdf5-openmpi-103 libhwloc-plugins libhwloc15 libilmbase-dev libjbig-dev libjpeg-dev libjpeg-turbo8-dev libjpeg8-dev libjsoncpp1 libkmlbase1 libkmldom1 libkmlengine1 liblept5 liblzma-dev
libminizip1 libnetcdf-c++4 libnetcdf15 libodbc1 libogdi4.1 libopencv-calib3d4.2 libopencv-contrib4.2 libopencv-dnn4.2 libopencv-features2d4.2 libopencv-flann4.2 libopencv-highgui4.2
libopencv-imgcodecs4.2 libopencv-imgproc4.2 libopencv-ml4.2 libopencv-objdetect4.2 libopencv-photo4.2 libopencv-shape4.2 libopencv-stitching4.2 libopencv-superres4.2 libopencv-video4.2
libopencv-videoio4.2 libopencv-videostab4.2 libopencv-viz4.2 libopencv4.2-java libopencv4.2-jni libopenexr-dev libopenmpi3 libpmix2 libpng-dev libpq5 libproj15 libqhull7 libraw1394-dev libsocket++1
libspatialite7 libsuperlu5 libswresample-dev libswscale-dev libsz2 libtbb-dev libtesseract4 libtiff-dev libtiffxx5 libtimezonemap-data libtimezonemap1 liburiparser1 libvtk6.3 libxerces-c3.2
libxnvctrl0 odbcinst odbcinst1debian2 os-prober proj-data python3-icu python3-pam rdate tasksel tasksel-data
Use ‘sudo apt autoremove’ to remove them.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded
cat /etc/nv_tegra_release
R34 (release), REVISION: 1.1, GCID: 30414990, BOARD: t186ref, EABI: aarch64, DATE: Tue May 17 04:20:55 UTC 2022
But the nv_tegra_release is showing the older release version as shown above. Could you please help us to check on the same.
