I have followed instruction to connect wifi by installing M2 wifi connector from this link
https://devtalk.nvidia.com/default/topic/1045195/jetson-agx-xavier/how-to-connect-nvidia-xavier-to-wifi-network-/
but just using 8260 model.
I also installed intel wireless driver
Intel® Dual Band Wireless-AC 8260 4.1+ iwlwifi-8000-ucode-25.30.13.0.tgz
and cp ucode to /lib/firmware
It seemed to work well, however, I cannot use OTG USB any more, and I lose control.
Only I can do is to ssh from another computer and do some investigation.
I could do iwconfig and it showed wlan0 info. That sound like wifi module works well.
But when I try dmesg, it showed some errors like
[ 38.573726] tegra194-vi5 15c10000.vi: ep of_device is not enabled /host1x/vi@15c10000/ports/port@0/endpoint.
[ 38.575000] tegra194-vi5 15c10000.vi: ep of_device is not enabled /host1x/vi@15c10000/ports/port@1/endpoint.
[ 38.578629] tegra-xusb 3610000.xhci: USB2 port 0 has OTG_CAP
[ 38.579816] tegra-xusb 3610000.xhci: USB3 port 2 has OTG_CAP
[ 38.585055] Could not get extcon-dev /xhci@3610000:id(0)
[ 38.591660] Could not get extcon-dev /host1x/nvdisplay@15210000:typec0(0)
[ 38.592328] Could not get extcon-dev /xudc@3550000:vbus(0)
I tried to remove M2 connector out and restart Xavier, later boot I can use mouse and keyboard via OTG USB.
I could do lsusb also
when no M2 Wifi connector, lsusb showed like below
Bus 002 Device 002: ID 05e3:0617 Genesys Logic, Inc.
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 004: ID 046d:c534 Logitech, Inc. Unifying Receiver
Bus 001 Device 003: ID 046d:c535 Logitech, Inc.
Bus 001 Device 002: ID 05e3:0610 Genesys Logic, Inc. 4-port hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
However, when I connect M2 Wifi, it showed nothing.
So could you please help to make both works?
