Output multiplex RTSP stream
Use the VLC video tool to pull the RTSP video stream output by deepstream. It is found that when a device or software is pulling the RTSP stream, other devices or the same software cannot pull the RTSP video stream again. So how to solve the problem of simultaneous streaming of multiple devices or software?
There should be only one RTSP server on each device. For your use-case, you may try to enable two RTSP sinks in config file and check if it works. Please refer to document for modifying config file:
DeepStream Reference Application - deepstream-app — DeepStream 5.1 Release documentation
