Hi guys, I have a weird problem. My output array shows incorrect data when i try to run it normally, but when I step through normally it shows the correct data that I get from a CPU program that runs the same algorithm.
The images will show you what I mean, leftImageD is from the GPU calculated kernel and leftImageDd is from when i step through debugging/or run the separate CPU program.
Also as you can see, the whole image isn’t covered by the depth information, I get memory errors when I try to run the whole image. So as a secondary problem I think I need some help with performance also!
I’m running Vista and I use a 8600m GS 256mb RAM.
The Visual Studio folder is attached (I use 2005).
Many thanks for any insight you guys can offer!
Paul
CUDA_TEST.rar (629 KB)
