• Hardware Platform (Jetson / GPU) GPU
• DeepStream Version 5.0.1
• TensorRT Version 7.2.2
• NVIDIA GPU Driver Version (valid for GPU only) 440.87
• Issue Type( questions, new requirements, bugs) question
I’m creating original convert which convert from NV12 to UYVU.
And the convert logic is as follows.
global void
d_nv12_uyvy(unsigned char *d_src_Y, unsigned char d_src_UV, unsigned char d_dest, int image_width, int image_height)
unsigned int tx = blockIdx.xblockDim.x + threadIdx.x;
unsigned int ty = blockIdx.yblockDim.y + threadIdx.y;
d_dest[(ty * image_width * 2) + (tx * 2)] = d_src_UV[(((ty - (ty & 0x1)) * image_width)/2) + tx];
d_dest[(ty * image_width * 2) + ((tx * 2) + 1)] = d_src_Y[(ty * image_width) + tx];
#define D_CUDA_BLOCKDIM_X 32
#define D_CUDA_BLOCKDIM_Y 8
extern “C”
double nv12_uyvy_cuda(unsigned char *d_src, unsigned char *d_dest, int image_width, int image_height)
int blockX = D_CUDA_BLOCKDIM_X;
int blockY = D_CUDA_BLOCKDIM_Y;
dim3 blockDim (D_CUDA_BLOCKDIM_X , D_CUDA_BLOCKDIM_Y);
dim3 gridDim ((image_width ) / blockX, (image_height) / blockY);
unsigned char *d_src_Y = d_src;
unsigned char *d_src_UV = d_src + image_width * image_height;
d_nv12_uyvy<<< gridDim, blockDim >>>(d_src_Y, d_src_UV, d_dest, (image_width), (image_height));
return 1;
However, I cannot convert the NV12 data, which is outputted from nvv4l2decoder, correctly.
For example, the ball image is converted to wide spreading ball image as attached image.
Now, I find that there are some NV12 format in GStreamer.
https://gstreamer.freedesktop.org/documentation/video/video-format.html?gi-language=c
So I want to confirm which format is outputted from nvv4l2decoder.
GST_VIDEO_FORMAT_NV12 (23) – planar 4:2:0 YUV with interleaved UV plane
GST_VIDEO_FORMAT_NV12_64Z32 (53) – NV12 with 64x32 tiling in zigzag pattern (Since: 1.4)
GST_VIDEO_FORMAT_NV12_4L4 (97) – NV12 with 4x4 tiles in linear order.
GST_VIDEO_FORMAT_NV12_32L32 (98) – NV12 with 32x32 tiles in linear order.
Regards,
hiro
