i have 3.3G available and i’m detecting in real time, i keep getting a “Low memory” warning after detecting for about 20 minutes. What could the issue be?
I have confirmed that it runs on the gpu.
I have a jetson orin nano.
import ultralytics
from ultralytics import YOLO
model = YOLO("yolov8n.pt")
Dependencies:
* torch==2.1.0a0+41361538.nv23.6
* ultralytics==8.2.38
Now, the code works perfectly well, it makes detection in real time but afyer about 20 minutes of real time detection, i get a "Low memory" prompt
After raising a discussion on the official ultralytics repo,i was asked to export to this format(.engine), although when i do so with the code below:
model.export(format = "engine", workspace = 2, int8 = True)
Error Message after running this:
[06/26/2024-12:24:43] [TRT] [W] Tactic Device request: 150MB Available: 149MB. Device memory is insufficient to use tactic.
[06/26/2024-12:24:43] [TRT] [W] Skipping tactic 2 due to insufficient memory on requested size of 150 detected for tactic 0x000000000000001e.
Thank You.`Preformatted text`
Could you run the tegrastats concurrently and check the memory usage?
If the memory keeps going up during the detection, the app might have some memory leakage.
In such a case, please double-check the implementation.
Maybe you can try valgrind to help you catch the leakage.
